- Aug 29, 2014
- 75
- 23
- Oswego, IL
- C?ID=224526
Twelve choices listed for "Assistance light functions"
Greetings: I attempted the High Beam Assist on my 2016 NAR Golf Sportwagen TSI SEL but ran into an issue when I followed the directions from post #29; it appears that the only option for headlight styles following this is the halogen whereas I have the bi-xenon. I did get the correct sub-menu to pop up in my MMI but each time I attempted to activate it, an error code would be thrown. I included the twelve different options under "Assistance Light Functions". Attempting the "IDE08786-ENG116637-Assistance light functions-Menueesteuerung Fernlichtassistent" will not provide an option for bi-xenon. Any insight would be appreciated!
Don, thanks for the prompt reply!
I didn't see an option for bi-xenon, only the standard lamps. I'm wondering if I should pick one of the eleven other options under "Assistance Light Functions" to see if the bi-xenon is there.
The only difference between my earlier and latest autoscan is my resetting of the original parameters and removing any error codes.
What are the new "yellow" screens you refer to in the latest RT software?
Thanks again and I look forward to your reply!
P.S. The McSpiffy derives from an adult Scouting program (WoodBadge); we were the Beaver Patrol and each of us had to personalize our mascot as a signature. Since I bagpiped, I had a bagpiping beaver as my signature (kinda like McSquizzy from the animated movie "Open Season") http://openseason.wikia.com/wiki/File:Quizzy3.jpg
Saturday,01,July,2017,22:38:11:06278
VCDS Version: 17.6.0.2 (x64) HEX-NET CB: 0.4341.4
Data version: 20170602 DS274
VIN: 3VWC17AU4GM501532 License Plate: V93 8607
Mileage: 31994km-19880mi Repair Order: 070117B
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 47 52 55 5F
75 A5
VIN: 3VWC17AU4GM501532 Mileage: 31994km-19880miles
2B-Steer. Col. Lock -- Status: Malfunction 0010
Address 01: Engine
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 749 AP HW: 09G 927 749 AP
Component: AISIN AG6 G3 129 2943
Shop #: WSC 00066 790 00221
ROD: EV_TCMAQ250031_002_VW25.rod
VCID: 075E5B89BE35B27F80-8052
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 61255000000354
Coding: 04FA6AA12420096D007C020381C5292056249000408194B416435052C082
Shop #: WSC 01383 790 50316
VCID: 7AB8327DFDC7DF978F-802E
10 Faults Found:
8246 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:36:01
8250 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:36:02
8252 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:57
8254 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:57
8256 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:58
8258 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:57
8264 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:57
8351 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:59
16409 - Display for Tire Pressure Monitoring
C1146 02 [008] - Signal Failure
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:36:07
16410 - Display for Tire Pressure Monitoring
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:36:07
Revision: 00021000 Serial number: 0367374266
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_002_VW37.rod
VCID: 3A38F27DBD471F97CF-806E
12716804 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:57
Part No SW: 5GM 907 044 A HW: 5GM 907 044 A
Component: Climatronic H03 1001
Revision: 00001K01
Coding: 02020024200100000105000012111402
VCID: 42C88A9DD597575797-8016
Air quality sensor:
459525 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:57
459023 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:57
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 087 AA HW: 5Q0 937 087 AA
Revision: -------- Serial number: 86581605150679
Coding: 00511B464041A2E969E44000001407001800000000000000000000000000
Shop #: WSC 00066 790 00211
ROD: EV_BCMBOSCH_015_VW37.rod
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150430 043 0581
Serial number: 150628095715
Component: RLHS 037 0059
Serial number: S5Y15M05D11H20M57S08
Coding: 90A8DD
Sun Roof:
Subsystem 3 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J245 PS22.409 H03 0004
Serial number: 0000FST0009CPKU00000
Coding: 191800
Roof Blind:
Subsystem 4 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J394 PS22.409 H03 0004
Serial number: 0000FST0009CQ2D00000
Coding: 191800
7 Faults Found:
534549 - Databus
Fault Frequency: 11
Reset counter: 69
Mileage: 30204 km
Date: 2017.06.27
Time: 20:10:25
541973 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:57
559125 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:36:01
555541 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:57
542229 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:57
542485 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:36:01
329480 - Heated Passenger Seat
