Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 45
Thread: 2010 Jetta TDI ABS issue missing software code
  1. #21
    Dec 2015
    Jack,
    had no luck with them long codes, this could be me. This coding thing could be me as this part is a learning curve for me.
    - Then I tried to follow (Change Cluster/Matching ECU)
    http://wiki.ross-tech.com/wiki/index...ument_Cluster)
    Determining IMMO-ID (ECU)
    [Select]
    [01 - Engine]
    Look at the first "Extra" field. The 14-digit string is the Immo-ID.
    [Close Controller, Go Back - 06]
    Note: If the 17 Digit VIN is shown the vehicle does not use Immo II and the procedure here does not apply.
    (scanning this got me the VIN but did not show the 14-digit string for the Immo-ID)
    Well that failed so I went ahead and changed the cluster to the Matching ECU (donor car):
    with no luck just got more codes with the matching cluster. (key not matching) Immobilizer has been unlocked so I am able to start the car with the correct cut key and lost steering wheel controls.
    I was told the code was 4144 after having the ecu done as stage 2 ( Immobilizer code)
    how do we come up with this long code?
    Ok im so lost now..
    I no I should not do this but here is my cell I hope someone will be able to get me on track here
    612.203.8913
    Thank you all!
    SteveOOO
  2. #22
    Dallas (McKinney) ,TX ,USA
    Quote Originally Posted by Homefront View Post
    Jack,
    [Select]
    [01 - Engine]
    Ok im so lost now..
    612.203.8913
    Thank you all!
    SteveOOO
    I gave you answer in post #19.
    And most likely when you fix VIN in both modules , you will need to go to Vw Dealer to get online ABS coding, best and safest way.
    If you put original cluster in car , of curse you will get Immobilizer code bacuse cluster is not programmed.
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  3. #23
    You could send me all your equipment so it can be properly programmed, because VW-Audi GeKo policy to change entire identity must be changed with all new parts.
    You still have not posted the data I requested...........
    Put what works in there for now with matching cluster, key and ecu that operates even if immo defeated.
    Don't alter config from here trying this or that........
    Post a full auto-scan and give me additional data ...
    ecu 0x01-10-091 and 0x01-08-081
    Immo 0x25-08-003 and 081
    Stop putzing around.
    Last chance because I have this car in my bay right now while playing G235 and other service.......
    I can simulate this with entire car.......
  4. #24
    Dec 2015
    Jack,
    I put everything back to factory now.
    081 shows the correct VIN #
    01 engine doesn't show vin# or Immobilizer
    025 no codes on Immobilizer
    003 ? showing EGR 100% all good there
    Cluster I have been googling dont no how to get you that info...
    here is the update scans I pulled I hope this will be helpful
    here is the full scan
    Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
    VCDS Version: Release 15.7.2(x64) Data version: 20151124
    Dealer/Shop Name: Homefront
    Workshop Code: 000 00000 000000
    Self-Diagnosis Log
    Monday,14,December,2015,14:08:02:34959
    VIN: 3VWAL7AJ3AM116056 License Plate:
    Mileage: 139920km-86942mi Repair Order:
    Chassis Type: AJ (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 65 72
    77
    VIN: 3VWAL7AJ3AM116056 Mileage: 139920km-86942miles
    2E-Media Player 3 -- Status: Cannot be reached 1100
    56-Radio -- Status: Malfunction 1110
