Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 65
Thread: Skoda Fabia MY16 Power Steering fault
  1. #51
    May 2017
    All sorted ✅ thanks for all the help.
  2. Likes Uwe, Dana liked this post
  3. #52
    Aug 2017
    Poland
    Hello!
    My first post so welcome all
    My problem is similar to mentioned above. Fabia 16MY, after light collision (bumper, headlights, hood, airbags) - but I havent seen car before body repair so I'm not 100% sure about scale of damage. In 0x44 steering assist fault P1609. Only one red icon on dashboard - steering assist and not working. After "return to factory settings" procedure assist start to work but many other faults appears, mainly about steering angle sensor. It works, but raw value shows -142 degree at straight wheels. It is rather not possible to rotate steering column, as it fits only in one position. Also steering rack looking below the car doesnt seem to be dismantled recently. The basic settings cannot be done either using VCDS or VAS, also after logging in Security Access, or maybe I dont know how to do it.
    Please look at my Autoscan:
    Saturday,26,August,2017,12:31:16:36988
    VCDS Version: 17.8.0.1
    Workshop Code: 031 73430 000063
    VIN: TMBEM6NJ0HZ102002   License Plate:
    Chassis Type: NJ-SK26 (6C0)
    Scan: 01 03 08 09 10 15 17 19 44 5F
    VIN: TMBEM6NJ0HZ102002   Mileage: 10090km-6269miles
    Address 01: Engine (J623-CJZC)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 027 BB    HW: 04E 907 309 AF
       Component: R4 1.2l TFS   H23 9085
       Revision: R4H23---
       Coding: 01110032230415080000
       Shop #: WSC 73430 031 00000
       ASAM Dataset: EV_ECM12TFS01104E906027BB 001009
       ROD: EV_ECM12TFS01104E906027BB.rod
       VCID: 65CA5F4564F1BA6E19-8030
       CAN Converter 01:
              U0428 00 [039] - -
                        Mileage: 10090 km
                        Date: 2017.07.07
                        Time: 02:07:03
                        Coolant temperature: 23 C
                        Intake air temperature: 24 C
                        Voltage terminal 30: 13.853 V
                        CAN status - engine control module-Bit 0: 0
                        selected gear-Bit 0: 0
    Readiness: 1110 0001
       Part No SW: 6C0 907 379 R    HW: 6R0 907 379 BA
       Component: ESP9.0i       H04 0006
       Serial number: 08505782161109
       Coding: 41F5247D492333C2091410690053822492CC9008000DCA098F00
       Shop #: WSC 73430 031 00063
       ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
       VCID: 3E78D029A1E7C9B6B8-806A
    0625 - Display for Tire Pressure Monitoring
                        Reset counter: 122
                        Mileage: 10090 km
                        Date: 2017.07.07
                        Time: 02:07:03
    1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
              U0428 00 [137] - -
                        Reset counter: 122
                        Mileage: 10090 km
                        Date: 2017.07.07
                        Time: 02:07:03
    1149 - Implausible Data Received from Steering Angle Sensor Module (G85)
              U0428 00 [137] - -
                        Reset counter: 122
                        Mileage: 10090 km
                        Date: 2017.07.07
                        Time: 02:07:03
    Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
       Part No SW: 6V0 820 045 C    HW: 6V0 820 045 C
       Component: AC Manuell    H01 0204
       Serial number:  1611041B-0515
       Coding: 100000001100100000
       ROD: EV_ACManueKMMValeoPQ26_VW26.rod
       VCID: 3260F41965BF1DD64C-8066
    Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
       Part No SW: 6C0 937 089 D    HW: 6C0 937 089
       Component: BCM PQ26 Hi4R H10 0094
       Serial number: 006308244111
       Coding: 0C0008504205497B43804000400703080000D80050013500000000000000
       ASAM Dataset: EV_BCMA0 006002
       ROD: EV_BCMA0_006_SK25.rod
       VCID: 3162FB1560B926CE35-8064
       Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
       Component: PARKHILFE 3K  H10 0054
       Revision: --------    Serial number: 39231633302445
       Coding: 0001050001
       ASAM Dataset: EV_EPHVA14AU3700000 002024
       ROD: EV_EPHVA14AU3700000_002_SK37.rod
       VCID: 3C7CDA21B7FBDBA696-8068
    13637426 - Databus
                        Reset counter: 122
                        Mileage: 10090 km
