Page 1 of 10 123 ... LastLast
Results 1 to 10 of 98
Thread: TDI Convertion with no VAS errors does not want to start
    Dec 2015
    Post TDI Convertion with no VAS errors does not want to start
    Systens cranks over. All VAS errors has been resolved excpet for the following three. Engine cranks over, Fuel is pumped to PD. ECU commincates fine, various logs collected. BUT Systen does not start?
    HELP HELP HELP. Where do I start? The 3 systems are not connected in this conversion.
    Address 01: Engine Labels: 038-906-012-AGR.lbl
    Control Module Part Number: 038 906 012 H
    Component and/or Version: 1,9l R4 EDC G000SG 3332
    Software Coding: 00002
    Work Shop Code: WSC 04356
    VCID: 15219CCE6FAE46969E-4AE8
    18058 - Powertrain Data Bus
    P1650 - 35-10 - Missing Message from Instrument Cluster - Intermittent
    18044 - Powertrain Data Bus
    P1636 - 35-10 - Missing Message from Airbag Controller - Intermittent
    18057 - Powertrain Data Bus
    P1649 - 35-00 - Missing Message from ABS Controller
    Sub system redundancy check...........information lacking.........please advise.
    Dec 2015
    what information is missing.
    TDI ALH Engine 2001?
    VCDS SYSTEM?
    Please be patient as this is my first post on this forum.
    Tuesday,01,December,2015,14:29:39:12240
    VCDS Version: 15.7.1.0 (x64)
    Data version: 20150904
    Address 01: Engine (038 906 012 H)
    14:29:26 Group 010: Air System && Charge Pressure Control
    0.0 mg/str Mass Air Flow (Actual)
    948.6 mbar Air Pressure (F96) BARO
    2070.6 mbar Manifold Pressure (Actual) MAP (G71)
    5.5 % Accel. Pedal Pos. Sensor 1 (G79)
    14:29:26 Group 007: Temperatures
    11.7C Fuel Temp. (G81)
    N/A
    10.8C Intake Air Temp. (G72)
    7.2C Coolant Temperature (G62)
    14:29:26 Group 002: Idle speed
    0 /min Engine Speed (G28)
    1 1 0 Operating condition
    Tuesday,01,December,2015,14:46:42:12240
    14:46:30
    0.0 mg/str Injection Quantity
    0.680 V Mod. Piston Disp. (G149)
    9.0 BTDC Start of injection Specified
    0.0 BTDC Start of injection Actual
    94.4 % Cold Start Injector Duty cycle
    99.6 % Charge Pressure (N75) Solenoid
    0.70 Glow Period Preheat
    12.62 V Supply Voltage ECM
    8.1C Coolant Temperature (G62)
    Tuesday,01,December,2015,17:34:09:12240
    17911 - Load Signal from Alternator Term. DF
    P1503 - 35-00 - Implausible Signal
    Readiness: N/A
    Tuesday,01,December,2015,17:36:38:12240
    Adaptation Channel 005:
    Stored value
    ERROR:
    Channel 05
    Not
    Available
    Tuesday,01,December,2015,17:51:31:12240
    Stored value 32768
    Starting Conditions
    0 /min Engine Speed
    0.0 mg/str Start Injection Quantity
    0.0 BTDC Actual Start Quantity
    9.9C Coolant Temperature
    Tuesday,01,December,2015,18:23:58:12240
    VCDS Version: 15.7.2.0 (x64)
    Data version: 20151124
    18:23:32 Group 000: Testing Dynamic Start of Injection
    000 Engine speed (G28) - Specification (Idle): 41...46 (861...950 RPM) | (Full Load): 138...148 (2900...3100 RPM)
    038 Start of Injection - Specification (Idle): 12...75 (2 ATDC ... 4 BTDC) | (Full Load): 137...215 (8...14 BTDC)
    014 Throttle Position - Specification (Idle): 0 (0 %) | (Full Load): 255 (100 %)
    000 Injected Quantity - Specification (Idle): 11...45 (2.2...9 mg/stroke) | (Full Load): 199...214 (39.8...42.8 mg/stroke)
    203 Manifold pressure - Specification (Idle): 83...106 (920...1140 mbar) | (Full Load): 179...215 (1850...2250 mbar)
    192 Atmospheric Pressure (BARO metric) - Specification (Full Load) 183...224 (910...1110 mbar)
    182 Coolant Temp. (G62) - Specification: 80...35 (80...110 C)
    180 Intake Manifold Temp. (G42). - Specification: 182...50 (10...100 C)
    079 Fuel Temp. (G81) - Specification: 91...201 (20...80C)
    000 Air Mass (EGR On - 2 Min. after start-up) - Specification (Idle): 69...111 (230...370 mg/H)
    Crank.....?
