Results 1 to 10 of 15
Thread: Hello
    Jan 2016
    Newfoundland, Canada
    Hello
    Hi folks,
    chiming in from Newfoundland, Canada. Looking forward to sharing info and getting some help with a couple small issues.
    Just waiting to be granted access to post in the forums.............
    Thanks
    _ _ _ _
    2013 VW CC
    Feel free to post your questions here, in the New User forum.
    In order to be able top post in most other sections of this forum, you'll have to register you system with us for support as described in http://forums.ross-tech.com/showthre...o get Verified.
    Jan 2016
    Thank, I filled in the form.
    Here is my issue, not sure if I have a hardware problem or a software problem:
    I have recently made some changes to my 2013 CC with VCDS (including changing the country code, used to change the 'ding' tone in the vehicle as well as some other things). The car now gives me the error "FAULT: TIRE MONITORING CURRENTLY NOT AVAILABLE". When I try to store the tire pressures, it indicates "Tire pressures could not be stored".
    The tire light flashes for several seconds and then stays on. Tire pressures have all been checked and double checked.
    I have reset my car to it's original values in VCDS and am still getting the light and error.
    The error is in the ABS module, as i understand this is where the TMPS is stored in the vehicle
    Here is the printout from the ABS:
    Wednesday,20,January,2016,18:53:25:21195
    VCDS Version: Release 15.7.3 Running on Windows 10 x64
    Ross-Tech: Home
    Address 03: ABS Brakes Labels: 3AA-614-109.clb
    Control Module Part Number: 3AA 614 109 BK HW: 3AA 614 109 BK
    Component and/or Version: J104 C2 450M VD8E 0024
    Software Coding: 0001420
    Work Shop Code: WSC 05311 000 00000
    VCID: 77D31832069F8F8640-8022
    02757 - Learning Tire Pressures
    Reset counter: 141
    Mileage: 94541 km
    Date: 2016.01.20
    Time: 17:13:21
    Hex Value: 0x0001
    Bin. Bits: 00000000 00000000
    Voltage: 14.00 V
    Bin. Bits: 00011111
    Count: 194
    Hex Value: 0x0000
    03159 - TPMS Functionality in ESP
    Reset counter: 141
    Hex Value: 0x0000
    Voltage: 11.75 V
    Bin. Bits: 00011111
    Count: 190
    Hex Value: 0x0000
    _ _ _ _ _ _ _ _ _ _ _ _ _
    Here is my full VCDS:
    Wednesday,20,January,2016,17:12:44:21195
    VCDS Version: 15.7.3.0
    Data version: 20151216
    Ross-Tech: Home
    VIN: WVWAN7ANXDE534494 License Plate:
    Mileage: 94540km-58744mi Repair Order:
    Chassis Type: AN (7N0)
    Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4C 4F 52 53 55 56
    62 6C 72 77
    VIN: WVWAN7ANXDE534494 Mileage: 94540km-58744miles
    Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
    Part No SW: 06J 906 027 FE HW: 06J 907 309 B
    Component: MED17.5.2 TFSI 2 06 3952
    Revision: PAH04--- Serial number: VWZCZ000000000
    Coding: 0404010A18070160
    Shop #: WSC 05314 000 00000
    VCID: 73CB2C2212E7E3A67C-8026
    Part No SW: 3AA 614 109 BK HW: 3AA 614 109 BK
    Component: J104 C2 450M VD8C 0024
    Revision: --H07--- Serial number: 00000006186823
    Coding: 0001420
    Shop #: WSC 05311 000 00000
    Reset counter: 176
    Mileage: 94394 km
    Date: 2016.01.14
    Time: 07:52:31
    Hex Value: 0x0000
    Voltage: 14.00 V
    Bin. Bits: 00011111
    Count: 194
    Hex Value: 0x0000
    Fault Frequency: 13
    Reset counter: 136
    Hex Value: 0x0000
    Voltage: 11.50 V
    Bin. Bits: 00011111
    Count: 190
    Hex Value: 0x0000
    Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
