Long Coding for CAN gateway
enrico
Italy
C?ID=125918
Hello, I'm trying to code a new can gateway that I placed to solve battery drain due to RCD 310 Radio on Golf plus V in replacement of RCD300.
What I don't understand is how to obtain the long code starting from the installation list. Just selecting the variuos devices it creates the new code?
Now the Can gatewy code is 350000.
If I put the code of the old gateway I obtain error 22 'conditions not correct or incorrect sequence error'. I don't have the workshop code but I've put 12345 as suggested in the furum.
Please help...
Got Auto-Scans? Preferably one with the original gateway and one with the new?
enrico
Italy
C?ID=125918
Here the scans:
Old
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H11 0110
Revision: 11 Serial number: 29001052090167
Coding: 3D3F0B40079002
Shop #: WSC 01392 785 00200
VCID: 2976AFE480E203B
Reset counter: 35
Mileage: 58702 km
Time: 08:46:23
New:
Part No SW: 7N0 907 530 AM HW: 7N0 907 530 AM
Component: J533 Gateway H55 1642
Revision: H55 Serial number: 111213F1002338
Coding: 350000
VCID: 7BDAA5ACFAFE41B
Mileage: 59904 km
Time: 14:57:24
New GW does not have installation list in Long Coding. Use separate Installation List function in GW to populate installation list.
[Select]
[19-CAN Gateway]
[Installation List]
golfi_vend
Tartu, Estonia
C?ID=195131
But does Installation List populate if no label file?
This is the AM GW, that is meant for Chinese market.:thanks:
enrico
Italy
C?ID=125918
[Select]
[19-CAN Gateway]
[Installation List]
Thanks for your reply Uwe, what I don't understand is what I obtain if I compile my list. When the new code is built? Sorry for my question but I'm not such an expert...
enrico
Italy
C?ID=125918
Yes it is from china, a local italian VW forum told me it is fine to solve battery drain issue...
enrico
Italy
C?ID=125918
Do I only have to populate the list and press 'save'?
If something goes wrong the old code is retrieved with the other button?
thanks
golfi_vend
Tartu, Estonia
C?ID=195131
It sure does, but it lacks some things you might not even need. - Just a pointer for others.
Is your VCDS at latest update. I know some CAN GW-s got label file with 15.7.1 update. Including me, when i was working with "BC" GW and 15.7.0 didn't, but 15.7.1 did have a label for it. :) I thought I'll update it after I'm finished with this GW. Updated sooner then i wanted.
A gateway that's free of fault codes.
This will not change your coding. That's now a separate thing from the GVL. Use a current version of VCDS to set the 3 bytes of Long Coding appropriately for your car.
enrico
Italy
C?ID=125918
Well, I downloaded the latest version:
VCDS Version: Release 15.7.2 Running on Windows Vista x86
Data version: 20151124
Tuesday,08,December,2015,13:47:01:41339
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: W......... Mileage: 59940km-37244miles
04-Steering Angle -- Status: Not registered 0001
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Coding: 350000
VCID: 7BDAA5ACFA441BE63E-802E
Fault Frequency: 60
Mileage: 59904 km
Time: 14:57:24
I selected all the necessary components on the installation list and saved.
But the can gateway is still showed as Incorrectly coded. :(
enrico
Italy
C?ID=125918
Nope :) 04 - steering angle is not.
Yes you are true golfi_vend but I noticed now that if I compare the original scan with original gateway and the new scan with new gateway the order of devices is different.
Is this due to the new VCDS software or the new Gateway for the chinese market?
----ORIGINAL GATEWAY---------
Chassis Type: 1K0
VIN: W____________ Mileage: 43410km/26973miles
-----NEW CAN GATEWAY ------
Chassis Type: 1K (7N0) -------------> changed also chassis type!!
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 62 72 7D
VIN: W______________ Mileage: 59940km-37244miles
01-Engine -- Status: Not registered 0001
08-Auto HVAC -- Status: Not registered 0011
09-Cent. Elect. -- Status: Not registered 0011
15-Airbags -- Status: Not registered 0011
16-Steering wheel -- Status: Not registered 0011
17-Instruments -- Status: Not registered 0001
25-Immobilizer -- Status: Not registered 0001
42-Door Elect, Driver -- Status: Not registered 0001
44-Steering Assist -- Status: Not registered 0011
46-Central Conv. -- Status: Not registered 0011
52-Door Elect, Pass. -- Status: Not registered 0001
62-Door, Rear Left -- Status: Not registered 0001
72-Door, Rear Right -- Status: Not registered
Sorry but I imagined changing the gateway was much simpler :-(
golfi_vend
Tartu, Estonia
C?ID=195131
You're making it complicated for yourself. The only thing moved is steering angle. This is with all newer cans.
