Page 5 of 5 FirstFirst ... 345
Results 41 to 45 of 45
Thread: 2010 Jetta TDI ABS issue missing software code
  1. #41
    United States
    Yeah Jack, 0C versus 0D (Byte 3) is a VIN check digit. Even though this is a 1K239M it uses the silly NAR specific AJ VIN instead
  2. Likes Uwe, Jack@European_Parts liked this post
  3. #42
    United States
    Quote Originally Posted by Homefront View Post
    Now I got to ask a question? where can I learn about writing these codes for the ABS module so if this happens again I can keep my head on straight being I am doing repairable as a hobby I'm sure I will have this issue again.
    I'm glad that was accepted and please do post the new scan after you sort the Basic Settings if you haven't already.
    As far as MK60EC1 long coding goes.. saving a scan BEFORE any repairs are performed so the original coding isn't lost in the first place is the best plan
  4. Likes Uwe, Jack@European_Parts liked this post
  5. #43
    NostraJackASS notes..........
    3VWAL7AJ3AM116056
    114B400C49230000880B02E9921F0042310000
    114b400d49230000880b02e9921f0042310000 AJ same part # and VIN alternate platform.
    114b400d49230000880b02e9921f0042310000 AS " " MATCH
    114b400d49230000880b02e9921f0042310000 BB " " MATCH
    114b400d49230000880b02e9921f0042310000 BC " " MATCH
    114b400d49230000880b02e9921f0042310000 BD " " MATCH
    114b400d49230000880b02e9921f0042310000 BF " " MATCH
    114b400d21230000880b02e9841f0042310000 AT
    114b400d09230000880b02e9901f0042310000 AH Based on part # prefix Same VIN alternate part #final outcome.
    114b400d09230000880b02e9901f0042310000 BE
  6. #44
    New User
    Jan 2016
    India
    hi i have a quite similar situation with my 2010 vw jetta
    I replaced the abs module with an used abs module,i noted the coding on the original abs module before replacing and tried typing in the original coding on the replaced used abs module.
    The system simply rejected and now i am unable to code the used abs module.
    please help,i hv turned desperate in this situation.
    Tuesday,06,September,2016,06:35:52:46686
    VCDS Version: 15.7.4.1 (x64)
    Data version: 20160216
    VIN: WVWL091K5AA550307   License Plate: 123
    Mileage: 95250km-59185mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: WVWL091K5AA550307   Mileage: 95250km-59185miles
    Address 01: Engine        Labels: None
       Part No SW: 03G 906 056 AC    HW: 03G 906 021 AN
       Component: R4 1,9L EDC G000AG  5415
       Revision: --H11---    Serial number:
       Coding: 0000078
       Shop #: WSC 73430 790 00000
       VCID: 68DFEB5E5BC5857ED6-803C
       Part No SW: 02E 300 051 S    HW: 02E 927 770 AJ
       Component: GSG DSG AG6     440 1909
       Revision: 04844002    Serial number: 00000908281307
       Shop #: WSC 44551 111 44551
       VCID: 2345BC72E263A62643-8076
       Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
       Revision: 00H30001
       Shop #: WSC 73430 790 00051
       VCID: 7AFBA116F56907EE30-802E
                        Reset counter: 204
                        Mileage: 95253 km
                        Date: 2011.01.28
                        Time: 07:49:50
                        Count: 16391
                        Count: 12
                        Count: 8192
                        Count: 195
                        Count: 43520
                        Count: 512
                        Fault Status: 01100101
                        Reset counter: 204
                        Mileage: 95253 km
                        Date: 2011.01.28
                        Time: 07:49:31
                        Count: 3
                        Count: 12
                        Count: 12288
                        Count: 279
                        Count: 43520
                        Count: 512
                        Reset counter: 204
                        Mileage: 95253 km
                        Date: 2011.01.28
                        Time: 07:49:31
                        Count: 3
                        Count: 12
                        Count: 12288
                        Count: 295
                        Count: 43520
                        Count: 512
                        Reset counter: 204
                        Mileage: 95253 km
                        Date: 2011.01.28
                        Time: 07:49:31
                        Count: 3
                        Count: 12
                        Count: 12288
                        Count: 270
                        Count: 43520
                        Count: 512
                        Reset counter: 204
                        Mileage: 95253 km
                        Date: 2011.01.28
                        Time: 07:49:52
                        Count: 7
                        Count: 12
                        Count: 12288
                        Count: 107
                        Count: 43520
