Audi A3 8V Auto hold (ABS module) - Anyone figure this out yet?
ineedbeer
C?ID=236468
Sorry to post this as it has been asked before, but I thought I could consolidate all of the data into one post to be helpful, and ask if anyone has made any progress on this.
I'm trying to get Auto Hold enabled (this function causes the brakes to remain 'on' when the vehicle is stopped, so that you do not have to hold the brake pedal at lights, in traffic, etc).
I know it seems like a silly thing, but drive around every day in NYC and you'll realize how useful it can be. I miss it from my previous car (a Mercedes C class).
Vehicle is a 2016 A3 (8V) US model.
This is the modification in question:
Adaptation of the functional state of the Auto Hold setting - NOT TESTED
[03] Brakes Electronics -> Adaptation ->
Select AUTO HOLD function state -> Set value: (Default: last setting)
Last setting: AUTO HOLD uses the last defined setting which was set over the button
never active: AUTOHOLD not automatically activated
always active: AUTO HOLD always enabled
These are the security codes we know of for this ABS module, and I have tried them all with the following results:
ABS CODES ATTEMPTED FOR AUTO HOLD ADAPTATION CHANNEL:
18573   'controller refused the key'
44595   'controller ref the key'
28183   'invalid key!'
11966  engine on - 'sec access req'                    	engine off - 'sec access req'
15081  engine on - 'sec access req'			engine off - 'sec access req'
20103  engine on - 'sec access req'			engine off - 'sec access req'
24435  engine on - 'sec access req'			engine off - 'sec access req'
25004  engine on - 'sec access req'			engine off - 'sec access req'
31857  engine on - 'sec access req'			engine off - 'sec access req'
37202  engine on - 'sec access req'			engine off - 'sec access req'
40168  engine on - 'sec access req'                     engine off - 'sec access req'
This is the autoscan for my vehicle:
Wednesday,28,October,2015,15:33:09:59061
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WAUE8GFF0G1017868   License Plate:
Mileage: 1113km-691mi   Repair Order:
Chassis Type: FF (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 3C 42 44 52 55 5F 6C
VIN: WAUE8GFF0G1017868   Mileage: 1113km-691miles
Address 01: Engine (J623-CNTC)       Labels: 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 D    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 0A1D00124426000F3000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0205G0906259D 001002
   ROD: EV_ECM20TFS0205G0906259D_AU37.rod
   VCID: 2F43E1BA76FBF946F4-807A
   Part No SW: 0D9 300 013 B    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4902
   Revision: 06253104    Serial number: TFK01506151418
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 160D345EE961288E97-8042
10657 - RPM Signal from ECU
          P0726 00 [002] - Implausible Signal
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 61705000003059
   Coding: 13FF6A9234210A73017F030681CB29C8562C5080C08194B6024100548208
   ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
   VCID: 79D71FE2F83FE7F61A-802C
   Revision: 00021000    Serial number: 0371172870
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_AU37.rod
   VCID: 3A55C0EEBDB92CEE53-806E
Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
   Component: AC Automat    H13 0060
   Revision: 20027000    Serial number: 00000000675584
   Coding: 03000014010000000000000000001400
   VCID: 334BEDCA9AD3DDA690-8066
   Part No SW: 5Q0 937 085 AH    HW: 5Q0 937 085 AE
   Component: BCM MQBAB MNA H24 0175
   Serial number: 01061517300062
   Coding: 04151A46C04122F541C04004511007000800000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 7F23F1FAE61BC9C624-802A
   Slave 1:
   Component: WWS371 150622  042 0585
   Serial number:         150626163354
   Coding: 0A47F7
   Slave 2:
   Serial number: 24033012
   Coding: 00006C
   Slave 3:
   Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
   Serial number: 24 04 2015  00001464
   Serial number: 00000000000032761900
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST000DCYI500000
   Coding: 101F00
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Revision: --------    Serial number: 39391511401374
   Coding: 0030150011
   ROD: EV_EPHVA18AU3700000_AU37.rod
   VCID: 43ABBD0ACA736D2600-8016
   Serial number: 003GCR02FMY2
   Coding: 9DCCFCC0000000005000001AC24800000065
   VCID: 47B3A91AFE4B4106DC-8012
   Seat belt tensioner; left:
   Component: BeltPretRevFL  H36 0350
   Serial number: 34178311B26061540731
   Coding: 333135
   Seat belt tensioner; right:
   Component: BeltPretRevFR  H36 0350
   Serial number: 34178312B26061571183
   Coding: 333135
   Seat occupant detection; front passenger side:
   Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
   Serial number: 694000000000001D0LNY
   Coding: 303333
   Subsystem 4 - Part No SW: -----------    HW: 480 001 906 15
   Serial number: 35700000000570392514
   Subsystem 5 - Part No SW: -----------    HW: 480 001 906 15
   Serial number: 358000000001D1392518
   Subsystem 6 - Part No SW: -----------    HW: 480 401 606 15
   Serial number: 3510002991B5A870518%
   Subsystem 7 - Part No SW: -----------    HW: 480 402 306 15
   Serial number: 3520002B11B65D50A14.
