Results 1 to 1 of 1
Thread: Audi A5 8T coding on address 47 (J525) after CP removal
    Jan 2017
    Post Audi A5 8T coding on address 47 (J525) after CP removal
    Audi A5 8T coding on address 47 (J525) after CP removal anybody know i will upload scans before & after CP removal
    Tuesday,19,December,2017,22:00:49:26046
    VCDS Version: 17.8.1.0 (x64)  HEX-NET CB: 0.4407.4
    www.Ross-Tech.co
    VIN:
    Mileage: 183030km-113729mi   Repair Order:
    Chassis Type: 8T-AU48 (8T0)
    Scan: 01 02 03 05 07 08 09 0E 10 15 16 17 19 1E 37 42 46 47 52 53
              55 56 6C 77
    VIN:Mileage: 183030km-113729miles
    Address 01: Engine (J623-CGKA)       Labels:| 059-907-401-V1.clb
       Part No SW: 8K1 907 401 A    HW: 8K1 907 401 A
       Component: 2.7TDI EDC17  H01 0008
       Revision: --H01---
       Coding: 0114002C02070020
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_ECM27TDI0118K1907401A 001012
       ROD: EV_ECM27TDI0118K1907401A.rod
       VCID: AA185E00CD9A17166F-80FE
    7156 - Intake Manifold Flap Position Sensor (Bank 1)
              P2015 00 [032] - Implausible Signal
                        Mileage: 182914 km
                        Date: 2017.12.17
                        Time: 16:49:07
                        Coolant temperature: 4 °C
                        Intake air temperature: 6 °C
                        Voltage terminal 30: 10.540 V
                        Unlearning counter according OBD: 35
                        Crankshaft speed (RPM): 0.0 /min
                        Vehicle speed: 0.00 km/h
                        Vehicle voltage terminal 30: 10540 mV
                        Intake manifold flap offset position open: 14.65 %
                        Intake manifold flap offset position closed: 2.00 %
                        Intake manifold flap position sensor: 545.2 mV
                        V Sw Vlv st Mon B1-Bit 0: 00000000
                        V Sw Vlv st Mon B1-Bit 16: 00000000
                        V Sw Vlv st Mon B1-Bit 24: 00000000
                        V Sw Vlv st Mon B1-Bit 8: 00000000
    4533 - Please Check Fault Codes in Transmission Control Module
              U1026 00 [047] - -
                        Mileage: 182584 km
                        Date: 2017.10.25
                        Time: 21:54:33
                        Engine speed: 714.50 /min
                        Normed load value: 47.1 %
                        Vehicle speed: 3 km/h
                        Coolant temperature: 19 °C
                        Intake air temperature: 16 °C
                        Voltage terminal 30: 13.260 V
                        Crankshaft speed (RPM): 714.5 /min
                        Vehicle speed: 3.42 km/h
                        Accelerator position: 0.00 %
                        Vehicle voltage terminal 30: 13260 mV
                        Bus Diag st Node 0-Bit 0: 00000000
                        Com ct Rx TO TSC-Bit 0: 00000000
                        Cr C st Key 0-Bit 0: 00000000
                        Cr C st Key 0-Bit 8: 00000000
       Part No SW: 8K0 927 155 AG    HW: 0AW 927 156 G
       Component: 0AW 27 TDIRdW H01 0001
       Revision: --H01---    Serial number: 0000000088
       ASAM Dataset: EV_TCMVL381 A01014
       ROD: EV_TCMVL381_A01.rod
       VCID: F8BCB44843B6758629-80AC
    2228 - Transmission Output Speed Sensor (G195)
              P0722 00 [237] - No Signal
                        Fault Frequency: 237
                        Mileage: 182584 km
                        Date: 2017.10.25
                        Time: 21:54:32
                        Engine speed: 698.00 /min
                        Transmission input speed: 413 /min
                        Transmission output speed: 1 /min
                        Engine torque: 28 Nm
                        Transmission fluid temperature: 18 °C
                        Accelerator position: 0.0 %
                        Clutch status: 2
       Part No SW: 8K0 907 379 AA    HW: 8K0 907 379 AA
       Component: ESP8 front    H04 0060
       Coding: 1A0500
       VCID: F8BCB4484BB6758629-80AC
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Fault Frequency: 59
                        Reset counter: 86
                        Mileage: 182584 km
                        Date: 2017.10.25
                        Time: 21:54:32
                        Hex Value: 0x0340
                        Hex Value: 0x4002
                        Hex Value: 0x020A
                        Hex Value: 0x25A9
                        Hex Value: 0x00FF
       Part No SW: 8K0 907 064 AD    HW: 8K0 907 064 AD
       Component: BCM2 1.1      H71 0134
       Coding: 051000
       VCID: F2A886602DCA1FD617-80A6
       Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
