Skoda Fabia MY16 Power Steering fault
   #61
Dana
Western PA, USA
Hello ConD,
We do not have a TRW_G4L_MQBA0 procedure to offer but there may be an update in this thread moving forward: https://forums.ross-tech.com/showth...sh-data-stored&p=171959&viewfull=1#post171959
Even though your VCDS interface can't decrypt it, you are in the same crash shut down boat. A HEX-NET or HEX-V2 would show:
Crash Shut-Down Activated DEM_FRONT_CRASH_FAULT
I'll revisit our emails and forum threads containing TRW_G4L_MQBA0 with Crash Shut-Down and report back if I locate any SA codes that may be worth testing.
   #62
ConD
Oulu, Finland
C?ID=82663
Thank you Dana for your answer! The newer Polo is just the same as this Arona, so I'll start following that thread also.
Even though I wasn't able to decrypt that fault code, dealer was and we knew that it was the "same issue" as in this thread. But what we didn't know until yesterday was the version differences between components.
So... just now we need to wait and figure out what to do until some solutions are found...
   #63
Dana
Western PA, USA
I don't believe it will be of much assistance but we've had a handful of individuals report TRW_G4L_MQBA0 modules accept SA code 19249. For instance:
https://forums.ross-tech.com/showthread.php?14613-Seat-Ibiza-6F-Crash-Mode-deactivation
Based on the fact that "pre conditions not met" is shown with Odis, VCP and VCDS I'm under the impression this is a procedure problem rather than the lack of correct SA code.
Either way, in an email reply to someone this spring I wrote "I don't believe SA codes 17580 or 20103 are going to be accepted by this TRW_G4L_MQBA0 rack. Make sure your Advanced measuring value group [*IDE00323-IDE01022*] Security Access: Number of invalid keys - Incorrect key code inputs counter isn't above 2 because most modules lock-out at 3 and refuse perfectly valid codes at that point."
Followed by "This is a list of wild guesses based on modern MQB SA codes known to be accepted by 44 modules:
19249
28183
44595"
I did not receive any feedback via e-mail but Shuhel may be able to test those (if they haven't already been discussed or ruled out in our forum).
   #64
ConD
Oulu, Finland
C?ID=82663
   #65
Shuhel
Birmingham, UK
C?ID=368132
if only we can find a way with vcds ;) iv still got hope
   #66
jan steve hivand
Norway
C?ID=261610
Firstly I need to give credit to Piotr Brzezina (User Name automech) who shared his EPS_TRW_ALow reset procedure with us.
It received positive feedback from numerous VCDS customers to date so Verified VCDS forum users can download the instructions in plain text using this link:
If you need assistance with the vehicle please post the complete Auto-Scan before repairs, a list or summary of the repairs performed to the vehicle and the final Auto-Scan in the current condition in this forum.
If you are unable to download it:
  • Make sure you Registered for this forum and use that Username/Password to log in.
  • Check your profile page to make sure Verified VCDS User is shown. If something other than Verified VCDS User is shown see our How to get Verified thread.
