Page 1 of 8 123 ... LastLast
Results 1 to 10 of 82
Thread: Security Access for USA 2016 MK7 Golf R - 17/Instruments
Hybrid View
    Dec 2015
    I'm trying to do a tweak provided by DV52 to adjust the curves on the cluster light sensor, which requires Security Access to modify the necessary Adaption channels.
    I've tried 20103, which DV52 has provide as working on other MK7 Golf platform cars, but it's not accepted on my car no matter what I try. I've tried it with ignition power only and with engine running, but it always says the code is not accepted.
    Here's an AutoScan. Note that the malfunctions listed were caused by me when I disconnected the overhead console to install a homelink module.
    Wednesday,09,December,2015,09:06:43:43055
    VCDS Version: 15.7.3.0
    Data version: 20151124
    VIN: WVWLF7AU4GW136712   License Plate: 2016VWGOLFR
    Mileage: 2182km-1355mi   Repair Order:
    Chassis Type: AU (5Q0)
    Scan: 01 02 03 05 08 09 14 15 16 17 19 22 2B 42 44 52 55 5F 75 A9
    VIN: WVWLF7AU4GW136712   Mileage: 2182km-1355miles
    Address 01: Engine (J623-CYFB)       Labels: 06K-907-425-V1.clb
       Part No SW: 8V0 906 259 H    HW: 06K 907 425 E
       Component: 2.0l R4 TFSI  H13 0002
       Revision: --H13---
       Coding: 091D00122426000E3004
       ASAM Dataset: EV_ECM20TFS0208V0906259H 001003
       ROD: EV_ECM20TFS0208V0906259H_VW37.rod
       VCID: 458BBB3CC409C91602-8010
       Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H53 4904
       Revision: 06253104    Serial number: TFK01508230699
       ROD: EV_TCMDQ250021_AU37.rod
       VCID: 53AF95643A5D67A69C-8006
       Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
       Component: ESC           H42 0623
       Revision: 00000000    Serial number: 62575000000140
       Coding: 01FA6BA154230972057E030141C56980D62A90A0C08296B7004000D8C208
       VCID: 79F307CCF8717DF636-802C
       Revision: 00021000    Serial number: 0381191442
       Coding: 030C0C
       VCID: 3A71D8C0BDF7B6EE7F-806E
       Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
       Revision: 00001K08
       Coding: 00020004100100000005004012111402
       ROD: EV_ACClimaBHBVW37X_SK37.rod
       VCID: 6AD128808DD7C66ECF-803E
       Part No SW: 5Q0 937 085 AJ    HW: 5Q0 937 085 AF
       Component: BCM MQBAB HNA H24 0175
       Serial number: 01061526100485
       Coding: 00011A46C041A2E169E44000091C07201800000000000000000000000000
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: 01036F2C90A125367E-8054
       Slave 1:
       Component: WWS    150707  043 0551
       Serial number:         150804121608
       Slave 2:
       Component: RLHS  037 0059
       Serial number: S4Y15M08D20H08M24S55
       Coding: 90A8DD
    0263 - Supply Voltage for Interior Lights
              B1314 11 [008] - Short to Ground
                        Reset counter: 70
                        Mileage: 1849 km
                        Date: 2015.11.21
                        Time: 16:18:06
       Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
       Component: DAEMPFUNGS-SG H17 0120
       Serial number: 28091541350477
       ROD: EV_DRCONTITEMIC.rod
       VCID: 3777C1F48EE5AB8680-8062
       Serial number: 003GCR03H5SP
       VCID: 4797B134FE05DB06F0-8012
       Seat occupant detection; front passenger side:
    H11 0021
       Serial number: IBH0000000000034ZH8R
       Coding: 42462D4765776963687473732E
       Subsystem 2 - Part No SW: -----------    HW: 480 001 609 15
       Serial number: 35700000000CDC45661V
       Subsystem 3 - Part No SW: -----------    HW: 480 001 609 15
       Serial number: 358000000009748C561P
       Component: -----------  001 6149
       Serial number: 3510002AD1D25F7112D8
       Subsystem 5 - Part No SW: -----------    HW: 480 402 109 15
       Serial number: 3520002AB1D1B5D160DB
       Subsystem 6 - Part No SW: -----------    HW: 480 402 109 15
       Serial number: 3550002C11CF2DA4B28K
       Subsystem 7 - Part No SW: -----------    HW: 480 402 109 15
       Serial number: 3560002C11CF2DA5A22F
       Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0110
       Revision: --------    Serial number: 18091508490846
       Coding: 0410
       ROD: EV_SMLSKLOMQB_SE37.rod
       VCID: 07177134BE851B0630-8052
       Part No SW: 5G1 920 858 A    HW: 5G1 920 858 A
       Component: KOMBI         303 6420
       Coding: 0BAD081A3B80CF0502087A001400000000000000
       VCID: 2E59E49071BF6A4ED3-807A
       Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1223
       Revision: --------    Serial number: 0003980871
       Coding: 0101000830085900FB00022A9C0F00000001050000000000000000000000
       ROD: EV_GatewLear.rod
       VCID: 75EB0BFCD469199652-8020
       Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q
       Component: E221__MFL-DC1  H10 0101
       Serial number: 29150001812010035385
       Coding: 31FFFF
       Serial number: HA1-00010.08.15
       Coding: 0001
       VCID: 4A918800ED17266EEF-801E
       Revision: 00000000    Serial number: 15000214022006
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB_AU37.rod
       VCID: 346DF6F89F93409EA5-8060
       Serial number: 060915BI505416
       Coding: 003E13208000040000000000
       VCID: 438FA524CA3DF7262C-8016
       Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811
       Serial number: 00000000000007354588
       Coding: 111000
       Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
       Component: EPS_MQB_ZFLS  505 5063
       Coding: 8102
       ROD: EV_SteerAssisMQB.rod
       VCID: 3973C7CCB8F1BDF676-806C
       Serial number: 100915BI915411
       Coding: 003E13208000040000800000
       VCID: 4281A020D527FE2E27-8016
       Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812
       Serial number: 00000000000007504944
       Coding: 091000
       Coding: 022202010B000400
       ROD: EV_HeadlRegulVWAFS_SE26.rod
       VCID: 4085AA28DB2BEC3E31-8014
       Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0002
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0002
       Coding: 2E0000
       Part No SW: 3Q0 035 876     HW: 3Q0 035 876
       Component: MU-S-NS-US    H25 0245
       Serial number: VWZAZ2R0415075
       Coding: 027300020000000051220002001808001F0207F401200105C6
       ROD: EV_MUStd4CTSAT_VW26.rod
       VCID: 71E33FECA00135B68E-8024
       Media Player Position 1:
       Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605
       Component: ABT_Std-2_Nav  H52 1028
       Serial number: VWZ8Z9RFC0087X
       Engine Control Module 2:
       Subsystem 2 - Part No SW: 3G0 919 866 B    HW: -----------
       Component: NAR 2015/16  --- 0220
    Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
       Component: OCULowMQBUS   007 0568
       Coding: 02730002C2821A017F1E06020000
       ROD: EV_OCULowMQB.rod
    9455635 - Microphone 1
              B129B 13 [008] - Open Circuit
                        Reset counter: 79
                        Mileage: 1849 km
                        Date: 2015.11.21
                        Time: 12:35:41
    9458195 - Control Module for Cellular Telephone
              B1052 13 [008] - Open Circuit
                        Reset counter: 79
                        Mileage: 1849 km
                        Date: 2015.11.21
                        Time: 12:35:41
       Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0001
       Serial number: 150908201144
       VCID: 2F67F99476B56346D8-807A
    End-------------------------(Elapsed Time: 04:55)--------------------------
    May 2014
    Quote Originally Posted by HDClown View Post
    HDClown: If you still can't get access to the instrument control module to implement the tweak, perhaps this alternative option HERE might be worth looking-at. I've not tried the alternative tweak, but the author, MRG_AU is quite a gifted colleague, so I'm confident that it will work. Of course, a consequence of implementing the tweak is that the DRLs will be illuminated when the rotary light switch is in the "parker" position, but this is only a minor matter - and it's possibly an added advantage (IMO).
    EDIT: I've been having a nice chat with two of your compatriots on another forum about this issue. Seems that like you, they are having similar issues in getting 20103 accepted by this control module. Interesting bit is that they also have a 2016 "R" type mk7 of the NAR version and the PN/SW of the module is 5G1 920 858 A -like yours and 5G1 920 758 A. What's so special about this control module of the *** *** *58 A ilk - the "spiffy" cluster lighting perhaps? But why does this normally impact a security code? not sure!
    PPS: One of the Chat-ees tried the "alternative" tweak that I identified above. He reported that it lit-up everything inside the cabin EXCEPT the cluster lighting - bummer!
  3. Likes Uwe liked this post
    Dec 2015
    Can you try 31347
    Dec 2015
    Quote Originally Posted by Yomny View Post
    Can you try 31347
    Just tried that. Didn't work.
    May 2014
    Just to make sure that the lack of access to address 17 module wasn't somehow connected with RT's software (apology to RT for any unintended insinuation), I re-tried 20103 on my car after loading the new 15.7.3 - and it was accepted first time! Got to be something peculiar in the unit installed in the NAR 2016 "R" type mk7, or the newer version module.
    Question for anyone who knows - Has it happened in the past that security codes become ineffectual with subsequent releases of control modules?
    EDIT: OK- Given Zenerdiode's response below, this tweak might not be accessible with these newer modules until someone, somehow get's hold of the new SA - bummer!!
    Jun 2014
    Newcastle, England
    Yes, the 46-BCM2 module on the Audi A5 changed the SA code from BCM2 2.01 to BCM2 2.1 and subsequent versions. There's a recent thread where someone was wanting to unlock the ADP channels to code in their new rear LEDs that I was able to chip-in with a different SA code.
  8. Likes DV52 liked this post
    Dec 2015
    Nooooooooooooooooooooooooooooooooooooooooooo! So how can we help get the new SA?
  10. #8
    Dec 2015
    Bump, any way we can get the SA for the Instruments on the '16s?
  11. #9
    Dec 2015
    So there is no way to get the new security code?
  12. #10
    Feb 2016
    Has anybody made any progress on this? I'm also looking for the instruments security code.
    Coding: 0BAD081A3B80CF0502086A001400000000000000
    VCID: 2E7DF7DC71E69C4ED3-807A
  13. Likes nathan16mk7R liked this post
