Skoda Fabia MY16 Power Steering fault
   #41
Fabia3
Poland
C?ID=300418
0x01-07 could not code becouse do not have SA
0x15-07 could not code becouse do not have SA
   #42
Dana
Western PA, USA
1) I don't have access to repair info for this RoW vehicle to confirm or deny if G85 is part of the slip ring (AKA clockspring) -or- internal with #44 but I have to wonder if the slip ring (6C0 959 653) might communicate via diagnostics.
Please try the [Select] a control module screen, type 04 into the Direct Entry box at the bottom followed by [Go!]. If something communicates please save that info so it can be posted here. I would want to see what part number 04 shows, what coding it may have stored, if any faults are shown and look at advanced measuring values. Saving text from the Advanced ID and Fault code screens should give us what we need to confirm my Polo based theory.
2) I would want to make sure the Raw value (118.4 in that example)
changes from 0.0 when straight to similar values with the steering held at each stop. Make sure you get 0.0 when straight and then something like +/- 460 in each direction when turning the wheel. Pictures at each position or text would be helpful so we can rule out a bad G85 reading.
   #43
Fabia3
Poland
C?ID=300418
About that - I think it is a parto of 6c1909144 . I removed the steering whell and moove only the slip ring 6c0959653 and the steering angle sensor raw value did not change. If i moove steering rod (slip ring do not move) it change . Raw value is the unprocesed value that need to be calibrate I think. I can't moove it to 0,0 and get the whell straight. it mooves from about - 250 to +550 degrees. Will get and post this aditional information toomorow.
Fabia3
Poland
C?ID=300418
I did wsc on the #44 and #03 as the #15 module and it did not help.
   #46
Fabia3
Poland
C?ID=300418
So the problem is solved. I gave up. I visited skoda tooday. Thay did not replace any part. It was the #44 bad coding problem. They did not tell me what they did but looking at WSC only the #44 was coded. Thank You all for support .
   #47
Mind posting up a fresh scan so we people can see what changed?
Please post follow up auto-scan ..........Thank you!
   #49
Fabia3
Poland
C?ID=300418
Now I have only polish version if You wont I can post english toomorow. What I fond on #44 was 000300 now is 000700 but it is only the red or Yelow dashbort light.
But: in the adaptation is less to change. Was about 10 diferent parameters now is 5 or 6. If You will have an idea of what is going on please share
Friday,31,March,2017,20:04:51:10824
VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4336.4
Data version: 20170220 DS267.3
Workshop Code: 031 00031 073430
Chassis Type: NJ (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: TMBEA6NJ5GZ031323   Mileage: 44375km-27573miles
Address 01: Engine (J623-CHYA)       Labels: 04C-906-020-CHY.clb
   Part No SW: 04C 906 057     HW: 04C 907 309 J
   Component: R3 1.0l MPI   H24 8993
   Revision: 31H24000
   Coding: 01110052020405080000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM10MPI01104C906057 001016
   ROD: EV_ECM10MPI01104C906057_SK26.rod
   VCID: 629EA06454CD15975BD-8036
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 K    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0004
   Serial number: 08508679150618
   Coding: 41F5247D492633C10917106B0054822492CC9008000DCA098F00
   Shop #: WSC 73430 790 00000
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   VCID: 37282130AFCF203FDC3-8062
Address 08: Auto HVAC (J301)       Labels: 6C0-820-045.clb
   Part No SW: 6V0 820 045 A    HW: 6V0 820 045 A
   Component: AC Manuell    H01 0108
   Serial number:  1506121B-0556
   Coding: 100000001000100000
   ROD: EV_ACManueKMMValeoPQ26_VW26.rod
   VCID: 303A1A2C4AA1F7079D9-8064