Hi, have the same problem, tried to download link but it failed
   #67
Liteace1
Spain
C?ID=90243
Ive the same problem with 2018, NJ37N5, Fabia, It had small crash, airbag was replaced, no PS working due to:
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
1057792 - Databus
[DEM_WHEEL_SPD_INVALID_FAULT]
6351360 - Crash Shut-Down Activated
P1609 00 [009] - -
[DEM_FRONT_CRASH_FAULT]
U1101 00 [009] - Active
8526363 - Crash Shut-Down
B189C F0 [009] - Active
Those have been sorted out now and the P.S is working but still got warning lights, red PS light, yellow traction-control, yellow TPMS light, on dash and cant adapt / reset the SAS G85, its showing 0.0° constantly, here's a full scan
Thursday,23,September,2021,16:25:52:39628
VCDS Version: 20.12.0.1 (x64)  HEX-NET CB: 0.4529.4
Data version: 20201125 DS322.1
VIN: TMBER6NJ4KZ065769   License Plate:
Mileage: 57050km-35449mi   Repair Order: TYRE_SHOP
Chassis Type: NJ-SK26 (2Q0)
Scan: 01 03 05 08 09 10 15 17 19 2B 44 5F
VIN: TMBER6NJ4KZ065769   Mileage: 57050km-35449miles
Address 01: Engine (J623-DKRC)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 Q    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 6200
   Revision: D7H20000
   Coding: 01190032230415080000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ECM10TFS01104C906025Q 002003
   ROD: GV_ECM10TFS011SK25X1.rod
   VCID: 2E10FAAF718D89F4A0-807A
          U0428 00 [047] - -
                    Mileage: 57050 km
                    Date: 2021.09.23
                    Time: 15:33:23
                    Engine RPM: 0.00 /min
                    Coolant temperature: 65 °C
                    Intake air temperature: 39 °C
                    Voltage terminal 30: 11.920 V
                    Outside temperature: 24 °C
                    Absolute intake pressure: 96 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel: tank fill level: 24.0 l
                    Oxygen sensor B1: sensor 1: specified value: 1.0000
                    Particulate filter: loading stage: 0
                    Overrun cut-off-Bits 0-7: 0
Readiness: 1010 0001
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 R    HW: 6R0 907 379 BA
   Component: ESP9.0i       H04 0006
   Serial number: 08502667181031
   Coding: 41F5487D492933C5091B106F005A821292CC9008000DCB098F00
   Shop #: WSC 13765 031 00063
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   VCID: 3E30CAEFA1ED797430-806A
0625 - Display for Tire Pressure Monitoring
                    Reset counter: 96
                    Mileage: 57050 km
                    Date: 2021.09.23
                    Time: 16:09:00
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
          U0428 00 [137] - -
          [Scl_LWI_Lenkradwinkel_Error]
                    Reset counter: 96
                    Mileage: 57050 km
                    Date: 2021.09.23
                    Time: 16:09:01
1149 - Implausible Data Received from Steering Angle Sensor Module (G85)
          U0428 00 [137] - -
          [Scl_LWI_SensorNotCalibrated]
                    Reset counter: 96
                    Mileage: 57050 km
                    Date: 2021.09.23
                    Time: 16:09:01
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0498140142
   Coding: 032C0C1620
   Shop #: WSC 13765 790 00063
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43C6BB1BCA0F149C5F-8016
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6V0 820 045 C    HW: 6V0 820 045 C
   Component: AC Manuell    H01 0204
   Serial number:  1811011B-0182
   Coding: 100000001100000000
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26.rod
   VCID: 3228EEDF65B5AD14C4-8066
   Part No SW: 2Q0 937 089 A    HW: 2Q0 937 089
   Component: BCM A0 Std    H98 0926
   Serial number: 00001918000107
   ASAM Dataset: EV_BCMA0 204001
   ROD: EV_BCMA0_204.rod
   VCID: 383CDCF783C94744FA-806C
   Driver door control module:
   Subsystem 1 - Part No SW: 2Q2 959 881 C    HW: 2Q2 959 881 C
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000025054728
   Coding: 130208
   Front passenger door control module:
   Subsystem 2 - Part No SW: 2Q2 959 882     HW: 2Q2 959 882
   Component: FHSG_PSG  001 0001
   Serial number: 00000000000025030455
   Coding: 090208
   Subsystem 3 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000024955945
   Coding: 030200
