Saturday,03,May,2014,09:05:31:58542
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WVGBV7AX3AW522582
Mileage: 29823 Repair Order: 1
Chassis Type: AX (1K0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 37 42 44 46 52 53 56 62 65
72
56-Radio -- Status: Not registered 0001
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 06J 906 026 DP HW: 06J 906 026 DA
Component: MED17.5 TFSI 2,0 6988
Revision: AAH15--- Serial number:
Coding: 0423010A190F0160
Shop #: WSC 01079 444 999999
VCID: 7BF54D383A01CEC6CE5-802E
P0087 - 000 - Too Low - Intermittent
Mileage: 47910 km
Date: 2047.14.24
Time: 23:56:35
RPM: 412 /min
Load: 91.7 %
Speed: 10.0 km/h
Temperature: 90.0°C
Temperature: 39.0°C
Absolute Pres.: 990.0 mbar
Address 02: Auto Trans Labels: 09G-927-750.lbl
Part No SW: 09G 927 750 KN HW: 09G 927 750 KN
Component: AQ 250 6F 1704
Revision: 00H90000 Serial number:
Coding: 0000840
VCID: 871DA1C8F6C91A265AD-80D2
Address 03: ABS Brakes Labels: 5N0-614-109-C4.clb
Part No SW: 5N0 614 109 M HW: 5N0 614 109 M
Component: J104 C4 450 V25A 0003
Revision: --H28--- Serial number: 00000002566118
Coding: 0002336
VCID: 35619B005CA5D8B6781-8060
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 AH HW: 3C8 907 336 AH
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
ROD: EV_ClimaBasis_SE36.rod
VCID: 73E56518DA518686965-8026
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 G HW: 5K0 937 087 G
Component: BCM PQ35 H+ 111 1129
Revision: BL111001
Coding: 61580A3890212EC48080008110000F0441055186534D89605C8000000000
Shop #: WSC 18752 008 00032
VCID: 39799730B0BD3CD69C9-806C
Subsystem 1 - Part No SW: 5N1 955 119 HW: Labels: 1KX-955-119.CLB
Component: Wischer 08021 012 0203
Coding: 009795
Part No SW: 5N0 959 655 K HW: 5N0 959 655 K
Component: J234__200 VW10 HI 1916
Revision: 20013000 Serial number: 003E3P23889W
Coding: 0012336
VCID: 4581EBC00C454836E81-8010
Subsystem 1 - Part No: 5N0 959 339 A
Component: BF-Gewichtsens. 001 0004
Subsystem 2 - Serial number: 00000000005XH8
Subsystem 3 - Serial number: 0031.12.090000100000650142ÿ†63
Subsystem 4 - Serial number: 650142ÿ†6332MTS625010280 ÿ†63
Subsystem 5 - Serial number: 10280 ÿ†6342MTS665850270 ÿ†63
Subsystem 6 - Serial number: 50270 ÿ†6351HTS6IMB386KJ ÿ†63
Subsystem 7 - Serial number: 386KJ ÿ†6361HTS6CPV386KJ ÿ†63
Subsystem 8 - Serial number: 386KJ ÿ†63727TS6JDFS39KJ ÿ†63
Subsystem 9 - Serial number: S39KJ ÿ†63827TS6GHCM76KJ ÿ
Subsystem 10 - Serial number: M76KJ ÿ
Part No SW: 1K0 953 549 CM HW: 1K0 953 549 CM
Component: J0527 053 0111
Coding: 0001032
VCID: 7F0DB9282E19D2E6E2D-802A
Part No SW: 5N0 920 961 A HW: 5N0 920 961 A
Component: KOMBI H05 0308
Coding: 210700
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
VCID: 2F6DA96876F9E26632D-807A
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AF HW: 1K0 907 951
Component: J533 Gateway H17 0233
Revision: H17 Serial number: 1521J102150EF4
Coding: FD827F07400002006002
Shop #: WSC 01814 444 59259
VCID: 6BD57D784A615E465E5-803E
Reset counter: 78
Mileage: 47389 km
Date: 2046.14.24
Time: 21:20:59
Address 22: AWD Labels: None
Part No SW: 0AY 907 554 C HW: 0AY 907 554 C
Component: Haldex 4Motion 0041
Coding: 0000005
VCID: 4B95DDF82A21BE463E5-801E
Component: IMMO H05 0308
ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
