so Im not sure when this issue started, but it was a few months ago to say the least.
I can pair my phone with Bluetooth.
If I make a call, I can hear it ringing and hear the person... however the other person cannot hear me...
second part of this issue is on my steering wheel,
the tele button works and brings up info on the DIS. the other side of the steering wheel. the button where volume control is, there is a voice control. before when clicking this button it would say possible commands and what not... pressing the volume scroll(pressing not scrolling) it would say Navi not active or something..
now it just says Button inactive when I hit the Voice control button...
any ideas where I could start?
Friday,27,November,2015,12:33:48:12681
VCDS Version 15.7.1.0 (x64)
Data version: 20150904
VIN: WAURV78T59A011130 License Plate:
Mileage: 188660km-117227mi Repair Order:
Chassis Type: 8T (8T - Audi A5/S5/RS5 (2008 >))
Scan: 01 03 04 05 06 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 3C 42
46 47 52 53 55 56 67 6C 77
VIN: WAURV78T59A011130 Mileage: 188660km-117227miles
Address 01: Engine (J623-CAUB) Labels: 079-907-560-CAU.clb
Part No SW: 8T0 907 560 K HW: 8T0 907 560
Component: 4.2l V8/4V H10 0002
Revision: 76H10---
Coding: 01140009180F0120
Shop #: WSC 64847 128 16448
VCID: 428B4E12DDBE582E0B-8017
P0300 - 001 - - MIL ON
Fault Status: 11100001
Mileage: 188657 km
Date: 2015.11.27
Time: 12:16:18
RPM: 706 /min
Load: 29.4 %
Temperature: 45.0°C
Temperature: 42.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.843 V
000773 - Cylinder 5
P0305 - 001 - Misfire Detected - MIL ON
Mileage: 188657 km
Date: 2015.11.27
Time: 12:16:18
RPM: 706 /min
Load: 29.4 %
Temperature: 45.0°C
Temperature: 42.0°C
Voltage: 13.843 V
004874 - Cylinder Disabling
P130A - 001 -
Fault Status: 01100001
Mileage: 188657 km
Date: 2015.11.27
Time: 12:17:16
RPM: 3676 /min
Load: 39.6 %
Speed: 75.0 km/h
Temperature: 93.0°C
Temperature: 22.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.970 V
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AB HW: 8K0 907 379 AB
Component: ESP8 quattro H04 H04 00600060
Coding: 110500
Shop #: WSC 06325 000 00000
VCID: 79F9E9FEF0E8DBF61A-802D
No Faults Found
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 AG HW: 8K0 907 064 AG
Component: BCM2 1.1 H71 0134
Coding: 0F0000
VCID: 75E1E5CEDCF0BF967E-8021
Subsystem 1 - Part No SW: 8T0 959 754 S HW: 8T0 959 754 S
Component: FBSAUDIB8 IDG H37 0060
Component: ELVAUDIB8 H36 0041
Address 06: Seat Mem. Pass (J521) Labels: 8T0-959-760.clb
Part No SW: 8T0 959 760 B HW: 8T0 959 760 B
Component: MEM-BFS H09 0043
Revision: AA000000 Serial number: 00001001117716
Coding: 00017025002C00000000
Part No SW: 8T1 820 043 AC HW: 8T1 820 043 AC
Component: KLIMA 3 ZONEN H06 0140
Revision: C1000000 Serial number: 0116.07.080364
Coding: 48022000
VCID: 72EBDED2AD9EA8AE5B-8027
03023 - Running-in Requirement
Fault Status: 01100101
Reset counter: 74
Mileage: 188580 km
Date: 2015.11.26
Time: 09:50:15
00256 - A/C Pressure/Temperature Sensor (G395)
008 - Implausible Signal
Fault Status: 01101000
Reset counter: 74
Mileage: 188580 km
Date: 2015.11.26
Time: 09:50:15
Temperature: 9.0°C
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 74
Mileage: 188580 km
Date: 2015.11.26
Time: 09:50:15
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000188211
Coding: 26081095003CAF251700000300003D3D4F94138800010161000000
VCID: 306F14DA6312DABEED-8065
Subsystem 1 - Part No SW: 8T1 955 119 C HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 160708 H13 0040
Coding: 00F531
Component: RLS H04 0003
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 J HW: 8K0 941 531 J
Component: E1 - LDS H07 0070
Subsystem 4 - Part No SW: 8K0 907 410 A HW: 8K0 907 410 A
Component: UGDO HL US H04 0060
Fault Status: 00101100
Reset counter: 115
Mileage: 188580 km
Date: 2015.11.26
Time: 18:36:00
Reset counter: 115
Mileage: 188580 km
Date: 2015.11.26
Time: 18:36:00