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 6C0 937 087 C    HW: 6C0 937 087
   Component: BCM PQ26 Me4R H08 0084
   Serial number: 001368003882
   Coding: 0C0008404205497B43804000400703080000D80050013500000000000000
   ASAM Dataset: EV_BCMA0 005005
   ROD: EV_BCMA0_005_SK25.rod
   VCID: 2E0604545095E1F78F5-807A
Address 15: Airbags (J234)       Labels: 6C0-959-655.clb
   Part No SW: 6C0 959 655 F    HW: 6C0 959 655 F
   Component: VW20Airbag733 001 0360
   Revision: --------    Serial number: 003RJ003NK4D
   Coding: 88CCC000000000005C5400CF000800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 36362C34A8C5D937C75-8062
   Subsystem 1 - Part No SW: -----------    HW: 410 820 906 15
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00B51AC0682F20N
   Subsystem 2 - Part No SW: -----------    HW: 410 820 906 15
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00B31AC0683612F
   Subsystem 3 - Part No SW: -----------    HW: 442 152 506 15
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00B91AC53B3919O
   Subsystem 4 - Part No SW: -----------    HW: 442 152 506 15
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00BB1AC53B4419N
   Part No SW: 6V0 920 730 A    HW: 6V0 920 730 A
   Component: KOMBI         105 1420
   Coding: 0724010021000008010808001000000000000000
   ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
   VCID: 323E102444ADC517EBD-8066
Address 19: CAN Gateway (J533)       Labels: 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 087
   Component: GW MQB A0     H08 0084
   Revision: --------    Serial number: 001368003882
   Coding: 030000042F0A640000000000000000010001050000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_VW26.rod
   VCID: 6594BB7845E362AFBEF-8030
   Subsystem 1 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 22163633342821249920
Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 AJ    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3242
   Serial number: CF6R0981
   Coding: 000700
   Shop #: WSC 57012 002 1048576
   ASAM Dataset: EV_SteerAssisUDSTRW 016134
   ROD: EV_SteerAssisUDSTRW_SE26.rod
   VCID: 70BADA2C8A21B707DD9-8024
Address 5F: Information Electr. (J794)       Labels: 3V0-035-MIB-ENT2.clb
   Part No SW: 6V0 035 867 C    HW: 6V0 035 867 C
   Component: MU-E--ER      852 6490
   Serial number: 16061500012730
   Coding: 036200003C0000005011000101000A00000000C40000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001025
   ROD: EV_MUEnt4CGen2LGE_SK26.rod
   VCID: 3C223E1C96E90367311-8068
End----------(Elapsed Time: 00:30, VBatt start/end: 14.9V/14.7V)-----------
10bars
C?ID=305085
Hi
Sorry this is my first first post so please bear with me:
I have the same trouble on my VW polo Crash shut down
I have erased the code and enterd the code in the VCDS,
selected the factory settings and selected GO the question is how long does this procedure take ? as the message is saying RUNNING ?
hope this makes scene
   #51
10bars
C?ID=305085
All sorted ✅ thanks for all the help.
   #52
Jetronik
Poland
C?ID=82969
Hello!
My first post so welcome all :)
My problem is similar to mentioned above. Fabia 16MY, after light collision (bumper, headlights, hood, airbags) - but I havent seen car before body repair so I'm not 100% sure about scale of damage. In 0x44 steering assist fault P1609. Only one red icon on dashboard - steering assist and not working. After "return to factory settings" procedure assist start to work but many other faults appears, mainly about steering angle sensor. It works, but raw value shows -142 degree at straight wheels. It is rather not possible to rotate steering column, as it fits only in one position. Also steering rack looking below the car doesnt seem to be dismantled recently. The basic settings cannot be done either using VCDS or VAS, also after logging in Security Access, or maybe I dont know how to do it.
