Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: 03 GTI 1.8t rough idle (misfire). Multiple DTC's
    Sep 2014
    Hey guys.
    I've got an issue that developed not long ago. my wife's '03 GTI 1.8T all of a sudden started to run rough (has a misfire). the Check Engine/EPC light is not on. But I did an auto-scan. here are the results...
    I've looked for threads pertaining to similar issues before posting.
    Thanks for any help you guys can offer.
    Tuesday,22,December,2015,16:22:04:54350
    VCDS Version: 15.7.3.0 (x64)
    Data version: 20151216
    VIN: 9BWDE61J834042657   License Plate:
    Mileage: 201650km-125299mi   Repair Order: Ann Marie
    Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
              76
    VIN: 9BWDE61J834042657   Mileage: 201650km-125299miles
    Address 01: Engine        Labels: 06A-906-032-AWP.lbl
       Part No: 06A 906 032 LP
       Component: 1.8L R4/5VT     G   0005
       Coding: 07500
       VCID: 77F3E30D55190A8640-5178
       9BWDE61J834042657     VWZ7Z0B5992535
    18 Faults Found:
    16621 - Manifold Pressure / Boost Sensor (G31)
                P0237 - 35-10 - Signal too Low - Intermittent
    16490 - Manifold / Barometric Pressure Sensor (G71) / (F96)
                P0106 - 35-10 - Implausible Signal - Intermittent
    16727 - Camshaft Position Sensor (G40)
                P0343 - 35-10 - Signal too High - Intermittent
    16712 - Knock Sensor 1 (G61)
                P0328 - 35-10 - Signal too High - Intermittent
                P0300 - 35-10 -  - Intermittent
    16686 - Cylinder 2
                P0302 - 35-10 - Misfire Detected - Intermittent
    17633 - Fuel Injector for Cylinder 1 (N30)
                P1225 - 35-10 - Short to Ground - Intermittent
    17635 - Fuel Injector for Cylinder 3 (N32)
                P1227 - 35-10 - Short to Ground - Intermittent
    17636 - Fuel Injector for Cylinder 4 (N33)
                P1228 - 35-10 - Short to Ground - Intermittent
    17634 - Fuel Injector for Cylinder 2 (N31)
                P1226 - 35-10 - Short to Ground - Intermittent
    17833 - EVAP Purge Valve (N80)
                P1425 - 35-10 - Short to Ground - Intermittent
    17955 - Boost Pressure Regulation Valve (N75)
                P1547 - 35-10 - Short to Ground - Intermittent
    17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2
                P1117 - 35-10 - Short to Ground - Intermittent
    17843 - Secondary Air Pump Relay (J299)
                P1435 - 35-10 - Short to Ground - Intermittent
    17938 - Camshaft Timing Adjustment
                P1530 - 35-10 - Short to Ground - Intermittent
    17829 - Secondary Air Injection Solenoid Valve (N112)
                P1421 - 35-10 - Short to Ground - Intermittent
    17697 - Boost Pressure Control Valve (N249)
                P1289 - 35-10 - Short to Ground - Intermittent
    17522 - Oxygen (Lambda) Sensor; B1 S2
                P1114 - 35-00 - Internal Resistance too High
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
       Part No: 1C0 907 379 M
       Coding: 0019970
       Shop #: WSC 00000 785 00200
       VCID: 3469140154EF219EA5-5178
       Part No: 1C0 909 605 F
       Component: 08 AIRBAG VW61 0202 0001
       Coding: 12344
       VCID: 2753F34DC5395A0610-513C
       Part No: 1J0 920 906 J
       Component: KOMBI+WEGFAHRSP VDO V07
       Coding: 07232
       Shop #: WSC 55390
       VCID: 2F631B6DEDC90246D8-515A
    01304 - Radio
                49-00 - No Communications
       Part No: 6N0 909 901
       Coding: 00006
       VCID: 70E1D81130775DBE81-513C
    01304 - Radio
       Part No: 1C0 959 799 C
       Component: 8B Komfortgerát HLO 0003
       Coding: 00064
       VCID: 3773230D1599CA8680-4B18
       Component: 8B Tőrsteuer.FS KLO 0002
       Component: 8B Tőrsteuer.BF KLO 0002
    End-------------------------(Elapsed Time: 04:31)--------------------------
    There may be other things going on here as well, but the very first thing I'd do is put a fuel pump relay in that car, then clear fault codes, drive it, and see what comes back.