                        Date: 2017.07.07
                        Time: 02:07:03
    Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
       Part No SW: 6C0 959 655 K    HW: 6C0 959 655 K
       Component: VW20Airbag743 002 0380
       Revision: --------    Serial number: 003TJ0090U15
       Coding: 88CCC000000000005C5400CF000800000000
       Shop #: WSC 73430 790 00000
       ROD: EV_AirbaVW20BPAVW26X.rod
       VCID: 3B7ED93DB2F5DC9E9F-806E
       Subsystem 1 - Part No SW: -----------    HW: 410 820 611 16
       Component: SideSensor_Df  151 0800
       Serial number: 3575H00A7218C262307B
       Subsystem 2 - Part No SW: -----------    HW: 410 820 711 16
       Component: SideSensor_Pf  151 0800
       Serial number: 3585H009F22AE861D19%
       Subsystem 3 - Part No SW: -----------    HW: 442 152 910 16
       Component: SideSensor_Dr  1CA 0148
       Serial number: 3517A00C72182421536-
       Subsystem 4 - Part No SW: -----------    HW: 442 152 910 16
       Component: SideSensor_Pr  1CA 0148
       Serial number: 3527A00C7218242371C2
                        Mileage: 10090 km
                        Date: 2017.07.07
                        Time: 02:07:05
       Part No SW: 6V0 920 740 B    HW: 6V0 920 740 B
       Component: KOMBI         202 2310
       Coding: 072401002180000801082A001000000000000000
       ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
       VCID: 346CF2019FAB13E65E-8060
    Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
       Part No SW: 6C0 909 901 A    HW: 6C0 937 089
       Component: GW MQB A0     H10 0094
       Revision: --------    Serial number: 006308244111
       Coding: 030100042F0A640000000000000000010001050000000000000000000000
       ASAM Dataset: EV_GatewA0Lear 013020
       ROD: EV_GatewA0Lear_013_SK25.rod
       VCID: 2648184959777176D0-8072
       Subsystem 1 - Part No SW: 6C0 915 181 B    HW: 6C0 915 181 B
       Component: J367-BDM  H08 0270
       Serial number: 63321004145881883207
    197169 - Controls in Steering Wheel
                        Reset counter: 122
                        Mileage: 10090 km
                        Date: 2017.07.07
                        Time: 02:07:03
                        Supply voltage: Terminal 30: 13.9 V
                        Terminal 15: On
       Part No SW: 6C1 909 144 AJ    HW: 6C1 909 144 D
       Component: EPS_TRW_ALow  313 3242
       Serial number: CGBT0578
       Coding: 000700
       ASAM Dataset: EV_SteerAssisUDSTRW 016134
       ROD: EV_SteerAssisUDSTRW.rod
       VCID: 70E43E11AB336FC67A-8024
    1094656 - Steering angle sensor
                        Reset counter: 122
                        Mileage: 10090 km
                        Date: 2017.07.07
                        Time: 02:07:03
    1073664 - Steering End Stops Not Learned
                        Reset counter: 122
                        Mileage: 10090 km
                        Date: 2017.07.07
                        Time: 02:07:03
    1073920 - Steering End Stops Not Learned
                        Reset counter: 122
                        Mileage: 10090 km
                        Date: 2017.07.07
                        Time: 02:07:03
       Part No SW: 6V0 035 871 D    HW: 6V0 035 871 D
       Component: MU-E--ER      050 7080
       Serial number: 15111600013194
       Coding: 03620000BE0000001111000401000A002F0000C40000010000
       ASAM Dataset: EV_MUEnt4CGen2LGE 001032
       ROD: EV_MUEnt4CGen2LGE_SK26.rod
       VCID: 3874C63183C3F78672-806C
    End-------------------------(Elapsed Time: 02:34)--------------------------
    Also screenshot with angle sensor parameters:
    [IMG]<a href="https://www.fotosik.pl/zdjecie/e6725b88762a7207" target="_blank"><img src="https://images84.fotosik.pl/769/e6725b88762a7207med.jpg" border="0" alt="" /></a>[/IMG]
    Hmm, I dont know how to paste image....
    Many thanks for any advices
  4. Likes Dana liked this post
  5. #53
    Quote Originally Posted by Jetronik View Post
    Let me try:
    Yes, that works. I did it like this:
    [img]https://images84.fotosik.pl/769/e6725b88762a7207gen.jpg[/img]
  6. Likes Dana liked this post
  7. #54
    United States
    The G85 data appears to come from the 44 (rack) itself rather than the slip ring in this car type. I couldn't get a diagram for this car so I used Polo information. Feel free to correct me if you believe G85 is in the slip ring!