    Part No SW: 3AA 907 044 AG HW: 3AA 907 044 AG
    Component: Climatronic H03 0303
    Revision: 00001K02
    Coding: 0018001048
    Shop #: WSC 00015 115 12345
    VCID: 75CF123AD493FD9652-8020
    Address 09: Cent. Elect. (J519) Labels: 3AA-937-087.clb
    Part No SW: 3AA 937 087 J HW: 3AA 937 087 J
    Component: BCM PQ47 H++ 421 0465
    Revision: BD421001
    Coding: 00080000000000000088028594000B442675000840200D20E4 84402400C0
    Shop #: WSC 05311 123 08193
    VCID: 41A7B6EAD8DB01363E-8014
    Subsystem 1 - Part No SW: 3C8 955 119 F HW: 3C8 955 119 F Labels: 1KX-955-119.CLB
    Component: WWS464 100712 010 0604
    Coding: 00B795
    Component: RLFS 024 0042
    Coding: 0228DD
    Part No SW: 5N0 959 655 T HW: 5N0 959 655 T
    Component: J234__713 VW10 HI 2118
    Revision: 24017000 Serial number: 003LDPJ9B4GZ
    Coding: 0012595
    VCID: 4EBD9DD6D985EE4EB3-801A
    Subsystem 1 - Part No: 3C8 959 339 A
    Component: BF-Gewichtsens. 003 0001
    Subsystem 2 - Serial number: 0000000000ADUE
    Subsystem 3 - Serial number: 0008.08.120000300000650014†63
    Subsystem 4 - Serial number: 650014†6332MTS644822282 †63
    Subsystem 5 - Serial number: 22282 †6342MTS603162262 †63
    Subsystem 6 - Serial number: 62262 †6351HTS6BIEAABKJ †63
    Subsystem 7 - Serial number: AABKJ †6361HTS688Q9ABKR †63
    Subsystem 8 - Serial number: 9ABKR †63727TS68NQE8BKJ †63
    Subsystem 9 - Serial number: E8BKJ †63827TS6VN8E8BKJ
    Subsystem 10 - Serial number: E8BKJ
    Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb
    Part No SW: 3C5 953 501 BN HW: 5K0 953 569 AB
    Revision: FF010041 Serial number: 20120904100315
    Coding: 018A270000
    Shop #: WSC 00015 115 00000
    VCID: 72C52926A5FDEAAE77-8026
    Component: E221__MFL-TK6 H07 0022
    Coding: E20000
    Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
    Part No SW: 3C8 920 870 M HW: 3C8 920 870 M
    Component: KOMBI H05 0705
    Coding: 340F01
    Shop #: WSC 05314 115 12345
    VCID: 354FD23A9413BD9692-8060
    Part No SW: 7N0 907 530 AE HW: 7N0 907 530 AE
    Component: J533 Gateway H46 1633
    Revision: H46 Serial number: 090912F1003576
    Coding: 469006
    VCID: 73CB2C22D2E7E3A67C-8026
    Part No SW: 3C8 919 965 HW: 3C8 919 965
    Component: Kompass 001 0001
    Revision: 00001000 Serial number: 1614128R381V03
    VCID: 75CF123A1C93FD9652-8020
    Part No SW: 3AA 959 433 A HW: 3AA 959 433 A
    Component: IMMO 046 0400
    Revision: 00046000 Serial number: VWZCZ000000000
    Shop #: WSC 65157 001 1048576
    VCID: 3753D832461F4F8680-8062
    Component: ELV 029 0380
    3C0905861J ELV 029 0380
    Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
    Component: SG EXT.PLAYER H18 0546
    Revision: A1001003 Serial number: 7663418777
    Coding: 010100
    VCID: 2A75F14645ADE26E0F-807E
    Part No SW: 3C8 959 701 HW: 3C0 959 793 C
    Component: TUER-SG FT 002 0551
    Revision: 12110009 Serial number: 0005651272
    Coding: 0004B7
    Shop #: WSC 05311 115 00000
    ROD: EV_TSGFPQ35BRFVW46X.rod
    VCID: 6DFF3A5ABCC33556AA-8038
    Slave Driver:
    Subsystem 1 - Part No SW: 3C8 959 703 D HW: 3C8 959 795 Labels: 1K0-959-70X-GEN4.CLB
    Component: J388__TSG-HL 004 0501
    Serial number: 00000003090408
    Coding: 010490
    Part No SW: 5N1 909 144 N HW: 5N1 909 148 G
    Component: J500__APA-BS KL.302 1101
    Revision: 1AH03735 Serial number: 00122390020901
    Coding: 0000258
    VCID: 3D5FCA1A642365D65A-8068
    Address 46: Central Conv. Labels: 3C0-959-433-46.clb
    Component: KSG PQ47 ELV 046 0634
