2010 Jetta TDI ABS issue missing software code
   #41
Dana
Western PA, USA
Yeah Jack, 0C versus 0D (Byte 3) is a VIN check digit. Even though this is a 1K239M it uses the silly NAR specific AJ VIN instead ;)
   #42
Dana
Western PA, USA
Now I got to ask a question? where can I learn about writing these codes for the ABS module so if this happens again I can keep my head on straight being I am doing repairable as a hobby I'm sure I will have this issue again.
I'm glad that was accepted and please do post the new scan after you sort the Basic Settings if you haven't already.
As far as MK60EC1 long coding goes.. saving a scan BEFORE any repairs are performed so the original coding isn't lost in the first place is the best plan :D
   #43
NostraJackASS notes..........
3VWAL7AJ3AM116056
114B400C49230000880B02E9921F0042310000
114b400d49230000880b02e9921f0042310000 AJ same part # and VIN alternate platform.
114b400d49230000880b02e9921f0042310000 AS " " MATCH
114b400d49230000880b02e9921f0042310000 BB " " MATCH
114b400d49230000880b02e9921f0042310000 BC " " MATCH
114b400d49230000880b02e9921f0042310000 BD " " MATCH
114b400d49230000880b02e9921f0042310000 BF " " MATCH
114b400d21230000880b02e9841f0042310000 AT
114b400d09230000880b02e9901f0042310000 AH Based on part # prefix Same VIN alternate part #final outcome.
114b400d09230000880b02e9901f0042310000 BE
   #44
asselen
New Member
India
HC839933
hi i have a quite similar situation with my 2010 vw jetta
I replaced the abs module with an used abs module,i noted the coding on the original abs module before replacing and tried typing in the original coding on the replaced used abs module.
The system simply rejected and now i am unable to code the used abs module.
please help,i hv turned desperate in this situation.
Tuesday,06,September,2016,06:35:52:46686
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WVWL091K5AA550307   License Plate: 123
Mileage: 95250km-59185mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWL091K5AA550307   Mileage: 95250km-59185miles
Address 01: Engine        Labels: None
   Part No SW: 03G 906 056 AC    HW: 03G 906 021 AN
   Component: R4 1,9L EDC G000AG  5415
   Revision: --H11---    Serial number:
   Coding: 0000078
   Shop #: WSC 73430 790 00000
   VCID: 68DFEB5E5BC5857ED6-803C
   Part No SW: 02E 300 051 S    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1909
   Revision: 04844002    Serial number: 00000908281307
   Shop #: WSC 44551 111 44551
   VCID: 2345BC72E263A62643-8076
   Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
   Revision: 00H30001
   Shop #: WSC 73430 790 00051
   VCID: 7AFBA116F56907EE30-802E
                    Reset counter: 204
                    Mileage: 95253 km
                    Date: 2011.01.28
                    Time: 07:49:50
                    Count: 16391
                    Count: 12
                    Count: 8192
                    Count: 195
                    Count: 43520
                    Count: 512
                    Fault Status: 01100101
                    Reset counter: 204
                    Mileage: 95253 km
                    Date: 2011.01.28
                    Time: 07:49:31
                    Count: 3
                    Count: 12
                    Count: 12288
                    Count: 279
                    Count: 43520
                    Count: 512
                    Reset counter: 204
                    Mileage: 95253 km
                    Date: 2011.01.28
                    Time: 07:49:31
                    Count: 3
                    Count: 12
                    Count: 12288
                    Count: 295
                    Count: 43520
                    Count: 512
                    Reset counter: 204
                    Mileage: 95253 km
                    Date: 2011.01.28
                    Time: 07:49:31
                    Count: 3
                    Count: 12
                    Count: 12288
                    Count: 270
                    Count: 43520
                    Count: 512
                    Reset counter: 204
                    Mileage: 95253 km
                    Date: 2011.01.28
                    Time: 07:49:52