    I think the -142 reading is the problem so please straighten the steering and then try Basic Settings: [*IDE03192*] Steering angle sensor: zero calibration w/ steer. wheel scales. That should store a set point of zero resulting in live readings of 0. If you get a SA required message try 17580.
    If G85 reports 0 the actual Basic Settings should be: [*MAS00815*] Steering angle sensor.
  8. Likes Uwe liked this post
  9. #55
    Sep 2017
    Hello all,
    I have one problem like VW_FI,
    6355968 - Crash Shut-Down Activated
    P1609 00 [009] - -
    Reset counter: 188
    Mileage: 12452 km
    Date: 2016.07.20
    Time: 16:24:03
    Engine speed: 893 /min
    Vehicle speed: 0.00 km/h
    System status: ERROR
    Voltage terminal 30: 13.72 V
    Power steering current consumption: 0.50 A
    End stage temperature: 30 C
    Steering assistance: engine output: 0.00 %
    Sensor for motor position: 0
    Sensor for motor position: 0 /min
    Steering assistance: target engine torque: 0.00 Nm
    Steering torque: 0.03 Nm
    Steering torque: OK
    How to reset this error?
    Security Access -16 => Steering Aid 1***80 => Basic Settings => IDE02325-Reset to Factory settings => Go... and it running but have no end...
  10. #56
    Aug 2016
    Eindhoven, NB, NL
    a full autoscan to start with?
  11. #57
    Sep 2017
    I do note have a car, only EPS and CAN BusSimulation.
    If you want I resend a full autoscan from VW_FI
  12. #58
    United States
    Quote Originally Posted by LeonID View Post
    It is entirely possible #44 needs information from other modules on the network that aren't installed in your bench setup. I would repeat the process after the rack is installed in a vehicle.
  13. Likes Uwe liked this post
  14. #59
    Verified VCDS User Abbott Automotive's Avatar
    Feb 2016
    Mansfield, Nottinghamshire, UK
    Here's a little video I put together to help anyone with the same issues.
  15. #60
    Verified VCDS User ConD's Avatar
    Jul 2014
    Oulu, Finland
    Hi everyone!
    This has been quite interesting topic and i was involved with this due to fellow car enthusiast repairing his lightly crashed Seat Arona. Seat Dealer would be very happy to sell completely new steering column & rack to car which has had minor damages to front end plastics. Codes are about the same - Crash shut-down activated as well as couple of others.
    However, Seat Arona is a bit newer MQB A0-platform vehicle, and with my current HEX-USB+CAN cable I'm unable to work with this. Some things I'm able to get scanned:
    Tuesday,30,July,2019,18:26:35:60995
    VCDS Version: 19.6.1.0 (x64)
    VIN: VSSZZZKJZJR082375   License Plate: XXX-NNN
    Mileage:    Repair Order: arona
    Chassis Type: KJ-SE27 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 44 55 5F
    08-Auto HVAC -- Status: Cannot be reached 0100
    Address 01: Engine (J623-DKJA)       Labels: None
       Part No SW: 04C 906 025 G    HW: 04C 907 309 BB
       Component: R3 1.0l TFS   H20 5178
       Revision: D7H20000
       Coding: 0125003223641D081000
       Shop #: WSC 00049 770 00139
       ASAM Dataset: EV_ECM10TFS01104C906025G 001003
       ROD: N/A
       VCID: 244C01B32F35BC6FDD-8070
    Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
    No ASAM data for: "EV_ECM10TFS01104C906025G" (SE27)
    7150 - ROD - Unknown Error Code
              - 00 [047]
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:22
    4708 - ROD - Unknown Error Code
              - 00 [047]
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:21
    4709 - ROD - Unknown Error Code
              - 00 [047]
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:21
    Readiness: 0010 0001
       Part No SW: 0CW 300 042 E    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 1603
       Revision: 00005008    Serial number: CU501710236571
       ROD: N/A
       VCID: 3874C5C383BDC88F61-806C
    No ASAM data for: "EV_TCMDQ200021" (SE27)
    21193 - ROD - Unknown Error Code
              - 00 [047]
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:22
       Part No SW: 2Q0 614 517 T    HW: 2Q0 614 517 M
       Component: ESC_high_vFGS H33 0322
       Serial number: 08515614170912
       Coding: 8A0D4C573D4951AF32FFBC1D12DF11A649344D26226A24484454625445488865922CB26444562412222A462AA269D64AFD966B52BF
       Shop #: WSC 00049 770 00020
       ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
       ROD: N/A
       VCID: 3F86AEDFA693FFB7A0-806A
    No ASAM data for: "EV_Brake1BOSCHESPMQBA0" (SE27)