    Self-Diagnosis Log
    Page 2
    Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
    Part No SW: 03L 906 019 CM HW: 03L 906 022 TS
    Component: R4 2,0L EDC G000AG 9971
    Revision: 12H03--- Serial number:
    Coding: 0050078
    Shop #: WSC 02408 444 11192
    VCID: 78FFB5480B5BC4FE53-802C
    6 Faults Found:
    001166 - Sensor for Exhaust Flap
    P048E - 000 - Short to Plus
    Mileage: 139923 km
    Date: 2010.05.06
    Time: 00:05:01
    Voltage: 11.86 V
    Lambda: 99.4 %
    Lambda: 0.0 %
    Bin. Bits: 00000000
    Voltage: 5.016 V
    001029 - EGR Sensor 1
    P0405 - 000 - Signal too Low
    Mileage: 139923 km
    Date: 2010.05.06
    Time: 00:05:01
    Voltage: 11.86 V
    Lambda: 99.4 %
    Lambda: 0.0 %
    Voltage: 0.000 V
    Bin. Bits: 00000000
    009258 - Exhaust Gas Temperature Sensor; B1 S3
    Self-Diagnosis Log
    Page 3
    P242A - 001 - Malfunction
    Fault Status: 01100001
    Mileage: 139923 km
    Date: 2010.05.06
    Time: 00:05:01
    Voltage: 11.86 V
    Temperature: 14.4C
    Temperature: 18.0C
    Temperature: 930.0C
    Temperature: 18.0C
    001141 - Exhaust Pressure Control Valve
    P0475 - 000 - Electrical Malfunction
    Mileage: 139923 km
    Date: 2010.05.06
    Time: 00:05:02
    Load: 100.0 %
    Lambda: 99.4 %
    Temperature: 18.0C
    Temperature: 14.4C
    005184 - EGR Valve (N18)
    P1440 - 000 - Open Circuit
    Mileage: 139923 km
    Date: 2010.05.06
    Time: 00:05:02
    Self-Diagnosis Log
    Page 4
    Load: 100.0 %
    Lambda: 99.4 %
    Mass Air / Rev.: 0.0 mg/str
    Temperature: 14.4C
    P242A - 000 - Malfunction - MIL ON
    Fault Status: 11100000
    Mileage: 139923 km
    Date: 2010.05.06
    Time: 00:05:06
    Voltage: 11.86 V
    Temperature: 14.4C
    Temperature: 18.0C
    Temperature: 930.0C
    Temperature: 18.0C
    Address 02: Auto Trans Labels: 02E-927-770.lbl
    Part No SW: 02E 300 052 T HW: 02E 927 770 AL
    Component: L DSG AG6 511 2114
    Revision: 51112 Serial number: 00001004291528
    Coding: 0000024
    VCID: 2541AC3CEC69891638-8070
    Self-Diagnosis Log
    Page 5
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
    Component: ESP MK60EC1 H30 0107
    Revision: 00H30001
    VCID: 7AFBAF40F557D6EE25-802E
    Reset counter: 179
    Date: 2010.05.06
    Time: 00:07:25
    Count: 3
    Count: 12
    Count: 20992
    Count: 195
    Count: 42752
    Fault Status: 01100101
    Reset counter: 179
    Mileage: 139923 km
    Date: 2010.05.06
    Time: 00:06:29
    Count: 3
    Count: 12
    Count: 4096
    Count: 279
    Count: 43008
    Count: 768
    Self-Diagnosis Log
    Page 6
    Reset counter: 179
    Mileage: 139923 km
    Date: 2010.05.06
    Time: 00:06:29
    Count: 3
    Count: 12
    Count: 4096
    Count: 295
    Count: 43008
    Count: 768
    Reset counter: 179
    Mileage: 139923 km
    Date: 2010.05.06
    Time: 00:06:29
    Count: 3
    Count: 12
    Count: 4096
    Count: 270
    Count: 43008
    Count: 768
    Self-Diagnosis Log
    Page 7
    Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
    Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
    Component: Climatic H14 0305
    Revision: 00009001
    Coding: 0000001002
    Shop #: WSC 00066 000 00148
    ROD: EV_ClimaBasis_VW36.rod
    VCID: 75E1BC7CD449B99648-8020
    B10AB F0 [009] - Too Low
    Reset counter: 175
    Mileage: 139754 km
    Date: 2015.12.08
    Time: 06:59:11
    Self-Diagnosis Log
    Page 8
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 5K0 937 085 G HW: 5K0 937 085 G
    Component: BCM PQ35 B++ 111 0129