                    Count: 7
                    Count: 12
                    Count: 12288
                    Count: 107
                    Count: 43520
                    Count: 512
   Part No SW: 5K0 907 044 BR    HW: 5K0 907 044 BR
   Component: Climatronic   H14 0609
   Revision: 00003001
   Coding: 0000000000
   ASAM Dataset: EV_Climatronic A01001
   VCID: 7CF7A70EF75D39DE22-8028
   Part No SW: 5K0 937 086     HW: 5K0 937 086
   Component: BCM PQ35 M    008 0019
   Revision: BC008001
   Coding: 40000A3A982DE1E0440800800400012001702388512085605C8000000000
   VCID: 71E9863AA81F44B681-8024
   Component: Wischer 07070  21  0501
   Coding: 009795
   Component: RLS 230708 05  54  0402
   Coding: 0330AD
   Subsystem 4 - Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
   Subsystem 5 - Part No: 1K8 951 171
                    Reset counter: 244
                        Term 15 Off
                    Voltage: 9.35 V
   Part No SW: 1K0 909 605 AC    HW: 1K0 909 605 AC
   Component: 27 AIRBAG VW8R  038 8600
   Revision: 07038000    Serial number: 003E7M08WG9P
   Coding: 0012855
   VCID: 6DD19A4A7427A056A5-8038
   Subsystem 1 - Serial number: 6332MSME4A132D3FM
   Subsystem 2 - Serial number: 6342MSME49450F27I
   Subsystem 3 - Serial number: 6351HSME1D2D5F2CU
   Subsystem 4 - Serial number: 6361HSME1D3406724
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Component: J0527           056 0111
   Coding: 0001631
   VCID: 76E3B5260171638E54-8022
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000131
   Part No SW: 5M0 920 870 C    HW: 5M0 920 870 C
   Component: KOMBI         H04 0207
   Coding: 171B00
   VCID: 2F6D404276AB1246D7-807A
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H07 0081
   Revision:   H07 01    Serial number: 070709F1000767
   Coding: ED807F06000202001003
   VCID: 66C3E56651D1930EE4-8032
   Component: IMMO          H04 0207
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1K0 959 701 AE    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1520
   Revision: 71009005    Serial number: 00000500398714
   Coding: 0004790
   VCID: 71E9863A681F44B681-8024
   Part No: 1K0 909 144 C
   Revision: 00H15000
   VCID: 2A5B51568549776E00-807E
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 8.7 V
                        PD
                    Temperature: 28.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1K0 959 702 AE    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1520
   Revision: 71009005    Serial number: 00000540588829
   Coding: 0005046
   VCID: 72EB89366D197FAE78-8026
00097 - Front Passengers Central Locking (Safe) Motor (V162)
                    Reset counter: 204
                    Mileage: 94719 km
                    Date: 2011.01.15
                    Time: 18:35:18
                    Fault Frequency: 96
                    Reset counter: 244
                    Mileage: 94719 km
                    Date: 2011.01.15
                    Time: 18:35:18
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  039 0144
   Revision: 00000001    Serial number: VWZ1Z3I5393790
   Coding: 0500040004
   VCID: 65C1E26A6CD79816ED-8030
03138 - Input AUX IN
                    Reset counter: 190
                    Mileage: 94719 km
                    Date: 2011.01.15
                    Time: 18:33:03
   Part No SW: 1K0 959 703 AG    HW: 1K0 959 795 R
   Revision: 11006001    Serial number: 00000004086875
   Coding: 0000144
   VCID: 75E1B22A1C7768965D-8020
   Part No SW: 1K0 959 704 AG    HW: 1K0 959 794 R
   Revision: 11006001    Serial number: 00000004057546
   Coding: 0000144
00099 - Rear Right Central Locking (Safe) Motor (V164)
                    Reset counter: 204
                    Mileage: 94719 km
                    Date: 2011.01.15
                    Time: 18:35:18
                    Fault Frequency: 96
                    Reset counter: 244
                    Mileage: 94719 km
                    Date: 2011.01.15
                    Time: 18:35:18
End-------------------------(Elapsed Time: 02:18)--------------------------
thank you
Please don't post the same question in two different threads. You already started your own thread here.
