Results 1 to 6 of 6
Thread: 2012 VW CC Indirect TPMS activation
    Jan 2015
    Good evening,
    I've mounted my new snow tyres to my NAR 2012 VW CC Sport. The TPMS sensors in these wheels (as I subsequently discovered) are of the 315 MHz variety, but my TPMS module (65) uses the newer 433 MHz sensors.
    Rather than disabling TPMS entirely, I was hoping to use Indirect TPMS via the ABS module for the winter. There were coding instructions in a hover-over in VCDS that said to add 1024 to the ABS coding, but that resulted in an "out of range" error. I then found coding instructions online (though for different models) that indicate that +2048 is the way to go. This coding was accepted, but I don't have channel 042 available, and that tells me that +2048 didn't work. Incidentally, +2048 was only accepted after I activated TPMS II (4C) in the gateway.
    My autoscan is below. I'd love to make this work if at all possible, and pick up another set of 433 MHz sensors for next season.
    Tuesday,29,December,2015,18:15:07:36082
    VCDS Version: 15.7.3.0
    Data version: 20151216
    VIN: WVWMP7AN1CE512485   License Plate: 2KC 648
    Mileage: 108360km-67331mi   Repair Order: ABS TPMS
    Chassis Type: AN (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4C 4F 52 53 56
              62 65 6C 72 77
    VIN: WVWMP7AN1CE512485   Mileage: 108360km-67331miles
    4C-Tire Pressure II -- Status: Cannot be reached 1100
    65-Tire Pressure -- Status: Not registered 0011
    Address 01: Engine (CBF)       Labels: 06J-907-115-CBF.clb
       Part No SW: 06J 906 027 FD    HW: 06J 907 309 B
       Component: MED17.5.2 TFSI 2    3951
       Revision: PAH04---    Serial number: VWZCZ000000000
       Coding: 040401081C070160
       Shop #: WSC 00001 000 00000
       VCID: 72EBEB126D23D3AE77-8026
    Readiness: 0110 0001
       Part No SW: 02E 300 058 N    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 3509
       Revision: 05351113    Serial number: 00001103101277
       Shop #: WSC 44551 111 44551
       VCID: 2541C04EEC6DF41622-8070
       Part No SW: 3AA 614 109 M    HW: 3AA 614 109 M
       Component: J104   C2 450M V4AF 0005
       Revision: --H07---    Serial number: 00000004040736
       Coding: 0002447
       Shop #: WSC 05311 000 00000
       VCID: 377D1A0646C1768680-8062
       Part No SW: 7N0 907 426 L    HW: 7N0 907 426 L
       Component: AC Manuell    H17 0202
       Revision: 00012001
       Coding: 0000001002
       Shop #: WSC 00015 115 00000
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 3D71082EACFD5CD65A-8068
    Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
       Part No SW: 3AA 937 087 A    HW: 3AA 937 087 A
       Component: BCM PQ47 H    413 0452
       Revision: BB413001
       Coding: 0000000000000000009802058000088447517C8840200D605C8060200040
       Shop #: WSC 05311 123 12345
       VCID: 387F193A8BDF79FE89-806C
       Subsystem 1 - Part No SW: 3C8 955 119 D    HW: 3C8 955 119 D  Labels: 1KX-955-119.CLB
       Component: Wischer 11021  10  0603
       Coding: 00B795
       Component: RLS 070411 05  54  0403
       Coding: 0330ED
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 143
                        Mileage: 106420 km
                        Date: 2015.12.14
                        Time: 08:32:55
                        Voltage: 14.45 V
    01800 - Light Switch (E1)
                        Reset counter: 208
                        Mileage: 108091 km
                        Date: 2015.12.25
                        Time: 13:40:16
                            Term 15 Off
                        Voltage: 12.65 V
       Part No SW: 5N0 959 655 Q    HW: 5N0 959 655 Q
       Component: J234__30S VW10 HI   1918
       Revision: 22014000    Serial number: 003JZP5UQR86
       Coding: 0012371
       VCID: 4B9556F62A49E266D4-801E
       Subsystem 1 - Part No: 3C8 959 339 A
       Subsystem 2 - Serial number: 00000000002YTD
       Subsystem 3 - Serial number: 0002.03.11000030000064003063
       Subsystem 4 - Serial number: 6400306332MTS676670751 63
       Subsystem 5 - Serial number: 70751 6342MTS680110751 63