   Subsystem 8 - Part No SW: -----------    HW: 480 402 502 15
   Serial number: 35500029919DB8B522AJ
   Subsystem 9 - Part No SW: -----------    HW: 480 402 502 15
   Serial number: 3560002BD19DB8B250AO
   Part No SW: 8V0 953 521 FH    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 28061508490273
   Coding: A018
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 052F631284C793166E-8050
   Part No SW: 8V0 920 971 Q    HW: 8V0 920 971 Q
   Component: KOMBI         H03 6420
   Coding: 0BED18192B88D7050200EA001800000000000000
   VCID: 4BBB952AE223A566F8-801E
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2223
   Revision: --------    Serial number: 24061510803255
   Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
   ROD: EV_GatewConti.rod
   VCID: 75CF13D2D42783967E-8020
   Serial number: 18 06 2015  D0050891
Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
   Serial number: HA1-00025.03.15
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_AU21.rod
   VCID: 46ADA41EF941580E27-8012
   Revision: 00000000    Serial number: 15000162954002
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: 3449EED69FDDDA9E89-8060
Address 3C: Lane Change (J769)       Labels: 5Q0-907-566.clb
   Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
   Component: SWA Master    H05 0080
   Serial number: 0368931344
   Coding: 030211
   ROD: EV_LaneChangAssis_AU37.rod
   VCID: 3851DAE683B53EFEA5-806C
   Lane Change Assistant 2:
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 070615BF611299
   Coding: 00101B204000048000000002
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   VCID: 41A7B702D06F7F3612-8014
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   ROD: EV_SteerAssisMQB.rod
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 070615BF615066
   Coding: 001013204000048000000002
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   VCID: 40A1B206DB65763E1D-8014
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 012A000101000000
   ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
   Part No SW: 8V0 035 038 B    HW: 8V0 035 038 B
   Component: MU-H-LNS-US   H43 0394
   Serial number: A302F0FB015010
   Coding: 01730102FF0A000021220001041A00102F000105010001047E
   ROD: EV_MUHig6C3HBAS_AU37.rod
   Engine Control Module 2:
   Subsystem 1 - Part No SW: V03 959 800 SS    HW: -----------
   Component: NAR 2015  --- 0035
   Seat Adjustment Driver Side:
   Component: DU High  H49 0014
   Serial number: AUZ8Z9FY203DZ3
   Sound System:
   Subsystem 3 - Part No SW: 8V0 919 614 L    HW: 8V0 919 614 L
   Component: ControlUnit_H  H81 0816
   Serial number: C1000029041500030337
   Door Electronics Rear Left:
   Component: Gracenote  --- 3006
Address 6C: Back-up Cam. (J772)       Labels: 5Q0-907-441.clb
   Part No SW: 5Q0 907 441 A    HW: 5Q0 907 441 A
   Component: MQB RVC Mid   H07 0140
   Coding: 027300010201000300
   ASAM Dataset: EV_2CamSysRearPASE 006016
   ROD: EV_CamSysRearPANAAU914.rod
   VCID: 3041E2C66BC5E6BEED-8064
End-------------------------(Elapsed Time: 03:40)--------------------------
I have also mapped the adaptations for every channel, if the files would be of any help I can send them.
