Ok completed the following steps
Rebuild the harness and replaced the accelerator connector- intermittent error now solved
Rebuild the wiring from alternator to both and dashboard. - intermittent accel. signal now solved.
Timing graph still gives me "Engine not a Idle" error at bottom of screen. Followed the steps and was testing "Channel 2". Changed little if you go down from 32768 to 32760 but after that no response.
Adaptation Channel 002:
Stored value 32758
Test value 32750
Idle speed
1302 /min Engine Speed
5.5 % Throttle Position
0 1 0 Operating Condition
72.0°C Coolant Temperature
Engine not running
Adaptation Channel 001:
Stored value 32768
Injected Quantity (IQ)
0 /min Engine Speed (G28)
0.0 mg/str IQ
0.680 V Mod. Piston
75.6°C Coolant Temp
Monday,07,December,2015,18:19:25:12240
-- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
Version: 15.7.2.0 (x64)
Data version: 20151124
Stored value 32768
Idle speed
0 /min Engine Speed
74.7°C Coolant Temperature
Monday,07,December,2015,18:19:49:12240
Adaptation Channel 003:
Stored value 32768
Exhaust Gas Recirculation ()
0 /min Engine Speed
850.0 mg/str MAF (Specified)
0.0 mg/str MAF (Actual)
4.8 % Solenoid (N18)
Monday,07,December,2015,18:20:17:12240
Adaptation Channel 004:
Stored value 32768
Start of Injection - Modification is Strongly Discouraged
0 /min Engine Speed
11.0 °BTDC Specified Start
0.0 °BTDC Actual Start
2.8 % Cold Start Valve
Monday,07,December,2015,18:20:40:12240
Adaptation Channel 005:
Stored value 32768
Starting Conditions
0 /min Engine Speed
29.6 mg/str Start Injection Quantity
0.0 °BTDC Actual Start Quantity
73.8°C Coolant Temperature
Monday,07,December,2015,18:22:07:12240
Engine running.
Stored value 32768
1281 /min Engine Speed (G28)
3.6 mg/str IQ
1.620 V Mod. Piston
81.9°C Coolant Temp
Monday,07,December,2015,18:26:30:12240
Stored value 32758
Idle speed
82.8°C Coolant Temperature
Monday,07,December,2015,18:26:42:12240
Stored value 32768
275.0 mg/str MAF (Specified)
60.0 mg/str MAF (Actual)
19.9 % Solenoid (N18)
Monday,07,December,2015,18:27:01:12240
Stored value 32768
1.3 °ATDC Specified Start
1.5 °BTDC Actual Start
Monday,07,December,2015,18:27:17:12240
Stored value 32768
Starting Conditions
42.0 mg/str Start Injection Quantity
1.5 °BTDC Actual Start Quantity
83.7°C Coolant Temperature
