- Joined
- May 6, 2014
- Messages
- 3
- Reaction score
- 1
- VCDS Serial number
- C?ID=52893
Hi all. New to the forum but a long time user of HEX+CAN USB interface for basic stuff and diagnostics.
I need a bit of support with my Audi A8 (D3) 4.0TDI 2003MY. The car has a couple of issues, but the most critical seems to be with the Control Head (address 07). I am getting "Component Protection - No or Incorrect Basic Setting/Adaptation". It has had this issue since I bought the car 4 years ago, but I really need to fix it before it kills another battery. Full scan included below.
I have attempted to code the Control Head - and it keeps the coding while the engine is switched on. However, after switching off - it seems to revert back to no coding after a short period of time. This results in the climate control thinking that the car is LHD, and all language settings reverting to default (German/Deutsch), amongst other things. In addition, I think it also results in a large drain on the battery - although I havent been able to confirm. Coding attempted is 0000002 with shop#: WSC 02313 785 00200. I have then added some of the fitted options via adaptation and they all work - until I switch off the engine - although the component protection DTC remains throughout, even after clearing DTCs for this module.
Do I need to access the "Security Access" option to code this module when it is in this condition? I have tried security access codes 08108 & 01850 based on some info found on the web and the serial number of the Control Head - but neither worked.
Any assistance greatly appreciated.
Thursday,01,May,2014,22:40:16:18626
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WAUZZZ4E84N007999 License Plate: D10 CEE
Mileage: 187250km-116351mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 11 31 13 15 16 17 18 19 1D 1E 25 28
34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 72 76 77
VIN: WAUZZZ4E84N007999 Mileage: 187250km/116351miles
1D-Driver Ident. -- Status: Malfunction 0010
57-TV Tuner -- Status: Malfunction 0010
Part No SW: 4E0 910 409 C HW: 4E0 907 409 B
Component: 4.0L 4V/TDI A000AGMª0020
Revision: <> Serial number: AUX3Z0C7320871
Coding: 0010773
Shop #: WSC 02313 785 00200
VCID: 234E57C1E29D3A06A65-8076
19591 - Intake Manifold Runner Control
P3135 - 000 - Lower Stop not Reached
Torque: 19.5 Nm
Duty Cycle: 88.3 %
Duty Cycle: 20.3 %
Duty Cycle: 0.4 %
Temperature: 91.8°C
18284 - Valve for Torque Support Mount
P1876 - 000 - Open Circuit - Intermittent
RPM: 126 /min
Torque: 19.5 Nm
Bin. Bits: 0
Bin. Bits: 0
Bin. Bits: 0
Temperature: 89.1°C
Readiness: 0 0 X X X
Part No SW: 4E0 910 156 J HW: 09E 927 156 A
Component: AG6 09E 4,0LTDI RdW 0040
Revision: 00000001 Serial number: 0018770
Shop #: WSC 00515 210 88537
VCID: 295245E980B1E056EC9-807C
Part No SW: 4E0 910 517 A HW: 4E0 614 517 A
Component: ESP 5.7 allrad H29 0420
Coding: 0008557
Shop #: WSC 02313 000 00000
VCID: 21425DC9F8812816B49-8074
00003 - Control Module
014 - Defective
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 C
Component: FBS AUDID3 H03 0120
Revision: 01203603 Serial number: AUX3Z0C7320871
Coding: 0411648
Shop #: WSC 02311 785 00200
VCID: D8B4B02D6B5B29DE037-808D
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H06 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063456
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 729 F HW: 4E0 035 729 A
Component: Interfacebox H43 0350
Revision: 00000000 Serial number: 300EH037518580
Coding: 0000000
VCID: 2B5EBFE18A4DF2461E5-807E
Subsystem 1 - Part No: 4E0 910 609
Component: Bedienteil MMI H41 0010
Subsystem 2 - Serial number: 318GT037504757
Subsystem 3 - Serial number: ÿÿ29.07.03ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Subsystem 4 - Serial number: ÿÿÿÿÿÿÿ
02084 - Component Protection
Fault Status: 01100101
Reset counter: 146
Mileage: 175054 km
Date: 2013.06.22
Time: 14:25:19
Fault Status: 00100101
Reset counter: 146
Mileage: 185622 km
Date: 2014.03.13
Time: 15:31:28
Reset counter: 147
Mileage: 185625 km
Date: 2014.03.14
Time: 15:33:18
Part No SW: 4E0 910 043 HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 015 0240
Revision: 00000018 Serial number: 00000000022716
Coding: 0088185
VCID: DAB0AA2515573BCE353-808F
Subsystem 1 - Part No: 4E0 910 772
Component: Sitzluefter FS H05 010
Subsystem 2 - Part No: 4E0 910 772
Component: Sitzluefter BFS H05 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO08082003065A000000000066ÿ†89
Subsystem 5 - Serial number: 000066ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO08082003065A00000000
Subsystem 7 - Serial number: 65A000000000047ÿ
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0111111
VCID: 2A50BAE585B7EB4EE53-807F
Subsystem 1 - Part No: 4E2 910 113 B
Component: Wischer WWS D3 H40 0400
Coding: 00000044
Shop #: WSC 02311
Address 11: Engine II Labels: Redir Fail!