Is there any way to crack this nut? I'm willing to test pretty much anything to help out if possible.
NEtech
C?ID=56995
Maybe buy a new ABS ?
My guess is, you need an ABS that has PR-UH2 (PR code), your ABS controller has PR-UH1.
ineedbeer
C?ID=236468
Curious where this info came from? I was (and am) under the impression that it's just a matter of finding the security code, as it has been on other models. The ABS module has all the necessary hardware as far as I know.
mtl
Slovenia
C?ID=153305
Just a question: so you would like to have Auto Hold and not Hill Hold activated?
Because according to my info, Hill Hold (3s auto braking on hill) should be already active with DSG transmission.
ineedbeer
C?ID=236468
No, why would I not want hill hold?
I simply want to enable auto hold, which I know is already available with this ABS module and requires no hardware changes (except for the button which is optional)
Hill hold still remains active for auto braking on a hill as you pointed out.
ineedbeer
C?ID=236468
2016 A3 Auto Hold Security Code Found! Only more questions though...
Ok so credit to DJAlix for finding the ABS security code (24990) for the channel AUTO HOLD Functionality.
With this code, I was able to change it to "active".
I expected to find another adaptation channel "AUTO HOLD function state" which can be set to "last setting" "never active" or "always active". Without that setting available, I do not believe auto hold can be turned on short of installing the button.
Anyone? At least it's progress...
EDIT: Some more info...
This is the adaptation map with the "AUTO HOLD functional status" channel that I was expecting:
;SW:5Q0-907-379-AC HW:5Q0-907-379-D --- ABS Brakes
;Component:ESC H75 0437	Coding:01FA8AA1202312700377060701C32980510448C0608094F3002A0028C1
;EV_Brake1UDSContiMK100IPB	8020	EV_Brake1UDSContiMK100IPB_AU37.rod
;Saturday	2	August	2014
;VCDS Version: Release 12.12.0 Data version: 20130910
;VCID: 7DF1154CECFCAFF6FF5-8028
;With access code for module controller
ABS in lower speed range	activated
Activating and deactivating all development messages	0
AUTO HOLD functional status	Last setting
AUTO HOLD functionality	not activated
AUTO HOLD increase threshold; full tensioning force	10%
AUTO HOLD increase threshold; reduced tensioning force	0%
AUTO HOLD slippage recognition	activated
This is what I am getting on my vehicle:
;SW:3Q0-907-379-AA   HW:3Q0-907-379-F ---  ABS Brakes
;Component:ESC           H42 0623	 Coding:13FF6A9234210A73017F030681CB29C8562C5080C08194B6024100548208
;EV_Brake1UDSContiMK100IPB	34036	EV_Brake1UDSContiMK100IPB_AU37.rod
;Wednesday	28	October	2015	15:34:54:59061
;VCDS Version: Release 15.7.1 (x64)  Data version: 20150904
;VCID: 79D71FE2F83FE7F61A-802C
Activating and deactivating all development messages	not active
AUTO HOLD functionality	not activated 	       [OK, this line now says activated, posting an older admap here, but otherwise identical]
Xpower
C?ID=163029
We have been looking into this for a while.
I have scanned 2 vehicles (mk7 golfs) both with auto hold, neither of them had the "auto hold" adaptation set to active.
This leads me to believe the function lies in the coding of the module and not the adaptation channels, despite my best efforts I cannot makes many changes to the coding without the error "coding rejected, out of range"
Xpower
C?ID=163029
I can confirm that this function is not in the adaptations.
As a test I have set my channels to "active" for AUTO-HOLD and "always" for when to be active as I don't have a switch. This doesn't work.