VCID: EADBF87C0D9BC74EA53-80BF
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 D HW: 1K0 035 274 D
Component: RNS315-NAR H53 0319
Serial number: VWZAZ2M4276341
Coding: 04010401040000000000000A
ROD: EV_RNS315NARV2UDS.rod
VCID: 25414B402405A836C81-8070
Component: NAR_V3_(0037) 0037
6 Faults Found:
1048625 - Front Left Audio Signal Output
B1105 F0 [009] - Short Circuit Between Poles
Fault Frequency: 10
Reset counter: 90
Mileage: 47389 km
Date: 2046.14.26
Time: 13:47:32
1048626 - Front Right Audio Signal Output
B1106 F0 [009] - Short Circuit Between Poles
Fault Frequency: 10
Reset counter: 90
Mileage: 47389 km
Date: 2046.14.26
Time: 13:34:28
1048628 - Rear Right Audio Signal Output
B1107 F0 [008] - Short Circuit Between Poles
Reset counter: 118
Mileage: 47389 km
Date: 2046.14.26
Time: 13:47:32
1048632 - Antenna 1 for Radio
B1119 13 [008] - Open Circuit
Fault Frequency: 17
Reset counter: 130
Mileage: 47389 km
Date: 2046.14.24
Time: 21:38:15
1048634 - Antenna 2 for radio
B111A 13 [008] - Open Circuit
Fault Frequency: 10
Reset counter: 130
Mileage: 47389 km
Date: 2046.14.24
Time: 21:38:07
1048667 - Antenna for Satelite Radio
B10F4 13 [009] - Open Circuit
Reset counter: 78
Mileage: 47389 km
Date: 2046.14.24
Time: 21:22:49
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5N0 959 701 D HW: 5N0 959 701 D
Component: Tuer-SG 009 2101
Coding: 0001205
VCID: 36639C0C41A3D3AE71B-8063
Part No SW: 5N1 909 144 K HW: 5N1 909 148 G
Component: J500__APA-BS KL.162 0703
Revision: 1AH03828 Serial number: 00093190167102
Coding: 0000258
VCID: 3A7B883C75BB37CE953-806F
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5N0 959 702 D HW: 5N0 959 702 D
Coding: 0001204
VCID: 377D910846A92AA66AD-8062
Part No SW: 3AA 907 801 B HW: 3AA 907 801 B
Component: J540 EPB4 VW-49878 0004
Revision: H17 Serial number: 00000000002596
Coding: 0023057
VCID: 306FAA14A3C7FD9E2B7-8065
Part No SW: 5N0 959 703 E HW: 5N0 959 703 E
Component: Tuer-SG 007 2102
Coding: 0001168
Shop #: WSC 01357 011 1012552
VCID: 3979973070BD3CD69C9-806C
Address 65: Tire Pressure (J502) Labels: 1K0-937-08x-65.clb
Component: RDK 111 0821
Coding: 018705
Part No SW: 5N0 959 704 E HW: 5N0 959 704 E
Coding: 0001168
End ---------------------------------------------------------------------
I am having a problem with my 2010 Tiguan, when the car has been driven for about an hour and then parked for at least 10 minutes the engine will stall within 30 seconds of being started, this may happen several times before it will run normally. You can put the car in either drive or reverse and start moving before it stalls or just wait in park, sometimes the engine will be erratic before stalling most times it just stalls. The car runs perfectly and cold starts are not a problem, this only happens after a warm start.
I have noticed that the drivers door no longer primes the low pressure fuel pump when it is opened, but it will run normally if the key is turned in the ignition, the interior lights work correctly as does the key chime and lights on chime.
Recently it has thrown a P0087 which is a fuel rail too low warning, I have checked the fuel pressure when the car is running and it is correct, the car is no longer in warranty due to age .
Any help to identify the cause of problem would be appreciated.