                        Count: 512
       Part No SW: 5K0 907 044 BR    HW: 5K0 907 044 BR
       Component: Climatronic   H14 0609
       Revision: 00003001
       Coding: 0000000000
       ASAM Dataset: EV_Climatronic A01001
       VCID: 7CF7A70EF75D39DE22-8028
       Part No SW: 5K0 937 086     HW: 5K0 937 086
       Component: BCM PQ35 M    008 0019
       Revision: BC008001
       Coding: 40000A3A982DE1E0440800800400012001702388512085605C8000000000
       VCID: 71E9863AA81F44B681-8024
       Component: Wischer 07070  21  0501
       Coding: 009795
       Component: RLS 230708 05  54  0402
       Coding: 0330AD
       Subsystem 4 - Part No: 1K8 951 605
       Component: LIN BACKUP HO  H09 9002
       Subsystem 5 - Part No: 1K8 951 171
                        Reset counter: 244
                            Term 15 Off
                        Voltage: 9.35 V
       Part No SW: 1K0 909 605 AC    HW: 1K0 909 605 AC
       Component: 27 AIRBAG VW8R  038 8600
       Revision: 07038000    Serial number: 003E7M08WG9P
       Coding: 0012855
       VCID: 6DD19A4A7427A056A5-8038
       Subsystem 1 - Serial number: 6332MSME4A132D3FM
       Subsystem 2 - Serial number: 6342MSME49450F27I
       Subsystem 3 - Serial number: 6351HSME1D2D5F2CU
       Subsystem 4 - Serial number: 6361HSME1D3406724
       Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
       Component: J0527           056 0111
       Coding: 0001631
       VCID: 76E3B5260171638E54-8022
       Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS   H05 0010
       Coding: 00000131
       Part No SW: 5M0 920 870 C    HW: 5M0 920 870 C
       Component: KOMBI         H04 0207
       Coding: 171B00
       VCID: 2F6D404276AB1246D7-807A
    Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
       Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
       Component: J533  Gateway   H07 0081
       Revision:   H07 01    Serial number: 070709F1000767
       Coding: ED807F06000202001003
       VCID: 66C3E56651D1930EE4-8032
       Component: IMMO          H04 0207
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
       Part No SW: 1K0 959 701 AE    HW: 1K0 959 793 P
       Component: J386  TUER-SG FT    1520
       Revision: 71009005    Serial number: 00000500398714
       Coding: 0004790
       VCID: 71E9863A681F44B681-8024
       Part No: 1K0 909 144 C
       Revision: 00H15000
       VCID: 2A5B51568549776E00-807E
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Battery Volts: 8.7 V
                            PD
                        Temperature: 28.0C
                        Count: 2
                        Steering Angle: 0.00
                            SteerAng n.Init
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
       Part No SW: 1K0 959 702 AE    HW: 1K0 959 792 P
       Component: J387  TUER-SG BT    1520
       Revision: 71009005    Serial number: 00000540588829
       Coding: 0005046
       VCID: 72EB89366D197FAE78-8026
    00097 - Front Passengers Central Locking (Safe) Motor (V162)
                        Reset counter: 204
                        Mileage: 94719 km
                        Date: 2011.01.15
                        Time: 18:35:18
                        Fault Frequency: 96
                        Reset counter: 244
                        Mileage: 94719 km
                        Date: 2011.01.15
                        Time: 18:35:18
    Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 3C8 035 195     HW: 3C8 035 195
       Component: Radio RCD510  039 0144
       Revision: 00000001    Serial number: VWZ1Z3I5393790
       Coding: 0500040004
       VCID: 65C1E26A6CD79816ED-8030
    03138 - Input AUX IN
                        Reset counter: 190
                        Mileage: 94719 km
                        Date: 2011.01.15
                        Time: 18:33:03
       Part No SW: 1K0 959 703 AG    HW: 1K0 959 795 R
       Revision: 11006001    Serial number: 00000004086875
       Coding: 0000144
       VCID: 75E1B22A1C7768965D-8020
       Part No SW: 1K0 959 704 AG    HW: 1K0 959 794 R
       Revision: 11006001    Serial number: 00000004057546
       Coding: 0000144
    00099 - Rear Right Central Locking (Safe) Motor (V164)
                        Reset counter: 204
                        Mileage: 94719 km
                        Date: 2011.01.15
                        Time: 18:35:18
                        Fault Frequency: 96
                        Reset counter: 244
                        Mileage: 94719 km
                        Date: 2011.01.15
                        Time: 18:35:18
    End-------------------------(Elapsed Time: 02:18)--------------------------
    thank you
  7. #45
    Quote Originally Posted by asselen View Post
    Please don't post the same question in two different threads. You already started your own thread here.
  8. Likes Jack@European_Parts liked this post
