2016 A7 Matrix led headlight is broken
Hi
I'm new of this forum.
#And sorry that my english is very poor and strange...
I had set some coding DRL and other to my car(2016 A7SB).
After that, matrix led lights error appear on the console.
And error detected module09 and module55.
It may be resetted Matrix Led Headlight setting to zero.
I'd like to know reset this setting to basic setting and not to apear error message on the console.
Please let me know how.
#Do you understand my poor english?
#Thanks
Your English is OK. But please post an Auto-Scan so people can see how the car is equipped and configured, and any faults that may be present.
Thanks for your reply.
And below is full scan of my car.
Saturday,05,December,2015,11:26:42:63270
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
VIN: WAUZZZ4G9Gxxxxxxx License Plate:
Mileage: 392km-243mi Repair Order:
Chassis Type: 4G (4G8)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3B 3C 42 44 46 52
53 55 5F 62 6C 6D 72 82 84 85 8B 8E 8F 90
VIN: WAUZZZxxxxxxxxxxx Mileage: 392km-243miles
84-Night Vision -- Status: OK 0000
Address 01: Engine (J623-CREC) Labels: None
Part No SW: 4G2 907 551 B HW: 4H2 907 551 A
Component: 3.0l V6 TFSI H10 0001
Revision: --H10---
Coding: 1A2500340567010B3000
ASAM Dataset: EV_ECM30TFS0214G2907551B 002001
ROD: EV_ECM30TFS0214G2907551B.rod
VCID: 2A50CBB04D080F6E15-807E
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 4G0 927 166 D HW: 0B5 927 156 K
Component: 0B5 30TFSIRdW H03 0009
Revision: --H03---
Coding: 100001
ASAM Dataset: EV_TCMDL501021 001021
ROD: EV_TCMDL501021.rod
VCID: 2E58C7A071E0634EC9-807A
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 44A68F4B2265F1D29B00
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 41828C1CD07EEC3624-8014
Part No SW: 4H0 907 064 GR HW: 4H0 907 064 GR
Component: BCM2 2.0 H37 0572
Coding: 059A6F0E000000000000
VCID: 7F06CAE4EE0A5AC612-802A
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Component: KLIMA 4 ZONEN H14 0112
Serial number: 28071500041353
Coding: 662371B8350000
ROD: EV_AirCondiComfoUDS.rod
VCID: 63CE66946AA29E2616-8036
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 4H0 907 063 DG HW: 4H0 907 063 AG
Component: BCM1 2.0 H20 0311
Revision: 14020001 Serial number: 00001129677002
Coding: 0105409140309FE2C1014083A0001800CF9DC2082F080201000008946101130200400009090000
VCID: 70E419D8A35435BE9B-8024
Component: WWS57X 150626 H37 0080
Coding: 004DF7
Component: G397_RLFS H06 0002
Coding: 000023
Subsystem 3 - Part No SW: 4G0 941 531 BH HW: 4G0 941 531 BH
Component: E1 - LDS H07 0044
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
03455 - Function Restriction due to Faults in Other Modules
Reset counter: 46
Mileage: 334 km
Date: 2015.11.29
Time: 12:10:59
Address 10: Park/Steer Assist (J791) Labels: None
Part No SW: 4G0 919 475 G HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0070
Revision: -------- Serial number: 56231520200066
Coding: B83B10
ASAM Dataset: EV_EPHVA2CAU64X0000 001011
ROD: EV_EPHVA2CAU57X0000.rod
VCID: 356AE8CC94B6509688-8060
Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 561 B HW: 4G0 907 561
Component: ACC3 H21 0053
Coding: 7E02010201
ASAM Dataset: EV_AdaptCruisContrAU57X 002014
ROD: EV_AdaptCruisContrAU57X.rod
VCID: 295234BC480E04761C-807C
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P1005WK66
Coding: 30333046313130313134554A305234473853
VCID: 3B7EFEF4B29286E67E-806E
Serial number: 3575HRB404R3BS605OU2
Serial number: 3585HRB40553BS62EPCJ
Serial number: 3515JRB404V3I0AS6058
Serial number: 3525JRB40573FQH0BHNS
Serial number: 3554VRB40533IQQ8H1C.