    Coding: 1B910F8001864E7F1206141FF08A0F0E105C01
    Address 4C: Tire Pressure II
    Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
    Part No SW: 7N0 907 532 HW: 7N0 907 530 AE
    Component: EZE_2 H46 1633
    Coding: 01030108
    VCID: 6FC32052BECFC74698-803A
    Subsystem 1 - Part No SW: 6R0 959 591 HW: 6R0 959 591
    Component: J245/J878 H04 0054
    Coding: 000006
    Subsystem 2 - Part No SW: 3C8 919 204 A HW: 3C8 919 204 A
    Component: Analoguhr 005 0004
    Part No SW: 3C8 959 702 HW: 3C0 959 792 C
    Component: TUER-SG BT 002 0551
    Revision: 14110009 Serial number: 0005653629
    Coding: 0004B6
    ROD: EV_TSGBPQ35BRFVW46X.rod
    VCID: 6EFD3D56B1C5CE4E93-803A
    Slave Passenger:
    Subsystem 1 - Part No SW: 3C8 959 704 D HW: 3C8 959 794 Labels: 1K0-959-70X-GEN4.CLB
    Component: J389__TSG-HR 004 0501
    Serial number: 00000003079539
    Coding: 010490
    Revision: H19 Serial number: 00000000440617
    Coding: 0022156
    VCID: 364DD5364115B68E9B-8062
    Address 55: Headlight Range (J745) Labels: 5M0-907-357-V3.clb
    Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
    Component: AFS-ECU H04 0111
    Coding: 071200010B000400
    ROD: EV_HeadlRegulVWAFSPt_SK46.rod
    VCID: 3753D8328E1F4F8680-8062
    Subsystem 1 - Part No SW: 1T0 941 329 HW: 1T0 941 329 Labels: 3D0-941-329.CLB
    Component: LeiMo links H06 0007
    Coding: 350000
    Subsystem 2 - Part No SW: 1T0 941 329 HW: 1T0 941 329 Labels: 3D0-941-329.CLB
    Component: LeiMo rechts H06 0007
    Coding: 350000
    Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 1K0 035 188 F HW: 1K0 035 188 F
    Component: Radio Prem-8 H04 0007
    Revision: -----08S Serial number: VWZ4Z7M3311008
    Coding: 2100040004000F
    VCID: 2B7BF4424A57FB66F4-807E
    Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
    Part No SW: 3C8 907 441 HW: 3C8 907 441
    Revision: 00H11000 Serial number: 525PA8-J282309
    Coding: 0000008
    VCID: 67F34872563F1F06D0-8032
    Address 77: Telephone (J412) Labels: 7P6-035-730.clb
    Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
    Component: TELEFON H15 3200
    Revision: 1B001001 Serial number: 00007663356271
    Coding: 0A10040000010110
    ASAM Dataset: EV_UHVNA 002720
    ROD: EV_UHVNA.rod
    VCID: 3A55C106BD0D52EE7F-806E
    End-------------------------(Elapsed Time: 02:26)--------------------------
    Wednesday,20,January,2016,18:52:37:21195
    Ross-Tech: Home
    62 6C 72 77
    Component: J104 C2 450M VD8E 0024
    Coding: 0001420
    Reset counter: 141
    Mileage: 94541 km
    Date: 2016.01.20
    Time: 17:13:21
    Hex Value: 0x0001
    Voltage: 14.00 V
    Bin. Bits: 00011111
    Count: 194
    Hex Value: 0x0000
    Reset counter: 141
    Hex Value: 0x0000
    Voltage: 11.75 V
    Bin. Bits: 00011111
    Count: 190
    Hex Value: 0x0000
    Revision: 00001K02
    Coding: 0018001048
    Revision: BD421001
    Coding: 000800000000000000880281940009442675000840200D20E4 84402400C0
    Coding: 00B795
    Coding: 0228DD
    Coding: 0012595
    Coding: 018A270000
    Coding: E20000
    Coding: 340F01
    Coding: 469006
    Coding: 010100
    Coding: 0004B7
    Slave Driver:
    Coding: 010490
    Coding: 0000258
    Coding: 01030108
    Coding: 000006
    Coding: 0004B6
    Slave Passenger:
    Coding: 010490
    Coding: 0022156
    Coding: 350000
    Coding: 350000
    Coding: 0000008
    ROD: EV_UHVNA.rod
    End-------------------------(Elapsed Time: 02:25)--------------------------
    _ _ _ _
    2013 VW CC
    Hmm.... Wanna post up CodingLog.txt too, please?
