Hello Guys!
As title says, I got this error after fuel injectors job, also the readness-15 is bad. This is auto scan after job, all others gone.
Any shots?
Any shots?
Thursday,19,November,2015,20:27:00:49163
VCDS Version: 15.7.1.0
Data version: 20150904
Dealer/Shop Name: Oficina Freitas
VIN: WVWLS83C86E117168 License Plate: ANL5188
Mileage: 169060km-105049mi Repair Order: NOV-15 fuel injector
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 36 42 44 46 52 53 55 56 62
72 77
VIN: WVWLS83C86E117168 Mileage: 169060km-105049miles
Part No SW: 06F 906 056 EE HW: Hardware No
Component: MED9 G00 7970
Revision: --H01--- Serial number: VWZCZ000000000
Coding: 0000075
VCID: 70EA5597636318BEAD-8024
000152 - Intake Air Temperature Sensor 2 (G299)
P0098 - 002 - Signal too Low
Fault Status: 01100010
Temperature: 24.0°C
P0300 - 001 - - Intermittent
Fault Status: 00100001
Mileage: 169056 km
Date: 2015.11.18
Time: 11:49:20
RPM: 720 /min
Load: 83.1 %
Temperature: 27.0°C
000771 - Cylinder 3
P0303 - 001 - Misfire Detected - Intermittent
Mileage: 169056 km
Date: 2015.11.18
Time: 11:49:20
RPM: 720 /min
Load: 83.1 %
Temperature: 27.0°C
000772 - Cylinder 4
P0304 - 001 - Misfire Detected - Intermittent
Mileage: 169056 km
Date: 2015.11.18
Time: 11:49:20
RPM: 760 /min
Load: 81.1 %
Temperature: 27.0°C
Address 02: Auto Trans
Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0658315201
Coding: 0046481
Shop #: WSC 05311 000 00000
VCID: 306A9597A3E358BEED-8064
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Fault Status: 00101001
Reset counter: 165
Mileage: 169056 km
Date: 2015.11.18
Time: 16:24:39
Reset counter: 165
Mileage: 169056 km
Date: 2015.11.18
Time: 16:24:39
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 Q HW: 3C0 907 044 Q
Component: ClimatronicPQ46 042 0202
Revision: 00042004 Serial number: 00000000000000
VCID: 2F6896EBBEDD4746F4-807A
Fault Status: 00101101
Reset counter: 165
Mileage: 169056 km
Date: 2015.11.18
Time: 16:24:43
Reset counter: 166
Mileage: 169056 km
Date: 2015.11.19
Time: 10:26:03
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000002226735
Coding: E3828F0700041A00000A00000F000000000B5D435C0000
Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00065493
Shop #: WSC 12345
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Coding: 00479309
Shop #: WSC 12345
02071 - Local Databus
Reset counter: 160
Mileage: 168963 km
Voltage: 12.40 V
Reset counter: 160
Mileage: 168963 km
Voltage: 12.40 V
Address 10: Park/Steer Assist (J446) Labels: 1Z0-919-475-V2.clb
Part No SW: 1Z0 919 475 G HW: 7N0 919 475
Component: PARKHILFE 8K H06 0011
Revision: --H06--- Serial number: 28201429303769
Coding: 100104
ASAM Dataset: EV_EPHVA18SKxxx0000 002001
ROD: EV_EPHVA18SKxxx0000.rod
VCID: 4584D443C461ED162E-8010
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 F HW: 3C0 909 605 F
Component: 01 AIRBAG VW8 029 2421
Revision: 08029000 Serial number: 0039USLPHXA4
Coding: 0012337
VCID: 295C78F3803929762A-807C
Subsystem 1 - Serial number: 6332MSME0C276170
Subsystem 2 - Serial number: 6342MSME0C227C5F
Subsystem 3 - Serial number: 6351HTS69SDAEOL2
Subsystem 4 - Serial number: 6361HTS69SD2F843
Subsystem 5 - Serial number: 6371VTS65CHITPB2
Part No SW: 3C0 953 549 B HW: 3C0 953 549 B
Component: Lenksäulenmodul 005 0010
Revision: 00005000 Serial number: 3C5953507E
Coding: 0001111
VCID: 2B5082FB8AC53B66D8-807E
Component: Lenkradmodul 007 0050
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3C8 920 880 F HW: 3C8 920 880 F
Component: KOMBI H03 0132
Coding: 160F00
VCID: 2F6896EB76DD4746F4-807A
Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 Q HW: 3C0 907 951
Component: J533 Gateway H13 0172
Revision: H13 Serial number: 3690P118100186
Coding: FDA1FF0600060200F100
Part No SW: 3C0 959 433 K HW: 3C0 959 433 K
Component: IMMO 038 0367
Revision: 00038000 Serial number: VWZCZ000000000
Shop #: WSC 01414 998 14101
VCID: 326E9F9FADEF6AAE9B-8066
Subsystem 1 - Part No: 3C0 905 861 D
Component: ELV 024 0370
3C0905861D ELV 024 0370
02823 - Requirements for Locking the Steering Column Lock not met
Fault Status: 00110000
Reset counter: 165
Mileage: 169056 km
Date: 2015.11.18
Time: 16:25:05
02827 - Wake-Up request via ESP
Reset counter: 165
Mileage: 169056 km
Date: 2015.11.18
Time: 16:25:05
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 A HW: 3C0 959 760 A
Component: Sitzverstellung 0601
Revision: 00002000 Serial number: 00000000000000
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1K0 959 701 L
Component: Tuer-SG 024 2461
Coding: 0000439
VCID: 3778AE8B468D8F86AC-8062
00105 - Signal Central Locking SAVE/LOCK Drivers Side
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
00625 - Vehicle Speed Signal
Mileage: 9040 km
Temperature: 38.0°C
Voltage: 12.30 V
Voltage: 12.00 V
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 038 0455
Coding: 19910A0801864E763802951D7008CFC6703840
Subsystem 2 - Part No: 3C0 951 171 A
Component: Neigungssensor 002 0508
Subsystem 3 - Part No: 3C0 951 171 A
Component: Innenraumueberw.002 0508
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1K0 959 702 L
Coding: 0000438
VCID: 387AADB74B9380FEA5-806C
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000012
VCID: 214C60D3F809E13672-8074
Address 55: Headlight Range Labels: 5M0-907-357-V1.lbl
Part No SW: 5M0 907 357 HW: 5M0 907 357
Component: AFS-Steuergeraet X016
Revision: H09 Serial number:
VCID: 71EC5093686911B6A2-8024
Subsystem 1 - Part No: 7L6 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l X017
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 330
Component: AFS-Lst.-Modul r X017
Coding: 00000035
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 A HW: 5K0 035 190 A
Component: Radio RCD510 050 0207
Revision: 00000001 Serial number: VWZ1Z3L1651108
Coding: 09000410040010
VCID: 23406ADB2215F32660-8076
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 F
Component: Tuer-SG 021 2432
Coding: 0000144
VCID: 33609A9B52F563A690-8066
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 F
Coding: 0000144
VCID: 3462998757FB649E89-8060
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 N HW: 7P6 035 730 N
Component: TELEFON H16 4217
Revision: 1B001001 Serial number: 00007666178144
Coding: 0A01000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3D74BCA3ACB1A5D676-8068
End-------------------------(Elapsed Time: 02:50)--------------------------
