2009 passat rns315 retrofit. Mfsw volume control not working.
travis017
C?ID=122463
I just installed an rns315 in my 09 passat wagon komfort 2.0t and now the volume, mute, and phone Buttons don't work on my steering wheel. Looked through the coding and didn't see anything wrong. After doing some searching I noticed I should have a Mac screen in the mfd screen and it looks like I don't have that either. I'm sure I have something not coded right. Can anyone point me in the right direction?
The likelihood that someone can point you in the right direction would be somewhat increased if you were to post an Auto-Scan so people can see exactly how your car is equipped and configured.
travis017
C?ID=122463
Thursday,24,December,2015,12:57:20:53535
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: WVWXK73C69E136527   License Plate: PASSAT
Mileage: 160890km-99972mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 37 42 44 46 52 53 56 62
          65 6D 72 77
VIN: WVWXK73C69E136527   Mileage: 160890km-99972miles
56-Radio -- Status: Not registered 1001
Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
   Part No SW: 06J 906 026 AG    HW: 06J 906 026 AF
   Component: MED17.5 TFSI 2,0    4061
   Revision: AAH03---    Serial number: VWZCZ000000000
   Coding: 0404010A19070160
   Shop #: WSC 05314 000 00000
   VCID: 6FE72B7A7E4C134698-803A
   Part No SW: 09G 927 750 GP    HW: 09G 927 750 GP
   Component: AQ 250 6F           1391
   Revision: 00H76000    Serial number:
   Coding: 0000072
   Shop #: WSC 05311 000 00000
   VCID: 050B69D24CF0391642-8050
Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 AJ    HW: 3C0 614 109 AJ
   Component: J104    C4 440 V2   0016
   Revision: --025---    Serial number: 00000795146377
   Coding: 0000376
   VCID: 66C94E5E51B6D20EEB-8032
   Part No SW: 1K0 820 047 JJ    HW: 1K0 820 047 JJ
   Component: Climatic PQ35   143 1313
   Revision: 00143033    Serial number: 00000000000000
   VCID: 75EB19121C10299652-8020
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Revision: 00H54000    Serial number: 00000009410420
   Coding: 248C8F2340041A00470000000F000000000959435C000120000000000000
   Shop #: WSC 05124 000 00000
   VCID: 3261E20EADFE7EAEB7-8066
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 271108 004  0206
   Coding: 00046997
   Shop #: WSC 05124
01800 - Light Switch (E1)
                    Reset counter: 102
                    Mileage: 160809 km
                    Voltage: 12.25 V
   Revision: 00000000    Serial number: AUZ4Z7I0535118
   Coding: 0000100
   VCID: 336FE70A52E477A6BC-8066
   Part No SW: 5N0 959 655 H    HW: 5N0 959 655 H
   Component: J234__00H VW10 HI   1916
   Revision: 20013000    Serial number: 003E1P6H3MBG
   Coding: 0012360
   VCID: 4281B2CE1D5ECE2E27-8016
   Subsystem 1 - Part No: 3C0 959 339 D
   Component: BF-Gewichtsens. 001 0002
   Subsystem 2 - Serial number: 000000000020G6
   Subsystem 3 - Serial number: 0018.10.080000100000650085ÿ†63
   Subsystem 4 - Serial number: 650085ÿ†6332MTS657930689 ÿ†63
   Subsystem 5 - Serial number: 30689 ÿ†6342MTS681770269 ÿ†63
   Subsystem 6 - Serial number: 70269 ÿ†6351HTS6L8P206KR ÿ†63
   Subsystem 7 - Serial number: 206KR ÿ†6361HTS621F306KR ÿ†63
   Subsystem 8 - Serial number: 306KR ÿ†63727TS62RADV5KJ ÿ†63
   Subsystem 9 - Serial number: DV5KJ ÿ†63827TS69OQVV5KJ ÿ
   Subsystem 10 - Serial number: VV5KJ ÿ
   Part No SW: 3C0 953 549 AC    HW: 3C0 953 549 AC
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C9953507CN
   Coding: 0001112
   VCID: 6DDB31727440E156AA-8038
   Component: E0221           002 0030
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C0 920 971 S    HW: 3C0 920 971 S
   Component: KOMBI         H05 0110
   Coding: 260D00
   Shop #: WSC 05314 115 00000
   VCID: 356BD9129490699692-8060
Address 19: CAN Gateway        Labels: 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 L    HW: 3C0 907 951
   Component: J533__Gateway   H13 0152
   Revision:   H13       Serial number: 3300P094090263
   Coding: FD807F07421502002002
   VCID: 2A51FA6E852E366E0F-807E
01304 - Radio
                    Reset counter: 139
                    Mileage: 160851 km
                    Date: 2010.05.15
                    Time: 11:30:59
                    Reset counter: 101
                    Mileage: 160851 km
                    Date: 2010.05.15
                    Time: 12:57:48
                    Reset counter: 101
                    Mileage: 160860 km
                    Date: 2010.05.15
                    Time: 14:06:56
   Part No SW: 3C8 919 965     HW: 3C8 919 965
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1614128T0HXV02
   Part No SW: 3C0 959 433 AP    HW: 3C0 959 433 AP
   Component:    IMMO         052 0383
   Revision: 00052000    Serial number: VWZCZ000000000