B1806 F0 [008] - Safety Shut-Off due to Occupant Detection
Reset counter: 107
Mileage: 31152 km
Date: 2017.06.30
Time: 10:46:10
Part No SW: 5Q0 919 298 K HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0054
Revision: -------- Serial number: 39431513200575
Coding: 0031165011
ASAM Dataset: EV_EPHVA2CAU3700000 003021
ROD: EV_EPHVA2CAU3700000_003_VW37.rod
VCID: 47DE9B89FEB5727F40-8012
13637426 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:57
12648465 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:57
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 D
Component: ACC Bosch MQB H05 0400
Serial number: 13031503210237
Coding: 01045400FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
10 Faults Found:
1066 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:58
Control Module temperature: 51 ∞C
Voltage terminal 15: 12.4 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s≤
1056 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:58
0276 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:58
0277 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:36:01
0278 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:36:01
0279 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:57
Control Module temperature: 50 ∞C
0280 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:36:01
0281 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:57
1050 - Transmission in Limp Mode
P305B 00 [008] - -
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:57
1043 - Automatic Distance Control
B10E7 F0 [008] - Disconnected
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:59:33
Control Module temperature: 53 ∞C
Voltage terminal 15: 12.2 V
Component: AirbagVW20 009 0825
Serial number: 003GCR01Y1DL
Occupant Detection:
Component: BF-Gewichtss. H11 0021
Serial number: IBH0000J1500031ZIL0K
Coding: 303137
Subsystem 2 - Part No SW: ----------- HW: 480 002 305 15
Serial number: 357000000000A560A418
Subsystem 3 - Part No SW: ----------- HW: 480 002 205 15
Serial number: 358000000000D0B06418
Subsystem 4 - Part No SW: ----------- HW: 480 402 704 15
Serial number: 3510002C91A91E714070
Subsystem 5 - Part No SW: ----------- HW: 480 402 804 15
Serial number: 35200029B1A87872711+
Subsystem 6 - Part No SW: ----------- HW: 480 400 505 15
Serial number: 3550002AF1A8787292DL
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 505 15
Serial number: 3560002B31A878729376
Part No SW: 5Q0 953 521 BB HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150328500718
Coding: 0C10
ROD: EV_SMLSVALEOMQB_VW37.rod
VCID: 73A61F59DAADAEDFCC-8026
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 5G1 920 840 A HW: 5G1 920 840 A
Component: KOMBI 242 6420
Coding: 0BA4111AED98CF0502886A0B5000000000000000
Shop #: WSC 00066 790 00194
VCID: 2502310124F9806F92-8070
16776971 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:57
16776988 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:57
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M
Component: GW MQB High 212 2223
Revision: -------- Serial number: 22051510000845
Coding: 0901000830085900FB00021A1C0F00000001050000000000000000000000
ROD: EV_GatewConti_013_VW37.rod
VCID: 75A22141D4D9B0EFE2-8020
Subsystem 2 - Part No SW: 5G0 959 442 R HW: 5G0 959 442 R Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0040
Serial number: 29150000641010105136
Coding: 35FFFF
Power Converter DC AC:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H53 0041
Serial number: 0071941
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [008] - -
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:36:00
Supply voltage: Terminal 30: 12.3 V
Terminal 15: On
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000127554002
Coding: 5D00000000000000
Shop #: WSC 00066 790 07025
ROD: EV_ELVMarquMQB_004_VW37.rod
VCID: 3424DC459F23E9E715-8060
12666369 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:56
ELV State: 04
Information Clamps: 77 60
CoCo State: A0 01
WFS State: 17 06
Vehicle speed: 0.00 km/h
Voltage: 6B
AD-Value H-bridge: 35
Clamp15 flip flop: SSTx: button contacts: 06
CAN signals: 00
12666381 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:57
ELV State: 04
CoCo State: A0 01
WFS State: 17 06
Voltage: 6B
CAN signals: 00
Address 3C: Lane Change (J1086) Labels:* None
Component: HRE_Master H11 0071
Serial number: 0368374670
Coding: 02011103
ROD: EV_HREntryHella_VW32.rod
VCID: 3C34F465B77321A7DD-8068
Component: TSG FS 020 0041
Serial number: 0506150605043U
Coding: 003A13200000040000000000
VCID: 43C68F99CA8D5E5F9C-8016
Serial number: 00000000000001360106
Coding: 011000
458803 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:57
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 1302
ROD: EV_SteerAssisMQB.rod
22272 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:58
Motor status: 00
Supply voltage: 12.25 V
Temperature: 52.0 ∞C