       Component: ELVAUDIB8  H35 0039
       Serial number: 0208000021339004
    03285 - Sensor for Contact with Door Handle; Front Left
                        Reset counter: 112
                        Mileage: 182584 km
                        Date: 2017.10.24
                        Time: 22:32:58
    03286 - Sensor for Contact with Door Handle; Front Right
                        Fault Status: 01101011
                        Reset counter: 72
                        Mileage: 182584 km
                        Date: 2017.10.25
                        Time: 21:55:11
    Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
       Part No SW: 8T0 035 729 P    HW: 4E0 035 729 A
       Component: Interfacebox    H43 5170
       Revision: 00000000    Serial number: 331EO087524833
       Coding: 0005002
       VCID: C6C00AB0B1C2D3766B-8092
       Subsystem 1 - Part No: 8T0 919 609 C
       Subsystem 2 - Serial number: 00000000086605
       Subsystem 3 - Serial number: 0113.05.080000000100010321˙
       Subsystem 4 - Serial number: 010321˙
    02244 - Button in Control Head is Stuck
                000 -  -  - Intermittent
                        Reset counter: 116
                        Mileage: 182724 km
                        Date: 2017.11.12
                        Time: 01:13:52
                        Bin. Bits: 00000000
                        Bin. Bits:  0000000
                        Bin. Bits:      001
    00384 - Optical Databus
                        Fault Status: 00101011
                        Reset counter: 114
                        Time Indication: 15
       Part No SW: 8T2 820 043 T    HW: 8T2 820 043 T
       Component: KLIMA 3 ZONEN H06 0140
       Revision: D1000000    Serial number: 0107.05.080053
       Coding: 36060000
       VCID: C3C613A442F0E65E4C-8096
       Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
       Revision: 05022001    Serial number: 00000000147354
       Coding: 260050914034AF010009000300005D5D001D438800010141000000
       VCID: B02C4C68E3466DC6A1-80E4
       Subsystem 1 - Part No SW: 8T2 955 119 C    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 080508  H11 0040
       Serial number: SWFBIE 0000354
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10133161
       Coding: 02532C
       Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
       Component: E1 - LDS  H07 0070
       Serial number: 00000000002305081445
       Part No SW: 8T2 035 110 C    HW: 8T2 035 110 C
       Component: MP3-Changer     H42 0390
       Revision: 00042001    Serial number: AUZ5ZBH8426094
       VCID: AB165B040A600E1E94-80FE
    Address 10: Park/Steer Assist (J446)       Labels:. 8K0-919-475.clb
       Part No SW: 8K0 919 475 C    HW: 8K0 919 475 A
       Component: PARKHILFE 8K  H06 0010
       Revision: 11001001    Serial number: 75240814502518
       Coding: 300101
       VCID: B93A714C303CAC8E16-80EC
       Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
       Component: AirbagVW-AU10 H26 0410
       Serial number: 0038JD15U4NK
       Coding: 30323433363030303030554A305238543053
       VCID: BC346858370E99A60D-80E8
       Serial number: 6334MSME3D651845I
       Serial number: 6344MSME2D24640EJ
       Serial number: 6352QSME67762541F
       Serial number: 6362QSME68383269N
       Serial number: 63732SME661C27392
       Serial number: 63832SME661A3B194
       Component: Lenks.Modul   H12 0013
       Revision: --------    Serial number: 90304HEN000FX
       Coding: 000032
       VCID: BD32655C241490AE3A-80E8
       Part No SW: 8T0 920 981 B    HW: 8T0 920 981 B
       Component: KOMBIINSTR.   H28 0221
       Revision: 00200000    Serial number: 71Y27HF58
       Coding: 2F07000002002600010000
       VCID: BB366B443A009E9E04-80EE
       Part No SW: 8T0 907 468 K    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0092
       Revision: EB302042    Serial number: 4200E0851381A3
       Coding: 000303
       VCID: C9DA018C60DC3C0E86-809C
       Component: J367-BDM  H04 0150
       Serial number: 1801CEA1060508
                000 -  -
                        Reset counter: 74
                        Mileage: 182584 km
                        Date: 2017.10.24
                        Time: 22:19:54
    Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
       Part No SW: 4E0 035 785 D    HW: 4E0 035 785 C
       Component: SG ext.Player H15 0830
       Revision: 00000000
       VCID: A91AA10CC09C1C0E66-80FC
       Part No SW: 4E0 910 888 P    HW: 4E0 919 887 M
       Component: MNS ECE         H51 1060
       Revision: 00000000    Serial number: 333ET087575065
       Shop #: WSC 00976 210 67917
       VCID: BB366B44FA009E9E04-80EE
                        Reset counter: 114
