I changed the cluster, it gives me an error of autonomy in the fis but VCDS not detect any error. I guess it will be some adjustment of fuel tank ... can someone tell me how to make this adjustment to remove the warning?
I still don't know what it means. Maybe change cluster language to English or German so we can see what it says in that language?yes ... error of autonomy
Do we have an Auto-Scan from this car? Right now, we don't even know what kind of car it is...now , i see the picture ... the connector is electric , is possible that have an coding for car hibryd ??
thank you UWE
VCDS Version: Release 15.7.3 (x64) Running on Windows 10 x64
Data version: 20151216
Saturday,19,December,2015,12:09:29:22717
Chassis Type: 5F (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 3C 42 44 52 55 5F 65 A5
VIN: VSSZZZ5FZER117826 Mileage: 72km-44miles
Address 01: Engine (J623-CLHA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 M HW: 04L 907 309 B
Component: R4 1,6L EDC H22 6545
Revision: 84H22---
Coding: 01110032032401090000
ASAM Dataset: EV_ECM16TDI01104L906021M 002011
ROD: EV_ECM16TDI01104L906021M_SE37.rod
VCID: 2F43E82D7645F146D8-807A
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 626630000009B2
Coding: 20EE629214210973007F060241C9240446289000608224F20061F0024009
Shop #: WSC 06314 790 00021
ROD: EV_Brake1UDSContiMK100IPB_SE37.rod
VCID: 7BDB0C7DF2BDDDE624-802E
8299 - Databus
Reset counter: 230
Date: 2015.12.19
Time: 12:02:02
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5F0 907 044 D HW: 5F0 907 044 D
Component: Climatronic H03 0705
Revision: 00001K07
Coding: 01000104202100011105004000101000
Shop #: WSC 00049 770 00106
ROD: EV_ACClimaBHBVW37X_SE37.rod
VCID: 2773000D5EB5A90610-8072
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011408501699
Coding: 08000B42424102FB4BE4400051040308100E000000000000000000000000
Shop #: WSC 27574 001 104857
ROD: EV_BCMBOSCH_SE37.rod
Slave 1:
Subsystem 1 - Part No SW: 5F1 955 119 HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 140325 041 0574
Serial number: 140326073449
Coding: 0BC5FD
Slave 2:
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y14M03D27H02M52S25S7
Coding: 06885D
Subsystem 3 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000031592682
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5Q0 919 298 A HW: 5Q0 919 298
Component: PARKHILFE PLA 011 0029
Coding: 0031163041
Shop #: WSC 00123 123 12345
ASAM Dataset: EV_EPHVA2CAU3700000 003014
ROD: N/A
VCID: 3D5FC265AC2913D65A-8068
No ASAM data for: "EV_EPHVA2CAU3700000" (SE37)
12658704 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 230
Mileage: 72 km
Date: 2015.12.19
Time: 12:01:44
Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 012 0189
Revision: -------- Serial number: 003P4P79TV59
Coding: 98CCC000000000005C0000CC000800000065
ROD: EV_AirbaVW20TS6VW48X_SE37.rod
VCID: 7F23F86DE6A5C1C608-802A
Subsystem 1 - Part No SW: ----------- HW: 454 000 304 14
Serial number: 3576U000000947145F0A
Subsystem 2 - Part No SW: ----------- HW: 454 000 404 14
Serial number: 3586U000000945814F0C
Subsystem 3 - Part No SW: ----------- HW: 454 802 703 14
Component: SideSensor_Dr 111 0148
Serial number: 3516R0B2D4D030000002
Subsystem 4 - Part No SW: ----------- HW: 454 802 703 14
Component: SideSensor_Pr 111 0148
Serial number: 3526R55ED44030000005
Subsystem 5 - Part No SW: ----------- HW: 454 801 903 14
Component: FrontSensor_D 114 0149
Serial number: 3556VCFA02D03000000J
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 DK HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 05041408490170
Coding: 2C00
ROD: EV_SMLSKLOMQB_SE37.rod
