A few problems to resolve
ProtoFly
C?ID=132348
I've got a few unresolved (persistent) faults being reported, since my engine re-installation.
Acc/Start Auth, 01049, Supply Voltage Term 50
Central Conv. 01134 Alarm Horn Electrical Fault in Circuit
Telephone, Control Module Not Coded
<solved> [strike]First, the Telephone Module: I can't seem to get it to take a code. It's a replacement Bluetooth unit under the seat, supposedly new. Based on what the 'helper' says, it should take 0020202, but it claims it is out of range.[/strike]
The Alarm horn seems to work OK - at least if it is the same horn that beeps when you lock the doors.
No idea on the 01049. Clear it, it comes right back.
There's also something about the immobilizer, but it doesn't appear in the logs, other than
'25-Immobilizer -- Status: Malfunction 0010'
Any ideas on where to start?
-Darryl
Tuesday,06,May,2014,21:06:12:01367
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WAUDL74F15N036836   License Plate:
Mileage: 265780km-165148mi   Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 42 46 47 4F 52 53
          55 56 61 62 72 77
VIN: WAUDL74F15N036836   Mileage: 265780km/165148miles
   Part No SW: 4F0 910 560 A    HW: 4F0 907 559
   Component: 4.2L V8/5V      G   0010
   Revision: --------    Serial number:
   Coding: 0007772
   Shop #: WSC 02335 785 00200
   VCID: 2045F75CF3C6B41EBB7-8075
Readiness: 0010 1101
   Part No SW: 4F1 910 156 G    HW: 09L 927 156
   Component: AG6 09L 4.2L5V USA  0070
   Revision: --H01---    Serial number:        0044417
   Coding: 0001002
   VCID: 2855EF7C9BF64C5EF37-807D
   Part No SW: 4F0 910 517 E    HW: 4F0 614 517 A
   Component: ESP8 quattro    H03 0010
   Coding: 0004456
   VCID: 2649E14491E25A2EC1B-8073
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Component: FBSAUDIC6 ELV   H30 0130
   Revision: 30040401    Serial number: 10600300050824
   Coding: 0000011
   Shop #: WSC 06121 444 13925
   VCID: E3CF385022506F06665-80B6
   Subsystem 1 - Part No: 4F0 910 131 J
   Component: FBSAUDIC6 EZS   H43 0070
   Subsystem 2 - Part No: 4F0 910 220 A
   Component: FBSAUDIC6 IDG   H01 0054
01049 - Supply Voltage Term 50
            006 - Short to Plus
                    Fault Status: 01100110
                    Reset counter: 73
                    Mileage: 265785 km
                    Date: 2014.05.06
                    Time: 20:45:26
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
   Part No SW: 4F0 910 732 C    HW: 4E0 035 729
   Component: Interfacebox    H43 4140
   Revision: 00000000    Serial number: 360BO057519572
   Coding: 0030003
   VCID: 234FF850E2D0AF06A65-8076
   Subsystem 1 - Part No: 4F0 910 609
   Component: Bedienteil MMIC6H07 0870
   Subsystem 2 - Serial number: 00000000040872
   Subsystem 3 - Serial number: 0111.08.040000000100010178ˇ
   Subsystem 4 - Serial number: 010178ˇ
Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
   Part No SW: 4F0 910 043     HW: 4F1 820 043 J
   Component: KLIMABETAETIGUNGH11 0110
   Revision: 00000023    Serial number: 00000000046041
   Coding: 0008232
   VCID: DBBF00B01A2057C62E5-808E
   Part No SW: 4F0 910 279 A    HW: 4F0 907 279 A
   Component: ILM Fahrer      H14 0080
   Coding: 0113123
   VCID: 2757EC4096E84326FAD-8072
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Component: REGENLICHTSENSORH10 0040
   Coding: 00141886
   Shop #: WSC 02335
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H43 0470
   Revision: 00000000    Serial number: AUZ5ZBD6001919
   VCID: 1C3DC3ACDFAE90FE67F-8049
Address 0F: Digital Radio        Labels: 4E0-910-593-XM.lbl
   Part No SW: 4E0 910 593 G    HW: 4E0 035 593 C
   Component: SDAR XM         H04 0670
   Revision: 00000000    Serial number: AUZ4Z7D8017094
   VCID: 2B5F10708A0067461E5-807E
Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
   Part No SW: 4F0 910 655 B    HW: 4F0 959 655 A
   Component: 46 AIRBAG AUDI8RH28 0310
