Immobilizer delete
lineman1
Battle Creek, Michigan
C?ID=202874
Gentlemen,
I have a 05 A6 with a 3.2L gas engine. The problem I have is the key is stuck in the ignition ( access start module ) and the engine will not turn over. Some of the dash lights light up, seat move but nothing else comes on. I have had the car to two dealers, they have replaced the steering column (immobilizer) and the access start module and they cannot get the two modules to communicate with each other and can't sync up. With my Vag Com I can see and communicate with all modules except the two. Does anyone have any suggestions or does anyone know a tuner that can reflash the ECU to delete the immobilizer. I sent the ECU out to Colorado to have reflashed but they only do Bosch ECU's and my car has a Seimens ECU. Any suggestions ??
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Immobilizer delete in that situation will not help you at all.
You must find why modules not communicating.
But of course Autoscan will be helpful.