VCID: 022571999557AC2E67-8056
Part No SW: 5F0 920 873 A HW: 5F0 920 873 A
Component: KOMBI C02 F150
Coding: 07AD1280689C000800087E0E4400000000000000
ROD: EV_DashBoardVDDMQBAB_SE37.rod
VCID: 2977063548A19F7606-807C
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001886578
Coding: 030100F40B087300DF040658081F00010001000000000008000000000000
ROD: EV_GatewLear.rod
VCID: 3FA3B86DA62501C648-806A
Subsystem 2 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B
Component: E221__MFL-PR6 H03 0120
Serial number: 000000000A0311070314
Coding: 002000
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 4475232803
Address 3C: Lane Change (J769) Labels: 5Q0-907-566.clb
Part No SW: 5Q0 907 566 HW: 8T0 907 566
Component: SWA Master H16 0046
Serial number: 0162026687
Coding: 030311
ROD: N/A
VCID: 77D3104DCE95F98640-8022
No ASAM data for: "EV_LaneChangAssis" (SE37)
Part No SW: 5Q4 959 593 B HW: 5Q4 959 593 B
Component: TSG FS 009 0014
Serial number: 0000097358999
Coding: 00100320DE00040000001000
Shop #: WSC 00049 770 00125
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 44A9B781CFC3621E15-8010
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Serial number: 00000000000002245433
Coding: 310000
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 123 1043
Coding: 1303
ROD: EV_SteerAssisMQB.rod
VCID: 41A7BE95D0D177363E-8014
Part No SW: 5Q4 959 592 B HW: 5Q4 959 592 B
Component: TSG BFS 009 0014
Serial number: 0000097584970
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 43ABB49DCACD65262C-8016
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Serial number: 00000000000002203632
Coding: 290000
Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 048A000009000000
ROD: EV_HeadlRegulVWLWRMQB_SE25.rod
VCID: 75CF1A45D4998B9652-8020
Address 5F: Information Electr. (J794) Labels: Redir Fail!
Part No SW: 5F0 035 846 A HW: 5F0 035 846 A
Component: MU-S-N-ER 040 0425
Serial number: E1F00204140353
Coding: 04731001FF0A000021110001000800002F0210100100010046
ASAM Dataset: EV_MUStd6C1PASE 002030
ROD: EV_MUStd6C1PASE_SE37.rod
VCID: 266D0D0959BFB00E2B-8072
Media Player Position 1:
Subsystem 1 - Part No SW: 5F0 919 603 A HW: 5F0 919 603 A
Component: ABTmin_Std_Nv H60 0030
Serial number: SEZ8Z9PT90028K
Engine Control Module 2:
Subsystem 2 - Part No SW: 5F0 060 884 J HW: -----------
Component: ECE 2015/16 --- 0051
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 30000000009036
ROD: EV_RDKBERU30_VW36.rod
VCID: 3449E7419F63D29EA5-8060
Address A5: Frt Sens. Drv. Assist (R242) Labels: 5Q0-980-653.clb
Part No SW: 5Q0 980 653 F HW: 5Q0 980 653
Component: MQB_MFK H05 0052
Serial number: 10000060385
Coding: 0101010001020304010500010000000100
ROD: EV_MFKBoschAU370_SE37.rod
VCID: 3B5BCC7DB23D1DE664-806E
End-------------------------(Elapsed Time: 03:02)--------------------------
SW:5F0-920-873-A HW:5F0-920-873-A --- Instruments
Component:KOMBI C02 F150, Coding:07A402002180000800086A001000000000000000
EV_DashBoardVDDMQBAB,009043,EV_DashBoardVDDMQBAB_SE37.rod
Thursday,10,December,2015,21:01:53:22717
VCDS Version: Release 15.7.2 (x64) Data version: 20151124
VCID: 2977063548A19F761C-807C
Activating and deactivating all development messages,not active
Cylinder shut-off,Display
Day,3 d
Day counter,2 d
Deactivate seat belt warning,No
Digital speedometer,Display
Display correction of consumption and operating range gas,100 %
Display correction of consumptions and operating range,100 %
Display depiction,Version 1
Distance,0 km
Driving profile for range remaining LPG,10.0 l/100km
Driving profiled for range remaining,8.0 l/100km
Driving profiled for range remaining CNG,6.0 kg/100 km