   Revision: 09H28000    Serial number: 00359D0708VX
   Coding: 0013366
   Shop #: WSC 08353 444 84867
   Subsystem 1 - Part No: 4F0 910 339
   Component: BF-Gewichtsens. 002 0040
   Subsystem 2 - Serial number: 6332CSME04091E4E7
   Subsystem 3 - Serial number: 6342CSME035B180E4
   Subsystem 4 - Serial number: 6351HSME03680B01$
   Subsystem 5 - Serial number: 6361HSME03420B7E9
   Subsystem 6 - Serial number: 6371VSME031E4C47S
   Subsystem 7 - Serial number: 6381VSME031D415BM
   Part No SW: 4F0 910 549     HW: 4F0 953 549 B
   Component: Lenks‰ulenmodul H07 0230
   Revision: 00H07000    Serial number: 90025042010073
   Coding: 0012241
   VCID: E6C92144D1621A2E81B-80B3
   Component: Lenkradmodul    H04 0080
   Part No SW: 4F0 910 900 A    HW: 4F0 920 950 M
   Component: KOMBIINSTR. M73 H08 0460
   Revision: 00200000    Serial number: 4I254XX74
   Coding: 0065263
   Shop #: WSC 06449 444 11649
   VCID: 1E39C9A4C9B282EE89B-804B
Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 B
   Component: Gateway         H09 0030
   Revision: 09          Serial number: 08008047250011
   Coding: 6CFE73CC1B1904
   Coding: 0082946
   VCID: E1C33258384C7D16749-80B4
   Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
   Component: TSG FA          H10 0020
   Revision: 00000000    Serial number: óW
   Coding: 0035563
   VCID: 2953EA7880FC7556EC9-807C
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 E    HW: 4F0 907 289 E
   Component: Komfortgeraet   H14 0090
   Revision: 00900014    Serial number: 01000539530000
   Coding: 0425021
   VCID: 2C5D136C8F0E607E17F-8079
   Subsystem 1 - Part No: 1K0 951 605 A
   Component: LIN BACKUP HORN H01 1201
01134 - Alarm Horn (H12)
                    Fault Frequency: 39
                    Reset counter: 73
                    Mileage: 265764 km
                    Date: 2014.05.04
                    Time: 14:25:41
   Part No SW: 4F5 910 223 D    HW: 4F5 035 223 E
   Component: DSP-High C6     H14 0310
   Revision: PROD_01     Serial number: 00000000005685
   Coding: 0000016
   VCID: 244DFB4CE7DEA83EDFF-8071
   Component: ILM Beifahrer   H07 0040
   Revision:             Serial number: 00000000024107
   Coding: 0011114
   VCID: DEB909A4093242EE49B-808B
   Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
   Component: TSG BF          H10 0020
   Revision: 00000000    Serial number: xp
   Coding: 0035563
   Part No SW: 4F0 910 801 A    HW: 4F0 907 801
   Component: EPB  CA3C0040   H03 0040
   Revision: --H03---
   Coding: 0006022
   Shop #: WSC 08353 444 54433
Address 55: Xenon Range        Labels: 4F0-910-357.lbl
   Part No SW: 4F0 910 357 A    HW: 4F0 907 357 A
   Component: AFS 1           H03 0010
   Coding: 0000016
   Shop #: WSC 02327 785 00200
   Subsystem 1 - Part No: 4F0 941 329 A
   Component: AFS-Modul links H05 0010
   Subsystem 2 - Part No: 4F0 941 329 A
   Component: AFS-Modul rechtsH05 0010
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541
   Component: TUNER EU/US/RDW H41 0620
   Revision: 00000000    Serial number: 352HT047549424
   VCID: 2E591964B912126E39B-807B
   Component: ENERGIEMANAGER  H11 0400
   Revision: 00000000    Serial number: 00000000041891
   Shop #: WSC 08091 444 59425
   Component: von VA0  1407270095
   Coding: 344630393135313035442056413031343037323730303935
   Shop #: WSC 00000 640 00290
   Part No SW: 4F0 910 795     HW: 4F0 959 795
   Component: TSG HL          H09 0010
   Coding: 0035370
   VCID: E9D32A78C07C3556AC9-80BC
   Part No SW: 4F0 910 795     HW: 4F0 959 794
   Component: TSG HR          H09 0010
   Coding: 0035370
   Component: Handyvorb2      H16 1130
   Revision: 00000000    Serial number: 00000007551085
   Coding: 0000000
                    Reset counter: 73
                    Mileage: 265785 km
                    Date: 2014.05.06
                    Time: 20:47:36
Check your ignition switch please.......for Terminal 50 proper function and good visual inspection.