    Jan 2016
    Here it is, I didn't even know this existed!
    Address 08:3AA 907 044 AG recoded (ADP-Retention of driver's seat heater level) from not active  to active for 10 minutes   Monday,11,January,2016,17:08:20:21195
    Address 08:3AA 907 044 AG recoded (ADP-Retention of frt.pass. seat heater level) from not active  to active for 10 minutes   Monday,11,January,2016,17:08:36:21195
    Address 09:3AA 937 087 J recoded (Long Coding) from 0008000000000000008802819400094C2055000840200D20E484402400C0 to 0008000000000000008802859400094C2055000840200D20E484402400C0  (05311/000/08193)  Monday,11,January,2016,17:26:02:21195
    Address 09:3AA 937 087 J recoded (Long Coding) from 0008000000000000008802859400094C2055000840200D20E484402400C0 to 00080000000000000088028194000B4C2055000840200D20E484402400C0  (05311/123/08193)  Monday,11,January,2016,17:29:55:21195
    Address 09-01:3C8 955 119 F recoded (Long Coding) from 00B795 to 00BF95  (05311/123/08193)  Monday,11,January,2016,18:32:01:21195
    Address 09-02:5Q0 955 547  recoded (Long Coding) from 0228DD to 0628DD  (05311/123/08193)  Monday,11,January,2016,18:41:42:21195
    Address 09-02:5Q0 955 547  recoded (Long Coding) from 0228DD to 0628DD  (05311/123/08193)  Monday,11,January,2016,18:47:08:21195
    Address 46: recoded (Long Coding) from 1B910F8001862E521204141FF08A0F0E105C01 to 1B910F8001862E521200141FF08A0F0E105C01  (65157/001/1048576)  Monday,11,January,2016,18:57:04:21195
    Address 46:3AA 959 433 A recoded (Long Coding) from 1B910F8001862E521204141FF08A0F0E105C01 to 1B910F8001866E521200141FF08A0F0E105C01  (65157/001/1048576)  Monday,11,January,2016,19:01:38:21195
    Address 09-02:5Q0 955 547  recoded (Long Coding) from 0228DD to 0628DD  (05311/123/08193)  Monday,11,January,2016,19:02:15:21195
    Address 46:3AA 959 433 A recoded (Long Coding) from 1B910F8001866E521200141FF08A0F0E105C01 to 1B910F8001866E521200141FF0880F0E105C01  (65157/001/104857)  Monday,11,January,2016,19:10:32:21195
    Address 46:3AA 959 433 A recoded (Long Coding) from 1B910F8001866E521200141FF0880F0E105C01 to 1B910F8001866E521202141FF08A0F0E105C01  (65157/001/104857)  Monday,11,January,2016,19:50:14:21195
    Address 09:3AA 937 087 J recoded (Long Coding) from 00080000000000000088028194000B4C2055000840200D20E484402400C0 to 00080000000000000088028194000B4C2075000840200D20E484402400C0  (05311/123/08193)  Monday,11,January,2016,19:54:26:21195
    Address 09-02:5Q0 955 547  recoded (Long Coding) from 0228DD to 0628DD  (05311/123/08193)  Monday,11,January,2016,19:57:58:21195
    Address 46:3AA 959 433 A recoded (Long Coding) from 1B910F8001866E521202141FF08A0F0E105C01 to 1B910F8001864E763602141FF08A0F0E105C01  (65157/001/104857)  Monday,11,January,2016,20:17:02:21195
    Address 46:3AA 959 433 A recoded (Long Coding) from 1B910F8001864E763602141FF08A0F0E105C01 to 1B910F8001864E7F3E02141FF08A0F0E105C01  (65157/001/104857)  Monday,11,January,2016,20:20:53:21195
    Address 09-02:5Q0 955 547  recoded (Long Coding) from 0228DD to 0628DD  (05311/123/08193)  Monday,11,January,2016,20:29:32:21195
    Address 09:3AA 937 087 J recoded (Long Coding) from 00080000000000000088028194000B4C2075000840200D20E484402400C0 to 00080000000000000088028190000B4C2075000840200D20E484402400C0  (05311/123/08193)  Monday,11,January,2016,20:33:28:21195
    Address 09-02:5Q0 955 547  recoded (Long Coding) from 0228DD to 0428DD  (05311/123/08193)  Monday,11,January,2016,20:35:07:21195
    Address 09-02:5Q0 955 547  recoded (Long Coding) from 0428DD to 0628DD  (05311/123/08193)  Monday,11,January,2016,20:37:35:21195
    Address 17:3C8 920 870 M recoded (Long Coding) from 340F01 to 340D01  (05314/115/00000)  Monday,11,January,2016,20:55:51:21195
