- Joined
- May 16, 2014
- Messages
- 5,469
- Reaction score
- 5,935
- Location
- Melbourne, Australia
- VCDS Serial number
- C?ID=194404
So, here's a question - what's the greatest DTC "infection" that has been found in an auto-scan from a single car (that is "road worthy" - not sure what the equivalent term is in other countries)?
Second question - what's an appropriate measure for the first question. It's not simply the highest DTC count because different cars have different number of control modules. Perhaps DTC count/control module count?
Reason why this question has been spinning through my brain is because of the autoscan below that I recently saw in another forum (no name will be given for who posted it, but he is well known to this forum). Now to be fair, the owner of the vehicle below has indicated that the DTCs were not all caused as a result of normal road use faults - but the autoscan is legitimate nevertheless
Total number of DTCs = 40
Total number of control modules (excluding slave modules) = 17
Ave DTC/module =2.35 - Impressive!! Can anyone better this?
VIN: ***************** License Plate: **-*-*-**-**
Mileage: 16033km-9962mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 52 55 5F 75 A9
VIN: ***************** Mileage: 16033km-9962miles
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (J623-CNTA) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0005
Revision: --H13---
Coding: 091900122424000F1000
Shop #: WSC 00066 790 00221
ASAM Dataset: EV_ECM20TFS0205G0906259A 001007
ROD: EV_ECM20TFS0205G0906259A_VW37.rod
VCID: 2C14D46847D7645EE7-8078
Readiness: 0010 0001
Part No SW: 5Q0 907 379 K HW: 5Q0 907 379 F
Component: ESC H31 0371
Revision: 00000000 Serial number: 51184000000712
Coding: 01FA6BA134200973007E020681CC2980D62C9000408194B400430050C006
Shop #: WSC 01383 790 50316
ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
VCID: 44C49CC8CF478C1E0F-8010
9 Faults Found:
8246 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:47
8250 - Databus
Fault Frequency: 24
Reset counter: 251
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:47
8252 - Databus
Fault Frequency: 36
Reset counter: 251
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:42
8254 - Databus
Fault Frequency: 36
Reset counter: 251
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:42
8256 - Databus
Fault Frequency: 35
Reset counter: 251
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:43
8258 - Databus
Fault Frequency: 36
Reset counter: 251
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:42
8277 - Databus
Fault Frequency: 19
Reset counter: 251
Date: 2015.10.15
Time: 18:28:33
8351 - Databus
Fault Frequency: 30
Reset counter: 251
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:43
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:09:18
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0328646360
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_AU37.rod
VCID: 3A38E230BD83CAEE65-806E
12716804 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:43
Address 08: Auto HVAC (J301) Labels: 5G0-907-426.clb
Part No SW: 5G0 907 426 N HW: 5G0 907 426 N
Component: AC Manuell H01 0705
Revision: 00001K06
Coding: 00020004200100000000000000000000
ROD: EV_ACManueBHBVW37X_SE37.rod
VCID: 3620F600899B2E8E81-8062
459525 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:43
459023 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:43
590081 - Control Circuit for A/C Compressor
B10A9 11 [008] - Short to Ground
Reset counter: 242
Mileage: 15333 km
Date: 2015.11.02
Time: 08:41:58
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 087 K HW: 5Q0 937 087 K
Component: BCM PQ37BOSCH 026 0097
Revision: -------- Serial number: 86580805140110
Coding: 00110A464041A26969E44000001407201800000000000000000000000000
Shop #: WSC 00066 790 00145
ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
ROD: EV_BCMBOSCH_AU37.rod
VCID: 43C69FD4CA498B2636-8016
Slave 1:
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 140212 042 0581
Serial number: 140528153750
Slave 2:
Subsystem 2 - Part No SW: 5Q0 955 559 HW: 5Q0 955 559 Labels: 5Q0-955-547.CLB
Component: RLS 024 0042
Serial number: Y14M02D19H17M22S34S9
Coding: 06A8DD
Subsystem 3 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.014 H02 0007
Serial number: WOO2889941F
Coding: 181801
6 Faults Found:
541973 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:42
559125 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:47
555541 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:42
542229 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:43
542485 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:47
Fault Frequency: 87
Reset counter: 250
Mileage: 14991 km
Date: 2015.10.15
Time: 18:54:02
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM008N6F
VCID: 51EAA59C003569B6B4-8004
Seat occupant detection; front passenger side:
Subsystem 1 - Part No SW: 4M0 959 339 A HW: 4M0 959 339 A
Component: BF-Gewichtss. H05 0016
Serial number: IBH0000J140000SQA409
Coding: 303331
Subsystem 2 - Part No SW: ----------- HW: 480 001 004 14
Serial number: 357000000005C5BC5F0.