Please look at my Autoscan:
Saturday,26,August,2017,12:31:16:36988
VCDS Version: 17.8.0.1
Workshop Code: 031 73430 000063
VIN: TMBEM6NJ0HZ102002   License Plate:
Chassis Type: NJ-SK26 (6C0)
Scan: 01 03 08 09 10 15 17 19 44 5F
VIN: TMBEM6NJ0HZ102002   Mileage: 10090km-6269miles
Address 01: Engine (J623-CJZC)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 BB    HW: 04E 907 309 AF
   Component: R4 1.2l TFS   H23 9085
   Revision: R4H23---
   Coding: 01110032230415080000
   ASAM Dataset: EV_ECM12TFS01104E906027BB 001009
   ROD: EV_ECM12TFS01104E906027BB.rod
   VCID: 65CA5F4564F1BA6E19-8030
   CAN Converter 01:
          U0428 00 [039] - -
                    Mileage: 10090 km
                    Date: 2017.07.07
                    Time: 02:07:03
                    Coolant temperature: 23 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 13.853 V
                    CAN status - engine control module-Bit 0: 0
                    selected gear-Bit 0: 0
Readiness: 1110 0001
   Part No SW: 6C0 907 379 R    HW: 6R0 907 379 BA
   Component: ESP9.0i       H04 0006
   Serial number: 08505782161109
   Coding: 41F5247D492333C2091410690053822492CC9008000DCA098F00
   Shop #: WSC 73430 031 00063
   VCID: 3E78D029A1E7C9B6B8-806A
0625 - Display for Tire Pressure Monitoring
                    Reset counter: 122
                    Mileage: 10090 km
                    Date: 2017.07.07
                    Time: 02:07:03
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
          U0428 00 [137] - -
                    Reset counter: 122
                    Mileage: 10090 km
                    Date: 2017.07.07
                    Time: 02:07:03
1149 - Implausible Data Received from Steering Angle Sensor Module (G85)
          U0428 00 [137] - -
                    Reset counter: 122
                    Mileage: 10090 km
                    Date: 2017.07.07
                    Time: 02:07:03
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6V0 820 045 C    HW: 6V0 820 045 C
   Component: AC Manuell    H01 0204
   Serial number:  1611041B-0515
   Coding: 100000001100100000
   VCID: 3260F41965BF1DD64C-8066
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 D    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H10 0094
   Serial number: 006308244111
   Coding: 0C0008504205497B43804000400703080000D80050013500000000000000
   ASAM Dataset: EV_BCMA0 006002
   ROD: EV_BCMA0_006_SK25.rod
   VCID: 3162FB1560B926CE35-8064
   Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
   Component: PARKHILFE 3K  H10 0054
   Revision: --------    Serial number: 39231633302445
   Coding: 0001050001
   ASAM Dataset: EV_EPHVA14AU3700000 002024
   ROD: EV_EPHVA14AU3700000_002_SK37.rod
   VCID: 3C7CDA21B7FBDBA696-8068
13637426 - Databus
                    Reset counter: 122
                    Mileage: 10090 km
                    Date: 2017.07.07
                    Time: 02:07:03
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 K    HW: 6C0 959 655 K
   Component: VW20Airbag743 002 0380
   Revision: --------    Serial number: 003TJ0090U15
   VCID: 3B7ED93DB2F5DC9E9F-806E
   Subsystem 1 - Part No SW: -----------    HW: 410 820 611 16
   Serial number: 3575H00A7218C262307B
   Subsystem 2 - Part No SW: -----------    HW: 410 820 711 16
   Serial number: 3585H009F22AE861D19%
   Subsystem 3 - Part No SW: -----------    HW: 442 152 910 16
   Serial number: 3517A00C72182421536-
   Subsystem 4 - Part No SW: -----------    HW: 442 152 910 16
   Serial number: 3527A00C7218242371C2
                    Mileage: 10090 km
                    Date: 2017.07.07
                    Time: 02:07:05
   Part No SW: 6V0 920 740 B    HW: 6V0 920 740 B
   Component: KOMBI         202 2310
   Coding: 072401002180000801082A001000000000000000
   VCID: 346CF2019FAB13E65E-8060
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901 A    HW: 6C0 937 089
   Component: GW MQB A0     H10 0094
   Revision: --------    Serial number: 006308244111
   Coding: 030100042F0A640000000000000000010001050000000000000000000000
   ROD: EV_GatewA0Lear_013_SK25.rod
   VCID: 2648184959777176D0-8072
   Subsystem 1 - Part No SW: 6C0 915 181 B    HW: 6C0 915 181 B
   Component: J367-BDM  H08 0270
   Serial number: 63321004145881883207
197169 - Controls in Steering Wheel
                    Reset counter: 122
                    Mileage: 10090 km
                    Date: 2017.07.07
                    Time: 02:07:03
                    Supply voltage: Terminal 30: 13.9 V
                    Terminal 15: On
   Component: EPS_TRW_ALow  313 3242
   Serial number: CGBT0578
   Coding: 000700
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 70E43E11AB336FC67A-8024
1094656 - Steering angle sensor
                    Reset counter: 122
                    Mileage: 10090 km
                    Date: 2017.07.07
                    Time: 02:07:03
1073664 - Steering End Stops Not Learned
                    Reset counter: 122
                    Mileage: 10090 km
                    Date: 2017.07.07
                    Time: 02:07:03
1073920 - Steering End Stops Not Learned
                    Reset counter: 122
                    Mileage: 10090 km
                    Date: 2017.07.07
                    Time: 02:07:03
   Part No SW: 6V0 035 871 D    HW: 6V0 035 871 D
   Component: MU-E--ER      050 7080
   Serial number: 15111600013194
   Coding: 03620000BE0000001111000401000A002F0000C40000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001032
   VCID: 3874C63183C3F78672-806C
End-------------------------(Elapsed Time: 02:34)--------------------------
Also screenshot with angle sensor parameters:
a>
e6725b88762a7207
https://www.fotosik.pl/zdjecie/e6725b88762a7207
Hmm, I dont know how to paste image....