    Address 46:3AA 959 433 A recoded (Long Coding) from 0B910F8001864E7F3E02141FF08A0F0E105C01 to 0B910F8001864E7F3802141FF08A0F0E105C01  (65157/001/104857)  Tuesday,12,January,2016,18:21:31:21195
    Address 46:3AA 959 433 A recoded (Long Coding) from 0B910F8001864E7F3802141FF08A0F0E105C01 to 0B910F8001864E7F3202141FF08A0F0E105C01  (65157/001/104857)  Tuesday,12,January,2016,18:23:38:21195
    Address 09:3AA 937 087 J recoded (Long Coding) from 00080000000000000088028190000B4C2075000840200D20E484402400C0 to 00080000000000000088028190008B4C2075000840200D20E484402400C0  (05311/123/08193)  Tuesday,12,January,2016,18:25:40:21195
    Address 09:3AA 937 087 J recoded (Long Coding) from 00080000000000000088028190008B4C2075000840200D20E484402400C0 to 00080000000000000088028190008B4C2675000840200D20E484402400C0  (05311/123/08193)  Tuesday,12,January,2016,18:35:54:21195
    Address 17:3C8 920 870 M recoded (Long Coding) from 340D01 to 140D01  (05314/115/12345)  Tuesday,12,January,2016,18:41:03:21195
    Address 17:3C8 920 870 M recoded (Long Coding) from 140D01 to 140F01  (05314/115/12345)  Tuesday,12,January,2016,18:42:43:21195
    Address 09-02:5Q0 955 547  recoded (Long Coding) from 0428DD to 0628DD  (05311/123/08193)  Tuesday,12,January,2016,18:46:52:21195
    Address 17:3C8 920 870 M recoded (ADP-Volume to be replenished) from No  to Yes   Tuesday,12,January,2016,19:24:43:21195
    Address 09:3AA 937 087 J recoded (Long Coding) from 00080000000000000088028190008B4C2675000840200D20E484402400C0 to 00080000000000000088028190008BCC2675000840200D20E484402400C0  (05311/123/08193)  Tuesday,12,January,2016,19:33:31:21195
    Address 09:3AA 937 087 J recoded (Long Coding) from 00080000000000000088028190008BCC2675000840200D20E484402400C0 to 00080000000000000088028190008BCC2675006A40200D20E484402400C0  (05311/123/08193)  Tuesday,12,January,2016,19:46:08:21195
    Address 09:3AA 937 087 J recoded (Long Coding) from 00080000000000000088028190008BCC2675006A40200D20E484402400C0 to 00080000000000000088028190008BCC2675006440200D20E484402400C0  (05311/123/08193)  Tuesday,12,January,2016,19:46:46:21195
    Address 09:3AA 937 087 J recoded (Long Coding) from 00080000000000000088028190008BCC2675006440200D20E484402400C0 to 00080000000000000088028190008BCC2675006840200D20E484402400C0  (05311/123/08193)  Tuesday,12,January,2016,19:47:20:21195
    Address 08:3AA 907 044 AG recoded (Long Coding) from 0010004048 to 0010001048  (00015/115/00000)  Thursday,14,January,2016,08:33:28:21195
    Address 09:3AA 937 087 J recoded (Long Coding) from 00080000000000000088028190008BCC2675006840200D20E484402400C0 to 0008000000000000008802819400094C2055000840200D20E484402400C0  (05311/123/08193)  Thursday,14,January,2016,08:34:25:21195
    Address 09-01:3C8 955 119 F recoded (Long Coding) from 00BF95 to 00B795  (05311/123/08193)  Thursday,14,January,2016,08:40:56:21195
    Address 09-02:5Q0 955 547  recoded (Long Coding) from 0428DD to 0228DD  (05311/123/08193)  Thursday,14,January,2016,08:41:18:21195
    Address 46:3AA 959 433 A recoded (Long Coding) from 0B910F8001864E7F3202141FF08A0F0E105C01 to 1B910F8001862E521204141FF08A0F0E105C01  (65157/001/104857)  Thursday,14,January,2016,08:41:47:21195
    Address 17:3C8 920 870 M recoded (Long Coding) from 140F01 to 340F01  (05314/115/12345)  Thursday,14,January,2016,08:47:10:21195
    Address 09:3AA 937 087 J recoded (Long Coding) from 0008000000000000008802819400094C2055000840200D20E484402400C0 to 00080000000000000088028594000B442675000840200D20E484402400C0  (05311/123/08193)  Thursday,14,January,2016,09:07:01:21195
    Address 46:3AA 959 433 A recoded (Long Coding) from 1B910F8001862E521204141FF08A0F0E105C01 to 1B910F8001864E7F1206141FF08A0F0E105C01  (65157/001/104857)  Thursday,14,January,2016,09:08:55:21195