                        Mileage: 182689 km
                        Date: 2017.11.08
                        Time: 21:40:42
       Part No SW: 8K0 959 793 A    HW: 8K0 959 793 A
       Component: TSG FA        H09 0149
       Revision:             Serial number: `
       Coding: 0110122240012201
       VCID: BE30625029128BB623-80EA
       Revision: 00002001    Serial number: 0111355933
       Coding: 011B0E8200390401002000
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 72
                        Mileage: 182584 km
                        Date: 2017.10.24
                        Time: 22:33:21
    02616 - Fuel Tank Cap; Unlock
                        Reset counter: 72
                        Mileage: 182584 km
                        Date: 2017.10.24
                        Time: 22:33:47
    00230 - Transmission Park Selector Switch (F305)
                        Fault Status: 01101000
                        Fault Frequency: 22
                        Reset counter: 86
                        Mileage: 182588 km
                        Date: 2017.10.25
                        Time: 22:16:32
       Revision: 00005001    Serial number: 94813003634502
       VCID: AD12551CF474002E8A-80F8
                000 -  -
                        Reset counter: 72
                        Mileage: 182584 km
                        Date: 2017.10.24
                        Time: 22:19:52
                        Voltage: 11.70 V
                        Temperature: 39.0°C
                        Temperature: 41.0°C
                        Bin. Bits: 00000100
       Part No SW: 8K0 959 792 A    HW: 8K0 959 792 A
       Component: TSG BF        H09 0149
       Revision:             Serial number: sX
    02111 - Motor for Window Regulator
                        Fault Status: 01100101
                        Reset counter: 73
                        Mileage: 182589 km
                        Date: 2017.10.25
                        Time: 22:28:03
       Part No SW: 8K0 907 801 D    HW: 8K0 907 801 D
       Component: EPB Audi B8   H04 0050
       Revision: 00000003    Serial number: 00000000131727
       Part No: 8K0 907 357 B
       Coding: 0000001
       Shop #: WSC 06324 000 00000
       VCID: B4244078D75E51E6C5-80E0
       Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
       Component: TUNER EU/US/RDW H42 0620
       Revision: 00000000    Serial number: 336EQ087562522
       Coding: 0000001
       VCID: AE10521039727B36B3-80FA
       Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
       Component: J772__Rearview      0070
       Revision: --H12---    Serial number: 525PA8-J8391M0
       Coding: 1022008
       VCID: B73E7774C628BAFEE0-80E2
    Address 77: Telephone        Labels: 4E0-910-336.lbl
       Part No SW: 4E0 910 336 K    HW: 4E0 862 335
       Component: Handyvorb2      H20 0950
       Revision: 00000000    Serial number: 00000005167854
       Coding: 0010920
       VCID: AA185E00059A17166F-80FE
    End----(Elapsed Time: 01:55, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
    Friday,22,December,2017,21:27:14:26046
    VCDS Version: 17.10.0.2 (x64)  HEX-NET CB: 0.4407.4
    Data version: 20171026 DS283.3
    Dealer/Shop Name
    VINLicense Plate:
    Mileage: 183110km-113779mi   Repair Order:
              55 56 6C 77
    VIN:
      Mileage: 183110km-113779miles
       Revision: --H01---
       VCID: AA185E00CD9A177A42D-80FE
       VCID: F8BCB44843B675EA049-80AC
       Coding: 1A0500
       VCID: F8BCB4484BB675EA049-80AC
       Coding: 051000
       VCID: F2A886602DCA1FBA3AD-80A6
       Subsystem 1 - Part No SW: 8T0 959 754 K    HW: 8T0 959 754 K
       Serial number: 0508000020033010
       Coding: 0005002
       VCID: C6C00AB0B1C2D31A465-8092
       Coding: 36060000
       VCID: C3C613A442F0E63261B-8096
       VCID: B02C4C68E3466DAA8C9-80E4
       Coding: 00FD11
       Coding: 02532C
       VCID: AB165B040A600E72B9B-80FE
       Coding: 300101
       VCID: B93A714C303CACE23B7-80EC
       VCID: BC346858370E99CA201-80E8
       Coding: 000032
       VCID: BD32655C241490C217F-80E8
       Shop #: WSC 17850 003 1048576
       VCID: BB366B443A009EF229B-80EE
       Coding: 000303
       VCID: C9DA018C60DC3C62AB7-809C
       Revision: 00000000
       VCID: A91AA10CC09C1C624B7-80FC
       VCID: BB366B44FA009EF229B-80EE
       VCID: BE30625029128BDA0E5-80EA
       VCID: AD12551CF4740042A7F-80F8
       Coding: 0000001
       VCID: B4244078D75E518AE81-80E0
       Coding: 0000001
       VCID: AE10521039727B5A9E5-80FA
       Coding: 1022008
       VCID: B73E7774C628BA92CD3-80E2
       Coding: 0010920
       VCID: AA185E00059A177A42D-80FE
    End----(Elapsed Time: 01:51, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
    √ƇṖ ƇΛИ ṖŔᎾ + √ĪM FĪĿƐS ~ √ƇDS ĤƐӾ √②