    Now I'm not normally an advocate of doing diagnostics by throwing parts at the problem, but a fuel pump relay isn't expensive, it's a common failure item, and when it starts failing, the ECU will set many of the fault codes in your list (particularly the "Short to GND" ones).
    Dec 2015
    Canada
    Change your fuel filter, could be clogged.
    But i think Uwe is on the right track too... fuel relay or fuel pump going.
    if anything else
    When is the last time you replaced timing belt?
    also look for vacuum leak. disconnected/cracked line. (Spray carb cleaner around hoses, throttle body, injectors...see if idle changes.Don't do this with a hot engine....don't need to spray crazy lots either. Keep a fire extinguisher handy incase. )
    Boost leak.
    Also make sure your sparkplugs are tight. I had one sparkplug come loose and it caused misfires.
    DISCLAIMER: All of the foregoing is based on a quick google search, so it may be totally incorrect. Hopefully somebody with more knowledge can offer more reliable info
    Cheers.
  4. Likes DimeGuy liked this post
    P1114 - 35-00 - Internal Resistance too High <<<<<<<<<<<< See this one?
    The OXS sensors when taking a shit/short ........also a common brown out, will cause that FP relay to get hot. Cause verse effect!
    If left untreated it wipes the ECU out entirely.
    Component: 1.8L R4/5VT G 0005 <<<<<<<<<<<<< This!
    You need a firmware update
    If you like we have package deals on genuine sensors and firmware updates.
    Please use the contact form.
  6. Likes DimeGuy liked this post
    Sep 2014
    Thanks for the input guys. I had a hard/no start issue with my 02 VR6 GTI, and it had lots of codes like this. I replaced the fuel pump relay and viola! ...fixed. So the relay was the first thing I replaced on her car, but it made no difference and I thought it might be a MAF, so I tested it and it is good, too. That's when I did the autoscan. I also did a full service including the plugs and fuel filter at 104K miles (the day after we bought this car). The fuel pump is new also. The guage was not reading correctly and I diagnosed it to the fuel level sensor and replaced the pump and sender as one unit (at 108K and with a new gasket). The T-belt and all goodies were replaced just prior to us buying it at 102K (The Previous owner kept great service records and gave us the file). The brake booster vacuum hose does have some cracks in it at the check valve and where it connects to the booster, I did already buy another along with the rubber fuel lines that connect to the fuel rail (they are cracking) at the same time I bought the fuel pump relay. I just haven't installed the hoses yet. I was trying to diagnose this issue first. I didn't want to add too many variables into the mix and spin this way out of control.
    I am not a fan of just throwing parts at it either, but was thinking that I might replace the over pressure sensor in the intercooler and see how that goes. I also have the service manual on CD so I printed the wiring diagram and am going to test the power and ground wires at the ECU and both the Boost sensor and cam sensor as they share power and grounds at the ECU. Any other suggestions?
    Jack, I think you might be confused about which car he's talking about.
  9. Likes Jack@European_Parts liked this post
  10. #7
    Dimeguy: If you've already put a fuel pump relay in this 1.8T GTI, then the Auto-Scan is indicative of some other source of drop-out of +12V to all the actuators that have "Short to GND" codes.
  11. Likes Jack@European_Parts liked this post
  12. #8
    Well I do confuse things and am mentally challenged.........
    I must apologize for my retardation.......
  13. Likes Uwe liked this post
  14. #9
    Jul 2014
    check connections in fuse box above battery
  15. Likes Jack@European_Parts, Uwe liked this post
  16. #10
    Yes yes Bar's and also the ground lugs under the battery box to chassis.....
  17. Likes Uwe liked this post