ESI: distance driven from inspection,0 km
ESI: maximum value km-driving distance/inspection,30000 km
ESI: maximum value of time between inspections,730 d
ESI: minimum value km-driving distance/inspection,15000 km
ESI: minimum value of time between inspections,365 d
ESI: oil quality,good oil quality
ESI: Resetting ESI,Reset
ESI: soot entry,0 km
ESI: thermal load,0 km
ESI: time from inspection,2 d
FIX: Distance covered since last mileage-dependent inspection,0 km
FIX: Max. distance until next mileage-related inspection,30000 km
FIX: Maximum time until next time-dependent inspection,730 d
FIX: Reset value for next mileage-dependent inspection,30000 km
FIX: Reset value for next mileage-dependent inspections,365 d
FIX: Time since last time-dependent inspection,2 d
Hour,0 H
Ignition active message actuator,Driver door
Language version,Spanish
(1)-MFA3-Reset-MFI button RESET / OK,Manual reset not possible
(2)-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset
(3)-MFA3-Reset-Refuel detection gas,MFA3-Reset
(4)-MFA3-Reset-Nachtankerkennung Elektro,MFA3-Reset
Minute,16 min
Month,1 mon
No-voltage display,No display
(1)-Offset for tank calibration values-Offset sensor 1,-12.8 l
(2)-Offset for tank calibration values-Offset sensor 2,12.7 l
(3)-Offset for tank calibration values-Offset sensor 3,12.7 l
(4)-Offset for tank calibration values-Offset sensor 4,12.7 l
(5)-Offset for tank calibration values-Complete tank calibration,-12.8 l
Oil temperature display,On
Roller test bench mode functional,not activated
Service notification,30 d
Service notification in days,30 d
(1)-Service-key settings-p_write_delay_time,40 s
(2)-Service-key settings-p_write_delay_speed,20 km/h
(3)-Service-key settings-p_write_distance,20 km
(4)-Service-key settings-p_forcewrite_qual_time,10 s
(5)-Service-key settings-p_main_switch_keyless,On
(6)-Service-key settings-p_main_switch_Basic,On
(7)-Service-key settings-p_deactivate_SK_Function,On
SIA: maximum value of distance to service,15000 km
SIA: maximum value of time to service,365 d
Source for synchronization of time,internal clock
(1)-Speed warning-,not active
(2)-Speed warning-Unit,Kilometers per hour
(3)-Speed warning-Speed,30
Staging,No
Trip recorder,not installed
(1)-Units adjusted-Temperature,Degrees Celsius
(2)-Units adjusted-Distance,Kilometers
(3)-Units adjusted-Speed,Kilometers per hour
(4)-Units adjusted-Pressure,bar
(5)-Units adjusted-Volume,Liter
(6)-Units adjusted-Time,24h
(7)-Units adjusted-Date,dd_mm_yy
(8)-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km
(9)-Units adjusted-Operating range consumption CNG (compressed natural gas),kg per 100 km
(10)-Units adjusted-Average consumption electric drive,kWh per 100 km
Vehicle Positioning System Interface Control Module,not installed
Year,2011 yr
(1)-Total operating range gas-State,not active
(2)-Total operating range gas-selection_consumption_factor,consumption_factor_CAN
(3)-Total operating range gas-consumption_profile,consumption_profile_calculation
(4)-Total operating range gas-consumption_factor,0.000
BAP_Debug_Mode_Release,not_released
(1)-Configuration of Development CAN-Messages-Block 1,OFF
(2)-Configuration of Development CAN-Messages-Block 2,OFF
(3)-Configuration of Development CAN-Messages-Block 3,OFF
(4)-Configuration of Development CAN-Messages-Block 4,OFF
(5)-Configuration of Development CAN-Messages-Block 5,OFF
(6)-Configuration of Development CAN-Messages-Block 6,OFF
(7)-Configuration of Development CAN-Messages-Block 7,OFF
(8)-Configuration of Development CAN-Messages-Block 8,OFF
(9)-Configuration of Development CAN-Messages-Block 9,OFF