Many thanks for any advices :)
   #53
Let me try:
Yes, that works. I did it like this:
[img]https://images84.fotosik.pl/769/e6725b88762a7207gen.jpg[/img]
Dana
Western PA, USA
The G85 data appears to come from the 44 (rack) itself rather than the slip ring in this car type. I couldn't get a diagram for this car so I used Polo information. Feel free to correct me if you believe G85 is in the slip ring!
I think the -142° reading is the problem so please straighten the steering and then try Basic Settings: [*IDE03192*] Steering angle sensor: zero calibration w/ steer. wheel scales. That should store a set point of zero resulting in live readings of 0°. If you get a SA required message try 17580.
If G85 reports 0 the actual Basic Settings should be: [*MAS00815*] Steering angle sensor.
LeonID
C?ID=273327
Hello all,
I have one problem like VW_FI,
6355968 - Crash Shut-Down Activated
P1609 00 [009] - -
Reset counter: 188
Mileage: 12452 km
Date: 2016.07.20
Time: 16:24:03
Engine speed: 893 /min
Vehicle speed: 0.00 km/h
System status: ERROR
Voltage terminal 30: 13.72 V
Power steering current consumption: 0.50 A
End stage temperature: 30 °C
Steering assistance: engine output: 0.00 %
Sensor for motor position: 0 °
Sensor for motor position: 0 /min
Steering assistance: target engine torque: 0.00 Nm
Steering torque: 0.03 Nm
Steering torque: OK
How to reset this error?
Security Access -16 => Steering Aid 1***80 => Basic Settings => IDE02325-Reset to Factory settings => Go... and it running but have no end...
   #57
LeonID
C?ID=273327
I do note have a car, only EPS and CAN BusSimulation.
If you want I resend a full autoscan from VW_FI :cool:
Dana
Western PA, USA
It is entirely possible #44 needs information from other modules on the network that aren't installed in your bench setup. I would repeat the process after the rack is installed in a vehicle.
ConD
Oulu, Finland
C?ID=82663
Hi everyone!
This has been quite interesting topic and i was involved with this due to fellow car enthusiast repairing his lightly crashed Seat Arona. Seat Dealer would be very happy to sell completely new steering column & rack to car which has had minor damages to front end plastics. Codes are about the same - Crash shut-down activated as well as couple of others.
