Skoda Fabia MY16 Power Steering fault
VW_FI
C?ID=21939
I have a "new" Skoda that was crashed in the front after being
registered for 10 days. Now it has been repaired incl. new front
airbags + seatbelts, otherwise it's fine but the power steering isn't
working; red steering wheel icon shining in instruments panel.
For some reason I'm not able to clear the dtc from 44: Steering Assist
(J792) as it comes straight back.
Is this a Basic setting / Adaptation question or something worse?
Address 44: Steering Assist (J792) Labels: 6Rx-909-144-V2.clb
Part No SW: 6C1 909 144 AG HW: 6C1 909 144 D
Component: EPS_TRW_ALow 312 3232
Serial number: CF5P0503
Coding: 000700
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_SteerAssisUDSTRW 016026
ROD: EV_SteerAssisUDSTRW_SK26.rod
VCID: EDDA600B3C1912562A-80B8
6351360 - Crash Shut-Down Activated
P1609 00 [137] - -
MIL ON - Confirmed - Tested Since Memory Clea
VW_FI
C?ID=21939
Ok, here we go:
Wednesday,06,January,2016,15:44:58:34924
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: TMBEN6NJ3GZ0113xx   License Plate: FABIA 612015_2
Mileage: 797km-495mi   Repair Order:
Chassis Type: NJ (6C0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 44 5F
VIN: TMBEN6NJ3GZ0113xx   Mileage: 797km-495miles
Address 01: Engine (J623-CJZD)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 027 BC    HW: 04E 907 309 AF
   Component: R4 1.2l TFS   H22 9023
   Revision: R4H22---
   Coding: 01250032232415080000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ECM12TFS01104E906027BC 001008
   ROD: EV_ECM12TFS01104E906027BC_SK25.rod
   VCID: E6C81F2719EF210E6B-80B2
Readiness: 1110 0001
   Part No SW: 0CW 300 048 S    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 6502
   Revision: 00043014    Serial number: CU501505215870
   ROD: EV_TCMDQ200021_SK25.rod
   VCID: CC9CCD8F6743FB5E5D-8098
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 G    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0003
   Serial number: 08506108150515
   Coding: 41F5487D892433C111171070005A821291CC8808000DCBF98F00
   Shop #: WSC 13765 031 00063
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
   VCID: B36EB6731ABD84A63C-80E6
   Revision: 00021000    Serial number: 0368944589
   Coding: 030C0C
   Shop #: WSC 13765 790 00063
   ROD: EV_KessyHellaMQBAB_AU37.rod
   VCID: BA709B573DD775EEFF-80EE
Address 08: Auto HVAC (J255)       Labels: 6C0-907-044.clb
   Part No SW: 6V0 907 044     HW: 6V0 907 044
   Component: Climatronic   H01 0201
   Serial number:  1505142A-1014
   Coding: 100000001011100001
   ASAM Dataset: EV_ACClimaValeoPQ26 003001
   ROD: EV_ACClimaValeoPQ26_SE25.rod
   VCID: F4EC756F5F33C39EE5-80A0
Address 09: Cent. Elect. (J519)       Labels: 6C0-937-090-V1.clb
   Part No SW: 6C0 937 090 C    HW: 6C0 937 090
   Component: BCM PQ26 HiKR H08 0084
   Serial number: 001388002866
   Coding: 0C01185042150AFB43804000402F07081800D900D30A3500000000000000
   ASAM Dataset: EV_BCMA0 005005
   ROD: EV_BCMA0_SK25.rod
   VCID: A854511FD37BF77E99-80FC
   Slave 2:
   Subsystem 1 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: 5Q0-955-547.CLB
   Component: RLHS  037 0059
   Serial number: S3Y15M05D27H01M26S00
   Coding: 00185E
   Subsystem 2 - Part No SW: 6V1 959 801 B    HW: 6V1 959 801 B
   Component: FHSG DRV  007 0001
   Serial number: 00000000000001429034
   Coding: 011200
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 D    HW: 5Q0 919 283
   Component: PARKHILFE 3K  H10 0048
   Revision: --------    Serial number: 39291513908374
   Coding: 0001050011
   ROD: EV_EPHVA14AU3700000_AU37.rod
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H05 0304
   Serial number: 28041503273445
   Coding: 00001000FE0739
   ROD: EV_ACCMRRBoschVW372_AU37.rod
   VCID: B874815F03DB67FE09-80EC
Address 15: Airbags (J234)       Labels: 6C0-959-655.clb
   Part No SW: 6C0 959 655 F    HW: 6C0 959 655 F