    Crank no start?
    Crank start then die?
    Conversion attributes please explain and how wired or pictures?
    Does RPM ref show in blocks when cranking?
    Immobilizer status?
    What systems are being used in this conversion?
    Terminal status for 15 30 and 31 supply voltage relay and bus?
    I don't know you tell me.............
  5. Likes Zenerdiode liked this post
    Dallas (McKinney) ,TX ,USA
    You wrote down in first post you getting fuel in PD unit, then you wrote in other post ALH 2001 , ALH engine does not have PD injectors.
    Also why are you using SKODA ECU?????
    To many things does not match.
    Give us little background , what car you putting this,do you use only ECU , or other components.
    Immobilizer/ECU
    /Cluster Programing (Used or NEW)
    email: marinmm2001@gmail.com , info@advancedcarelectronics.com
    https://www.advancedcarelectronics.com/
  7. Likes Uwe liked this post
    Also your MAP sensor is reporting way too high.
  9. Likes Uwe liked this post
  10. #7
    Dec 2015
    OK let me take a step back.
    Engine cranks but does not start at all. Tried so many times eventually blown the fuse on the battery.
    Ok lets call it the diesel pump and not PD.
    Some history on the harness and ECU. Send the original harness that came with the engine to a person in BC and this crap is what I got back. Most sensors stripped out and only a few sensors came back. The ECU was also send to him and this is what I got back. He was supposed to have done some eliminations like the IMMO on the system and do basic coding for economy.
    Eventually fitted back some of the sensors which the VCDS complained about to remove all the errors.
    I do not understand the comment about the Skoda ECU as hopefully I have received back the same ECU I have send this person in BC. I had a falling out with this person as the work done was very bad and after some insults from him, told him to take a hike. How do you know that this is a Skoda ECU?
    I see there are two relays added to the harness. Both relays are connected to the fusebox on the battery.
    Conversion attributes: standalone harness for engine and original harness for interior of Samurai. Only connections are those for the starter and the display wires for the instrument panel.
    TDI engine, harness and ECU came as a single order and that was what I used. Added the fusebox on the battery from another TDI donor vehicle. (One of my other projects).
    Vehicle is a 1995 Suzuki samurai with the ACME adapter and original Suzuki manual gearbox, Did not use the ACME harness. Using the Suzuki fuel pump as the additional lift pump.
    Will add photos tomorrow.
    [IMG]C:\Users\Pieter\Documents\Suzuki docs[/IMG]
    http://www.expeditionportal.com/foru...44#post1975844
  11. #8
    I bet a resistor is soldered or crimped in the harness .......seen that before.
    Sounds like harness has been miss installed or missing inputs maybe when custom wired.
    Time to RTFB and use a WD to verify from ecu pins to components in harness PIN for PIN!
    Marin ( Jetta97 ) is using the part # to determine that the ecu is from a Skoda.
    It being a Skoda ecu or flash file shouldn't matter either.......basically same shit, probably just an EU tuning from some eBay CD.
    The three codes it has should not stop it from running.
    Have you tried VCDS outputs to determine what clicks and functions 0x01-03-GO ?
  12. Likes Uwe liked this post
  13. #9
    Dec 2015
    Ok wil open the Harness and check all off it.
    Did find 3 pins in the diesel pump connection that had continuity problems. will check all the pins for problems.
    Do you think getting a VW ECU will help solve the problems faster.
    will report back later today.
    Do you have a schematic of the basic harness and what should be there?
    and YES ran the basic test nad heard the pump go through its tests.
  14. #10
    www.erwin.vw.com
    For manuals above link ............nope doesn't matter the ecu is okay unless it is actually bad or programming is suspect.......and it is kind of suspect.
    If you need a new or reman ecu with Immo defeat let me know or see my eBay store.
    http://stores.ebay.com/fixmyeuro
