Results 11 to 20 of 28
Thread: Long Coding for CAN gateway
    Quote Originally Posted by enrico View Post
    Thanks for your reply Uwe, what I don't understand is what I obtain if I compile my list.
    A gateway that's free of fault codes.
    When the new code is built? Sorry for my question but I'm not such an expert...
    This will not change your coding. That's now a separate thing from the GVL. Use a current version of VCDS to set the 3 bytes of Long Coding appropriately for your car.
  2. Likes enrico liked this post
  3. #12
    Aug 2015
    Italy
    Well, I downloaded the latest version:
    VCDS Version: Release 15.7.2 Running on Windows Vista x86
    Data version: 20151124
    Tuesday,08,December,2015,13:47:01:41339
    Chassis Type: 1K (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
    VIN: W......... Mileage: 59940km-37244miles
    04-Steering Angle -- Status: Not registered 0001
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 AM HW: 7N0 907 530 AM
    Component: J533 Gateway H55 1642
    Revision: H55 Serial number: 111213F1002338
    Coding: 350000
    VCID: 7BDAA5ACFA441BE63E-802E
    Fault Frequency: 60
    Mileage: 59904 km
    Time: 14:57:24
    I selected all the necessary components on the installation list and saved.
    But the can gateway is still showed as Incorrectly coded.
  4. #13
    Tartu, Estonia
    Nope 04 - steering angle is not.
    The world is my oyster...
  5. Likes Uwe, enrico, Jack@European_Parts liked this post
  6. #14
    Aug 2015
    Italy
    Yes you are true golfi_vend but I noticed now that if I compare the original scan with original gateway and the new scan with new gateway the order of devices is different.
    Is this due to the new VCDS software or the new Gateway for the chinese market?
    ----ORIGINAL GATEWAY---------
    Chassis Type: 1K0
    VIN: W____________ Mileage: 43410km/26973miles
    -----NEW CAN GATEWAY ------
    Chassis Type: 1K (7N0) -------------> changed also chassis type!!
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 62 72 7D
    VIN: W______________ Mileage: 59940km-37244miles
    01-Engine -- Status: Not registered 0001
    08-Auto HVAC -- Status: Not registered 0011
    09-Cent. Elect. -- Status: Not registered 0011
    15-Airbags -- Status: Not registered 0011
    16-Steering wheel -- Status: Not registered 0011
    17-Instruments -- Status: Not registered 0001
    25-Immobilizer -- Status: Not registered 0001
    42-Door Elect, Driver -- Status: Not registered 0001
    44-Steering Assist -- Status: Not registered 0011
    46-Central Conv. -- Status: Not registered 0011
    52-Door Elect, Pass. -- Status: Not registered 0001
    62-Door, Rear Left -- Status: Not registered 0001
    72-Door, Rear Right -- Status: Not registered
    Sorry but I imagined changing the gateway was much simpler :-(
  7. #15
    Tartu, Estonia
    You're making it complicated for yourself. The only thing moved is steering angle. This is with all newer cans.
    On new scan you're missing 7D - Aux heating, do you have it removed or unmarked in install list.
    Also please fresh new autoscan so it's possible to assist you further. For instance the error with battery management.
  8. Likes Uwe, Jack@European_Parts liked this post
  9. #16
    Aug 2015
    Italy
    Yep I did some mistakes in doing the installation list
    Now I have a new scan (I removed serial numbers). All devices are recognized. Some malfuncions, do they came from the new Can gateway?