   Component: VW20Airbag733 001 0360
   Revision: --------    Serial number: 003RJ002L9E9
   Coding: 88CCC000000000005C5400CF000800000000
   ROD: EV_AirbaVW20BPAVW26X_SK25.rod
   VCID: B6688F6709CF918E1B-80E2
   Subsystem 1 - Part No SW: -----------    HW: 410 822 005 15
   Component: SideSensor_Df  151 0800
   Serial number: 3575H009B1A96E54012N
   Subsystem 2 - Part No SW: -----------    HW: 410 822 005 15
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00C71ADE602A3A/
   Subsystem 3 - Part No SW: -----------    HW: 442 152 605 15
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00B91A234B3E3EP
   Subsystem 4 - Part No SW: -----------    HW: 442 152 605 15
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00B91A234B0B227
   Part No SW: 6V0 920 740 A    HW: 6V0 920 740 A
   Component: KOMBI         205 1420
   Coding: 072401182180000801882A011000000000000000
   ROD: EV_DashBoardVDDMQBAB_SK25.rod
Address 19: CAN Gateway (J533)       Labels: 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 090
   Component: GW MQB A0     H08 0084
   Revision: --------    Serial number: 001388002866
   Coding: 030100042F0A640000000000000000010001050000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_SE26.rod
   VCID: E5CA182BE4E92A1662-80B0
   Subsystem 1 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000B1187150515
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 52134638482821084491
   Revision: 00000000    Serial number: 15000112283003
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_SE25.rod
   VCID: B46CB56F1FB3839E25-80E0
   Coding: 000700
          P1609 00 [137] - -
                    Reset counter: 23
                    Mileage: 797 km
                    Date: 2015.09.12
                    Time: 01:48:31
Address 5F: Information Electr. (J794)       Labels: 3V0-035-MIB-STD2.clb
   Part No SW: 5Q0 035 840 A    HW: 5Q0 035 840 A
   Component: MU-S--ER      H24 0241
   Serial number: SKZAZ2R8595528
   Coding: 03620000BE00000011110004000808002F0100C40120010000
   ROD: EV_MUStd4CTSAT_SE25.rod
   VCID: AB5EAE13C28DDC6674-80FE
   Media Player Position 1:
   Subsystem 1 - Part No SW: 6V0 919 604     HW: 6V0 919 604
   Component: ABTm_Std2  H40 1022
   Serial number: SKZ8Z9RH300R3G
End-------------------------(Elapsed Time: 03:12)--------------------------
Dana
Western PA, USA
Hmm, since #44 has that Crash Shut-Down Activated DTC I was expecting another module in the vehicle to show fault codes. That isn't the case now but I would scan that vehicle again after a short test drive to see if any show up. If so, please post that scan and let us know if the power steering decided to work at roads speeds.
You mentioned the Airbag controller itself was replaced. Was that a brand new control module ordered by VIN and coded online via SVM?
VW_FI
C?ID=21939
The Airbag controller wasn't replaced just the front airbags & seatbelts. So no coding done, just cleaning the fault codes.
I took it for a spin on the road and the situation remains the same, no new codes only this "6351360 - Crash Shut-Down Activated" keeps coming up.
Edit.
Here's what Basic settings & Adaptation are offering:
Basic Settings:
-Reset to factory setting
-Resetting of all adaptation values
-Resetting of all adaptations
-Software end-stop reset
-Steering angle sensor
-Steering angle sensor, zero calibration w/ steer wheel scales
Adaptation:
-Activating and deactivating all development messages
-Activation of pwr steering asst without engine running
-Characteristic curve of steering assistance
-Download without rest bus
-Driving profile switchover
-Engine type
-Plausibility check
-Software end stop
-Straight line running
-Support power
-XCP calibration protocol
Any suggestions if I should try the first 3 of Basic Settings?
automech
Poland
C?ID=14925
I have a solution but I need to consult it with Ross-Tech first. Please be patient.