Serial number: 3564VRB400253408A9DG
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372OGU000OL
Coding: 0000FC
VCID: 3776E2C486BAA2869A-8062
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 934 G HW: 4G8 920 934 G
Component: TBenRdwAccNv H10 0104
Revision: 06001087 Serial number: 658170715596042
Coding: 338700020F53000E0F0100
ASAM Dataset: EV_RBD4K 004055
ROD: EV_RBD4K.rod
Part No SW: 4G8 907 468 F HW: 4G8 907 468
Component: J533--Gateway H14 0083
Revision: -------- Serial number: 00000001949361
Coding: C0CD073018
ASAM Dataset: EV_GatewPkoUDS 001028
ROD: EV_GatewPkoUDS.rod
Serial number: 8393827303
Voltage stabilizer:
Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
Part No SW: 4G0 919 158 R HW: 4G0 919 158 R
Component: KLIMA FOND H08 0112
Serial number: 25071500040110
Coding: 22
ROD: EV_ClimaContrUnitRearUDS.rod
VCID: 3E78F7E0A18093CE59-806A
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000158597595
Coding: 00781B0000006001000001010101102030303232203232
VCID: 77F622C4C63A62865A-8022
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA8209Z49I
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2_AU57.rod
VCID: 3668EFC089B05B8E81-8062
Address 3C: Lane Change (J769) Labels: 5Q0-907-566.clb
Part No SW: 4G0 907 566 M HW: 4H0 907 566 F
Component: SWA Master H06 0060
Serial number: 0374766770
Coding: 040312
VCID: 3972E4FCB8AEB4F66C-806C
Lane Change Assistant 2:
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0511
Coding: 011F57035E01628002080413
VCID: 458A980CCC56C01618-8010
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 4G0 909 144 S HW: 4G0 909 144 G
Component: RCEPS H43 0012
Revision: 00001000 Serial number: 0013025082
Coding: 101101010001
ASAM Dataset: EV_RCEPS 009013
ROD: EV_RCEPS.rod
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0374684160
Coding: 01000E3820B9B081C3300A800C030D400000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
Subsystem 2 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H11 0029
Subsystem 3 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Component: GEB.F.Heckoef H16 0811
Component: TSG BF H03 0511
Coding: 011F57035E01628002080402
VCID: 46889F00F150CB0E11-8012
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001556241
ROD: EV_ParkiBrake_AU48.rod
VCID: 2D5AC0AC7CE61856F0-8078
Address 55: Headlight Range (J745) Labels: 4H4-907-357-V2.clb
Component: MxB-ECU 001 0100
Coding: 05FE02202A180200
ROD: EV_HeadlRegulAUDIMXBAU64X_AU57.rod
VCID: 346CD5C89FCC499EBF-8060
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E02100
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E02100
Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo li. H03 0031
Coding: E02100
Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo re. H03 0031
Coding: E02100
5350720 - Left Matrix High Beam
C1175 54 [137] - Missing Calibration / Basic Setting
Reset counter: 46
Mileage: 334 km
Date: 2015.11.29
Time: 12:11:10
5350976 - Right Matrix High Beam
C1176 54 [137] - Missing Calibration / Basic Setting
Reset counter: 46
Mileage: 334 km
Date: 2015.11.29
Time: 12:11:10
Part No SW: 4G1 035 034 A HW: 4G1 035 034
Component: MU-H-TN-JP 040 0010
Serial number: K5F AW7H103KA9
Coding: 017503060000000013330002001200102F000CE6F17001007E
ASAM Dataset: EV_MUHig6C3Gen2AW7 001290
ROD: EV_MUHig6C3Gen2AW7_AU37.rod
VCID: 1C3C1D68175CE1DE97-8048
Engine Control Module 2:
Subsystem 1 - Part No SW: V03 959 801 GP HW: -----------
Component: JPN 2015/2016 --- 7412
Seat Adjustment Driver Side:
Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A
Component: DU8 C7 SV H63 0006
Serial number: AUZ8Z9FY8028JD
Door Electronics Driver Side:
Subsystem 3 - Part No SW: 8V0 919 813 B HW: 8V0 919 813 B
Component: DSRC UNIT H06 0002
Serial number: 502129338735
Brake Assistance:
Subsystem 4 - Part No SW: 8V0 035 504 B HW: 8V0 035 504 B
Component: VICS Antenna H06 0001
Serial number: 503310086703
Sound System:
Subsystem 5 - Part No SW: 4G2 919 610 G HW: 4G2 919 610 G
Serial number: 90349OGL0004P
Door Electronics Rear Left:
Subsystem 6 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 2006
Component: TSG HL H03 0511
Coding: 010F15024001628002080002
VCID: 4992943CE04E2476FC-801C
Address 6C: Back-up Cam. (J928) Labels: None
Part No SW: 4H0 907 428 D HW: 7P6 907 441 F
Component: TopView H07 0330
Revision: 11001001 Serial number: 82330JF0243224
Coding: 0216000001000100000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
ROD: EV_CamerSysteTopViewAUDI.rod
Address 6D: Trunk Elect. (----) Labels: Redir Fail!