    Revision: BI111001
    Coding: 2D200B1A902F3EE4800800854000000401000086510085605C8020000000
    VCID: 377D767486C50B869A-8062
    Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
    Component: Wischer 19031 21 0512
    Coding: 009795
    14 Faults Found:
    00153 - Windshield Wiper Motor; Driver Side (V216)
    Reset counter: 219
    Mileage: 139923 km
    Date: 2010.05.06
    Time: 00:19:20
    Voltage: 9.55 V
    Fault Frequency: 26
    Reset counter: 219
    Mileage: 138941 km
    Date: 2015.09.07
    Time: 17:43:41
    Term 15 Off
    Voltage: 8.50 V
    Self-Diagnosis Log
    Page 9
    00532 - Supply Voltage B+
    Reset counter: 219
    Mileage: 139923 km
    Date: 2010.05.02
    Time: 06:56:10
    Voltage: 8.65 V
    Fault Status: 00101010
    Reset counter: 210
    Mileage: 139465 km
    Date: 2015.10.01
    Time: 02:11:21
    Voltage: 13.85 V
    Reset counter: 210
    Self-Diagnosis Log
    Page 10
    Mileage: 139465 km
    Date: 2015.10.01
    Time: 02:11:21
    Voltage: 13.85 V
    Reset counter: 210
    Mileage: 139465 km
    Date: 2015.10.01
    Time: 02:11:16
    Voltage: 14.05 V
    Reset counter: 210
    Mileage: 139465 km
    Date: 2015.10.01
    Time: 02:11:16
    Voltage: 14.05 V
    Self-Diagnosis Log
    Page 11
    Reset counter: 210
    Mileage: 139465 km
    Date: 2015.09.30
    Time: 22:09:49
    Voltage: 13.50 V
    Reset counter: 210
    Mileage: 139465 km
    Date: 2015.10.01
    Time: 02:11:16
    Voltage: 13.90 V
    Self-Diagnosis Log
    Page 12
    Reset counter: 217
    Mileage: 139923 km
    Date: 2010.05.01
    Time: 05:49:11
    Voltage: 11.65 V
    Reset counter: 217
    Mileage: 139923 km
    Date: 2010.05.01
    Time: 06:41:57
    Voltage: 11.60 V
    01800 - Light Switch (E1)
    Reset counter: 210
    Mileage: 54223 km
    Date: 2015.07.29
    Time: 00:00:04
    Term 15 Off
    Voltage: 12.55 V
    Self-Diagnosis Log
    Page 13
    Reset counter: 210
    Mileage: 139465 km
    Date: 2015.10.04
    Time: 21:52:11
    Term 15 Off
    Voltage: 12.05 V
    Reset counter: 210
    Mileage: 139465 km
    Date: 2015.10.04
    Time: 21:52:11
    Term 15 Off
    Voltage: 12.05 V
    Self-Diagnosis Log
    Page 14
    Part No SW: 1K0 909 605 AD HW: 1K0 909 605 AD
    Component: 04 AIRBAG VW8R 036 8900
    Revision: 06036000 Serial number: 003EVM02H6PY
    Coding: 0012340
    VCID: 6ED39310791F8A4E89-803A
    Subsystem 2 - Serial number: 6332MSME4F10263BD
    Subsystem 3 - Serial number: 6342MSME4F414F1BR
    Subsystem 4 - Serial number: 6351HSME1F75282EL
    Subsystem 5 - Serial number: 6361HSME1F751544A
    Subsystem 6 - Serial number: 63727SME2157565D4
    Subsystem 7 - Serial number: 63827SME21576C40+
    Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
    Component: J0527 056 0111
    Coding: 0001731
    VCID: 76E3BB70014FB28E41-8022
    Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAS H05 0010
    Coding: 00000130
    Self-Diagnosis Log
    Page 15
    Part No SW: 5M0 920 970 G HW: 5M0 920 970 G
    Component: KOMBI H05 0305
    Coding: 271F00
    VCID: 346741789FB3E09EBF-8060
    13635840 - Supply voltage
    Reset counter: 217
    Mileage: 139923 km
    Date: 2015.12.10
    Time: 06:56:38
    Self-Diagnosis Log
    Page 16
    Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
    Part No SW: 1K0 907 530 AD HW: 1K0 907 951
    Component: J533 Gateway H07 0112
    Revision: H07 01 Serial number: 040210F1000342
    Coding: ED807F07001612001002
    VCID: 69D9E00C40F16D76DC-803C
    Fault Status: 00110100
    Reset counter: 217