Component: 4.0L 4V/TDI A000AGSª0020
Coding: 0010773
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4E0 910 561 D HW: 4E0 907 561 D
Component: ABSTANDSREGELUNG 0010
Coding: 0011154
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655
Component: Airbag 8.4E+ H09 0940
Coding: 0431707
VCID: E3CE97C1221DFA06665-80B6
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H09 0030
Coding: 0112351
VCID: E5CA89D92C298436881-80B0
Component: Lenkradmodul H02 0050
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 930 HW: 4E0 920 980 A
Component: KOMBIINSTR. VDO H49 0070
Revision: D08 Serial number: AUDID3C5000286
Coding: 0000413
Shop #: WSC 00011 000 00000
VCID: DFC69B310E75DEE642D-808A
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 HW: 4E0 815 069 D
Component: Heizgeraet H06 0290
Revision: 0000000F Serial number: 00000009001484
VCID: D9B2B529105130D63C9-808C
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 HW: 4E0 907 468 B
Component: Gateway H07 0050
Revision: 07 Serial number: 12004036220069
Coding: FEFFFFDF2B7504
Shop #: WSC 00000 128 00289
Address 1D: Driver Ident. Labels: 4E0-910-218.lbl
Part No SW: 4E0 910 218 HW: 4E2 905 218
Component: FPI_1 H04 0060
Revision: 06000104 Serial number: 23052003152755
VCID: DEB8A635097FD7EE49B-808B
02540 - Driver Identification Sensor Defective or Dirty (G455)
Reset counter: 171
Mileage: 187248 km
Date: 2014.05.01
Time: 22:26:50
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 HW: 4E0 035 111
Component: CD-Changer H43 0220
Revision: 00000501 Serial number: AUZ5ZBC1021872
VCID: D6A8BE15614F1FAE11B-8083
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0411648
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 A
Component: KLIMA-STG. FOND 015 0200
Revision: 00000013 Serial number: 00000000009292
Coding: 0000000
VCID: E1C29DC93801E816749-80B4
01866 - Rear Right Air Outlet Motor Position Sensor (G350)
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
VCID: 254A49D9ECA9C436C81-8070
Component: Sitzmemory FS H06 0060
Coding: 4063470
Part No SW: 4E0 910 887 T HW: 4E0 919 887 C
Component: MNS ECE H41 1030
Revision: 00000000 Serial number: 305HX037537794
VCID: 3E7886B5693F77EEA9B-806B
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H01 0090
Serial number: 00000404300044
Coding: 0036572
Shop #: WSC 00337 210 09666
VCID: 1D3A6139C4F90CF6901-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 802
Component: Türsteuer.FS BRM005 0100
Coding: 0028463
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040307300026
Coding: 0004857
VCID: 275643D196A5D626FAD-8072
Component: Heckdeckel H06 0060
Component: Neigungssensor H02 0020
00892 - Switch for Trunk Closing Cylinder (F248)
Fault Status: 00100111
Reset counter: 209
Mileage: 186824 km
Date: 2014.04.29
Time: 19:34:40
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 E HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0210
Revision: PROD_01 Serial number: 00000000261852
Coding: 0000023
VCID: 1F465B31CEF51EE682D-804A
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 HW: 4E0 907 280 A
Component: ILM Beifahrer H07 0070
Revision: Serial number: 00000000020137
Coding: 0010101
VCID: DDBAA1390479CCF6501-8088
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 801
Component: Türsteuer.BF BRM005 0100
Coding: 0028463
Reset counter: 210
Mileage: 187040 km
Date: 2014.04.30
Time: 14:17:42
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000431
02596 - Rear Brake Pads Worn
002 - Lower Limit Exceeded
Fault Status: 01100010
Fault Frequency: 20
Reset counter: 168
Date: 2064.00.00
Time: 00:00:00
Voltage: 11.39 V
Count: 60
Address 55: Xenon Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0030
VCID: E2C092C53D07F30E6D3-80B7
Part No SW: 4E0 910 541 B HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0220
Revision: 00000000 Serial number: 304HH037540029
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 A HW: 4E0 919 146
Component: TV analog TUNER H12 0180
Revision: 00000052 Serial number: 00000000001635
Coding: 0001003
00866 - Antenna 4 for TV (R58)
Fault Status: 00101011
Reset counter: 210
Mileage: 186824 km
Date: 2014.04.29
Time: 19:37:13
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 B HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0240
Revision: 00000000 Serial number: 00000000012939
Subsystem 1 - Part No: 000 GBA 401 9
Component: von VA0 029APR2014
Coding: 303030474241343031392056413030323941505232303134
Shop #: WSC 02313 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM004 0090
Coding: 0028463
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0202833
01477 - System Switched Off
Fault Frequency: 13
Reset counter: 171
Mileage: 186825 km
Date: 2014.04.29
Time: 19:57:41
Temperature: 16.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Fault Status: 11100100
Reset counter: 170
Mileage: 186831 km
Date: 2014.04.30
Time: 10:07:04
Speed: 28.0 km/h
Temperature: 14.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 753 B HW: 4E0 035 753
Component: SDS 3502 UK H43 0190
Revision: 00000000 Serial number: 00000307100286
Shop #: WSC 12336 024 394758
VCID: 244C54DDE7933D3EDFF-8071
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM004 0090
Coding: 0028463
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 HW: 4E0 919 283 A
Component: Parkhilfe 8-Kan H07 0030
Coding: 0101008
VCID: E0C498CD330BE11E7B7-80B5
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 C HW: 4E0 862 333 B
Component: TELEFONMODUL EU 0210
Revision: 00000004 Serial number: T2AUD3080908N2
Coding: 0000004
End ---------------------------------------------------------------------