    Thursday,10,December,2015,08:14:46:41339
    VIN: W____________   Mileage: 60040km-37307miles
    Address 01: Engine        Labels: 03G-906-016-BKD.lbl
       Part No SW: 03G 906 016 T    HW: 028 101 195 6
       Component: R4 2,0L EDC 0000SG  7001
       Revision: 12345678    Serial number: VW______
       Coding: 0000072
       Shop #: WSC 01392 785 00200
       VCID: 34484E90579A149EBF-8060
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0104
       Coding: 0023282
       VCID: 3A5460A875FEE2EE65-806E
       Part No: 1K0 907 044 AF
       Component: ClimatronicPQ35 066 0505
       VCID: 6BFA95EC4A248B66AE-803E
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
       Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
       Component: Bordnetz-SG     H34 0803
       Revision: 00H34000    Serial number: 0000000_____
       Coding: 01890F2600041800000A00000F00000000085D035C
       Subsystem 1 - Part No: 5M0 955 119
       Component: Wischer VW359  012  0402
       Coding: 00065493
       Part No SW: 1K0 909 605 C    HW: 1K0 909 605 C
       Component: 1M AIRBAG VW8   013 2100
       Revision: 02013000    Serial number: 00_______
       Coding: 0012621
       Shop #: WSC 01372 785 00200
       VCID: 2C7856F08FAA4C5EE7-8078
       Subsystem 1 - Serial number: 6____________
       Subsystem 2 - Serial number: 6____________
       Subsystem 3 - Serial number: 6_______
       Subsystem 4 - Serial number: 6______
                013 - Check DTC Memory - Intermittent - MIL ON
       Part No SW: 1K0 953 549 G    HW: 1K0 953 549 G
       Component: Lenksäulenmodul 521 0050
       Coding: 0002012
       VCID: 364C749841E6068E81-8062
       Component: Lenkradmodul    007 0050
       Part No: 1K0 920 861 B
       Component: KOMBIINSTRUMENT VDD 0814
       Coding: 0003103
       Shop #: WSC 30562 264 68225
       VCID: 2870AAE09B52607E03-807C
       Revision:   H55       Serial number: 11__________
       Coding: 350000
                        Reset counter: 2
                        Mileage: 59949 km
                        Time: 14:38:50
                000 -  -  - Intermittent
                        Fault Frequency: 70
                        Mileage: 59904 km
                        Time: 14:57:24
       Component: IMMO            VDD 0814
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
       Part No: 1K0 959 701 E
       Component: Tuersteuergeraet 09 0167
       Coding: 0000052
       Shop #: WSC 01287 785 00200
       VCID: 30404280A38228BEDB-8064
       Part No: 1K1 909 144 H
       Component: EPS_ZFLS Kl.3       1502
    00750 - Warning Lamp
                        Mileage: 9880 km
                        Temperature: 9.0°C
                        Voltage: 12.20 V
                        Voltage: 12.00 V
    Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 AK
       Coding: 00C802087F2D8404084F01E010CC
       VCID: 79D6BFA4307829F62C-802C
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
       Part No: 1K0 959 702 E
       Coding: 0000052
       VCID: 31464784A88821B6D4-8064
    Address 56: Radio
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
       Part No: 1K0 959 703 C
       Component: Tuersteuergeraet 06 0220
       Coding: 0000016
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
       Part No: 1K0 959 704 C
       Coding: 0000016
       Revision: 00800000    Serial number:
       VCID: 2D7E5BF4B4B04556F0-8078
    End-------------------------(Elapsed Time: 01:13)--------------------------
    Thanks for your support
  10. #17
    Aug 2015
    Italy
    And if I go in CAN Gateway, coding I see:
    35 Vehicle platform PQ35/PQ36
    Options:
    00 Control module not coded
    35 Vehicle Platform PQ35/PQ36
    46 PQ35/PQ36
  11. #18
    Almost all the fault codes are flagged "Intermittent". That means the condition that set the fault code did not exist (or could not be detected) at the time the scan was performed. Clear them and see what comes back.
  12. #19
    Although you have removed most information (did you steal the car )
    Coding for [CAN Gateway - 19] should be: 359002
  13. Likes Uwe, Dana liked this post
  14. #20
    United States
    After I created this thread I realized I should have done something specific for the CAN GW module alone. In any event, The Installation List followed by Long Coding is all you need to do.
    As mentioned by golfi_vend, the Battery Manager issue may just be the end result of the incorrect control module. We'd really want to look at the complete scan before repairs with the VIN (so we can check PR codes) to make sure.
  15. Likes Uwe liked this post