    Address 08:3AA 907 044 AG recoded (Long Coding) from 0010001048 to 0018001048  (00015/115/00000)  Thursday,14,January,2016,09:10:15:21195
    Address 09:3AA 937 087 J recoded (Long Coding) from 00080000000000000088028594000B442675000840200D20E484402400C0 to 000800000000000000880281940009442675000840200D20E484402400C0  (05311/123/08193)  Wednesday,20,January,2016,17:20:36:21195
    Address 17:3C8 920 870 M recoded (ADP-Seat belt warning) from Version 2  to Version 3   Wednesday,20,January,2016,17:26:00:21195
    Address 46:3AA 959 433 A recoded (Long Coding) from 1B910F8001864E7F1206141FF08A0F0E105C01 to 1B910F8001864E7F1206141FF08A0F0E107C01  (65157/001/104857)  Wednesday,20,January,2016,17:31:14:21195
    Address 46:3AA 959 433 A recoded (Long Coding) from 1B910F8001864E7F1206141FF08A0F0E107C01 to 1B910F8001864E7F1206141FF08A0F0E105C01  (65157/001/104857)  Wednesday,20,January,2016,17:31:56:21195
    Address 08:3AA 907 044 AG recoded (ADP-Retention of driver's seat heater level) from active for 10 minutes  to active   Wednesday,20,January,2016,18:30:27:21195
    Address 08:3AA 907 044 AG recoded (ADP-Retention of frt.pass. seat heater level) from active for 10 minutes  to active   Wednesday,20,January,2016,18:30:40:21195
    _ _ _ _
    2013 VW CC
  6. #6
    Dec 2015
    Canada
    Dumb question!!! but have to ask... did you push your TPMS set button? button in glove compartment or reset the tpms through the MFI in the instrument cluster!
    do you have to drive around, some reset on wheel speed??
    Inflate all tires to pressure listed on tire placard.
    Drive vehicle above 16mph to register sensor IDs.
    A malfunction with the vehicle’s TPMS tire pressure monitor system will flash the warning light ON for one second and OFF for three seconds. If the TPMS tire pressure monitor system light is flashing, it will need to be reset or repaired to turn the light off. If the TPMS light comes ON and stays ON, this means that one or more of your tires may have a low-pressure condition. Inspect all of your tires and check the air pressure. The correct air pressure for your vehicle can be found on the vehicle placard, usually located on the inside door panel.
    DISCLAIMER: All of the foregoing is based on a quick google search, so it may be totally incorrect. Hopefully somebody with more knowledge can offer more reliable info
    Cheers.
  7. #7
    Jan 2016
    Not a dumb question,
    When I try to reset on the dash it says " cannot store values" . All pressures are double checked, Driving around doesn't seem to improve things.
    When I start the car I get the error "fault: tire monitoring not available", light flashes for 5-10 sec and then stays solid
  8. #8
    Dec 2015
    Canada
    Have you read through this info
    http://wiki.ross-tech.com/wiki/index...on_Recognition
    Looks like it is in your coding for [09].
    2010 and newer vehicles equipped with the (BCM) 09-Cent. Elect. module have a different coding chart. These models include the Jetta, Golf, Tiguan and Eos and use Long Coding. The [Long Coding Helper] will provide the needed coding information if the original coding cannot be retrieved. --qouted from http://wiki.ross-tech.com/wiki/index...itoring#Coding
    if you have original coding for [09], revert back to it, try to set TPMS again
    Cheers.
  9. #9
    Dec 2015
    Canada
    read through this see if any similarities
    http://forums.ross-tech.com/showthre...th-VCDS-mk6-VW
    Cheers.
  10. #10
    Dec 2015
    Canada
    Also note that it can take up to a 1 hour road test for the tire pressure to be learnt .
    Cheers.