    01304 - Radio
    Fault Frequency: 88
    Reset counter: 179
    Mileage: 139635 km
    Date: 2010.04.29
    Time: 06:50:58
    Reset counter: 179
    Mileage: 54320 km
    Date: 2015.07.31
    Time: 12:24:14
    Reset counter: 217
    Mileage: 139923 km
    Date: 2010.05.02
    Self-Diagnosis Log
    Page 17
    Time: 06:56:09
    03272 - Control Module for Audio Interface
    Reset counter: 179
    Mileage: 139635 km
    Date: 2010.04.29
    Time: 06:50:58
    Part No SW: 1K5 919 965 D HW: 1K5 919 965 D
    Component: Kompass 001 0001
    Revision: 00001000 Serial number: 1293324T4Q0C05
    Coding: 0000004
    VCID: 3C7769587FE328DE77-8068
    Reset counter: 219
    Mileage: 139923 km
    Date: 2010.05.02
    Time: 06:56:07
    Component: IMMO H05 0305
    VCID: 6ADB9F008DF7666ED5-803E
    Self-Diagnosis Log
    Page 18
    Address 2E: Media Player 3
    Self-Diagnosis Log
    Page 19
    Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 3C0 959 701 B HW: 3C0 959 793
    Component: TUER-SG FT 002 0307
    Revision: 13101005 Serial number: 0000567620
    Coding: 0004B5
    Shop #: WSC 01383 790 50316
    ASAM Dataset: EV_DCU42BroseDriveSide A03004
    ROD: EV_DCU42BroseDriveSide.rod
    VCID: 275DA6345E659B060A-8072
    Slave Driver:
    Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
    Component: J388__TSG-HL 006 1401
    Serial number: 00000004703294
    Coding: 000490
    B11EC 54 [009] - Missing Calibration / Basic Setting
    Reset counter: 179
    67589 - Turn Signal in Exterior Mirror
    B11FD 01 [009] - Electrical Failure
    Reset counter: 174
    Mileage: 139635 km
    Date: 2015.12.07
    Time: 06:56:39
    65793 - Supply voltage
    Reset counter: 217
    Mileage: 139923 km
    Date: 2015.12.10
    Time: 06:55:08
    Self-Diagnosis Log
    Page 20
    Part No: 1K0 909 144 J
    Component: EPS_ZFLS Kl. 70 3001
    Revision: 00H17000
    VCID: 3169486CA8A1D5B6D4-8064
    Fault Status: 11100101
    Battery Volts: 11.2 V
    DD
    Temperature: 13.0C
    Count: 3
    Steering Angle: -5.25
    Count: 1
    SteerAng n.Init
    Self-Diagnosis Log
    Page 21
    Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 3C0 959 702 B HW: 3C0 959 792
    Component: TUER-SG BT 002 0307
    Revision: 15101005 Serial number: 0000549125
    Coding: 0004B4
    ASAM Dataset: EV_DCU52BrosePasseSide A03004
    ROD: EV_DCU52BrosePasseSide.rod
    VCID: 285FA508537B947E03-807C
    Slave Passenger:
    Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
    Component: J389__TSG-HR 006 1401
    Serial number: 00000004706195
    Coding: 000490
    B11EC 54 [008] - Missing Calibration / Basic Setting
    Reset counter: 217
    Reset counter: 175
    Mileage: 139645 km
    Date: 2015.12.07
    Time: 07:08:06
    Reset counter: 217
    Mileage: 139923 km
    Date: 2015.12.10
    Time: 06:55:07
    Self-Diagnosis Log
    Page 22
    Address 56: Radio
    Address 65: Tire Pressure (J502) Labels: 1K0-937-08x-65.clb
    Component: RDK 111 0821
    Coding: 018705
    Address 77: Telephone
    End-------------------------(Elapsed Time: 02:29)--------------------------
  5. #25
    Dec 2015
    Address 01: Engine (03L 906 019 CM)
    15:06:30
    3VWAL7AJ3AM116056 Vehicle Ident. Number (VIN)
    3VWAL7AJ3AM116056 Immobilizer Ident. Number (IMMO-ID)
    139920 km Vehicle Mileage
    Im am not able to find (IMMO-ID) everything has matching vin#'s now
    as for the cluster I cant find what it is your looking for, im sorry
    VCDS is kicking my XXX lol, had it now for 2 weeks so much to learn about it.
