Not sure whether to post this in the VCDS Support or Tweaks thread, but here goes:
I've had very spotty results trying to change some lighting adaptation channels on my 2016 Golf R. I've run into persistent "Request out of range" errors. These happen after I successfully enter the security code (31347) into the 09-Cent Electronics module. When I locate the "Leuchte" channels and try to change the "Dimmwert" I get an "Error Request out of Range" dialog.
After several tries I was finally able to lower the orange front sidemarkers from 127 to 0 to turn them off. I decided that I did not want to do without the white LED in the headlights which are also turned off by this channel, but now I'm not able to get the original value accepted again. Getting the "Request out of range" each time (meaning driving the car for long periods between attempts, rebooting and reconnecting VCDS each time).
A bit more pressingly, in trying to adjust the brightness of the reverse lights (Leuchte 28RFL and 29RFL) I inadvertently changed the Dimmwert on these to 0 as well. Now I have no backup lights. Interestingly, the backup camera seems to get its power from this circuit as well, because it is not working either and has thrown a fault.
I'm running Windows 10 on a Surface Pro 4. Tried reinstalling the VCDS software - didn't help either. Any guidance would be most appreciated.
Here's an autoscan:
Here's an autoscan:
Sunday,10,January,2016,20:28:08:25534
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: WVWUF7AU0GW154595 License Plate:
Chassis Type: AU (5Q0)
Scan: 01 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 52 55 5F
75 A5 A9
VIN: WVWUF7AU0GW154595 Mileage: 2472km-1536miles
Address 01: Engine (J623-CYFB) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 259 H HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091900122446000E3004
ASAM Dataset: EV_ECM20TFS0208V0906259H 001003
ROD: EV_ECM20TFS0208V0906259H_VW37.rod
VCID: 45AFAB2CC4C2581602-8010
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 62715000002331
Coding: 01FA6BA154250970057C030941C86980D62A90A0C08296B7144050D4C088
VCID: 79D717DCF8BAECF636-802C
16401 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 61
Mileage: 642 km
Date: 2015.12.22
Time: 13:00:22
Revision: 00021000 Serial number: 0383513784
Coding: 030C0C
VCID: 3A55C8D0BD3C27EE7F-806E
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00020004200100000105000012111402
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 6AF538908D1C576ECF-803E
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 085 AJ HW: 5Q0 937 085 AF
Component: BCM MQBAB HNA H24 0175
Serial number: 01061527400589
Coding: 00010A46C041A2E169E44000091C07201800000000000000000000000000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 01277F3C906AB4367E-8054
Slave 1:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150927 043 0551
Serial number: 151008211541
Slave 2:
Component: RLHS 037 0059
Serial number: S3Y15M10D19H17M11S12
Coding: 90A8DD
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Revision: -------- Serial number: 39391528700714
Coding: 0071155001
ROD: EV_EPHVA18AU3700000_SK48.rod
VCID: 43ABB534CAF666262C-8016
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 02091503210141
Coding: 01004700FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
ROD: EV_ACCMRRBoschVW372_AU37.rod
Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H16 0120
Serial number: 07071541350324
ROD: EV_DRCONTITEMIC.rod
VCID: 3753D1E48E2E3A8680-8062
Serial number: 003GCR03RVXN
VCID: 47B3A124FECE4A06F0-8012
Seat occupant detection; front passenger side:
Component: BF-Gewichtss. H11 0021
Serial number: IBH000000000003EOD1F
Coding: 30324E
Subsystem 2 - Part No SW: ----------- HW: 480 000 810 15
Serial number: 357000000008D06DC61V
Subsystem 3 - Part No SW: ----------- HW: 480 000 810 15
Serial number: 358000000003855DD61R
Subsystem 4 - Part No SW: ----------- HW: 480 400 510 15
Serial number: 3510002991D25F8212E6
Subsystem 5 - Part No SW: ----------- HW: 480 400 809 15
Serial number: 3520002B31CF1D34E09C
Subsystem 6 - Part No SW: ----------- HW: 480 400 610 15
Serial number: 3550002C71CF2D72627F
Subsystem 7 - Part No SW: ----------- HW: 480 400 610 15
Serial number: 3560002C71CF2D733128
Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 09101504220081
Coding: 0C00
ROD: EV_SMLSKLOMQB_SE37.rod
VCID: 0937671CA85AFC7626-805C
Part No SW: 5G1 920 858 A HW: 5G1 920 858 A
Component: KOMBI 303 6420
Coding: 0BAD08127F88CF0502886A0B5400000000000000
VCID: 2E7DF4807174FB4ED3-807A
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component: GW MQB High 128 1223
Revision: -------- Serial number: 0004045254
Coding: 0101000830085900FB00023A880F00000001050000000000000000000000
ROD: EV_GatewLear.rod
VCID: 75CF1BECD4A2889652-8020
Subsystem 2 - Part No SW: 5G0 959 442 S HW: 5G0 959 442 S
Component: E221__MFL-DC1 H11 0040
Serial number: 29150001980020075406
Coding: 34FFFF
Serial number: HA1-00027.08.15
Coding: 0001
VCID: 4AB59810EDDCB76EEF-801E
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000219108002
Coding: 5500000000000000
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 3449E6E89F58D19EA5-8060
Address 3C: Lane Change (J1086) Labels: None
Component: HRE_Master H11 0071
Serial number: 0381853903
Coding: 02011103
ROD: EV_HREntryHella_SK37.rod
VCID: 3C59CEC8B70819DE6D-8068
Component: TSG FS 020 0041
Serial number: 310515BEU17079
Coding: 003E13208000040000000000
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Serial number: 00000000000007570108
Coding: 111000
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 9102
ROD: EV_SteerAssisMQB.rod
VCID: 3957D7DCB83A2CF676-806C
12289 - Supply voltage
Reset counter: 40
Mileage: 148 km
Date: 2015.12.11
Time: 00:00:43
Component: TSG BFS 020 0041
Serial number: 120615BFB0479A
Coding: 003E13208000040000800000
VCID: 42A5B030D5EC6F2E27-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Serial number: 00000000000007653252
Coding: 091000
Component: AFS-ECU H07 0090
Coding: 022202010B000400
ROD: EV_HeadlRegulVWAFS_SE26.rod
VCID: 40A1BA38DBE07D3E31-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 876 HW: 3Q0 035 876
Component: MU-S-NS-US H25 0245
Serial number: VWZAZ2R0489992
Coding: 027300020000000051220002001808001F0207F401200105C6
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 71C72FFCA0CAA4B68E-8024
Media Player Position 1:
Subsystem 1 - Part No SW: 5GM 919 605 HW: 5GM 919 605
Component: ABT_Std-2_Nav H52 1028
Serial number: VWZ8Z9RFC008UX
Engine Control Module 2:
Subsystem 2 - Part No SW: 3G0 919 866 B HW: -----------
Component: NAR 2015/16 --- 0220
6720 - Rear View Camera
B1102 31 [009] - No Signal
Reset counter: 56
Mileage: 2321 km
Date: 2016.01.09
Time: 22:25:05
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Component: OCULowMQBUS 007 0568
Coding: 02730002C2821A017F1E06020000
ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels: 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H06 0060
Serial number: 10000440484
Coding: 0100000000020306000400010100000100
ROD: EV_MFKBoschAU370_AU37.rod
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 150909200209
VCID: 2F43E984767EF246D8-807A
End-------------------------(Elapsed Time: 04:22)--------------------------
