Does anyone have an idea what could be going on? This car, when new, had issue of bolt coming loose of oil pump chain. Since then, even today, still running perfect, no noise, starts perfect, no trembling (besides normal for this engine)
1000 miles ago, this fault showed up, but like mentioned, engine running perfect, no noise etc. I reset fault, and showed up again, like said, 1000 miles later. I must add one thing. Roughly 4000 or more, I heard a noise coming from engine, on passenger side, as if chain tensioner was not tight (similar as when it starts, once one does oil change) This happened while driving in traffic, and making a right turn. Accelerated car lightly 2 to 3 times, and noise went away, and never heard again. Below the engine report.
Does this sensor sense, if tensioner is not tight enough? Obviously, chain did not slip or jump a tooth.
Thanks for any help.
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 47 52 53 55
56 62 65 72 76
VIN: Mileage: 289510km-179893miles
Address 01: Engine Labels: 03H-906-032-BLV.lbl
Part No SW: 03H 997 033 N HW: Hardware No
Component: P3.6-FSI-LEV2 G00 2371
Revision: --H11--- Serial number: VWZCZ000000000
Coding: 0000075
Shop #: WSC 00028 028 00001
VCID: 387528D24B0800FE89-806C
000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
P0016 - 008 - Incorrect Correlation - MIL ON
Fault Status: 11101000
Mileage: 289452 km
Date: 2016.01.05
Time: 08:24:32
RPM: 1962 /min
Load: 32.5 %
Speed: 97.0 km/h
Temperature: 84.0°C
Temperature: 15.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.843 V
Part No SW: 09G 927 750 HK HW: 09G 927 750 AJ
Component: AQ 250 6F 1271
Revision: 00H38000 Serial number:
Coding: 0000072
Shop #: WSC 05152 444 83926
VCID: 01038536585281367E-8054
Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0667032157
Coding: 0046541
VCID: 306510F2A378D8BEC1-8064
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AC HW: 3C0 907 044 AC
Component: ClimatronicPQ46 050 0404
Revision: 00050005 Serial number: 00000000000000
VCID: 62C1AABABD143A2E07-8036
Fault Frequency: 120
Reset counter: 207
Mileage: 288319 km
Date: 2015.12.23
Time: 20:04:09
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000002333517
Coding: F7868F0340041A00470A00000F000000002A5D435C0000
VCID: 37772BEE46160F8680-8062
Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 00028
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Coding: 00208933
Shop #: WSC 00028
01335 - Drivers Seat/Mirror Position Control Module (J543)
Reset counter: 201
Mileage: 289184 km
Date: 2016.01.02
Time: 21:15:00
Voltage: 12.45 V
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS H03 0060
Revision: 00000000 Serial number: AUZ4Z7E4013623
VCID: 2A51029A85A4A26E0F-807E
Reset counter: 145
Mileage: 288319 km
Date: 2015.12.23
Time: 20:04:09
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
Component: 0P AIRBAG VW8R 029 2521
Revision: 10029000 Serial number: 003A3P1S2LGN
Coding: 0012368
VCID: 2E590E8AB94CCE4ED3-807A
Subsystem 1 - Part No: 3C0 959 339 A
Component: BF-Gewichtsens. 006 0002
Subsystem 2 - Serial number: 00000000031YSV
Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332MSME0E1A4B0CNÿ†63
Subsystem 5 - Serial number: A4B0CNÿ†6342MSME0E2F3074Hÿ†63
Subsystem 6 - Serial number: F3074Hÿ†6351HTS63IK2E4B3+ÿ†63
Subsystem 7 - Serial number: 2E4B3+ÿ†6361HTS63IK2A662Yÿ†63
Subsystem 8 - Serial number: 2A662Yÿ†63727TS6I2IQU652Nÿ†63
Subsystem 9 - Serial number: QU652Nÿ†63827TS61IKM6NK2Tÿ
Subsystem 10 - Serial number: M6NK2Tÿ
Part No SW: 3C0 953 549 E HW: 3C0 953 549 E
Component: J0527 0015
Revision: 00005000 Serial number: 3C5953507P
Coding: 0002211
Component: E0221 007 0050
Part No SW: 3C0 920 970 R HW: 3C0 920 970 R
Revision: X0033000 Serial number: 00000000000000
Coding: 0007205
Shop #: WSC 05152 444 53658
VCID: 336F1FFE526EE3A6BC-8066
Address 19: CAN Gateway Labels: 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C0611602A9
Coding: 7FFD1F14D31002
VCID: 2143E5B6F89261365E-8074
Reset counter: 154
Mileage: 288789 km
Date: 2015.12.29
Time: 15:31:03
Part No SW: 3C0 919 965 HW: 3C0 919 965
Component: Kompass 005 0002
Revision: 00005000 Serial number: 1166279TQ4EK04
VCID: 6DDBC98674CA7556AA-8038
Part No SW: 3C0 959 433 C HW: 3C0 959 433 C
Component: IMMO 041 0364
Revision: 00041000 Serial number: VWZCZ000000000
Subsystem 1 - Part No: 3C0 905 861 D
Component: ELV 024 0370
3C0905861D ELV 024 0370
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 B HW: 3C0 959 760 B
Component: Sitzverstellung 0701
Revision: 00003000 Serial number: 00000000000000
VCID: 2C5D04828F50BC5EFD-8078
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1K0 959 701 L
Component: Tuer-SG 024 2461
Coding: 0001463
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 RDK 041 0213
Coding: 13910F8801862E521804141FF00A8F0E081800
003 - Mechanical Failure
Fault Status: 01100011
Reset counter: 152
Mileage: 288634 km
Date: 2015.12.28
Time: 16:04:28
Reset counter: 154
Mileage: 288775 km
Date: 2015.12.29
Time: 15:09:03
Address 47: Sound System
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1K0 959 702 L
Coding: 0001462
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000013
Address 55: Headlight Range Labels: 5M0-907-357-V1.lbl
Part No SW: 5M0 907 357 HW: 5M0 907 357
Component: AFS-Steuergeraet X016
Revision: H09 Serial number:
Coding: 0000007
Shop #: WSC 05024 444 54444
VCID: 71E3D5F668F291B68E-8024
Subsystem 1 - Part No: 7L6 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l X017
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 330
Component: AFS-Lst.-Modul r X017
Coding: 00000035
Part No SW: 1K0 035 180 C HW: 1K0 035 180 C
Component: Radio PM6 016 0035
Revision: 00016000 Serial number: VWZ5Z7F2058909
Coding: 0000010
VCID: 2045E0B2F398683E51-8074
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2432
Coding: 0000144
VCID: 316315F6A872D1B6CE-8064
Component: RDK 0391
Coding: 0100101
00667 - Ambient Temperature Signal
Fault Status: 00111000
Reset counter: 194
Mileage: 288775 km
Date: 2015.12.29
Time: 15:11:45
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 32611AFAAD74EAAEB7-8066
Address 76: Park Assist Labels: 3C0-919-283.lbl
Part No SW: 3C0 919 283 B HW: 3C0 919 283 B
Component: Parkhilfe 8-Kan 004 0011
Revision: 00004000 Serial number: 82930600907473
Coding: 0001114
VCID: 2855F8929BA8907E19-807C
