Results 1 to 10 of 19
Thread: Golf 7 electric folding mirrors
    New User
    Jan 2016
    Gibraltar
    Hi folks
    I recently purchased a new Golf 7 which unfortunately was delivered without electric folding mirrors.
    These have now been retrofitted and operate OK using the door panel, but will not operate using the key fob.
    Any help would be appreciated
    Thanks in advance
    Jun 2014
    Start with posting an autoscan of the car... put the text between [ code] and [ /code]-tags
    We are all curious what options your car has...
    Golf VII, 1.6TDI BM Ed. 40 - 110 PK
  3. Likes Uwe liked this post
    New User
    Jan 2016
    Gibraltar
    Thanks Mari
    I hope this is correct
    Chassis Type: AU (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F
    VIN: WVWZZZAUZGW087847   Mileage: 1891km-1175miles
    Address 01: Engine (J623-CRLB)       Labels: 04L-907-309-V1.clb
       Part No SW: 04L 906 026 BP    HW: 04L 907 309 R
       Component: R4 2,0L EDC   H21 1198
       Revision: B5H21---
       Coding: 011D0032036405083000
       ASAM Dataset: EV_ECM20TDI01104L906026BP 002002
       ROD: EV_ECM20TDI01104L906026BP_VW37.rod
       VCID: 79F3CD52F8E186F61A-802C
    17158 - Databus
                        Mileage: 22 km
                        Date: 2015.11.03
                        Time: 22:23:25
              U0428 00 [032] - -
                        Mileage: 22 km
                        Date: 2015.11.03
                        Time: 06:35:37
       Part No SW: 0D9 300 041 H    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4902
       Revision: 06253104    Serial number: TFK01507080002
       ROD: EV_TCMDQ250021_AU37.rod
       VCID: 1D3BF9C20C891AD656-8048
       Revision: 00000000    Serial number: 62015000002156
       Coding: 01FA62A124280973077F060441CA2980462490E0608294F31862507AC202
       VCID: 7AF1D25EFDE78DEE13-802E
    0297 - Steering angle sensor
              B1168 16 [008] - Voltage Too Low
                        Reset counter: 43
                        Date: 2015.11.03
                        Time: 06:35:44
    16412 - Display for Tire Pressure Monitoring
                        Reset counter: 43
                        Mileage: 22 km
                        Date: 2015.11.03
                        Time: 06:35:56
    16413 - Display for Tire Pressure Monitoring
                        Reset counter: 43
                        Mileage: 22 km
                        Date: 2015.11.03
                        Time: 06:35:56
    32832 - Switch for Electric Parking Brake
              C100C 07 [008] - Mechanical Failure
                        Reset counter: 53
                        Mileage: 322 km
                        Date: 2015.11.23
                        Time: 15:27:40
       Revision: 00021000    Serial number: 0375598215
       Coding: 030C0C
       ROD: EV_KessyHellaMQBAB_AU37.rod
       VCID: 3A71125EBD674DEE53-806E
    12717828 - Databus
              U1121 00 [137] - Missing Message
                        Reset counter: 3
                        Mileage: 22 km
                        Date: 2015.11.03
                        Time: 06:35:45
       Part No SW: 5G0 907 044 BC    HW: 5G0 907 044 BC
       Revision: 00001K08
       Coding: 00020104200100011005000000101002
       ROD: EV_ACClimaBHBVW37X_SK37.rod
       VCID: 69D39D1288413676EA-803C
       Part No SW: 5Q0 937 084 AQ    HW: 5Q0 937 084 AL
       Component: BCM MQBAB M   H24 0175
       Serial number: 01061521500672
       Coding: 00011842C24102FB4BE44000000403081800000000000000000000000000
       Shop #: WSC 59193 001 1048576
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: 0717BBAABE15E0061C-8052
       Slave 1:
       Component: WWS    150716  043 0551
       Serial number:         150718174853
       Slave 2:
       Component: RLHS  037 0059
       Serial number: S3Y15M08D06H02M48S47
       Coding: 90A8DD
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
       Part No SW: 5Q0 919 298 K    HW: 5Q0 919 298
       Component: PARKHILFE PLA H12 0054
       Revision: --------    Serial number: 39431520400180
       Coding: 0031161051
       ASAM Dataset: EV_EPHVA2CAU3700000 003021
       ROD: EV_EPHVA2CAU3700000_VW37.rod
       VCID: 47977BAAFE952006DC-8012
    13637426 - Databus