(10)-Configuration of Development CAN-Messages-Block 10,OFF
(11)-Configuration of Development CAN-Messages-Block 11,OFF
(12)-Configuration of Development CAN-Messages-Block 12,OFF
(13)-Configuration of Development CAN-Messages-Block 13,OFF
(14)-Configuration of Development CAN-Messages-Block 14,OFF
(15)-Configuration of Development CAN-Messages-Block 15,OFF
(16)-Configuration of Development CAN-Messages-Block 16,OFF
(17)-Configuration of Development CAN-Messages-Block 17,OFF
(18)-Configuration of Development CAN-Messages-Block 18,OFF
(19)-Configuration of Development CAN-Messages-Block 19,OFF
(20)-Configuration of Development CAN-Messages-Block 20,OFF
(21)-Configuration of Development CAN-Messages-Block 21,OFF
(22)-Configuration of Development CAN-Messages-Block 22,OFF
(23)-Configuration of Development CAN-Messages-Block 23,OFF
(24)-Configuration of Development CAN-Messages-Block 24,OFF
(25)-Configuration of Development CAN-Messages-Block 25,OFF
(26)-Configuration of Development CAN-Messages-Block 26,OFF
(27)-Configuration of Development CAN-Messages-Block 27,OFF
(28)-Configuration of Development CAN-Messages-Block 28,OFF
(29)-Configuration of Development CAN-Messages-Block 29,OFF
(30)-Configuration of Development CAN-Messages-Block 30,OFF
(31)-Configuration of Development CAN-Messages-Block 31,OFF
(32)-Configuration of Development CAN-Messages-Block 32,OFF
(33)-Configuration of Development CAN-Messages-Block 33,OFF
(34)-Configuration of Development CAN-Messages-Block 34,OFF
(35)-Configuration of Development CAN-Messages-Block 35,OFF
(36)-Configuration of Development CAN-Messages-Block 36,OFF
(37)-Configuration of Development CAN-Messages-Block 37,OFF
(38)-Configuration of Development CAN-Messages-Block 38,OFF
(39)-Configuration of Development CAN-Messages-Block 39,OFF
defuel_threshold,45 l
(1)-dimming_characteristic_curve_adjustment_bargraph_main_colour-X1,00
(2)-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,01
(3)-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2,0A
(4)-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,01
(5)-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,64
(6)-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,06
(7)-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,96
(8)-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,0A
(9)-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5,DC
(10)-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,1E
(11)-dimming_characteristic_curve_adjustment_bargraph_main_colour-X6,FD
(12)-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y6,3C
(1)-dimming_characteristic_curve_adjustment_clock_dial_day-X1,00
(2)-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,00
(3)-dimming_characteristic_curve_adjustment_clock_dial_day-X2,0A
(4)-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,00
(5)-dimming_characteristic_curve_adjustment_clock_dial_day-X3,64
(6)-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00
(7)-dimming_characteristic_curve_adjustment_clock_dial_day-X4,96
(8)-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,05
(9)-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC
(10)-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,30
(11)-dimming_characteristic_curve_adjustment_clock_dial_day-X6,FD
(12)-dimming_characteristic_curve_adjustment_clock_dial_day-Y6,64
(1)-dimming_characteristic_curve_adjustment_clock_dial_night-X1,00
(2)-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,05
(3)-dimming_characteristic_curve_adjustment_clock_dial_night-X2,06
(4)-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,05
