Results 1 to 2 of 2
Thread: Fitting Rear Door Exit Lights on the new Jetta Mark 6
    Oct 2014
    Singapore
    On earlier Mark 6 Jetta since 2011, we have been fitting the door exit lights simply by coding the driver's door module and the slave rear door.
    Since this year, with the face lift 2015 models, the rear slave module have been replaced with a new part number (6R0 949 812M) used on the SEAT vehicles. There does not seem to be any coding on the slave modules unlike before. It appears as 000000 but suspect it may be a hidden code.
    Tried to change the Byte 2, Bit 6 as previously done on the earlier Jetta but it is rejected as "out of range" . Guess we may need the complete code for the whole module.
    Any body have any tips ?
    Thursday,31,December,2015,16:14:15:24118
    VCDS Version: 15.7.3.0 (x64)
    Data version: 20151216
    Dealer/Shop Name: cbx auto services
    Workshop Code: 305 91777 012345
    VIN: WVWZZZ16ZFM054297   License Plate: JETTA 2016 NO REAR DOOR MODULE CODING
    Mileage: 3790km-2354mi   Repair Order:
    Chassis Type: 16 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
    VIN: WVWZZZ16ZFM054297   Mileage: 3790km-2354miles
    Address 01: Engine (J623-CAXA)       Labels: 03C-906-016-CAX2.clb
       Part No SW: 03C 906 016 HK    HW: 03C 907 309 S
       Component: 1.4l R4 TSI   H13 8201
       Revision: LCH13---    Serial number: 00000000000000
       Coding: 00250012000400000000
       Shop #: WSC 00066 790 00185
       ASAM Dataset: EV_ECM14TFS01103C906016HK 001003
       ROD: EV_ECM14TFS01103C906016HK.rod
       VCID: 6FE73C86B6C33A4698-803A
    Address 02: Auto Trans        Labels: 0AM-927-769.CLB
       Part No SW: 0AM 300 062 B    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 6219
       Revision: 00043014    Serial number: CU501504235297
       Shop #: WSC 22349 002 1048576
       VCID: 2B5FE8968A5B0666F4-807E
    Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.CLB
       Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
       Revision: 00H46001
       Coding: A63B40F8112700FE650D02ED88200080A1100010
       VCID: 040D632A8745291E55-8050
       Part No SW: 1K8 907 426 K    HW: 1K8 907 426 K
       Component: AC Manuell    H20 0707
       Revision: 00001002
       Coding: 0010002002
       Shop #: WSC 00066 000 00320
       ROD: EV_ACManueBHBVW36X_SE36.rod
       VCID: 3B7FD8D6B23B96E664-806E
    Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08X-09.CLB
       Part No SW: 5K0 937 087 AC    HW: 5K0 937 087 AC
       Component: BCM PQ35 H+   122 0174
       Revision: BF122001
       Coding: 20000A3A902D00D4408000800000006403000088508089205C8000000040
       VCID: 76E909E2C1990B8E5B-8022
       Part No SW: 5C0 959 655 F    HW: 5C0 959 655 F
       Component: AirbagVW10    014 0613
       Serial number: 003JQM076063
       Coding: 00005047
       ROD: EV_AirbaVW10SMEVW360_SE36.rod
       VCID: 356BCEEE941F409692-8060
       Serial number: 3572MSME066B384FZZZ3
       Serial number: 3582MSME586B384FZZZB
       Serial number: 3516KSME46000A34ZZZG
       Serial number: 3526KSME69720737ZZZV
       Part No SW: 1K5 953 521 BH    HW: 5K0 953 569 AC
       Component: LENKS.MODUL   016 0162
       Revision: FF010042    Serial number: 20150409200065
       Coding: 4880040000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 74ED33EADFE5199E65-8020
       Part No SW: 5C6 920 864     HW: 5C6 920 864
       Component: KOMBI         H04 0905
       Coding: 170B00
       VCID: 6BDF289682DBC666B4-803E
    Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.CLB
       Part No SW: 7N0 907 530 AP    HW: 7N0 907 530 AK
       Component: J533  Gateway H57 1653
       Revision:   H57       Serial number: 04061503000349
       Coding: 351003
       Shop #: WSC 91777 305 12345
       VCID: 7EF911C2E9A943CE03-802A
                        Reset counter: 80
                        Mileage: 3796 km
                        Date: 2015.12.31
                        Time: 16:08:46
       Component: IMMO          H04 0905
       VCID: 6AD12D928D21DF6ECF-803E
    Address 37: Navigation
       Revision: 13110009    Serial number: 0009699444
       Coding: 0406F5
       ROD: EV_TSGFPQ35BRFVW46X.rod
       VCID: 5BBF7856527BB6E644-800E
       Slave Driver:
       Subsystem 1 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
       Serial number: 14202586150520172618
    67584 - Warning Light for Front Door
              B11F5 01 [009] - Electrical Failure
                        Reset counter: 80
                        Mileage: 3796 km
                        Date: 2015.12.31
                        Time: 15:58:09
    Address 44: Steering Assist        Labels: 1KX-909-14X-44.CLB
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 68     3501
       Revision: 00H22000
       VCID: 3973C2DE7007A4F676-806C
       Revision: 15110009    Serial number: 0009715400
       Coding: 0406F4
       ROD: EV_TSGBPQ35BRFVW46X.rod
       VCID: 5CBD7B4A5775B1DE4D-8008
       Slave Passenger:
       Subsystem 1 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
       Serial number: 14202587150519092153
                        Reset counter: 80
                        Mileage: 3796 km
                        Date: 2015.12.31
                        Time: 16:05:41
    Address 56: Radio (J503)       Labels: 5M0-035-1XX-56.CLB
       Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
       Component: RCD310 EU     H06 5007
       Revision: -----10S    Serial number: VWZ4Z2R1221534
       Coding: 05000400040006
       VCID: 72E135F2ADF117AE77-8026
    End---------------------(Elapsed Time: 02:27, Deb=2)-----------------------
  2. Likes Uwe liked this post
  3. #2
    Stoke on Trent, England
    New User Keith