On new scan you're missing 7D - Aux heating, do you have it removed or unmarked in install list.
Also please fresh new autoscan so it's possible to assist you further. For instance the error with battery management.
enrico
Italy
C?ID=125918
Yep I did some mistakes in doing the installation list :(
Now I have a new scan (I removed serial numbers). All devices are recognized. Some malfuncions, do they came from the new Can gateway?
Thursday,10,December,2015,08:14:46:41339
VIN: W____________   Mileage: 60040km-37307miles
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 016 T    HW: 028 101 195 6
   Component: R4 2,0L EDC 0000SG  7001
   Revision: 12345678    Serial number: VW______
   Coding: 0000072
   VCID: 34484E90579A149EBF-8060
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0023282
   VCID: 3A5460A875FEE2EE65-806E
   Part No: 1K0 907 044 AF
   Component: ClimatronicPQ35 066 0505
   VCID: 6BFA95EC4A248B66AE-803E
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 0000000_____
   Coding: 01890F2600041800000A00000F00000000085D035C
   Subsystem 1 - Part No: 5M0 955 119
   Component: Wischer VW359  012  0402
   Coding: 00065493
   Part No SW: 1K0 909 605 C    HW: 1K0 909 605 C
   Component: 1M AIRBAG VW8   013 2100
   Revision: 02013000    Serial number: 00_______
   Coding: 0012621
   Shop #: WSC 01372 785 00200
   VCID: 2C7856F08FAA4C5EE7-8078
   Subsystem 1 - Serial number: 6____________
   Subsystem 2 - Serial number: 6____________
   Subsystem 3 - Serial number: 6_______
   Subsystem 4 - Serial number: 6______
            013 - Check DTC Memory - Intermittent - MIL ON
   Part No SW: 1K0 953 549 G    HW: 1K0 953 549 G
   Component: Lenksäulenmodul 521 0050
   Coding: 0002012
   VCID: 364C749841E6068E81-8062
   Component: Lenkradmodul    007 0050
   Part No: 1K0 920 861 B
   Component: KOMBIINSTRUMENT VDD 0814
   Coding: 0003103
   Shop #: WSC 30562 264 68225
   VCID: 2870AAE09B52607E03-807C
   Revision:   H55       Serial number: 11__________
   Coding: 350000
                    Reset counter: 2
                    Mileage: 59949 km
                    Time: 14:38:50
            000 -  -  - Intermittent
                    Fault Frequency: 70
                    Mileage: 59904 km
                    Time: 14:57:24
   Component: IMMO            VDD 0814
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0167
   Coding: 0000052
   Shop #: WSC 01287 785 00200
   VCID: 30404280A38228BEDB-8064
   Part No: 1K1 909 144 H
   Component: EPS_ZFLS Kl.3       1502
00750 - Warning Lamp
                    Mileage: 9880 km
                    Temperature: 9.0°C
                    Voltage: 12.20 V
                    Voltage: 12.00 V
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Coding: 00C802087F2D8404084F01E010CC
   VCID: 79D6BFA4307829F62C-802C
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
   VCID: 31464784A88821B6D4-8064
Address 56: Radio
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0220
   Coding: 0000016
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
   Revision: 00800000    Serial number:
   VCID: 2D7E5BF4B4B04556F0-8078
End-------------------------(Elapsed Time: 01:13)--------------------------
Thanks for your support
enrico
Italy
C?ID=125918
And if I go in CAN Gateway, coding I see:
35 Vehicle platform PQ35/PQ36
Options:
00 Control module not coded
35 Vehicle Platform PQ35/PQ36
46 PQ35/PQ36
Almost all the fault codes are flagged "Intermittent". That means the condition that set the fault code did not exist (or could not be detected) at the time the scan was performed. Clear them and see what comes back.
NEtech
C?ID=56995
Although you have removed most information (did you steal the car :D)
Coding for [CAN Gateway - 19] should be: 359002
Dana
Western PA, USA
After I created this thread I realized I should have done something specific for the CAN GW module alone. In any event, The Installation List followed by Long Coding is all you need to do.
As mentioned by golfi_vend, the Battery Manager issue may just be the end result of the incorrect control module. We'd really want to look at the complete scan before repairs with the VIN (so we can check PR codes) to make sure.
