2012 VW CC Indirect TPMS activation
The1Bill
C?ID=197892
Good evening,
I've mounted my new snow tyres to my NAR 2012 VW CC Sport. The TPMS sensors in these wheels (as I subsequently discovered) are of the 315 MHz variety, but my TPMS module (65) uses the newer 433 MHz sensors.
Rather than disabling TPMS entirely, I was hoping to use Indirect TPMS via the ABS module for the winter. There were coding instructions in a hover-over in VCDS that said to add 1024 to the ABS coding, but that resulted in an "out of range" error. I then found coding instructions online (though for different models) that indicate that +2048 is the way to go. This coding was accepted, but I don't have channel 042 available, and that tells me that +2048 didn't work. Incidentally, +2048 was only accepted after I activated TPMS II (4C) in the gateway.
My autoscan is below. I'd love to make this work if at all possible, and pick up another set of 433 MHz sensors for next season.
Tuesday,29,December,2015,18:15:07:36082
VCDS Version: 15.7.3.0
Data version: 20151216
VIN: WVWMP7AN1CE512485   License Plate: 2KC 648
Mileage: 108360km-67331mi   Repair Order: ABS TPMS
Chassis Type: AN (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4C 4F 52 53 56
          62 65 6C 72 77
VIN: WVWMP7AN1CE512485   Mileage: 108360km-67331miles
4C-Tire Pressure II -- Status: Cannot be reached 1100
65-Tire Pressure -- Status: Not registered 0011
Address 01: Engine (CBF)       Labels: 06J-907-115-CBF.clb
   Part No SW: 06J 906 027 FD    HW: 06J 907 309 B
   Component: MED17.5.2 TFSI 2    3951
   Revision: PAH04---    Serial number: VWZCZ000000000
   Coding: 040401081C070160
   Shop #: WSC 00001 000 00000
   VCID: 72EBEB126D23D3AE77-8026
Readiness: 0110 0001
Address 02: Auto Trans        Labels: 02E-927-770.lbl
   Part No SW: 02E 300 058 N    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 3509
   Revision: 05351113    Serial number: 00001103101277
   Shop #: WSC 44551 111 44551
   VCID: 2541C04EEC6DF41622-8070
   Part No SW: 3AA 614 109 M    HW: 3AA 614 109 M
   Component: J104   C2 450M V4AF 0005
   Revision: --H07---    Serial number: 00000004040736
   Coding: 0002447
   Shop #: WSC 05311 000 00000
   VCID: 377D1A0646C1768680-8062
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 7N0 907 426 L    HW: 7N0 907 426 L
   Component: AC Manuell    H17 0202
   Revision: 00012001
   Coding: 0000001002
   Shop #: WSC 00015 115 00000
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 3D71082EACFD5CD65A-8068
Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
   Part No SW: 3AA 937 087 A    HW: 3AA 937 087 A
   Component: BCM PQ47 H    413 0452
   Revision: BB413001
   Coding: 0000000000000000009802058000088447517C8840200D605C8060200040
   Shop #: WSC 05311 123 12345
   VCID: 387F193A8BDF79FE89-806C
   Subsystem 1 - Part No SW: 3C8 955 119 D    HW: 3C8 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 11021  10  0603
   Coding: 00B795
   Component: RLS 070411 05  54  0403
   Coding: 0330ED
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 143
                    Mileage: 106420 km
                    Date: 2015.12.14
                    Time: 08:32:55
                        Term 15 On
                    Voltage: 14.45 V
01800 - Light Switch (E1)
                    Reset counter: 208
                    Mileage: 108091 km
                    Date: 2015.12.25
                    Time: 13:40:16
                        Term 15 Off
                    Voltage: 12.65 V
   Part No SW: 5N0 959 655 Q    HW: 5N0 959 655 Q
   Component: J234__30S VW10 HI   1918
   Revision: 22014000    Serial number: 003JZP5UQR86
   Coding: 0012371
   VCID: 4B9556F62A49E266D4-801E
   Subsystem 1 - Part No: 3C8 959 339 A
   Component: BF-Gewichtsens. 003 0001
   Subsystem 2 - Serial number: 00000000002YTD
   Subsystem 3 - Serial number: 0002.03.110000300000640030ÿ†63
   Subsystem 4 - Serial number: 640030ÿ†6332MTS676670751 ÿ†63
   Subsystem 5 - Serial number: 70751 ÿ†6342MTS680110751 ÿ†63
   Subsystem 6 - Serial number: 10751 ÿ†6351HTS6EN2DS9KR ÿ†63
   Subsystem 7 - Serial number: DS9KR ÿ†6361HTS6S2N7S9KR ÿ†63
   Subsystem 8 - Serial number: 7S9KR ÿ†63727TS6L55BS9KJ ÿ†63
   Subsystem 9 - Serial number: BS9KJ ÿ†63827TS6H3QLS9KJ ÿ
   Subsystem 10 - Serial number: LS9KJ ÿ
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
   Revision: FF010040    Serial number: 20110405200420
   Coding: 099A270000
   Shop #: WSC 00015 115 12345
   VCID: 6BD5F67682090266B4-803E
   Subsystem 1 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P
   Component: E221__MFL-DC1  H14 0101
   Coding: A9FFFF
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C8 920 980 T    HW: 3C8 920 980 T
   Component: KOMBI         H04 0407
   Coding: 240D01
   Shop #: WSC 05314 115 12345
   VCID: 3E730F22A1FB47CE43-806A
   Part No SW: 7N0 907 530 AN    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1642
   Revision:   H56       Serial number: 050314F2002699
   Coding: 469006
   Shop #: WSC 00079 790 45725
   VCID: 7CF7C52AFF6795DE2D-8028
            000 -  -
                    Mileage: 108365 km
                    Date: 2015.12.29
                    Time: 17:16:59
03109 - Tire Pressure Monitoring Control Module 2 (J793)
                    Reset counter: 175
                    Mileage: 108365 km
                    Date: 2015.12.29
                    Time: 17:26:13
   Part No SW: 3AA 959 433 A    HW: 3AA 959 433 A
   Component:    IMMO         042 0399
Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Component: SG EXT.PLAYER H13 0150
   Revision: A1001003    Serial number: 7669699996
   Shop #: WSC 05314 000 00000
   VCID: 285FC97A5B7FE97E19-807C
   Part No SW: 3C0 035 684 C    HW: 3C0 035 684 C
   Component: RNS-MID       H04 1140
   Revision: AB001001    Serial number: VWZ6Z7K7013121
   Coding: 040004000400008000
   VCID: 2345DE5622590A264C-8076
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0501
   Revision: 12110009    Serial number: 0002585897
   Coding: 0004B7
   Shop #: WSC 05311 115 00000
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 6DD1F86EBC1D0C56AA-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 703 C    HW: 3C0 959 795 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0401
   Serial number: 00000002039982
   Coding: 000490
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.303 0802
   Revision: 1AH03729    Serial number: 00110850051001
   Coding: 0000258
   VCID: 3B7506367AE952E664-806E
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ47 ELV 042 0631
   Coding: 1A910F8001860E7612061F1FF08A8F0E185801
   Shop #: WSC 08353 444 84822
Address 4C: Tire Pressure II
Address 4F: Centr. Electr. II (J520)       Labels: 1K0-907-532.clb
   Component: EZE_2         H56 1642
   Coding: 00000008
   VCID: 6FEDE266BE11FE4698-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0501
   Revision: 14110009    Serial number: 0002584657
   Coding: 0004B6
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 6ED3FF62B11BF74E93-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 704 C    HW: 3C0 959 794 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0401
   Serial number: 00000002050358
   Coding: 000490
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000279620
   Coding: 0022057
   VCID: 33652E1652B99AA6BC-8066
   Part No SW: 3AA 907 273 B    HW: 3AA 907 273 B
   Component: RDKBERU30     H08 0008
   Serial number: 10000000026701
   ASAM Dataset: EV_RDKBERU30 003010
   ROD: EV_RDKBERU30_VW36.rod
   VCID: 33652E169AB99AA6BC-8066
8397058 - Front Left TPMS Sensor
          C1050 31 [009] - No Signal
                    Reset counter: 171
                    Mileage: 108143 km
                    Date: 2015.12.26
                    Time: 19:53:56
8397314 - Front Right TPMS Sensor
          C1051 31 [009] - No Signal
                    Reset counter: 171
                    Mileage: 108143 km
                    Date: 2015.12.26
                    Time: 19:53:56
8397570 - Rear Left TPMS Sensor
          C1052 31 [009] - No Signal
                    Reset counter: 171
                    Mileage: 108143 km
                    Date: 2015.12.26
                    Time: 19:53:56
8397826 - Rear Right TPMS Sensor
          C1053 31 [009] - No Signal
                    Reset counter: 171
                    Mileage: 108143 km
                    Date: 2015.12.26
                    Time: 19:53:56
   Part No SW: 3C8 907 441     HW: 3C8 907 441
   Revision: 00H13000    Serial number: 525PA8-J482818
   Coding: 0100108
   Shop #: WSC 00079 790 00000
   VCID: 67DD8A4656E12606D0-8032
            000 -  -
                    Reset counter: 143
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 5K0 035 730     HW: 5K0 035 730
   Component: TELEFON       H09 1020
   Revision: 1B001001    Serial number: 00007669638126
   Coding: 0A00000000010100
   ASAM Dataset: UHVNA A01009
   ROD: UHVNA.rod
   VCID: 62CB9B5275C3432E07-8036
End-------------------------(Elapsed Time: 03:44)--------------------------
I appreciate any help that anybody can give.
Best,
-William
The1Bill
C?ID=197892
Thanks for the reply, Dave. The coding that I had was 000399, and I didn't see anything in the long coding helper that resembled the B6 instructions.
Being a 2012, my CC is a B7 electrically (3AA ABS controller). Perhaps it isn't fully mapped by Ross-Tech?
That's a substantially different ABS system than the one used in the Golf/Jetta cars...
Dana
Western PA, USA
Interesting. Did Basic Setting group 042 happen to become available after a short test drive or locking the car doors (10 min) so the CAN controllers go to sleep and refresh when waking up? If you were reluctant to drive it with experimental coding I don't blame you - but I'd like to know if the CAN nap helped.
Either way, I don't think you can have virtual address 4C-Tire Pressure II enabled with a real 65-Tire Pressure module online at the same time. I don't know if this ABS controller even supports Indirect TPMS bit I would be tempted to take 65 offline. Pull a fuse or just unplug the controller followed by a CAN Nap (if needed) and checking into the ABS controller Basic Setting 042 status couldn't hurt IMO.
P.S. I realize this is temporary and you plan on getting the proper sensors next winter but TPMS is a Federal requirement in the US. I need to tread lightly with the step-by-step instructions but any feedback you have would be excellent.
The1Bill
C?ID=197892
I gave it a nice long CAN nap, and no dice - channel 042 never made itself available.
My nest step is to determine where the controller is (so I can unplug it) or determine which fuse goes to it, and give your second recommendation a try.
This isn't the world's greatest ABS controller. I resent that it is incapable of XDS, so perhaps I'll try to find a higher line version. Besides, I will eventually want to install ACC, so it's just a matter of time anyways.
Thanks again, Dana.
-Bill