Dana
Western PA, USA
automech,
I just replied from our Support email account (Subject: Fabia 3 power steering shut down solution) so please check your junk folder if you didn't receive it.
VW_FI,
We have not reviewed the procedure yet but one of us will update this thread after doing so.
automech
Poland
C?ID=14925
I have sent an e-mail to you just now.
Mr. VW_FI have solved the problem after my PM to him.
Dana
Western PA, USA
automech,
Thanks for the update! I'm glad to hear VW_FI is taken care of. The fact that it was possible with VCDS (rather than a trip to the dealer) is even better.
Internal ref: E?ID=284860 and E?ID=292815
cn-vcds
China
C?ID=201083
44: Steering Assist(J792) Baisc Setting need to agin code, try 20103.
vastechnics
C?ID=143747
I have exactly the same problem with an Polo 6C. If need the autoscan let me know please.
Regards
Dana
Western PA, USA
Hi Rayen,
If you need help with a Crash Shut-Down Activated DTC in a EPS_TRW_ALow #44 module please post the Auto-Scan.
Andy
Sector 7G
HC424490
Internal Ref:
E?ID=320944
audilover
Turkey
C?ID=215744
Hi same issue clearing dtc dont work can we get this fixed please?
Sunday,06,November,2016,00:00:18:61606
VCDS Version: 16.8.3.1 (x64)
VIN: VSSZZZ6JZHR033286   License Plate:
Chassis Type: 6J (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
Address 01: Engine (J623-CJZC)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 027 BB    HW: 04E 907 309 AF
   Component: R4 1.2l TFS   H23 9085
   Revision: R4H23---
   Coding: 01110012232410080000
   Shop #: WSC 00049 770 00139
   ASAM Dataset: EV_ECM12TFS01104E906027BB 001009
   ROD: EV_ECM12TFS01104E906027BB.rod
   VCID: 65C1A7D26491606A2F-8030
   CAN Converter 01:
   Part No SW: 6C0 907 379 N    HW: 6R0 907 379 BA
   Component: ESP9.0i       H04 0005
   Serial number: 08506142160713
   Coding: 11DD287D492633C3091600710057881492CC90000005C9098F00
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   VCID: 3A7B24AEBDAF3F92B2-806E
   Part No SW: 6P0 907 044 C    HW: 6P0 907 044 C
   Component: Climatronic   H02 0203
   Serial number:  1607021A-0464
   Coding: 000000000100100001
   ROD: EV_ACClimaValeoPQ26_SK25.rod
   VCID: 3169038260D9FCCA03-8064
Address 09: Cent. Elect. (J519)       Labels: 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 D    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H10 0094
   Serial number: 006308018291
   Coding: 080008404053005B4B844000400703000000690051010000000000000000
   ASAM Dataset: EV_BCMA0 006002
   ROD: EV_BCMA0_006.rod
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 6R0 959 801 DS    HW: 6R0 959 801 DS  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 0630
   Serial number: KU0KU008071661903752
   Coding: 1000A4
   Subsystem 2 - Part No SW: 6R0 959 802 ED    HW: 6R0 959 802 ED  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 0630
   Serial number: KU0KU008071661900257
   Coding: 0000A4
   Subsystem 3 - Part No SW: 6R0 959 811 R    HW: 6R0 959 811 R
   Component: J388__TSG_HL  022 1112
   Serial number: 13102719160710225429
   Subsystem 4 - Part No SW: 6R0 959 812 R    HW: 6R0 959 812 R
   Component: J389__TSG_HR  022 1112
   Serial number: 13202718160711062545
   Part No SW: 6C0 959 655 J    HW: 6C0 959 655 J
   Component: VW20Airbag002 002 0380
   Revision: --------    Serial number: 003TH0091E4Y
   Coding: 88C0C000000000005C0000CA000800000000
   Shop #: WSC 00049 770 00112
   ROD: EV_AirbaVW20BPAVW26X.rod
   Subsystem 1 - Part No SW: -----------    HW: 410 271 406 16
   Component: SideSensor_Df  15B 0148
   Serial number: 3495R002E29C37A2D362
   Subsystem 2 - Part No SW: -----------    HW: 410 271 406 16
   Component: SideSensor_Pf  15B 0148
   Serial number: 3505R002E29C37A4D24-
Address 17: Instruments (J285)       Labels: None