However, Seat Arona is a bit newer MQB A0-platform vehicle, and with my current HEX-USB+CAN cable I'm unable to work with this. Some things I'm able to get scanned:
Tuesday,30,July,2019,18:26:35:60995
VCDS Version: 19.6.1.0 (x64)
VIN: VSSZZZKJZJR082375   License Plate: XXX-NNN
Mileage:    Repair Order: arona
Chassis Type: KJ-SE27 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 44 55 5F
08-Auto HVAC -- Status: Cannot be reached 0100
Address 01: Engine (J623-DKJA)       Labels: None
   Part No SW: 04C 906 025 G    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 5178
   Revision: D7H20000
   Coding: 0125003223641D081000
   Shop #: WSC 00049 770 00139
   ASAM Dataset: EV_ECM10TFS01104C906025G 001003
   ROD: N/A
   VCID: 244C01B32F35BC6FDD-8070
Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
No ASAM data for: "EV_ECM10TFS01104C906025G" (SE27)
7150 - ROD - Unknown Error Code
          - 00 [047]
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:22
4708 - ROD - Unknown Error Code
          - 00 [047]
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:21
4709 - ROD - Unknown Error Code
          - 00 [047]
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:21
Readiness: 0010 0001
   Part No SW: 0CW 300 042 E    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1603
   Revision: 00005008    Serial number: CU501710236571
   ROD: N/A
   VCID: 3874C5C383BDC88F61-806C
No ASAM data for: "EV_TCMDQ200021" (SE27)
21193 - ROD - Unknown Error Code
          - 00 [047]
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:22
   Part No SW: 2Q0 614 517 T    HW: 2Q0 614 517 M
   Component: ESC_high_vFGS H33 0322
   Serial number: 08515614170912
   Coding: 8A0D4C573D4951AF32FFBC1D12DF11A649344D26226A24484454625445488865922CB26444562412222A462AA269D64AFD966B52BF
   Shop #: WSC 00049 770 00020
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
   ROD: N/A
   VCID: 3F86AEDFA693FFB7A0-806A
No ASAM data for: "EV_Brake1BOSCHESPMQBA0" (SE27)
1200 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 181
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:22
1152 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 181
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:22
1272 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 222
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:22
1141 - ROD - Unknown Error Code
          - 00 [137]
                    Reset counter: 181
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:22
Address 05: Acc/Start Auth. (J518)       Labels:. 5Q0-959-435.clb
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0459118184
   Coding: 112E0E0703
   Shop #: WSC 00049 770 00021
   ROD: N/A
   VCID: 3E78D3DBA199F6BFAB-806A
No ASAM data for: "EV_KessyHellaMQBAB" (SE27)
   Part No SW: 2Q0 937 090     HW: 2Q0 937 090
   Component: BCM A0 Std+   H97 0915
   Serial number: 07001731100757
   ASAM Dataset: EV_BCMA0 204001
   ROD: N/A
   VCID: 6FE63E9FB6734F3770-803A
   Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  047 0105
   Serial number: S7Y17M10D25H21M17S46
   Coding: 00194D
   Subsystem 2 - Part No SW: 2Q1 959 881 B    HW: 2Q1 959 881 B
   Component: FHSG_DRV  001 0001
   Serial number: 00000000000017364395
   Coding: 13000F
   Subsystem 3 - Part No SW: 2Q1 959 882 D    HW: 2Q1 959 882 D
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000017052411
   Coding: 09000F
   Subsystem 4 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000017048600
   Subsystem 5 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000017285286
   Coding: 190000
No ASAM data for: "EV_BCMA0" (SE27)
539157 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 182
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:27
590853 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 222
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:26
592133 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 222
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:26
Address 10: Park/Steer Assist (J791)       Labels:. 5Q0-919-298.clb
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Serial number: 000308417617305
   Coding: 0271161051
   ROD: N/A
   VCID: 50A49D630B0D70CF49-8004
No ASAM data for: "EV_EPHVA2CAU3700000" (SE27)
13679372 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 181
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:26
13637426 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 181
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:26
13679386 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 181
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:25
Address 13: Auto Dist. Reg
Address 15: Airbags (J234)       Labels: None
   Part No SW: 5QF 959 655 L    HW: 5QF 959 655 L
   Component: Airbag VW22   006 0520
   Revision: --------    Serial number: 003XNPP0ZRQP
   Coding: 88CCC0C000000000585400CF000C00000065
   ASAM Dataset: EV_AirbaVW22TS6VW48X 001028
   ROD: N/A
   VCID: 5FC64E5F46D3DFB7C0-800A
   Subsystem 1 - Part No SW: -----------    HW: 454 001 310 17
