Results 1 to 4 of 4
Thread: 2001 allroad air suspension
    Dec 2015
    The bags are completely down on this parts car. The only thing wrong with the car is that the timing belt broke and ruined the engine. I would like to inflate the bags to make it easy to roll the car around, but note that repair/inflation/adjusting procedures for the bags say to have the engine running! Is there a work-around for this situation?
    Post an auto-scan and observe outputs............
    Dec 2015
    This is the last one I have for the system.
    I had reset fault codes first and then tried to run the system.
    The compressor tried to run momentarily, but stopped immediately.
    Address 34: Level Control Labels: 4Z7-907-553.lbl
    Part No: 4Z7 907 553 E
    Component: - 2C1A1 D040
    Coding: 25500
    Shop #: WSC 09999
    VCID: 478048F26520E419EF5-5140
    01772 - Signal from Level Control Pressure Sensor (G291)
    00806 - Suspension Strut Valve; Front Right (N149)
    This is not an auto-scan..........no fun tickets = no help.
    Fix the issues hook up battery charger, or pull the line, add Schrader...... and blow into it to raise the car.