                        Reset counter: 43
                        Mileage: 22 km
                        Date: 2015.11.03
                        Time: 06:35:44
    Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
       Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
       Component: ACC Bosch MQB H05 0400
       Serial number: 13071503210893
       Coding: 001C1100FE0739
       ASAM Dataset: EV_ACCMRRBoschVW372 001016
       ROD: EV_ACCMRRBoschVW372_AU37.rod
    1058 - Databus
                        Reset counter: 43
                        Mileage: 22 km
                        Date: 2015.11.03
                        Time: 06:35:46
    1062 - Databus
                        Reset counter: 53
                        Mileage: 322 km
                        Date: 2015.11.23
                        Time: 15:27:40
    1059 - Databus
                        Reset counter: 43
                        Mileage: 22 km
                        Date: 2015.11.03
                        Time: 06:35:46
    1078 - Databus
                        Reset counter: 43
                        Mileage: 22 km
                        Date: 2015.11.03
                        Time: 06:35:44
    1043 - Automatic Distance Control
              B10E7 F0 [008] - Disconnected
                        Reset counter: 43
                        Mileage: 22 km
                        Date: 2015.11.03
                        Time: 06:35:46
       Serial number: 003F6R0ZLL65
       VCID: 418365B2D0B11E3612-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 003 007 15
       Serial number: 357670000008C540751R
       Subsystem 2 - Part No SW: -----------    HW: 480 003 007 15
       Serial number: 35867000000D5295D51$
       Subsystem 3 - Part No SW: -----------    HW: 480 402 907 15
       Serial number: 3516502A51B7E8E4B2D-
       Subsystem 4 - Part No SW: -----------    HW: 480 403 007 15
       Serial number: 3526502A91C52F4402FG
       Subsystem 5 - Part No SW: -----------    HW: 480 402 907 15
       Serial number: 3556502C51B7E8E0F1F0
       Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0110
       Revision: --------    Serial number: 04081504220165
       Coding: 0C10
       ROD: EV_SMLSKLOMQB_SE37.rod
       VCID: 0913BD92A80196760A-805C
       Part No SW: 5G1 920 751 A    HW: 5G1 920 751 A
       Component: KOMBI         302 6420
       Coding: 07A419182790000801886A011400000000000000
       VCID: 2649D62E59DFD90E07-8072
    16777018 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
                        Reset counter: 50
                        Mileage: 235 km
                        Date: 2015.11.16
                        Time: 14:46:18
    16777020 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
                        Reset counter: 50
                        Mileage: 235 km
                        Date: 2015.11.16
                        Time: 14:46:18
    16777022 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
                        Reset counter: 50
                        Mileage: 235 km
                        Date: 2015.11.16
                        Time: 14:46:18
       Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1223
       Revision: --------    Serial number: 0003789175
       Coding: 030100041F087300FB0002581C0F00010001050000000000000000000000
       ROD: EV_GatewLear.rod
       VCID: 75EBC162D4F9E2967E-8020
       Subsystem 2 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K
       Component: E221__MFL-DC1  H16 0040
       Serial number: 29150001544340055311
       Coding: 2DFFFF
       Serial number: 5337277303
    66052 - Infotainment CAN Bus (SAE Bus E)
              U0065 00 [008] - Performance
                        Reset counter: 65
                        Mileage: 118 km
                        Date: 2015.11.09
                        Time: 13:36:27
       Revision: 00000000    Serial number: 15000176785009
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB_AU37.rod
       VCID: 346D3C669F03BB9E89-8060
       Serial number: 210715BGL00315
       Coding: 003B1320D000040000001000
       ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
       VCID: 438F6FBACAAD0C2600-8016
       Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811
       Serial number: 00000000000006845578