   Shop #: WSC 09115 444 85762
   VCID: 78F510260B0254FE49-802C
   Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
   Component: RNS315-NAR    H53 0319
   Serial number: VWZAZ2M4265504
   Coding: 04000001010006000000000A
   Shop #: WSC 01383 790 50316
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 254B09522430191622-8070
1048667 - Antenna for Satelite Radio
          B10F4 13 [009] - Open Circuit
                    Reset counter: 101
                    Mileage: 160890 km
                    Date: 2015.12.24
                    Time: 12:42:56
1048659 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 101
                    Mileage: 160890 km
                    Date: 2015.12.24
                    Time: 12:50:38
          B11CF 53 [009] - Deactivated
                    Reset counter: 101
                    Mileage: 160890 km
                    Date: 2015.12.24
                    Time: 12:42:56
   Component: J386  TUER-SG FT    1517
   Revision: 72009005    Serial number: 00000875298304
   Coding: 0001205
   Part No SW: 5N1 909 144 J    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.081 0503
   Revision: 1AH02250    Serial number: 00090500043802
   Coding: 0000258
   VCID: 3973D52270888DF676-806C
   Component:    KSG PQ46 RDK 052 0412
   Coding: 1A900E80D10340763F04141DE08A0F0E085801
   Component: J387  TUER-SG BT    1517
   Revision: 72009005    Serial number: 00000757098303
   Coding: 0001204
   VCID: 70E5280663720CBE81-8024
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 B
   Component: J540 EPB3  VW-10498 0003
   Revision:   010       Serial number: 00000000046646
   Coding: 0000057
   VCID: 285500669B22047E19-807C
   Part No SW: 1K0 959 703 AD    HW: 1K0 959 795 P
   Component: J388   TUER-SG HL   0307
   Revision: 42004101    Serial number: 00000000727236
   Coding: 0001168
   VCID: 72E1220E6D7E3EAE77-8026
   Component:    RDK              0453
   Coding: 0100101
   Part No SW: 3C9 827 383 F    HW: 3C9 827 383 F
   Component: J605  HECKDECKEL    0720
   Revision: 00H27001
   Shop #: WSC 05311 000 08193
   VCID: 346DE41657EA709EA5-8060
   Subsystem 1 - Part No: 3C9 827 384 F
   Component: J756  HECKDECKEL    0720
   Subsystem 2 - Serial number: 0900H27001001A0123ÿ
00317 - Rear Lid Control Module (J605)
                    Reset counter: 141
                    Mileage: 143360 km
                    Date: 2009.05.07
                    Time: 15:40:13
   Part No SW: 1K0 959 704 AD    HW: 1K0 959 794 P
   Component: J389   TUER-SG HR   0307
   Revision: 42004101    Serial number: 00000000847691
   Coding: 0001168
   VCID: 73EF270A126437A67C-8026
Address 77: Telephone
End-------------------------(Elapsed Time: 02:35)--------------------------
Address 19:3C0 907 530 L recoded (Long Coding) from FD807F07421502002002 to FD807F07421702002002  (05314/000/00000)
Address 19: DTCs cleared
Thursday,24,December,2015,13:13:28:53535
          65 6D 72 77
   Coding: 0000072
   Coding: 0000376
   Coding: 00046997
   Shop #: WSC 05124
                    Reset counter: 102
                    Mileage: 160809 km
                    Voltage: 12.25 V
   Coding: 0000100
   Coding: 0012360
   Coding: 0001112
   Coding: 260D00
   Coding: FD807F07421702002002
                    Reset counter: 101
                    Mileage: 160890 km
                    Date: 2010.05.16
                    Time: 13:07:19
                    Reset counter: 101
                    Mileage: 160890 km
                    Date: 2015.12.24
                    Time: 12:42:56
          U1111 00 [009] - -
                    Reset counter: 101
                    Mileage: 160890 km
                    Date: 2015.12.24
                    Time: 12:50:38
                    Reset counter: 101
                    Mileage: 160890 km
                    Date: 2015.12.24
                    Time: 12:42:56
   Coding: 0001205
   Coding: 0000258
   Coding: 0001204
   Coding: 0000057
   Coding: 0001168
   Component:    RDK              0453
   Coding: 0100101
   Revision: 00H27001
                    Reset counter: 141
                    Mileage: 143360 km
                    Date: 2009.05.07
                    Time: 15:40:13
   Coding: 0001168
End-------------------------(Elapsed Time: 02:34)--------------------------
travis017
C?ID=122463
here is the scan i did the other day. If someone sees something wrong please let me know.
travis017
C?ID=122463
Bump still looking for some answers.
diskoboy
C?ID=50403
Old software in the gateway?
[56-Radio] is missing... Is it added in the gateway list ?
travis017
C?ID=122463
Not exactly sure what you mean. From what I have read the Rns doesn't use the 56-radio channel and instead uses the digital radio channel.
diskoboy
C?ID=50403
At least in EU it uses [56-Radio]. Don't know in US.