(5)-dimming_characteristic_curve_adjustment_clock_dial_night-X3,64
(6)-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,36
(7)-dimming_characteristic_curve_adjustment_clock_dial_night-X4,96
(8)-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,44
(9)-dimming_characteristic_curve_adjustment_clock_dial_night-X5,DC
(10)-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,59
(11)-dimming_characteristic_curve_adjustment_clock_dial_night-X6,FD
(12)-dimming_characteristic_curve_adjustment_clock_dial_night-Y6,64
(1)-dimming_characteristic_curve_adjustment_gauge-X1,00
(2)-dimming_characteristic_curve_adjustment_gauge-Y1,0F
(3)-dimming_characteristic_curve_adjustment_gauge-X2,0A
(4)-dimming_characteristic_curve_adjustment_gauge-Y2,0F
(5)-dimming_characteristic_curve_adjustment_gauge-X3,64
(6)-dimming_characteristic_curve_adjustment_gauge-Y3,64
(7)-dimming_characteristic_curve_adjustment_gauge-X4,96
(8)-dimming_characteristic_curve_adjustment_gauge-Y4,64
(9)-dimming_characteristic_curve_adjustment_gauge-X5,DC
(10)-dimming_characteristic_curve_adjustment_gauge-Y5,64
(11)-dimming_characteristic_curve_adjustment_gauge-X6,FD
(12)-dimming_characteristic_curve_adjustment_gauge-Y6,64
(1)-dimming_characteristic_curve_adjustment_indicator_lights-X1,00
(2)-dimming_characteristic_curve_adjustment_indicator_lights-Y1,0E
(3)-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A
(4)-dimming_characteristic_curve_adjustment_indicator_lights-Y2,0E
(5)-dimming_characteristic_curve_adjustment_indicator_lights-X3,64
(6)-dimming_characteristic_curve_adjustment_indicator_lights-Y3,2D
(7)-dimming_characteristic_curve_adjustment_indicator_lights-X4,96
(8)-dimming_characteristic_curve_adjustment_indicator_lights-Y4,3E
(9)-dimming_characteristic_curve_adjustment_indicator_lights-X5,DC
(10)-dimming_characteristic_curve_adjustment_indicator_lights-Y5,57
(11)-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD
(12)-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64
(1)-dimming_characteristic_curve_adjustment_internal_phototransistor-X1,00 00
(2)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1,00 00
(3)-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 32
(4)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 15
(5)-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 64
(6)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 7D
(7)-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8
(8)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8
(9)-dimming_characteristic_curve_adjustment_internal_phototransistor-X5,01 F4
(10)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5,00 FD
(1)-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00
(2)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,02
(3)-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A
(4)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,02
(5)-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,64
(6)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,13
(7)-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,96
(8)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,21
(9)-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,DC
(10)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,46
(11)-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD
(12)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64
Display_Save_CP,Yes
Gas_functionality,not active
(1)-Illumination_algorithm-Scale_switching_algorithm,parking_light
(2)-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xt_bus
init_fuel_algorithm,No
Leaving_warning_delay,80 s
(1)-outside_temperature-p_time_constant_pt1,40 s