       Coding: 110000
       Component: EPS_MQB_ZFLS  126 1061
       Coding: 0303
       ROD: EV_SteerAssisMQB.rod
       Serial number: 220715BGM03634
       Coding: 003B1120DE00040000801000
       ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
       VCID: 42816ABED5B7052E0B-8016
       Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812
       Serial number: 00000000000006903024
       Coding: 090000
       Part No: -----------
       Component: ------------- X500
       Coding: 02730001FF00000051110001000808001F01009401200100CF
       ROD: EV_MUStd4CDELP_VW26.rod
       VCID: 6FE7F30AB6A5D846B4-803A
       Media Player Position 1:
       Component: ABT_Std-2_Nav  H43 4060
       Serial number: VWZ6Z9R2122443
       Engine Control Module 2:
       Subsystem 2 - Part No SW: 3G0 919 866 H    HW: -----------
       Component: ECE 2015/16  --- 0430
    5661 - Control Head for Multimedia System; PTT Button
              B1291 FF [009] - Unknown Error Elaboration
                        Fault Frequency: 74
                        Reset counter: 69
                        Mileage: 22 km
                        Date: 2015.11.04
                        Time: 23:14:06
    End-------------------------(Elapsed Time: 04:26)--------------------------
    New User
    Jan 2016
    Gibraltar
    Obviously not
    Quote Originally Posted by Fredbargate View Post
    Obviously not
    Don't use put a space after the open bracket. Mari did it that way so that the forum wouldn't parse them, something that can also be accomplished with NOPARSE tags.
    Obviously not
    Fred: Good morning and welcome.
    I (sadly) don't have folding mirrors on my mk7, but here are the BCM adaptation channel settings from a car that does have folding mirrors from my database -hope they help:
    I also assume that you have made the requisite coding changes to the door controllers as per the screen shot below:
    Cheers
  8. Likes Uwe liked this post
    New User
    Jan 2016
    Gibraltar
    Thanks Don
    I have tried the following gleaned from another forum:-
    VCDS:
    Choose "Select control Module"
    [09] Central Electronics
    [16] Security Access - Code is 31347, click "Do it!"
    [10] Adaptation, choose from the drop down channel
    [23] - Access control 2 - Funk Spiegelanklappen change to "active", click do it
    [26] - Access control 2 - Menuesteuerung Funkspiegelanklappen change to “active”
    [24] - Access control 2 - Funk Spiegelanklappung Modus change to “by look command via remote control key”
    In the car:
    In the Media display
    Click "Car"
    "Setup"
    "Mirrors & Wipers", select the option for “Fold away after parking.”
    However 23 and 26 refuse the active setting and show error whilst there is no "Fold away after parking" option in the media display
    The door controllers have been updated
  10. #8
    Nov 2015
    Spain
    Hi I've been trying to help fred get to the bottom of this with VCDS and followed adaptation and coding instructions fine, I'm wondering if it is possible that the central convienece module may be a medium or low line unit and do we have to upgrade it to a highline spec or for example one used in the GTI models?
  11. #9
    Quote Originally Posted by vw technik estepona View Post
    vw technik estepona: Good morning. I was hoping that Fred's issue could be solved through a simple change to adaptation settings, but I suspect that you could be correct. If you look at my BCM compare spread-sheet (the database where I extracted the table in my first post) HERE. you will find the cars in columns V,W,X,Y,Z and AA all have folding mirrors (see the settings for row ID #69. They also all have the BCM MQBAB H designation (at the top of each column). Fred's observations supports your hypothesis (alas)
  12. #10
    Nov 2015
    Spain
    With thanks for the prompt replies (to all)
    now...
    I need a price and exact part number realisticly for the central convienience module for Fred's car.
    also I can imagine it's going to be a pig to re code everything to a brand new unit so I suspect a second hand unit would be the way forward as it'll most likely be coded to the nines and just tweeking will be required.. plus a lot cheaper! iDEAs on a POSTCARD greatly appreciated 😂