    1200 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 181
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:22
    1152 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 181
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:22
    1272 - ROD - Unknown Error Code
              - 00 [008]
                        Reset counter: 222
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:22
    1141 - ROD - Unknown Error Code
              - 00 [137]
                        Reset counter: 181
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:22
    Address 05: Acc/Start Auth. (J518)       Labels:. 5Q0-959-435.clb
       Component: VWKESSYMQB    037 0907
       Revision: 00037000    Serial number: 0459118184
       Coding: 112E0E0703
       Shop #: WSC 00049 770 00021
       ROD: N/A
       VCID: 3E78D3DBA199F6BFAB-806A
    No ASAM data for: "EV_KessyHellaMQBAB" (SE27)
       Part No SW: 2Q0 937 090     HW: 2Q0 937 090
       Component: BCM A0 Std+   H97 0915
       Serial number: 07001731100757
       ASAM Dataset: EV_BCMA0 204001
       ROD: N/A
       VCID: 6FE63E9FB6734F3770-803A
       Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
       Component: RLS  047 0105
       Serial number: S7Y17M10D25H21M17S46
       Coding: 00194D
       Subsystem 2 - Part No SW: 2Q1 959 881 B    HW: 2Q1 959 881 B
       Component: FHSG_DRV  001 0001
       Serial number: 00000000000017364395
       Coding: 13000F
       Subsystem 3 - Part No SW: 2Q1 959 882 D    HW: 2Q1 959 882 D
       Component: FHSG_PSG  001 0002
       Serial number: 00000000000017052411
       Coding: 09000F
       Subsystem 4 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
       Component: FOND_FHSG_DRV  006 0007
       Serial number: 00000000000017048600
       Subsystem 5 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
       Component: FOND_FHSG_PSG  006 0007
       Serial number: 00000000000017285286
       Coding: 190000
    No ASAM data for: "EV_BCMA0" (SE27)
    539157 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 182
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:27
    590853 - ROD - Unknown Error Code
              - 00 [008]
                        Reset counter: 222
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:26
    592133 - ROD - Unknown Error Code
              - 00 [008]
                        Reset counter: 222
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:26
    Address 10: Park/Steer Assist (J791)       Labels:. 5Q0-919-298.clb
       Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
       Serial number: 000308417617305
       Coding: 0271161051
       ROD: N/A
       VCID: 50A49D630B0D70CF49-8004
    No ASAM data for: "EV_EPHVA2CAU3700000" (SE27)
    13679372 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 181
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:26
    13637426 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 181
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:26
    13679386 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 181
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:25
    Address 13: Auto Dist. Reg
    Address 15: Airbags (J234)       Labels: None
       Part No SW: 5QF 959 655 L    HW: 5QF 959 655 L
       Component: Airbag VW22   006 0520
       Revision: --------    Serial number: 003XNPP0ZRQP
       Coding: 88CCC0C000000000585400CF000C00000065
       ASAM Dataset: EV_AirbaVW22TS6VW48X 001028
       ROD: N/A
       VCID: 5FC64E5F46D3DFB7C0-800A
       Subsystem 1 - Part No SW: -----------    HW: 454 001 310 17
       Serial number: 35700000000EEBBCA92C
       Subsystem 2 - Part No SW: -----------    HW: 454 001 410 17
       Serial number: 358000000007839CA92X
       Subsystem 3 - Part No SW: -----------    HW: 454 801 410 17
       Serial number: 3510098002D120000001
       Subsystem 4 - Part No SW: -----------    HW: 454 801 910 17
       Serial number: 35200E8312C12000000A
       Subsystem 5 - Part No SW: -----------    HW: 454 801 810 17
       Component: FrontSensor_D  307 0189
       Serial number: 3550052E66F10000000J
    No ASAM data for: "EV_AirbaVW22TS6VW48X" (SE27)
    1050117 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 182
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:23
    1060608 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 181
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:25
    Address 16: Steering wheel (J524)       Labels:. 5Q0-953-549.clb
       Part No SW: 5Q0 953 521 GE    HW: 5Q0 953 569 A