Verify horn circuit via wire diagram and component.
Did you read out the phone module coding of old unit? Can you?
ProtoFly
C?ID=132348
I'll look at ignition switch and horn circuit, thanks. (alarm horn beeps, so maybe just wiggling the connector will help). For the ignition switch: Can I 'assume' that you are writing of the switch that the key physically goes into? Or something else? If my car were in your shop, what would you put the multimeter on first?
As to the phone module: Old one died, as they seem prone to do, and I don't have the coding for it. <sigh> Such is life, I suppose. Are the other fields mandatory? (Workshop, etc)
Jack, it is obvious that you spend a great deal of time helping others. Thank you. I hope to have the occasion to be in your area some time, and buy you a cold (beer, soda, whatever your preference).
ProtoFly
C?ID=132348
Great, that worked. Of course, now my phone won't connect, but that's a separate issue. (It worked a year ago, lol, before I pulled the engine to do the timing chain guides and tensioners).
One down, two to go.
Should be 0010900
Yes, you would think the last digit should be 2, it's not.
Language is handled by 07 on this vehicle.
Restart MMI after coding 77.
I would watch supply voltage values in VCDS with the ignition on after 10 minutes to see if battery is flaky first.
Visual inspections for damage/corrosion along with meter at main key switch first to steering module and than to BCM.
I do spend a great deal of my time...... helping others, because I really have always enjoyed it..... I am also in the business and others....its a balancing act for sure.
This site is by far the best I have seen so far....... weeding out mostly idiots/thieves........ where I don't have to worry about if I am helping a bad person stealing, from who I consider a valuable resource and friends in the industry.
Helping many over the years has not been without consequences......forcing me to hide behind email, not talking on phone, and a constant locked door/gate by appointment only.
You would not believe the amounts of money lost to change a light bulb for someone....... NC no doubt, or be disrupted by people which are so rude.
They expect I stop what I am doing to hear their mouth........ to only argue after actually getting the answer. ( oh face palms )
Here I answer what I want when I want, and the appreciation is nice Thank you.....
At least I am not forced to advertise as in Vortex to give things away......then get hammered for it even after paying for a stupid banner ad.
If you know someone who needs programming/keys or an ecu new/reman/data transfers....... etc.
Example: I more than likely if the coding was not able to be had from that module .......I could get it if RT didn't have it through forensic extraction.
jakematic
NC USA
C?ID=129085
Glad it worked.
Try clearing all recents on phone, remove connections via MMI.
You only have a short period after ignition on where you can pair with vehicle.
BT pin is adaptation channel 10 on 77.
ProtoFly
C?ID=132348
Glad it worked.
I'll give it a try immediately after ignition on. At the moment, my iPhone isn't even seeing it, which I find odd. Knowing how delicate the Audi BT interface is, it wouldn't surprise me if it went belly-up just from sitting for a year.
-Darryl
ProtoFly
C?ID=132348
So, I looked at the measurement values for terminal 50, and it simply said 'OFF'. The bentley is unclear as to the physical connection for that, else I'd just physically check it. B276, Plus Connection (50) (in main wiring harness). Component location section is unhelpful, doesn't point to B276 or 'Terminal 50'. Gotta love it.
ProtoFly
C?ID=132348
Bluetooth module seems to be malfunctioning, although no codes set. I tried various phones, none see the module to pair with it.
As to the terminal 50 thing: wiring diagram shows that the current flow goes through access start control module (J518), Engine harness D97 to starter, Starter relay. The car starts just fine. Maybe I've got another ground loose somewhere, and it is manifesting itself via the 01049 code.
jakematic
NC USA
C?ID=129085
Is it turned on ? See wiki page.
ProtoFly
C?ID=132348
Yes. (I should have put that in my post). Tried to switch the bluetooth off, reset, then on, to see if it would make a difference, and it did not.
Seems that the unit is typically sold on an exchange basis, which tells me that there's something inside that gets cooked, and is somehow replaceable. Might have to crack it open. I've got the original from the car, which went bad (dead), and now this one, which VCDS sees as good, but obviously the BlueTooth part isn't up to snuff.