DV52
C?ID=194404
ineedbeer: Further input if needed. Here are a section of the admaps for the ABS from my database for a couple of Aussie cars- both of which have auto-hold factory fitted
And here is a simplified WD for how the button operates- looks like a simple switch +12V supply to PN#23! I suspect that once the Auto-hold switch is fitted, all that's needed is to tell J104 about the fitment (probably by a code change as has been previously suggested). Problem is that the ABS module doesn't have a long Coding Helper screen set as yet! The other problem is that there is an intimate arrangement between the Auto-hold function and EPB (the console switched for two functions work together), but this might not be pertinent if your vehicle has a mechanical hand-brake
m_bolc
San José, Costa Rica
C?ID=230356
Hello all,
Maybe someone can work some hexadecimal magic and come up with a coding suggestion in order to activate auto hold (not hill hold, that one is already on all 8Vs).
Here is a reference scan from a friends A3 that has auto hold fitted from the factory.
Monday,18,April,2016,18:14:58:29892
VCDS Version: 16.3.0.0 (x64)
Data version: 20160216
VIN: WAUZZZ8V3EA000770   License Plate: MVL100
Mileage: 33717km-20950mi   Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 55 5F
VIN: WAUZZZ8V3EA000770   Mileage: 33717km-20950miles
Address 01: Engine (J623-CJZA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 016 B    HW: 04E 907 309 A
   Component: 1.2l R4 TSI   H08 5544
   Revision: WAH08---
   Coding: 02110012230400082000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM12TFS01104E906016B 001006
   ROD: EV_ECM12TFS01104E906016B.rod
   VCID: 2149CBAF30BD2E3480-8074
   Part No SW: 5Q0 907 379 P    HW: 5Q0 907 379 D
   Component: ESC           H75 0434
   Coding: 10F16AA220200A6C037E060701C32508560450C06080A4B30039000805
   Shop #: WSC 05212 002 104857
   VCID: 4999730FE8CDC67438-801C
Address 08: Auto HVAC (E87)       Labels: 8V0-820-047.clb
   Part No SW: 8V0 820 047 B    HW: 8V0 820 047 B
   Component: AC Manuell el H09 0031
   Revision: 20017000    Serial number: 00000000014027
   Coding: 00000004100000000000000000000000
   ASAM Dataset: EV_AirCondiFrontManAU37X 008016
   ROD: EV_AirCondiFrontManAU37X.rod
   VCID: 35610FFF9435B2944C-8060
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 [008] -  -
                    Fault Frequency: 7
                    Reset counter: 171
                    Mileage: 32445 km
                    Date: 2016.03.14
                    Time: 09:23:57
                    Voltage terminal 30: 13.9 V
                    Compressor shut-off requirement: Shut-off from Engine Control Module (ECM) via CAN
   Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
   Component: BCM MQBAB H   H14 0106
   Serial number: 00011311700298
   Coding: 04000A42C001227D03044000B30C07000000000000000000000000000000
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 46837833F9D3290CD5-8012
   Slave 1:
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 130418  041 0580
   Serial number:         130423140117
   Coding: 0A47F7
   Slave 2:
   Subsystem 2 - Part No SW: 8U0 955 559 A    HW: 8U0 955 559 A  Labels: 8U0-955-559.CLB
   Component: G397_RLS  H06 0002
   Serial number: 20114803
   Coding: 06885D
   Slave 3:
   Subsystem 3 - Part No SW: 8V0 941 531 L    HW: 8V0 941 531 L
   Serial number: 16 04 2013  00001858
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY130931L14
   Serial number: 00000000000056638894
197644 - Control Circuit for Fuel Tank Flap
          B1263 01 [008] - Electrical Failure
                    Fault Frequency: 13
                    Reset counter: 172
                    Mileage: 1048574 km
                    Time: 00:00:00
   Part No SW: 5Q0 959 655 L    HW: 5Q0 959 655 L
   Component: AirbagVW20    009 0349
   Serial number: 003GER00ZWUS
   Coding: 98CCC000000000005C540000004800000065
   Subsystem 1 - Part No SW: -----------    HW: 480 002 204 13
   Serial number: 3576700000033C688C0.