       Subsystem 6 - Serial number: 10751 6351HTS6EN2DS9KR 63
       Subsystem 7 - Serial number: DS9KR 6361HTS6S2N7S9KR 63
       Subsystem 8 - Serial number: 7S9KR 63727TS6L55BS9KJ 63
       Subsystem 9 - Serial number: BS9KJ 63827TS6H3QLS9KJ
       Subsystem 10 - Serial number: LS9KJ
    Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
       Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
       Revision: FF010040    Serial number: 20110405200420
       Coding: 099A270000
       Shop #: WSC 00015 115 12345
       VCID: 6BD5F67682090266B4-803E
       Subsystem 1 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P
       Component: E221__MFL-DC1  H14 0101
       Coding: A9FFFF
    Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
       Part No SW: 3C8 920 980 T    HW: 3C8 920 980 T
       Component: KOMBI         H04 0407
       Coding: 240D01
       Shop #: WSC 05314 115 12345
       VCID: 3E730F22A1FB47CE43-806A
       Part No SW: 7N0 907 530 AN    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1642
       Revision:   H56       Serial number: 050314F2002699
       Coding: 469006
       Shop #: WSC 00079 790 45725
       VCID: 7CF7C52AFF6795DE2D-8028
                        Mileage: 108365 km
                        Date: 2015.12.29
                        Time: 17:16:59
    03109 - Tire Pressure Monitoring Control Module 2 (J793)
                        Reset counter: 175
                        Mileage: 108365 km
                        Date: 2015.12.29
                        Time: 17:26:13
       Part No SW: 3AA 959 433 A    HW: 3AA 959 433 A
       Component:    IMMO         042 0399
       Revision: 00042000    Serial number: VWZCZ000000000
       Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
       Component: SG EXT.PLAYER H13 0150
       Revision: A1001003    Serial number: 7669699996
       Shop #: WSC 05314 000 00000
       VCID: 285FC97A5B7FE97E19-807C
    Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
       Part No SW: 3C0 035 684 C    HW: 3C0 035 684 C
       Component: RNS-MID       H04 1140
       Revision: AB001001    Serial number: VWZ6Z7K7013121
       Coding: 040004000400008000
       VCID: 2345DE5622590A264C-8076
       Part No SW: 3C8 959 701     HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0501
       Revision: 12110009    Serial number: 0002585897
       Coding: 0004B7
       Shop #: WSC 05311 115 00000
       ROD: EV_TSGFPQ35BRFVW46X.rod
       VCID: 6DD1F86EBC1D0C56AA-8038
       Slave Driver:
       Subsystem 1 - Part No SW: 3C8 959 703 C    HW: 3C0 959 795 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0401
       Serial number: 00000002039982
       Coding: 000490
       Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.303 0802
       Revision: 1AH03729    Serial number: 00110850051001
       Coding: 0000258
       VCID: 3B7506367AE952E664-806E
       Component:    KSG PQ47 ELV 042 0631
       Coding: 1A910F8001860E7612061F1FF08A8F0E185801
       Shop #: WSC 08353 444 84822
    Address 4C: Tire Pressure II
       Component: EZE_2         H56 1642
       Coding: 00000008
       VCID: 6FEDE266BE11FE4698-803A
       Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
       Component: Analoguhr  004 0003
       Part No SW: 3C8 959 702     HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0501
       Revision: 14110009    Serial number: 0002584657
       Coding: 0004B6
       ROD: EV_TSGBPQ35BRFVW46X.rod
       VCID: 6ED3FF62B11BF74E93-803A
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C8 959 704 C    HW: 3C0 959 794 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0401
       Serial number: 00000002050358
       Coding: 000490
       Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
       Component: J540 EPB4  VW-55183 0007
       Revision:   H18       Serial number: 00000000279620
       Coding: 0022057
       VCID: 33652E1652B99AA6BC-8066
    Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
       Part No SW: 3AA 907 273 B    HW: 3AA 907 273 B
       Component: RDKBERU30     H08 0008
