Results 11 to 20 of 23
Thread: Auto Hold function on MQB platform
    Jun 2014
    I tried these, none of them allowed me to change the auto hold functionality channel
    20103 - x
    40168 - x
    10505 - x
    11966 - x
    15081 - x
    18573 - x
    24435 - x
    25004 - x
    28183 - x
    31857 - x
    37202 - x
    40168 - x
    44595 - x
  2. #12
    Verified VCDS User andyvee's Avatar
    Rossendale, Lancashire, UK
    I've started something here haven't I
    Gizmo - was that the full list of ABS codes I gave you?
    I noticed there were some coding options elsewhere to let the car know Auto Hold was installed - I'll have a look later this week
  3. #13
    Verified VCDS User Gizmo's Avatar
    Mar 2014
    S.E.Kent UK
    Quote Originally Posted by andyvee View Post
    Yes I had a few saved, but unfortunately non let me change what I wanted
    HEX-NET
    2016 Škoda Superb L&K (190CR)
    Pre-booked a VW ID.3 1st Edition
  4. #14
    Oct 2015
    I have posted threads in the past, looking for this same ABS code.
    I have tried all the same ones as you on a 2016 A3 8V. None of the codes work.
    However codes were obtained in the past, it doesn't seem that anyone has gotten any for this particular ABS adaptation channel.
    Hey Uwe, how do we get our hands on this code?!?!
  5. #15
    Jun 2014
    Ok, I have been looking at a friends MY2016 Golf GTD manual with ACC with auto hold, his auto hold function channel is also set to "inactive" so it looks like we are barking up the wrong tree.
    I have been comparing our ABS coding but there are 24 bits on his module turned on which my 2016 octavia DSG with ACC doesn't have turned on.
    hmmmmm.......
  6. Likes andyvee, Uwe, XaGiCo, rojas, ineedbeer liked this post
  7. #16
    Jun 2014
    Quote Originally Posted by Mrclopec View Post
    Look in your trunk for your PR sticker. Youre looking for PR code 1AT. If you see 1AS, then you cant do it. I would assume that if you have ACC, then your ABS is 1AT. It would just be a matter of retrofitting the switch, 2 wires from the switch to the ABS unit in the engine compartment, and some coding.
    It looks like my code is 1AZ....
  8. #17
    Verified VCDS User rojas's Avatar
    Sep 2014
    Spain
    prueba 40168
  9. #18
    Sep 2014
    Spain
    my car is 1AT and is not compatible with AAC, I had to change :
    control unit ABS , ESP / ABS sensors, switch to ACC.
  10. #19
    Jun 2014
    Ok, I have tried re-coding every bit that the golf has on that the Octavia doesn't and with the exception of byte 25 they are all "rejected out of range".
    Byte 25 will recode but has no affect.
    I then tried to copy the HEX for every byte in turn but that was also "31-coding out of range" with the exception of byte 25.
    I'm open to ideas????? Is there a security access code for re-coding?
  11. #20
    Quote Originally Posted by Xpower View Post
    Ok,,,,,,,,,,,,,,,,,,,,,,,,,
    Xpower: I do admire your tenacity and dedication to solving this problem. I'm not sure that using the coding from your friend's GTD is a good way to proceed - if you wanted to use this approach, then I suspect that you will need a much greater number of reference vehicles (to eliminate differences in coding that result from of other features in the car)
    Anyway, here is some information from my database. The car is a mk7 GTI PP DSG (from Ireland) with J428 fitted (including in this case also with R242 fitted) - details of the ABS enclosed. Notice that notwithstanding that this car also has ACC (like your friends GTD), there are significant differences (and some similarities) in the two coding strings
    Not sure that my data will help in your crusade, but it might be of interest!
    Cheers
  12. Likes Uwe liked this post