KFC: 57
KFA: 00 00
Environmental conditions: 20
uioUdNotFilt_xdu16: 12.30 V
uAdSensI_SwitchedKl30_xdu16: 12.31 V
22528 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:58
Motor status: 00
KFC: 58
KFA: 00 00
23040 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:58
Motor status: 03
System status: Driving mode
KFC: 5A
KFA: 00 00
22784 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:58
Motor status: 03
KFC: 59
KFA: 00 00
Environmental conditions: 21
uioUdNotFilt_xdu16: 12.50 V
uAdSensI_SwitchedKl30_xdu16: 12.49 V
19460 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:59
Motor status: 03
KFC: 4C
KFA: 00 04
23296 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:36:01
Motor status: 03
KFC: 5B
KFA: 00 00
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H20 0110
Revision: 00000001 Serial number: VWZ8Z1FBA00BE4Z
VCID: 6D920921BC89782F1A-8038
Component: TSG BFS 020 0041
Serial number: 170615060504TQ
Serial number: 00000000000001369331
Coding: 091000
458803 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:57
Component: AFS-ECU H07 0090
Coding: 061A00010B000400
VCID: 40CC8095DB9B454781-8014
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
13705475 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:57
Part No SW: 3Q0 035 876 HW: 3Q0 035 876
Component: MU-S-NS-US H25 0241
Serial number: VWZAZ2R0154122
Coding: 027302020000000051220002001808001F0100F401200105C6
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 71AA1551A0B19CCF3E-8024
Subsystem 1 - Part No SW: 5GM 919 605 HW: 5GM 919 605
Component: ABT_Std-2_Nav H52 1028
Serial number: VWZ8Z9RFC000K0
Subsystem 2 - Part No SW: 3G0 919 866 B HW: -----------
Component: NAR 2015/16 --- 0220
6708 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:57
Voltage terminal 30: 12.4 V
Network diagnosis-Status: Enabled
Component: OCULowMQBUS 007 0564
Coding: 02730202C2823A017F1E06000000
Shop #: WSC 00066 790 00323
ROD: EV_OCULowMQB_VW37.rod
0041 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:56
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H06 0060
Serial number: 10000355732
Coding: 0100000000020306000400010100000100
ROD: EV_MFKBoschAU370.rod
3080192 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:58
Control Module temperature: 61 ∞C
Outside air temperature: 29.5 ∞C
Voltage terminal 15: 12.3 V
System run time: 1513.1 s
3670016 - Databus
Reset counter: 106
Mileage: 30278 km
Date: 2017.06.29
Time: 14:35:57
System run time: 1512.5 s
End----------(Elapsed Time: 02:03, VBatt start/end: 13.8V/13.7V)-----------
That's AWESOME, Don! Thanks so much for clarifying (+visuals) . . . I'm starting to see the light! I guess my next question is should I go back and change the sixth alpha-numeric from a "B" back to an "A"?
Don,
A new "wrinkle" in my latest adjustment is that my backup camera no longer functions; would one of the other options under Byte 2 allow for the backup camera?
Tuesday,18,July,2017,17:44:58:06278
Dealer/Shop Name: Moose Lodge VW Den
Mileage: 33052km-20537mi Repair Order: 071817B
75 A5
VIN: 3VWC17AU4GM501532 Mileage: 33052km-20537miles
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 F HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0003
Revision: --H13---
Coding: 091A00322464002F1000
ASAM Dataset: EV_ECM18TFS0208V0906264F 001003
ROD: EV_ECM18TFS0208V0906264F.rod
VCID: 3FCE8369A6653ABFF8-806A
Coding: 030C0C
Revision: 00001K01
Air quality sensor:
Coding: 005122464041A2E969E44000001407001800000000000000000000000000
Coding: 90A8DD
Sun Roof:
Coding: 191800
Roof Blind:
Coding: 191800
534549 - Databus
Reset counter: 121
Mileage: 32152 km
Date: 2017.07.07
Time: 20:44:55
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Reset counter: 77
Mileage: 32316 km
Date: 2017.07.08
Time: 12:45:16
Reset counter: 124
Mileage: 32152 km
Date: 2017.07.07
Time: 20:46:01
Coding: 0031165011
1542 - Sensor for Automatic Distance Control
Reset counter: 118
Mileage: 32741 km
Date: 2017.07.12
Time: 12:12:43
Control Module temperature: 33 ∞C
Voltage terminal 15: 13.7 V
Vehicle speed: 28.17 m/s
Acceleration: 0.02 m/s≤
Occupant Detection:
Coding: 303137
Coding: 0C10
Coding: 35FFFF
Coding: 02011103
Coding: 011000
Coding: 1302
Coding: 091000
Coding: 2E0000
Coding: 2E0000
End----------(Elapsed Time: 01:44, VBatt start/end: 13.4V/13.5V)-----------
Coding: 90A8DD
Sun Roof:
Coding: 191800
Roof Blind:
Coding: 191800
534549 - Databus
Reset counter: 121
Mileage: 32152 km
Date: 2017.07.07
Time: 20:44:55
Reset counter: 77
Mileage: 32316 km
Date: 2017.07.08
Time: 12:45:16
Reset counter: 124
Mileage: 32152 km
Date: 2017.07.07
Time: 20:46:01
Reset counter: 118
Mileage: 32741 km
Date: 2017.07.12
Time: 12:12:43
Since my recent change, I no longer have a backup camera functioning and now I have options under ACC for Eco/Normal/Sport . . . I don't recall having the choice previously.
