Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Long Coding for CAN gateway
  1. #21
    Tartu, Estonia
    The battery managemnt code will also flag up when very new can is installed in old car and can gw superseeding isn't followed.
    Reason is that older wirings have GND in place where newer cans have battery management LIN wire. It is needed to remove GND from there and you're fault free.
    Also, although the 61 is in Installation List, it is not in autoscan. - Please go to 61 directly and see fault and clear them.
    The world is my oyster...
  2. Likes Uwe liked this post
  3. #22
    Aug 2015
    Italy
    Well... I put 359002 as long code, cleared the faukts did the scan.
    VCDS Version: Release 15.7.2 Running on Windows Vista x86
    Data version: 20151124
    Saturday,12,December,2015,10:47:46:41339
    Chassis Type: 1K (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
    VIN: WV...............   Mileage: 60070km-37325miles
    Address 01: Engine        Labels: 03G-906-016-BKD.lbl
       Part No SW: 03G 906 016 T    HW: 028 101 195 6
       Component: R4 2,0L EDC 0000SG  7001
       Revision: 12345678    Serial number: VW.......
       Coding: 0000072
       Shop #: WSC 01392 785 00200
       VCID: 34484E90579A149EBF-8060
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0104
       Coding: 0023282
       VCID: 3A5460A875FEE2EE65-806E
       Part No: 1K0 907 044 AF
       Component: ClimatronicPQ35 066 0505
       VCID: 6BFA95EC4A248B66AE-803E
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
       Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
       Component: Bordnetz-SG     H34 0803
       Revision: 00H34000    Serial number: 0000000.........
       Coding: 01890F2600041800000A00000F00000000085D035C
       Subsystem 1 - Part No: 5M0 955 119
       Component: Wischer VW359  012  0402
       Coding: 00065493
       Part No SW: 1K0 909 605 C    HW: 1K0 909 605 C
       Component: 1M AIRBAG VW8   013 2100
       Revision: 02013000    Serial number: 0033.......
       Coding: 0012621
       Shop #: WSC 01372 785 00200
       VCID: 2C7856F08FAA4C5EE7-8078
       Subsystem 1 - Serial number: 6332MSME085610281
       Subsystem 2 - Serial number: 6342MSME08394B6CP
       Subsystem 3 - Serial number: 6351HSME06401118V
       Subsystem 4 - Serial number: 6361HSME062E5A75H
    01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
                009 - Open or Short to Ground - Intermittent - MIL ON
       Part No SW: 1K0 953 549 G    HW: 1K0 953 549 G
       Component: Lenksäulenmodul 521 0050
       Coding: 0002012
       VCID: 364C749841E6068E81-8062
       Component: Lenkradmodul    007 0050
       Part No: 1K0 920 861 B
       Component: KOMBIINSTRUMENT VDD 0814
       Coding: 0003103
       Shop #: WSC 30562 264 68225
       VCID: 2870AAE09B52607E03-807C
       Part No SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
       Component: J533  Gateway H55 1642
       Revision:   H55       Serial number: 111213F1002338
       Coding: 359002
       VCID: 7BDAA5ACFA441BE63E-802E
                        Reset counter: 46
                        Mileage: 60078 km
                        Time: 10:33:48
       Component: IMMO            VDD 0814
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
       Part No: 1K0 959 701 E
       Component: Tuersteuergeraet 09 0167
       Coding: 0000052
       Shop #: WSC 01287 785 00200
       VCID: 30404280A38228BEDB-8064
       Part No: 1K1 909 144 H
       Component: EPS_ZFLS Kl.3       1502
    Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 AK
       Coding: 00C802087F2D8404084F01E010CC
       VCID: 79D6BFA4307829F62C-802C
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
       Part No: 1K0 959 702 E
       Coding: 0000052
       VCID: 31464784A88821B6D4-8064
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 5J0 035 161 G    HW: 5J0 035 161 G
       Component: Radio-SWING   006 0005
       Revision: -----09S    Serial number: SKZ4Z2R1132598
       Coding: 0D0004000006
       Shop #: WSC 33361 790 00099
       VCID: 266CA4D85146760E31-8072
    00856 - Radio Antenna
                        Reset counter: 32
                        Mileage: 59040 km
                        Time: 19:13:38
                        Reset counter: 46
    01327 - Control Module for Parking Aid (J446)
                        Reset counter: 6
                        Mileage: 59949 km
                        Time: 14:18:58
                        Reset counter: 2
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
       Part No: 1K0 959 703 C
       Component: Tuersteuergeraet 06 0220
       Coding: 0000016
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
       Part No: 1K0 959 704 C
       Coding: 0000016
       Revision: 00800000    Serial number:
       VCID: 2D7E5BF4B4B04556F0-8078
    End-------------------------(Elapsed Time: 01:14)--------------------------
  4. #23
    Aug 2015
    Italy
    I omitted the serial numbers only for a matter of privacy.
    I am worried of the remaining faults... Except for the radio because I need a radio antenna cable adapter.
    What about the battery regulator? Do I have really to weld the groud in a different way?
    Address 61: Battery Regul. Labels: 1K0-907-534.clb
    Control Module Part Number: 7N0 907 534 HW: 7N0 907 530 AM
    Component and/or Version: Batt.regelung H55 1642
    Software Coding: F000185A
    Work Shop Code: WSC 12345 123 12345
    VCID: 71C68784A80861B694-8024
    02071 - Local Databus
    Reset counter: 6
    Mileage: 60078 km
    Time: 10:52:58
    Thanks again for your tips.
  5. #24
    Magdeburg, Germany
    #09 The gateaway you installed isn't exactly compatible to the central electronics, it will likely keep flagging those codes. Install a proper gateway to fix this.
    #19 See comments on #56.
    #56 A Skoda Fabia/Roomster Radio in a Golf will never run free of faults, you may be able to reduce them but that's about it. Install a proper radio to fix this.
    #61 Since your car doesn't have battery management (and the relating sensors), but the Gateway (that isn't meant for your car) looks for them - there is nothing you can do, other than installing a proper gateway. If if you retrofitted the sensor etc., the remaining vehicle systems would have no idea what to do with the information. IMO not worth it...
  6. Likes Uwe liked this post
  7. #25
    Tartu, Estonia
    61 fault will flag up because LIN wire is short to ground, not because the can has it listed.
  8. #26
    Aug 2015
    Italy
    But then... Can I solve the problem opening the CAN gateway and unwelding the LIN... or it is better to give up??
  9. #27
    Tartu, Estonia
    Quote Originally Posted by enrico View Post
    Yes cut pin or remove wire. But you have others faults to address.
  10. #28
    Aug 2015
    Italy
    Well, no... Better to stop this kind of troubleshooting on the car I own. Today I put back the old gateway and RCD300 radio.
    I thought it was much simpler upgrading a radio, even the volume control on steer does not work.
    But thank you for your support. Now I have much clear the use of VCDS.
    Bye