   Subsystem 2 - Part No SW: -----------    HW: 480 002 204 13
   Serial number: 3586700000013D688C0.
   Subsystem 3 - Part No SW: -----------    HW: 480 400 904 13
   Serial number: 3516502A90FBDE45B21V
   Subsystem 4 - Part No SW: -----------    HW: 480 400 904 13
   Serial number: 3526502AF0FBDE32738
   Subsystem 5 - Part No SW: -----------    HW: 480 401 403 13
   Serial number: 3556502A10FAE894404J
   Part No SW: 8V0 953 521     HW: 5Q0 953 549 A
   Revision: --------    Serial number: 25041304221057
   Coding: 8408
   VCID: 77FDC5F7CEB980849E-8022
   Part No SW: 8V0 920 860     HW: 8V0 920 860
   Component: KOMBI         H22 0570
   Coding: 078502002A8000080500AA00000000
   Part No SW: 5Q0 907 530 J    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1126
   Revision: --------    Serial number: 0000575131
   Coding: 010100F02008640000000200000B00000001000000000000000000000000
   ASAM Dataset: EV_GatewLear 008010
   ROD: EV_GatewLear.rod
   VCID: 387F06CB83274FFC57-806C
   Generator:
   Subsystem 2 - Part No SW: 8U0 951 528     HW: 8U0 951 528
   Serial number: 27 04 2013  A1163564
   Part No SW: 5Q0 959 393 A    HW: 5Q0 959 393
   Component: TSG FS        012 0006
   Serial number: 19041301100036
   Coding: 00100E204100040100001002
   VCID: 3D7117DFAC056AD484-8068
   Coding: 01
   Part No SW: 5Q0 959 392 A    HW: 5Q0 959 392
   Component: TSG BFS       012 0006
   Serial number: 08041301100276
   Coding: 001006204500040100001002
   VCID: 3C771ADBB71F63DCB3-8068
   Component: LWR-ECU       005 0070
   Coding: 010A000001000000
   Shop #: WSC 08960 001 1048576
   VCID: 75E1CFFFD4B5F2948C-8020
Address 5F: Information Electr. (J794)       Labels: 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 840 A    HW: 8V0 035 840
   Component: MU-S--ER      039 0370
   Serial number: A3E00105130061
   Coding: 01730000FF0A000021220001001A00002F0001440100010002
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE_AU37.rod
   VCID: 336531E79A41ACA462-8066
   Subsystem 1 - Part No SW: 8V0 919 603 A    HW: 8V0 919 603 A
   Component: DU Std  H47 0013
   Serial number: AUZ8Z9DG600T0N
   Sound System:
   Subsystem 2 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
   Component: ControlUnit_B  H33 0037
   Serial number: C1000013031300020231
0532 - Subwoofer
          B106C 13 [009] - Open Circuit
                    Reset counter: 246
                    Mileage: 31378 km
                    Date: 2016.02.05
                    Time: 08:21:11
6179 - Display Module 1 for Multimedia System
          B1297 F6 [008] - Cable for Video Signal; Open Circuit
                    Reset counter: 156
                    Mileage: 33429 km
                    Date: 2016.04.09
                    Time: 21:18:59
End-------------------------(Elapsed Time: 02:58)--------------------------
Address 5F:8V0 035 840 A recoded (ADP-(13)-Vehicle function list BAP-tire_pressure_system_0x07) from not activated  to activated
Address 5F:8V0 035 840 A recoded (ADP-(14)-Vehicle function list BAP-tire_pressure_system_0x07_msg_bus) from Comfort data bus  to Suspension data bus
Address 5F:8V0 035 840 A recoded (ADP-(56)-Vehicle menu operation-menu_display_rdk) from not activated  to activated
Address 5F:8V0 035 840 A recoded (ADP-(58)-Vehicle menu operation-menu_display_rdk_over_threshold_high) from not activated  to activated
Address 17:8V0 920 860  recoded (Long Coding) from 078502002A8000080500AA00000000 to 078502002B8000080500AA00000000  (06314/790/00021)
Address 03:5Q0 907 379 P recoded (Long Coding) from 10F16AA220200A6C037E060701C32508560450C06080A4B30039000805 to 10F16AA220200A6C037E060701C32508560450C06080A4B30039003885  (05212/002/104857)
Here is a reference scan of my new car, without auto-hold.