(2)-outside_temperature-p_time_constant_slow_damping,2.0
(3)-outside_temperature-P_speed_threshold,20 km/h
(4)-outside_temperature-p_tendency_threshold,1.0 °C
(5)-outside_temperature-p_kmt_at_delta,25 °C
(6)-outside_temperature-p_blocking_time_after_v_bigger_0,15 s
(7)-outside_temperature-p_storage_time_engine_off,180 min
(8)-outside_temperature-p_mileage_after_v_bigger_0,5.0 km
(9)-outside_temperature-p_ice_warning_exit_temperature,6 °C
(10)-outside_temperature-p_ice_warning_entry_temperature,4 °C
(11)-outside_temperature-p_tendency_damping,15 s
Picture_Upload_Download,not active
Service_Key_Clear_All_Counter,Yes
Statistic_phev_mileage,50 km
(1)-time_parameter_display-tDDWUP,0.00
(2)-time_parameter_display-tDD15_on,0.00
(3)-time_parameter_display-tDD15_off,0.60
(4)-time_parameter_display-hmi_t_Dreiter_ms,2.0
(5)-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s
(6)-time_parameter_display-hmi_t_UhrTimeout_ms,10 s
(7)-time_parameter_display-hmi_t_MenuTimeout_ms,255 s
(8)-time_parameter_display-hmi_t_TWSAnz_ms,3 s
(9)-time_parameter_display-hmi_t_NextWarning_ms,6 s
(10)-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s
(11)-time_parameter_display-hmi_t_P1Pause_ms,20 s
(12)-time_parameter_display-hmi_t_P2Pause_ms,900 s
(13)-time_parameter_display-hmi_t_Quit_ms,10 s
(14)-time_parameter_display-hmi_t_FondGurt,30 s
(15)-time_parameter_display-hmi_t_USZ,0.20 s
(16)-time_parameter_display-hmi_t_FTuerAUF,300 ms
(17)-time_parameter_display-rollierblockgroesse,3
Component:KOMBI C02 F150, Coding:07ED12806C9C000800887E0F4400000000000000
Saturday,19,December,2015,21:10:46:22717
VCDS Version: Release 15.7.3 (x64) Data version: 20151216
Day,19 d
Day counter,3 d
Distance,73 km
Driving profiled for range remaining,7.7 l/100km
ESI: distance driven from inspection,74 km
ESI: Resetting ESI,no warning
ESI: time from inspection,4 d
FIX: Time since last time-dependent inspection,4 d
Hour,21 H
Lap counter,Display
Minute,10 min
Month,12 mon
Staging,No
Year,2015 yr
Sunday,20,December,2015,01:22:38:22717
VCDS Version: 15.7.3.0 (x64)
VIN: VSSZZZ5FZER117826 License Plate:
Mileage: 73km-45mi Repair Order:
Scan: 01 03 08 09 10 13 15 16 17 19 3C 42 44 52 55 5F 65 A5
VIN: VSSZZZ5FZER117826 Mileage: 73km-45miles
Revision: 84H22---
Coding: 01110032036401090000
4709 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [039] - -
Mileage: 73 km
Date: 2015.12.20
Time: 01:03:53
Coding: 20EE629214210973007F060241C9240446289000608224F2F461F0024009
Revision: 00001K07
Slave 1:
Coding: 0BC5FD
Slave 2:
Coding: 06885D
Coding: 0031163041
ROD: N/A
- 00 [009]
Reset counter: 231
Mileage: 73 km
Date: 2015.12.20
Time: 01:05:24
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Component: ACC Bosch MQB H05 0304
Serial number: 02041503270551
Coding: 00200400FE0739
ROD: EV_ACCMRRBoschVW372_AU37.rod
VCID: 3851D371830B36FE89-806C
1039 - Databus
Reset counter: 231
Mileage: 73 km
Date: 2015.12.20
Time: 01:03:34
1807 - No Enable Indentifications Active
B2032 00 [009] - -
Reset counter: 231
Mileage: 73 km
Date: 2015.12.20
Time: 01:03:34
Coding: 6C00
Coding: 07ED12806C9C000800887E0F4400000000000000
10485826 - Internal Control Module Memory Check Sum Error
B2000 41 [009] - General checksum failure
Mileage: 73 km
Date: 2015.12.19
Time: 19:06:07
Coding: 030100F40A087300DF040658081F00010001000000000008000000000000
Coding: 002000
Coding: 030311
ROD: N/A
Coding: 310000
Coding: 1303
Coding: 290000
Coding: 0101010001020304010500010100000100
End-------------------------(Elapsed Time: 03:12)--------------------------
Look at first line in post #8even so , me paste the coding that you refer to me?
