Blandy
New Member
Newbie and any help much appreciated...
Car is in limp mode and I've swapped out the exhaust pressure sensor for a new one.
I can move the throttle valve, at first it seemed a little stuck, but then moved ok. I might try to lubricate it tomorrow with WD40 as suggested elsewhere.
Soot mass calculated is approx. 49g
Soot mass measured is approx. 25g
Friday,04,December,2015,21:46:57:29700
VCDS Version: 14.10.2.0
Data version: 20150311
VIN: WAUZZZ8T68A009532 License Plate: L10BSN
Mileage: 203180km-126250mi Repair Order:
Chassis Type: 8T (8T0)
Scan: 01 03 05 06 07 08 09 0E 10 15 16 17 19 1E 36 37 42 46 47 52
53 55 56 77
VIN: WAUZZZ8T68A009532 Mileage: 203180km-126250miles
Address 01: Engine (J623-CAPA) Labels: 059-907-401-CAP.clb
Part No SW: 8K0 907 401 HW: 8K0 907 401
Component: 3.0TDI EDC17 H01 0012
Revision: --H01---
Coding: 01140023180F0118
Shop #: WSC 00006 210 89738
ASAM Dataset: EV_ECM30LTDIA5 A01016
ROD: EV_ECM30LTDIA5.rod
VCID: 68DFBDF19307DF61C6F-803D
5188 - Diesel Particulate Filter (Bank 1)
P242F 00 [167] - Restricted/Clogged
Mileage: 203181 km
Date: 2015.12.04
Time: 21:40:01
5308 - Throttle Body Actuator Bank 1 (J338)
P0638 00 [039] - Implausible Signal
Mileage: 203181 km
Date: 2015.12.04
Time: 21:39:58
5189 - Particulate Trap Bank 1
P2002 00 [039] - Efficiency Below Threshold
Mileage: 203181 km
Date: 2015.12.04
Time: 21:40:01
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 J HW: 8K0 907 379 J
Component: ESP8 quattro H03 0190
Coding: 1B0500
Shop #: WSC 06325 000 00000
VCID: 408F4551D3F7C7212EF-8015
Part No SW: 8K0 907 289 C HW: 8K0 907 289 C
Component: BCM2.01 H38 0253
Coding: 031000
Shop #: WSC 06435 000 00000
VCID: 397928B5B02D96E9691-806C
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H34 0050
Subsystem 2 - Part No SW: 8K0 905 852 A HW: 8K0 905 852 A
Component: ELVAUDIB8 H34 0039
Address 06: Seat Mem. Pass (J521) Labels: 8T0-959-760.clb
Part No SW: 8T0 959 760 HW: 8T0 959 760
Component: MEM-BFS H08 0027
Revision: AA000000 Serial number: 00001001018929
Coding: 08217025002444441000
VCID: 55A184053C7552896D9-8000
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 HW: 4E0 035 729
Component: Interfacebox H43 3250
Revision: 00000000 Serial number: 329G.077516369
Coding: 0005002
VCID: 76E3E38901B33991443-8023
Subsystem 1 - Part No: 8T0 919 609
Component: E0380 BedienteilH07 0100
Subsystem 2 - Serial number: 00000000011548
Subsystem 3 - Serial number: 0121.07.070000000100010105ÿ
Subsystem 4 - Serial number: 010105ÿ
Part No SW: 8T2 820 043 N HW: 8T2 820 043 N
Component: KLIMA 3 ZONEN H05 0110
Revision: D1000000 Serial number: 0103.08.070156
Coding: 36060000
VCID: 3D713CA5A405AAC9459-8068
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 30
Mileage: 203181 km
Date: 2015.12.04
Time: 21:39:30
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 279 D
Component: BCM1 1.0 H19 0253
Revision: 05019001 Serial number: 00000000028735
Coding: 260050910014AF010009000300005D5D001D038800010141000000
Shop #: WSC 00121 210 90973
VCID: 306F1591635757A1DEF-8065
Subsystem 1 - Part No SW: 8T2 955 119 B HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 040707 H11 0040
Coding: 00FD11
Subsystem 2 - Part No SW: 8T0 955 559 HW: 4E0 955 559 B
Component: RLS H12 0001
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
014 - Defective
Fault Status: 01101110
Reset counter: 30
Mileage: 203181 km
Date: 2015.12.04
Time: 21:39:00
Part No SW: 8T2 035 110 A HW: 8T2 035 110 A
Component: MP3-Changer H42 0350