   Part No SW: 6P0 920 740 B    HW: 6P0 920 740 B
   Component: KOMBI         202 2310
   Coding: 072409002180000800082A001000000000000000
   ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
   VCID: 2E5318FE71E7E3321E-807A
   Part No SW: 6C0 909 901 A    HW: 6C0 937 089
   Component: GW MQB A0     H10 0094
   Revision: --------    Serial number: 006308018291
   Coding: 010100082008560070000000000000000001000000000000000000000000
   ROD: EV_GatewA0Lear_VW26.rod
   VCID: 2643E0DE5917AB72E6-8072
   Subsystem 1 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
   Serial number: 000000000A0094240616
   Coding: 002000
   Component: EPS_TRW_ALow  313 3232
   Serial number: CG7F1249
   Coding: 000300
   Shop #: WSC 00070 000 00000
   ROD: EV_SteerAssisUDSTRW_SE26.rod
   VCID: 6DD1DFF2BC61582A67-8038
          P1609 00 [009] - -
                    Reset counter: 88
                    Mileage: 1128 km
                    Date: 2016.11.02
                    Time: 00:02:29
                    Engine speed: 0 /min
                    Vehicle speed: 0.00 km/h
                    System status: ERROR
                    Voltage terminal 30: 12.34 V
                    Power steering current consumption: 0.50 A
                    End stage temperature: 21 °C
                    Steering assistance: engine output: 0.00 %
                    Sensor for motor position: 0 °
                    Sensor for motor position: 0 /min
                    Steering assistance: target engine torque: 0.00 Nm
                    Steering torque: -0.01 Nm
                    Steering torque: OK
   Part No SW: 5F0 035 871 B    HW: 5F0 035 871 B
   Component: MU-E--ER      050 7060
   Serial number: 04071600011000
   Coding: 04520000BE00000011110001010108002F0000840000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001032
   ROD: EV_MUEnt4CGen2LGE_SK25.rod
   VCID: 2541E7D22411A06AEF-8070
End-------------------------(Elapsed Time: 02:21)--------------------------
audilover
Turkey
C?ID=215744
I did already mail ,pm and all no response so far:)
Dana
Western PA, USA
We did not receive the Auto-Scan with the repair history from this vehicle via email but I received the PM this afternoon. Did you send it to Support or another e-mail address?
I replied to the PM notification e-mail from Support to the only address we had on file (a portion of your first and last name @ Hotmail) with the experimental procedure.
-- Edit, I located another email address and we did receive the original scan. It was burred under 9 inquiries that arrived before it - but we did explicitly request the scans via email to help improve our documentation :)
I forwarded and replied-to both with the procure so you should have it at this point.
audilover
Turkey
C?ID=215744
Thank you ....
Dana
Western PA, USA
Firstly I need to give credit to Piotr Brzezina (User Name automech) who shared his EPS_TRW_ALow reset procedure with us.
It received positive feedback from numerous VCDS customers to date so Verified VCDS forum users can download the instructions in plain text using this link:
View attachment EPS_TRW_ALow.txt
If you need assistance with the vehicle please post the complete Auto-Scan before repairs, a list or summary of the repairs performed to the vehicle and the final Auto-Scan in the current condition in this forum.
If you are unable to download it:
  • Make sure you Registered for this forum and use that Username/Password to log in.
  • Check your profile page to make sure Verified VCDS User is shown. If something other than Verified VCDS User is shown see our How to get Verified thread.
german
Argentina
C?ID=239723
I am with the following problem, my vcds does not show emergent balloon with security code to solve my problem.
[Access to security-16]
Enter the code that appears in the VCDS popup