       Revision: FF035035    Serial number: 20171021400570
       Coding: 6414
       ROD: N/A
       VCID: 7BFE1ACFF20B2397CC-802E
    No ASAM data for: "EV_SMLSVALEOMQB" (SE27)
    Address 17: Instruments (J285)       Labels: None
       Part No SW: 6F0 920 740     HW: 6F0 920 740
       Component: KOMBI         206 0450
       Coding: 04A4091A2D800008008822011001000080000000
       ASAM Dataset: EV_DashBoardVDDMQBA0 001020
       ROD: N/A
       VCID: 62C047AB75A1F25FEF-8036
    No ASAM data for: "EV_DashBoardVDDMQBA0" (SE27)
    16777028 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 181
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:26
    16776960 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 181
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:23
    16776961 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 181
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:23
    Address 19: CAN Gateway (J533)       Labels:. 3Q0-907-530-V1.clb
       Component: GW MQB High   436 4326
       Revision: --------    Serial number: 0007032400
       Coding: 030100046F085700E90002581C0F00010001070000000000000000000000
       ASAM Dataset: EV_GatewNF 013044
       ROD: N/A
       Subsystem 2 - Part No SW: 5F0 959 537 D    HW: 5F0 959 537 D
       Serial number: 000000000H1749031017
       Coding: 012000
       Subsystem 3 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
       Component: J367-BDMBOSCH  H02 2011
       Serial number: 100265D9
    No ASAM data for: "EV_GatewNF" (SE27)
    131654 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 181
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:23
    131671 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 181
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:23
       Part No SW: 2Q0 905 861     HW: 2Q0 905 861
       Component: ELV-MQBB      H06 0020
       Serial number: 17000189490014
       Coding: 0800000000000000
       ROD: N/A
       VCID: 70E43DE3AB4D50CF69-8024
    No ASAM data for: "EV_ELVMarqMQBA0" (SE27)
    Address 44: Steering Assist (J792)       Labels: None
       Part No SW: 2Q1 909 144 J    HW: 2Q1 909 144 F
       Component: TRW_G4L_MQBA0 610 6030
       Serial number: 0186381CB2H3032
       Coding: 01000101000000010101020101000101000001
       ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
       ROD: N/A
       VCID: 3972C0C7B8B7D1879E-806C
    No ASAM data for: "EV_SteerAssisTRWG4LMQBA0" (SE27)
    15788544 - ROD - Unknown Error Code
              - 00 [008]
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:23
       Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
       Component: AFS-ECU       H07 0070
       Coding: 078A000001200003
       ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
       ROD: N/A
       VCID: 4182A827D0678947D6-8014
    No ASAM data for: "EV_HeadlRegulAFSMQBMAX" (SE27)
    13705992 - ROD - Unknown Error Code
              - 00 [137]
                        Reset counter: 181
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:24
    Address 5F: Information Electr. (J794)       Labels:. 5F0-035-MIB-STD2.clb
       Part No SW: 5QA 035 824 B    HW: 5QA 035 824 B
       Component: MU-S--ER      H41 0468
       Serial number: SEZAZ2T1259728
       Coding: 04120600960A000011110001000808002F0101D40120050002
       ASAM Dataset: EV_MUStd6C1TSAT 001015
       ROD: N/A
       Subsystem 1 - Part No SW: 6F0 919 605     HW: 6F0 919 605
       Component: ABT_Std-2  H50 8130
       Serial number: SEZ6ZHT3151114
    No ASAM data for: "EV_MUStd6C1TSAT" (SE27)
    7173 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 181
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:25
    7195 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 181
                        Mileage: 13726 km
                        Date: 2019.07.14
                        Time: 22:27:24
    End-------------------------(Elapsed Time: 04:03)--------------------------
    Ok, there is lots of codes still unknown to my interface, so is this procedure still viable, because the [44] Component differs from the OP's // automech's procedure?
    This is the component now: Component: TRW_G4L_MQBA0 610 6030
    OP has the following: Component: EPS_TRW_ALow 312 3232
    If not, i have to discuss with my friend how to continue, BUT, if it happens to be doable with HEX-V2 or HEX-NET, i have to start considering to upgrade my toolkit. Thank you in advance for your help!
    VW Touareg 3.0TDI 2012
  16. Likes Dana liked this post