Monday,18,April,2016,20:53:00:29892
VIN: WAUZZZ8V7H1000288   License Plate: TRS456
Mileage: 2274km-1412mi   Repair Order:
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WAUZZZ8V7H1000288   Mileage: 2274km-1412miles
Address 01: Engine (J623-CYVB)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 027 GR    HW: 04E 907 309 BL
   Component: R4 1.2l TFS   H23 2394
   Revision: R4H23---
   Coding: 02250012230400082000
   ASAM Dataset: EV_ECM12TFS01104E906027GR 001005
   ROD: EV_ECM12TFS01104E906027GR.rod
   VCID: 7AFBDCC3FDAB9DECE1-802E
   Part No SW: 0CW 300 048 K    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 0614
   Revision: 00005005    Serial number: CU501512106812
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021.rod
   VCID: 4487623BCFEF1B1CCB-8010
   Revision: 00000000    Serial number: 63625000001935
   Coding: 13F16AA22420126C0179060841CB25C8562448806082A4B2002100348208
   VCID: 79F9C3CFF8AD96F4E8-802C
   Part No SW: 8V0 820 047 D    HW: 8V0 820 047 D
   Component: AC Manuell el H11 0052
   Revision: 20021000    Serial number: 00000000187281
   Coding: 03000004100000000000000000000000
   ASAM Dataset: EV_AirCondiFrontManAU37X 008018
   VCID: 377D05F78E3940845E-8062
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061533701281
   Coding: 04041A42C041227D03A04004B10807000000000000000000000000000000
   VCID: 0919B30FA84D8674F8-805C
   Slave 1:
   Component: WWS371 151118  043 0585
   Serial number:         151126161111
   Coding: 0A47F7
   Slave 2:
   Subsystem 2 - Part No SW: 8U0 955 559 D    HW: 8U0 955 559 A  Labels: 8U0-955-559.CLB
   Component: G397_RLS  H06 0004
   Serial number: 50030281
   Coding: 06885D
   Slave 3:
   Subsystem 3 - Part No SW: 8V0 941 531 AE    HW: 8V0 941 531 AE
   Serial number: 17 10 2015  00000327
   Serial number: 000000000ZY153154N42
   Serial number: 00000000000064431957
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0054
   Revision: --------    Serial number: 39291534203226
   Coding: 0000050011
   ASAM Dataset: EV_EPHVA14AU3700000 002024
   ROD: EV_EPHVA14AU3700000_AU37.rod
   Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
   Serial number: 003MMR1BC5J-
   VCID: 000FAE2B9B77C73CAF-8054
   Subsystem 1 - Part No SW: -----------    HW: 480 001 812 15
   Serial number: 357670000001F741381P
   Subsystem 2 - Part No SW: -----------    HW: 480 001 812 15
   Serial number: 358670000007A741381R
   Subsystem 3 - Part No SW: -----------    HW: 480 402 811 15
   Serial number: 3516502B11E34435E21%
   Subsystem 4 - Part No SW: -----------    HW: 480 403 011 15
   Serial number: 3526502C91E2431261B3
   Subsystem 5 - Part No SW: -----------    HW: 480 401 509 15
   Serial number: 3556502C71CF2D82920N
   Part No SW: 8V0 953 521 EM    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 10121504221033
   Coding: 8018
   ASAM Dataset: EV_SMLSKLOMQB 020001
   Part No SW: 8V0 920 860 N    HW: 8V0 920 860 N
   Component: KOMBI         H03 6423
   Coding: 07851A082B8000080500BA001000000000000000
   VCID: 45817F3FC4D52214DC-8010
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 10121510800534
   Coding: 01010008300864005B000208100B00000001010000000000000000000000
   Generator:
   Serial number: 11 12 2015  A0038721
   Serial number: 181015BJH00562
   Coding: 00100A204100040000001002
   VCID: 41896B2FD0FD0E34E0-8014
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811
   Serial number: 00000000000008171337
   Coding: 110000
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 0502
   Serial number: 111015BJA06371
   Coding: 001002204D00040000001002
   VCID: 408F6E2BDBF7073CEF-8014
   Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812