Subsystem 3 - Part No SW: ----------- HW: 480 001 504 14
Serial number: 35800000000A7A146F0Q
Subsystem 4 - Part No SW: ----------- HW: 480 401 504 14
Serial number: 3510002A3157E9D35353
Subsystem 5 - Part No SW: ----------- HW: 480 400 104 14
Serial number: 3520002B9153FB920361
Subsystem 6 - Part No SW: ----------- HW: 480 402 103 14
Serial number: 3550002C7142B1B071F1
Subsystem 7 - Part No SW: ----------- HW: 480 402 103 14
Serial number: 3560002C7142B1B131A.
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0155
Revision: FF028028 Serial number: 20140418400747
Coding: 0400
Shop #: WSC 66564 385 16448
ROD: EV_SMLSVALEOMQB.rod
VCID: 04445CC88FC74C1E4F-8050
Part No SW: 5G6 920 970 C HW: 5G6 920 970 C
Component: KOMBI 316 2210
Coding: 0BAD09122980CF0502087A00000000
VCID: 302CC0186BFF00BEDB-8064
16776971 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:42
16776988 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:42
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 M
Component: GW MQB High 212 2163
Revision: -------- Serial number: 26051410001453
Coding: 0101000820085900EF00002A080F00000001000000000000000000000000
Shop #: WSC 00066 790 07030
ASAM Dataset: EV_GatewConti 010015
ROD: EV_GatewConti.rod
VCID: 3FCE9324A6A1EFC652-806A
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q
Component: E221__MFL-DC1 H06 0101
Serial number: 27140000323690064081
Coding: 28FFFF
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [008] - -
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:45
66565 - Diagnostic Databus
U1202 00 [008] - Malfunction
Reset counter: 241
Mileage: 15971 km
Date: 2015.11.30
Time: 14:37:38
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000109707001
Coding: 5500000000000000
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 3424CC089FE73C9EBF-8060
12666369 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:42
12666381 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:43
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 140514060505KN
Coding: 003E13200000040000000000
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 40CC90D8DB5F903E2B-8014
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Serial number: 00000000000002377991
Coding: 011000
458803 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:43
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 9102
ROD: EV_SteerAssisMQB.rod
VCID: 3522F10C949D259688-8060
7 Faults Found:
21760 - Databus
Reset counter: 105
Mileage: 14991 km
Date: 2015.10.15
Time: 18:41:56
22272 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:43
22528 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:43
23040 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:43
22784 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:43
19460 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:44
23296 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:47
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 130514060504AB
Coding: 003E13200C00040000000000
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Serial number: 00000000000002591268
Coding: 191000
458803 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:43
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 021A01010B000400
Shop #: WSC 54321 444 54321
ROD: EV_HeadlRegulVWAFS_SE26.rod
Subsystem 1 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H05 0012
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H05 0012
Coding: 2E0000
13705475 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:43
Part No SW: 5G0 035 844 HW: 5G0 035 844
Component: MU-S-S-US 013 0645
Serial number: V7B02704140077
Coding: 027300000000000021220002001800001F0203340100010002
ROD: EV_MUStd4CPASE_SK37.rod
VCID: 64847C486F87EC1EEF-8030
Media Player Position 1:
Subsystem 1 - Part No SW: 5G0 919 605 H HW: 5G0 919 605 H
Component: ABT_Std_Plus H60 0030
Serial number: VWZ8Z9PS5003R3
B11CF 53 [009] - Deactivated
Reset counter: 104
Mileage: 14991 km
Date: 2015.10.15
Time: 18:28:14
6708 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:42
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 HW: 5QE 035 285
Component: OCULowMQBUS 006 0528
Coding: 02730002C2823A017F1E06000000
ROD: EV_OCULowMQB.rod
VCID: 02485AD095D3422E7D-8056
0041 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:42
2103041 - Control Module
Fault Priority: 8
Reset counter: 211
Mileage: 16033 km
Date: 2015.12.03
Time: 09:27:39
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0013
Serial number: 140325201352
VCID: 6B9617748259A366AE-803E
0010 - Databus
Reset counter: 244
Mileage: 16003 km
Date: 2015.12.01
Time: 11:05:43