Revision: 00042003 Serial number: AUZ5ZBG4512096
VCID: 2959F8F5808D2669191-807C
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 A HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0003
Revision: 11001001 Serial number: 46230719906244
Coding: 100001
VCID: 377D2E8D863980999F5-8062
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 HW: 8K0 959 655
Component: AirbagVW-AU10 H21 0334
Serial number: 0038GD0862Z5
Coding: 30323232333030303030554A305238543053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02001
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 7AFBF7B9FDAB5DF120B-802F
Serial number: 6334LSME181D1458D
Serial number: 6344LSME1C313449A
Serial number: 6352QSME332E3A79S
Serial number: 6362QSME31731F2DN
Serial number: 63734SME342D286D9
Serial number: 63834SME2B621B5B8
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 B HW: 8K0 953 568 B
Component: Lenks.Modul H09 0011
Revision: -------- Serial number: 90304GGO0002F
Coding: 000016
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 980 M HW: 8T0 920 980 M
Component: KOMBIINSTR. H20 0136
Revision: 00500000 Serial number: 6C1236T77
Coding: 2F0501000A002600010000
VCID: 45815445CCD5E2091D9-8010
00003 - Control Module
Fault Status: 01100101
Reset counter: 30
Mileage: 203181 km
Date: 2015.12.04
Time: 21:38:30
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 F HW: 8T0 907 468 F
Component: GW-BEM 4CAN-M H07 0084
Revision: EB002032 Serial number: 3200E07713812A
Coding: 000003
Shop #: WSC 00202 210 90025
VCID: 44874941C7EFDB010A7-8011
Subsystem 1 - Part No SW: 8K0 915 181 HW: 8K0 915 181
Component: J367-BDM H06 0150
Address 1E: Media Player 2 (R192) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 A HW: 4E0 035 785 A
Component: SG ext.Player H09 0530
Revision: 0
VCID: 2643F3C951930911343-8073
Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
Component: MEM-FS H08 0027
Revision: AA000000 Serial number: 00001001018930
Part No SW: 4E0 910 887 T HW: 4E0 919 887 M
Component: MNS ECE H50 1030
Revision: 00000000 Serial number: 333GQ077515193
VCID: 3E733BA96903B1D15C3-806B
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 A HW: 8K0 959 793 A
Component: TSG FA H09 0149
Revision: Serial number: 0xa
Coding: 0110022240012201
VCID: 3E733BA9A903B1D15C3-806B
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0105556784
Coding: 011B068200390440002000
Component: DWA-Sensor H02 0030
Component: LIN BACKUP HO H03 1301
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 M HW: 8T0 035 223 C
Component: DSP Prem H12 0280
Revision: 00H12003 Serial number: 34813000349002
Coding: 020101
Shop #: WSC 12336 024 394758
VCID: 387F2DB18B278FE196F-806D
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 A HW: 8K0 959 792 A
Component: TSG BF H09 0149
Revision: Serial number: 0a
Part No SW: 8K0 907 801 C HW: 8K0 907 801 C
Component: EPB Audi B8 H03 0040
Revision: 00000003 Serial number: 00000000014070
VCID: 2F6D16ED7E694859C75-807A
Address 55: Headlight Range Labels: 8T0-907-357.clb
Part No SW: 8T0 907 357 A HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000017
VCID: 3C7731A17F1FA3C1727-8069
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Revision: 00000000 Serial number: 336GP077513173
VCID: 2E530BE9B9634151CC3-807B
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 A HW: 4F1 862 335
Component: BTA H09 0710
Revision: 00H09000 Serial number: 00000007542777
Coding: 0010021
VCID: 224BEFD9FDBBF53158B-8077
End---------------------(Elapsed Time: 03:29, Deb=1)-----------------------
