Page 2 of 10 FirstFirst 1234 ... LastLast
Results 11 to 20 of 98
Thread: TDI Convertion with no VAS errors does not want to start
    Dallas (McKinney) ,TX ,USA
    I suggest you fix continuity problem from ECU to Pump.
    On this engine Diesel pump is brain , it controls everything and let car start and run.
    Also go to 01-Engine , find Engine speed (G28) in measuring block and crank car, you should see numbers moving up to 250-300???
    One more question ,do you have fuel coming to injectors form pump when you loose fuel line on top of the injector?
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  2. #12
    I think it would be best to start checking to make sure you have voltage to the fuel shut off solenoid.
    FYI there is no controller or brain in this EDC15 pump.......not even an Immobilizer alignment.........that is what the ecu is for.
  3. Likes ivagp liked this post
  4. #13
    Dec 2015
    Yes I am running the erwin manuals on my system.
  5. #14
    Dec 2015
    Yes I have a clear plastic pipe before the pump but will check on the injector side manually.
  6. #15
    In addition to the points above, has the timing belt been touched since the engine was last running? I once got a no-start exactly like that on my ALH after I set the injection pump shaft wheel (not the sprocket that attaches to it) in the wrong position by about 20 degrees (drill bit I was using went in sideways). See here:http://www.myturbodiesel.com/images/...em/pumppin.jpg
    You might want to recheck the mechanical basics of the camshaft and injection pump wheel at TDC.
  7. Likes Jack@European_Parts, ivagp, Uwe liked this post
  8. #16
    Pictures of this heap?
  9. #17
    Jul 2014
    on an alh jetta their are differnt ecm part#s i dont know if these are interchangeable. but make sure you have rpms while cranking say about 200 rpm.
  10. #18
    The main difference is coding for stick or auto.
    Additionally early KWP 2000 00> 01.9 production ECU's had a 2 wire compare glow relay recognition and the 02> where 4 wire glow monitoring.
    Note : labeled incorrectly in many diagnostic stacks for ref of each cylinder and that includes random cylinder misfire codes.......
    And of course which automatics to reject for incorrect hardware mismatch BS based on variant.
    There were some different versions of EDC15 V verse VM+ and flash size but in the USA most were a .5 meg.
    Some are wired different in Beetle verse GJ and pay attention to supply relay and bus.
    A fun read on the CHEAP!
    https://github.com/fjvva/ecu-tool/wiki
  11. Likes jyoung8607, ivagp liked this post
  12. #19
    Dec 2015
    Timebelt
    Yes I did change the belt when the engine was still out of the vehicle. I did mark everything before removing, but I will double check it again.
  13. #20
    Whether the belt is out or in TIME ..........the fuel should still be coming out of the lines if all is on and rotated.
    Pictures?
  14. Likes ivagp, Jetta ,97 liked this post
