Results 1 to 4 of 4
Thread: 2011 VW Polo 1.2 S 3 door UK 6R model - comfort controller
    New User
    Dec 2015
    My son who just passed his driving has bought a VW Polo 1.2 litre 6R model. He wants to conduct some mods on it, its no surprise as i had a number of VW's back in the day and did quite a few mods myself.
    The VW Polo did not come with a remote locking key fob, so that its a pain to manually lock and unlock the car with a key and is harder at night when its dark to locate the key hole. So been reading the vw polo forum and finding that it could be a plug and play job depending on what version of comfort controller is installed in the car. If it turns out to be the base model comfort controller then purchasing the next comfort controller will certainly give the ability to use VW remote fobs which i will need to purchase and program them in. I will also need to remove the transponder 'pills' from the current keys and glue them into the remote key fobs.
    I downloaded your VCDS lite version as i have a 3 party interface, it picks up the engine controller and apart from that doesnt see any other controller. I have tried 09 'electrical control' and 46 'central convenience' and get message back saying "controller not found". I have even tried to change the baud rate down to 4800 and that hasnt help so the question is should VCDS lite pick up the comfort controller ?
    I didnt want to purchase VCDS lite until i know it will conduct what we are planning ....
    Thanks in advance,
    Chas
    New User
    Dec 2015
    This is what i have found regards the various comfort control units also referenced as BCM's so hence need to know which one is installed in the car, its highly likey its the Base unit but need to check first and the requirement to read the controller data with vcds.
    6R0 937 084Basis
    6R0 937 085Low / medium
    6R0 937 086Medium
    6R0 937 087High
    6R0 937 088High with start / stop operation
    7H0 937 089High daytime running light, driving light assistant and Coming Home Function
    7H0 937 090Max
    Translated from German:
    base
    terminal control
    load management
    Control brake light, parking and parking lights and interior light
    Control indicators and hazard warning lights
    Wiper control, front and rear
    Control horn
    Control defogger rear
    Control door control devices
    tailgate release
    Diagnosis interface for data bus
    CAN drive and diagnostics
    medium
    Central locking (control locks, doors and flaps)
    Released Seat heating and Schiebeausstelldach
    Driving wheel cleaning system
    Control windscreen heater
    Control LIN data bus door
    Control LIN data bus roof (rain sensor, interior surveillance, inclination sensor, panoramic sunroof)
    Heated door mirrors
    CAN comfort
    medium
    Wireless remote (integrated in the control unit antenna)
    High
    Shift lock, starter interlock
    Cruise control
    Control LIN data theft alarm system
    Drive reverse light, static cornering lights, fog lights
    Quote Originally Posted by chaskalsi View Post
    Most of the modules in a 6R Polo require diagnostic communications directly via CAN bus, which VCDS-Lite is not capable of.
  4. Likes Dana liked this post
    United States
    As mentioned, you would need a CAN capable interface but that vehicle would use a BCM (address 09) rather that 46. Although this page is CCS specific it covers some of the part numbers you listed:
    http://wiki.ross-tech.com/wiki/index...tting_%286R%29
  6. Likes Uwe liked this post