       Serial number: 10000000026701
       ASAM Dataset: EV_RDKBERU30 003010
       ROD: EV_RDKBERU30_VW36.rod
       VCID: 33652E169AB99AA6BC-8066
    8397058 - Front Left TPMS Sensor
              C1050 31 [009] - No Signal
                        Reset counter: 171
                        Mileage: 108143 km
                        Date: 2015.12.26
                        Time: 19:53:56
    8397314 - Front Right TPMS Sensor
              C1051 31 [009] - No Signal
                        Reset counter: 171
                        Mileage: 108143 km
                        Date: 2015.12.26
                        Time: 19:53:56
    8397570 - Rear Left TPMS Sensor
              C1052 31 [009] - No Signal
                        Reset counter: 171
                        Mileage: 108143 km
                        Date: 2015.12.26
                        Time: 19:53:56
    8397826 - Rear Right TPMS Sensor
              C1053 31 [009] - No Signal
                        Reset counter: 171
                        Mileage: 108143 km
                        Date: 2015.12.26
                        Time: 19:53:56
       Part No SW: 3C8 907 441     HW: 3C8 907 441
       Revision: 00H13000    Serial number: 525PA8-J482818
       Coding: 0100108
       Shop #: WSC 00079 790 00000
       VCID: 67DD8A4656E12606D0-8032
    03006 - Back-up Camera System not calibrated
                        Reset counter: 143
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 5K0 035 730     HW: 5K0 035 730
       Component: TELEFON       H09 1020
       Revision: 1B001001    Serial number: 00007669638126
       Coding: 0A00000000010100
       ASAM Dataset: UHVNA A01009
       ROD: UHVNA.rod
       VCID: 62CB9B5275C3432E07-8036
    End-------------------------(Elapsed Time: 03:44)--------------------------
    I appreciate any help that anybody can give.
    Best,
    -William
    Sep 2015
    Here are the instructions to switch from direct to indirect monitoring: http://www.myturbodiesel.com/wiki/tp...h-vcds-mk6-vw/
  3. Likes The1Bill liked this post
    Jan 2015
    Thanks for the reply, Dave. The coding that I had was 000399, and I didn't see anything in the long coding helper that resembled the B6 instructions.
    Being a 2012, my CC is a B7 electrically (3AA ABS controller). Perhaps it isn't fully mapped by Ross-Tech?
    That's a substantially different ABS system than the one used in the Golf/Jetta cars...
  6. Likes The1Bill liked this post
    United States
    Quote Originally Posted by The1Bill View Post
    Interesting. Did Basic Setting group 042 happen to become available after a short test drive or locking the car doors (10 min) so the CAN controllers go to sleep and refresh when waking up? If you were reluctant to drive it with experimental coding I don't blame you - but I'd like to know if the CAN nap helped.
    Either way, I don't think you can have virtual address 4C-Tire Pressure II enabled with a real 65-Tire Pressure module online at the same time. I don't know if this ABS controller even supports Indirect TPMS bit I would be tempted to take 65 offline. Pull a fuse or just unplug the controller followed by a CAN Nap (if needed) and checking into the ABS controller Basic Setting 042 status couldn't hurt IMO.
    P.S. I realize this is temporary and you plan on getting the proper sensors next winter but TPMS is a Federal requirement in the US. I need to tread lightly with the step-by-step instructions but any feedback you have would be excellent.
  8. Likes Uwe, The1Bill liked this post
  9. #6
    Jan 2015
    I gave it a nice long CAN nap, and no dice - channel 042 never made itself available.
    My nest step is to determine where the controller is (so I can unplug it) or determine which fuse goes to it, and give your second recommendation a try.
    This isn't the world's greatest ABS controller. I resent that it is incapable of XDS, so perhaps I'll try to find a higher line version. Besides, I will eventually want to install ACC, so it's just a matter of time anyways.
    Thanks again, Dana.
    -Bill
  10. Likes Uwe, Dana liked this post