Reset counter: 74
Mileage: 188580 km
Date: 2015.11.26
Time: 09:50:00
03207 - Charisma Switch Module
Reset counter: 74
Mileage: 188580 km
Date: 2015.11.26
Time: 09:50:00
Part No SW: 8T1 035 110 C HW: 8T1 035 110 C
Component: MP3-Changer H43 0390
Revision: 00043003 Serial number: AUZ5ZBH8511003
VCID: 2A5B06B285CEA06E23-807F
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 M HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7H0372487
Coding: 0000100
VCID: 316911DEA818D3B6E2-8065
Reset counter: 74
Mileage: 188580 km
Date: 2015.11.26
Time: 09:50:27
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 D HW: 8K0 919 475
Component: PARKHILFE 4K H06 0020
Revision: 11001001 Serial number: 52930821000661
Coding: 200002
VCID: 3A7B36F2B56E10EE53-806F
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 C HW: 8K0 959 655 C
Component: AirbagVW-AU10 H26 0410
Serial number: 0039GD1287N$
Coding: 303333333730303030304A55304C38543053
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 3D713DEEAC4027D676-8069
Subsystem 1 - Part No SW: 8K0 959 339 HW: 8K0 959 339
Component: BF-Gewichtss. H01 0050
Serial number: 5810000R0800001LF9
Serial number: 6334MSME3E36014AE
Serial number: 6344MSME3E155A63L
Serial number: 6352QSME78767A11O
Serial number: 6362QSME78764F2F%
Serial number: 63732SME77081E575
Serial number: 63832SME6E7638337
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 981 E HW: 8T0 920 981 E
Component: KOMBIINSTR. H30 0221
Revision: 00000000 Serial number: 97S743R78
Coding: 832D01000B00D705020201
VCID: 3E733AE2A9463CCE6F-806B
Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
Component: MEM-FS H09 0043
Revision: AA000000 Serial number: 00001001116631
Coding: 00197B25002C00000000
Part No SW: 4E0 910 888 M HW: 4E0 919 887 M
Component: MNS US H51 1100
Revision: 00000000 Serial number: 341GH087510612
Shop #: WSC 01114 444 53357
VCID: 387F2CFA4B6202FEA5-806D
Address 3C: Lane Change Labels: None
Part No SW: 8K0 907 566 B HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0050
Revision: 00H01000 Serial number: 6PZ 009 014-13
Coding: 0000004
VCID: 366322C24176F48EB7-8063
Subsystem 1 - Part No: 8K0 907 568 B
Component: J0770_SWA_Slave_H01 0050
Subsystem 2 - Serial number: 6PZ 009 014-33
Subsystem 3 - Serial number: 5F29.07.0800H010003CD10227ÿ
Subsystem 4 - Serial number: D10227ÿ
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0113135222
Coding: 0106069A007A444700F000
Subsystem 1 - Part No: 8K0 959 719
Component: GTO BF H06 0040
Subsystem 3 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J245EE16SKB10 H01 0180
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 T HW: 8T0 035 223 F
Component: DSP Prem H14 0400
Revision: 00H14003 Serial number: 34814002235801
Coding: 030101
Shop #: WSC 12336 024 394758
VCID: 3F8D47E6AE4C35C664-806B
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 HW: 8K0 959 792
Component: TSG BF H09 0149
Revision: Serial number: "E
Coding: 011C13224E002201
VCID: 7CF7F0EAFFDAEEDE01-8029
Fault Status: 01101100
Reset counter: 75
Mileage: 188608 km
Date: 2015.11.27
Time: 06:48:37
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 00000000181836
VCID: 316911DE6818D3B6E2-8065
Address 55: Headlight Range Labels: 8T0-907-357.clb
Part No SW: 8H0 907 357 A HW: 8H0 907 357
Component: AFS 1 H01 0020
Coding: 0000017
Shop #: WSC 06324 000 00000
VCID: 306F14DAA312DABEED-8065
Component: AFS-Modul links H07 0004
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH07 0004
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H46 0630
Revision: 00000000 Serial number: 00000807080620
VCID: 346718CA570AE69E89-8061
Part No SW: 8T0 907 441 B HW: 4L0 907 441 A
Component: J772__Rearview 0070
Revision: --H12--- Serial number: 525PA8-J879083
Coding: 1000008
VCID: 377D2FC6467C0D86AC-8063
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005053055
Coding: 0010970
VCID: 285FFCBA9BC2927E35-807D
End-------------------------(Elapsed Time: 05:48)--------------------------
