Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 45
Thread: 2010 Jetta TDI ABS issue missing software code
    Good question. Don't know the answer. I *think* the ABS only really cares about the VIN in the cluster, so at a very minimum, anyone who's going to try to build you a coding for this car is going to need that. Take a look in the cluster, it should have an Adaptation channel named "WFS-Download - VIN" or (something close) and see if there's a VIN in there.
  2. #12
    Please post a photo of door VIN data plate to commence..............
    Please list old VIN from the donor car to be observed.
  3. #13
    Dec 2015
    grrr lost post look down 1 please
  4. #14
    Dec 2015
    Hello everyone,
    Jack I think this is what you were looking for. I hope someone will be able to get me through this problem
    Sorry for the delay on getting beck to you great folks, due to my back I had to take a few days off.
    Donor Car, what I used from it:
    5th & 7th Digits matched and thought I was good to go.
    VIN: 3VWRL7AJ4AM155628
    Donor Car has 16" wheels
    Engine Trans...
    front suspension assembly
    ECU
    Cluster
    Now for the rebuilt car:
    Vin: 3VWALJAJ3AM116056
    car has 17" wheels
    donor egeine & Trans...
    Donor front suspension assembly
    Donor CPU & Cluster
    car has 17" wheels
    Thanks again for your help
    SteveOOO
    Vin:
    https://onedrive.live.com/redir?resi...nt=photo%2cjpg
    Trunk Sticker
    Tire Door Sticker
  5. #15
    Okay send me a copy of your registration/title and drivers license to authenticate you are you........and the valid owner.
    I want a complete new auto-scan of what is in the car with additional data of ecu and immobilizer of components in car.
    0x01-08-081
    and
    0x25-08-081
    Thank you
    Send to my email on file below.
  6. #16
    3VWRL7AJ4AM155628
    113b400d092700ff281102e690210042310000
    114b400d492700ff881102e692210042310000
    3VWALJAJ3AM116056
    114b400d49230000880b02e9921f0042310000
    113b400d09230000880b02e9901f0042310000
    Try these........based on VIN#s above.
  7. #17
    Dec 2015
    Jack, you have mail
    The info you had requested is attached as well. I will try them codes in the morning
    Thanks Again
    SteveOOO
  8. #18
    What's the status.......?
  9. #19
    Dallas (McKinney) ,TX ,USA
    Quote Originally Posted by Homefront View Post
    OMG NO ITS NOT A MATCH, THAT BELONGS TO THE DONOR CAR! ok now what do I do? good catch!
    The above procedure is crack way. I really would not recommend to keep wrong VIN in modules vs VIN of the car.
    Correct way is write correct VIN in Cluster and ECU .So you will have all match. But this can not be done with VCDS.
    I can fix this , contact me direct .
    then after all is fix , you need to post auto scan here and see if someone can built ABS coding, or go to Dealer and do online ABS coding.
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  10. Likes Uwe liked this post
  11. #20
    Uwe, VIN can be seen in Advace Id, either in ECU or cluster.
    Immobilizer/ECU
  12. Likes Uwe liked this post