   Serial number: 00000000000008176200
   Coding: 090000
   Part No SW: 8V0 035 840 C    HW: 8V0 035 840 B
   Component: MU-S--ER      042 0461
   Serial number: A3E01212150142
   Coding: 01730100FF0A000021220001001A00002F0001040100010002
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0014
   Serial number: AUZ8Z9FY30F2K3
   Sound System:
   Subsystem 2 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
   Serial number: ALJAL111111500010126
Xpower
C?ID=163029
It's interesting - your example vehicle with Autohold enabled has ABS module 5Q0 907 379 P,
Your car is almost the same as my car (both looking to enable Autohold) and both have ABS module 3Q0 907 379 F (I have G)
Anyone at RT know if this may make a difference? I notice that both my car and the 2 example vehicles use the later 5Q0 label files
NEtech
C?ID=56995
Try this test:
Byte 08 = 03
Byte 19 = C0
Byte 23 = B3
m_bolc
C?ID=230356
The coding was accepted but the auto-hold functionality did not work.
No error codes to speak of either.
NEtech
C?ID=56995
Maybe look through your adaptation channels if there is something need to be changed.
lala30
Croatia
C?ID=71949
yes
Byte 08 = 03
Byte 19 = C0
Byte 23 = F7
and
Byte 25 = 42 , you have now 41
and with 41 you have activate HHA ,
i think Hild hold and Auto Hold is not possible coding together
Xpower
C?ID=163029
Ok, well I tried this and it seems to have screwed up my DSG ECU, despite me not touching it. I have reverted everything back to standard and there are no errors in any module except for DSG.
Just to confirm, the changes to the bytes suggested caused EPB comms errors but have all now gone in the ABS module when I reverted the coding to the original.
I have never experienced this where coding 1 module has what seems to be quite negative affects on another which can't be rectified by changing the coding back.
   Part No SW: 0D9 300 041 C    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4902
   Revision: 06253104    Serial number: TFK01512040820
   Shop #: WSC 73430 031 00063
   VCID: 1835ED88E3B38EFEA6-804C
          P1734 00 [002] - -
21221 - No Communications with Parking Brake Control Module
          U0128 00 [011] - -
                    Mileage: 6027 km
                    Date: 2016.04.20
                    Time: 17:15:27
If you scan it whilst its running you get more faults:
            Address 02: Auto Trans       Labels: 0D9-927-770.clb
Control Module Part Number: 0D9 300 041 C    HW: 02E 927 770 AQ
  Component and/or Version: DQ250-6F MQB  H53 4902
           Software Coding: 0014
            Work Shop Code: WSC 73430 031 00063
              ASAM Dataset: EV_TCMDQ250021 001001 (SK37)
6 Faults Found:
21153 - Gear 1
          P072C 00 [002] - Not Selectable
21159 - Gear R
          P072B 00 [002] - Not Selectable
10731 - Valve 3 in Transmission Part 1
          P174A 00 [002] - Electrical malfunction
10906 - Cooling Oil Valve
          P179D 00 [002] - Electrical Malfunction
          U0128 00 [011] - -
                    Mileage: 6058 km
                    Date: 2016.04.20
                    Time: 18:20:05
Physically the car run perfect and everything works - including adaptive cruise, start stop etc. I have tried disconnecting the battery for 15 mins but no change
HELP!!!!!!!!!!!!!!! :-(
Ross-tech = is there any way to force reset the module in any way?
I've seen stranger coincidences. One of them got me building my very first diagnostic interface back in 1999, but that's a long story...
m_bolc
C?ID=230356
yes
Byte 08 = 03
Byte 19 = C0
Byte 23 = F7
and
This is how my friend's car comes from the factory (hill and auto hold enabled).