Part No SW: 4G8 959 107 S HW: 4G8 959 107 H
Component: HDSG-Modul H14 0049
Revision: 11014001 Serial number: 202501689
Coding: 0A3305C022
ASAM Dataset: EV_HDSGAu573 001022
ROD: EV_HDSGAu571.rod
VCID: 458A980CC456C01618-8010
Component: TSG HR H03 0511
Address 82: Heads Up Display (J898) Labels: None
Part No SW: 4G8 919 604 N HW: 4G8 919 604 N
Component: HeadUpDisplay H07 0305
Coding: D60000
ASAM Dataset: EV_HUDContiC7 001027
ROD: EV_HUDContiC7.rod
Address 84: Night Vision (J853) Labels: None
Part No SW: 4G0 907 547 A HW: 4G0 907 547
Component: NV-ECU-Gen3 H08 0107
Serial number: 622352400201505
Coding: 401100
ASAM Dataset: EV_NightVisioGen3AE4AU64X 001001
ROD: EV_NightVisioGen3AE4AU64X.rod
VCID: 2C5CCDA847FC115EE7-8078
Subsystem 2 - Part No SW: 4G0 980 552 HW: 4G0 980 552
Component: NV-CAM-Gen3 H03 0006
Serial number: 623466500F1518100177
Address 85: On Board Cam. (J852) Labels: None
Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
Component: DPC-SG H27 0081
Revision: -------- Serial number: 262130025421000
Coding: 6A160000
ROD: EV_OnBoardCamerDPC.rod
Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 541 B HW: 4G0 907 541
Coding: 7E02010201
ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
ROD: EV_AdaptCruisContr2AU57X.rod
VCID: 275632845E1A32060A-8072
Address 8E: Image Processing (J851) Labels: None
Part No SW: 4H0 907 107 H HW: 4H0 907 107
Component: BV-SG H33 0090
Serial number: 005000622907157
Coding: 03C338180111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H13 0080
Coding: 0066E608031F0376070308004240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 3162DCDC60DE7CB6D4-8064
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 3260D3D065D847AEAD-8066
End-------------------------(Elapsed Time: 06:10)--------------------------
Reason: CODE tags
Post Thanks / Like - 2 Likes
NostraJackAss
http://wiki.ross-tech.com/wiki/index...d_Front_System
Did you save an archive auto-scan so you can go back if needed?
Certified Master Trained NY/BAR/BAD 7076062/ASE/SAE/NASTF Legal Factory Authorized/Licensed
GeKo/FaZit # 403738
www.FixMyEuro.com <<<<<CLICK HERE! or
vwemporium@aol.com ( JPPSG & Unverified members need not PM me & Please don't email or call facility for free tech support...use the forum )
Yes I saved an archive autoscan.
But I don't know how can I go back.
And I don't know security access number to module#55 of my A7.
didn't work for me. also manual is for xenon.
any procedure for matrix led?
Sunday,10,November,2019,22:29:51:31877
VCDS Version: Release 19.6.2 (x64) Running on Windows 7 x64
Address 55: Headlight Range Labels: 4H4-907-357-V2.CLB
Control Module Part Number: 4H4 907 357 E HW: 7P6 907 357 B
Component and/or Version: MxB-ECU 001 0100
Software Coding: 05FE02202A170200
Work Shop Code: WSC 02391 785 00200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009 (AU57)
VCID: 346730BB9F47EAEF73-8060
Fault Codes have been Erased
Reset counter: 26
Mileage: 49656 km
Date: 2019.11.10
Time: 22:26:36
Reset counter: 26
Mileage: 49656 km
Date: 2019.11.10
Time: 22:26:36