   Subsystem 4 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000025062936
   Coding: 1B0200
   Part No SW: 5Q0 919 283 G    HW: 5Q0 919 283
   Component: PARKHILFE 3K  H10 0056
   Revision: --------    Serial number: 39261830900545
   Coding: 0001150001
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_EPHVA14AU3700000 002024
   ROD: EV_EPHVA14AU3700000_SK26.rod
   VCID: 3D32CDE3ACEB626C29-8068
13637426 - Databus
                    Reset counter: 95
                    Mileage: 57050 km
                    Date: 2021.09.23
                    Time: 15:33:45
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 K    HW: 6C0 959 655 K
   Component: VW20Airbag743 002 0380
   Revision: --------    Serial number: 003TJ00UY2XL
   Coding: 88CCC000000000005C5400CF000800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3B36C3FBB2FF6C5C17-806E
   Subsystem 1 - Part No SW: -----------    HW: 410 820 611 18
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00A92E3C7E360A+
   Subsystem 2 - Part No SW: -----------    HW: 410 820 511 18
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00AB2DE5022C38Y
   Subsystem 3 - Part No SW: -----------    HW: 442 152 704 18
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00A12A2D0F2917C
   Subsystem 4 - Part No SW: -----------    HW: 442 152 510 18
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00C32DB6612D1CN
   Part No SW: 6V0 920 746 D    HW: 6V0 920 746 D
   Component: KOMBI         205 2321
   Coding: 072401102180000801082A001000000000000000
   ROD: EV_DashBoardVDDMQBAB_SK26.rod
   VCID: 3C34C0E7B7F16B641E-8068
   Part No SW: 2Q0 909 901 B    HW: 2Q0 937 089
   Component: GW MQB A0     H98 0926
   Coding: 030100042F0A570000000000000000010001070000000000000000000000
   ASAM Dataset: EV_GatewA0 013024
   ROD: EV_GatewA0_SK25.rod
   VCID: 312AE1D360B3960CBD-8064
   Generator:
   Subsystem 2 - Part No SW: 3V0 919 719 E    HW: 3V0 919 719 E
   Component: E221__MFL-PR6  H03 0170
   Serial number: 000000000E2007131118
   Subsystem 3 - Part No SW: 6C0 915 181 D    HW: 6C0 915 181 D
   Serial number: 3329049504
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H07 0021
   Serial number: 18000344027002
   Coding: 0000000000000000
   ROD: EV_ELVMarqMQBA0_AU49.rod
   Part No SW: 6C1 909 144 AK    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  313 3250
   Serial number: CIBE1089
   Coding: 000300
   Shop #: WSC 21425 003 104857
   ASAM Dataset: EV_SteerAssisUDSTRW 016134
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 71AA21D3A033D60CFD-8024
1094656 - Steering angle sensor
                    Reset counter: 96
                    Mileage: 57050 km
                    Date: 2021.09.23
                    Time: 16:19:05
1073664 - Steering End Stops Not Learned
          C10AC F0 [137] - Unknown Error Elaboration
          [DEM_LEFT_ENDSTOP_NOT_KNOWN]
                    Reset counter: 96
                    Mileage: 57050 km
                    Date: 2021.09.23
                    Time: 16:19:05
1073920 - Steering End Stops Not Learned
          [DEM_RIGHT_ENDSTOP_NOT_KNOWN]
                    Reset counter: 96
                    Mileage: 57050 km
                    Date: 2021.09.23
                    Time: 16:19:05
   Part No SW: 6V0 035 871 J    HW: 6V0 035 871 J
   Component: MU-E--US      690 8740
   Serial number: 09111800021083
   Coding: 03620000BE0000000111000400000A002F0007D40000010001
   ASAM Dataset: EV_MUEnt4CGen2LGE 001041
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
End----------(Elapsed Time: 00:48, VBatt start/end: 12.6V/12.6V)-----------
Address 10: DTCs cleared
Any clues on how to reset the G85
Thanks
   #69
Dana
Western PA, USA
If this car isn't fixed I would connect to 03-ABS, use SA code 40168 (Basic Setting Enabling), set the steering wheel straight and use Basic Settings:
[*IDE02284-ENG98502*] Steering angle sensor: carry out zero calibration
If that results in an error I would check the Advanced Measuring Value [*IDE04448-IDE00924*] - Steering angle sensor: angle - Steering angle° in address 44 directly to see if the readings are accurate. If you can get 44 to show reasonable readings at right lock, left lock and when straight (which should rule out an alignment issue or faulty rack) try leaving the steering wheel at 0.0° and repeating the calibration in 03-ABS.