   Serial number: 35700000000EEBBCA92C
   Subsystem 2 - Part No SW: -----------    HW: 454 001 410 17
   Serial number: 358000000007839CA92X
   Subsystem 3 - Part No SW: -----------    HW: 454 801 410 17
   Serial number: 3510098002D120000001
   Subsystem 4 - Part No SW: -----------    HW: 454 801 910 17
   Serial number: 35200E8312C12000000A
   Subsystem 5 - Part No SW: -----------    HW: 454 801 810 17
   Component: FrontSensor_D  307 0189
   Serial number: 3550052E66F10000000J
No ASAM data for: "EV_AirbaVW22TS6VW48X" (SE27)
1050117 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 182
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:23
1060608 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 181
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:25
Address 16: Steering wheel (J524)       Labels:. 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 GE    HW: 5Q0 953 569 A
   Revision: FF035035    Serial number: 20171021400570
   Coding: 6414
   ROD: N/A
   VCID: 7BFE1ACFF20B2397CC-802E
No ASAM data for: "EV_SMLSVALEOMQB" (SE27)
Address 17: Instruments (J285)       Labels: None
   Part No SW: 6F0 920 740     HW: 6F0 920 740
   Component: KOMBI         206 0450
   Coding: 04A4091A2D800008008822011001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001020
   ROD: N/A
   VCID: 62C047AB75A1F25FEF-8036
No ASAM data for: "EV_DashBoardVDDMQBA0" (SE27)
16777028 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 181
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:26
16776960 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 181
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:23
16776961 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 181
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:23
Address 19: CAN Gateway (J533)       Labels:. 3Q0-907-530-V1.clb
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007032400
   Coding: 030100046F085700E90002581C0F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: N/A
   Subsystem 2 - Part No SW: 5F0 959 537 D    HW: 5F0 959 537 D
   Serial number: 000000000H1749031017
   Coding: 012000
   Subsystem 3 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
   Component: J367-BDMBOSCH  H02 2011
   Serial number: 100265D9
No ASAM data for: "EV_GatewNF" (SE27)
131654 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 181
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:23
131671 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 181
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:23
   Part No SW: 2Q0 905 861     HW: 2Q0 905 861
   Component: ELV-MQBB      H06 0020
   Serial number: 17000189490014
   Coding: 0800000000000000
   ROD: N/A
   VCID: 70E43DE3AB4D50CF69-8024
No ASAM data for: "EV_ELVMarqMQBA0" (SE27)
Address 44: Steering Assist (J792)       Labels: None
   Part No SW: 2Q1 909 144 J    HW: 2Q1 909 144 F
   Component: TRW_G4L_MQBA0 610 6030
   Serial number: 0186381CB2H3032
   Coding: 01000101000000010101020101000101000001
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
   ROD: N/A
   VCID: 3972C0C7B8B7D1879E-806C
No ASAM data for: "EV_SteerAssisTRWG4LMQBA0" (SE27)
15788544 - ROD - Unknown Error Code
          - 00 [008]
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:23
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0070
   Coding: 078A000001200003
   ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
   ROD: N/A
   VCID: 4182A827D0678947D6-8014
No ASAM data for: "EV_HeadlRegulAFSMQBMAX" (SE27)
13705992 - ROD - Unknown Error Code
          - 00 [137]
                    Reset counter: 181
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:24
Address 5F: Information Electr. (J794)       Labels:. 5F0-035-MIB-STD2.clb
   Part No SW: 5QA 035 824 B    HW: 5QA 035 824 B
   Component: MU-S--ER      H41 0468
   Serial number: SEZAZ2T1259728
   Coding: 04120600960A000011110001000808002F0101D40120050002
   ASAM Dataset: EV_MUStd6C1TSAT 001015
   ROD: N/A
   Subsystem 1 - Part No SW: 6F0 919 605     HW: 6F0 919 605
   Component: ABT_Std-2  H50 8130
   Serial number: SEZ6ZHT3151114
No ASAM data for: "EV_MUStd6C1TSAT" (SE27)
7173 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 181
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:25
7195 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 181
                    Mileage: 13726 km
                    Date: 2019.07.14
                    Time: 22:27:24
End-------------------------(Elapsed Time: 04:03)--------------------------
Ok, there is lots of codes still unknown to my interface, so is this procedure still viable, because the [44] Component differs from the OP's // automech's procedure?
This is the component now: Component: TRW_G4L_MQBA0 610 6030
OP has the following: Component: EPS_TRW_ALow 312 3232
If not, i have to discuss with my friend how to continue, BUT, if it happens to be doable with HEX-V2 or HEX-NET, i have to start considering to upgrade my toolkit. Thank you in advance for your help!