  6. #26
    Revision: 00H30001
    Revision: 00H30001
    Coding: 114B400C492A00FC880D02EC921E0042310000 <<<<<<<<<<<<<< Found trolling scans!
    TRY this !
    114b400d49230000880b02e9921f0042310000
    3VWAL7AJ3AM116056 <<<<<<<<<<<<Yup....... can't trust you verse the scan see........?
    3VWALJAJ3AM116056 <<<<<<<<<<<<<<<<<<<<< Inconsistent VIN .....face palm.
    Now for the rebuilt car:
    Vin: 3VWALJAJ3AM116056 ............from page 2............OP!
  7. #27
    Dec 2015
    im entering these codes your sending me under ABS/ESP - Coding I hope that is the correct place if so then no again im ready to ship it if your able to correct the damn coding issue
  8. #28
    Dec 2015
    Jack up one.... LOL lets just say my blood pressure is now boiling
  9. #29
    Homefront: When you post scans, please do not use [Print]. Please use [Copy] or [Save]. The results from [Print] are much more difficult to read on-line than the results from Copy or Save. Thanks!
  11. #30
    Any luck with above codification?
    Please let me know if the ecu accepts it..........?
    FYI ............this code below in 0x44 must be adapted before a codification will be accepted in 0x03 ABS.......... in some cases not all from my personal experience.
    http://wiki.ross-tech.com/wiki/index...ngle_.28G85.29
    Sensor for Steering Angle (G85) Important Note: This procedure ONLY applies to Models with Conti/Teves MK70 ABS/ASR.
    This Procedure does NOT apply to Conti/Teves MK60, MK60CE, MK60EC1 and similar ABS/ASR/ESP systems. Check the Vehicle specific Diagnostic Procedures pages for each ABS System page with documentation.
    Prerequisites:
    • Start the vehicle.
    • Turn the steering wheel one turn to the right and one turn to the left.
    • Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
    • If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight.
    • Ensure that the steering wheel is not moved again.
    • Keep the engine running and do not switch off the ignition.
    • System voltage at least 12.0 V.
    [Select]
    [44 - Steering Assist]
    [Coding-II - 11] or if that function is not available then use [Sec.Access - 16] instead
    Enter 40168, to enable the basic setting.
    [Do it!]
    [Basic Settings - 04]
    Group 060
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    After a successful basic setting, field 1 should say "OK".
    [Done, Go Back]
    To make sure the basic setting was successful, check the sensor again.
    [Measuring Blocks - 08]
    Group 007
    [Go!]
    Check field 1, the value has to be between -1.5 and +1.5 .
    [Done, Go Back]
    Note: After successful basic setting, the Steering Limit Stop needs to be adapted too.
    Page 20
    Revision: 00H17000
    1 Fault Found: <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
    DD
    Temperature: 13.0C
    Count: 3
    Count: 1
    SteerAng n.Init
