Results 1 to 7 of 7
Thread: Unable to update HEX-NET ROD and ASAM data
    Jul 2015
    Italy
    I update firmware with success but every time when I check the update
    using java utility with pc I got "update rod data needed".
    I do the update, I check again and I heve the save message then I
    switch off the HEX-NET, I connect egain, I check the update and again
    the message "update rod data needed".
    If I do "autoscan" using android app then during scan I am getting
    update ASAM data every time even if I agree for update!
    It seams that something is going wrong with rod and asam update.
    Someone know how to fix?
    Thank you.
  2. Likes Uwe liked this post
  3. #2
    Lansdale, PA
    What version of the Java utility are you running?
    What OS ?
  4. Likes Uwe liked this post
  5. #3
    Jul 2015
    Italy
    Java utility: HexNetConfigV2.007.jar
    OS: MS Windows 8.1 Pro
  6. #4
    Jul 2015
    Italy
    There is the same problem using android app during autoscan.
    When the dialog "No ASAM data etc..." then I confirm the update but nothing huppen,
    I mean there is no download from cloud server.
    Lansdale, PA
    Can you post an autoscan from the car? Without knowing the module part number, we cannot check the server for the Asam file.
  8. Likes Uwe liked this post
  9. #6
    Jul 2015
    Italy
    Sunday,01,November,2015,11:51:42:18535
    VCDS Version: 15.7.1.0 (x64)
    Data version: 20150904
    VIN: WVWZZZAUZFP617747   License Plate:
    Mileage: 17512km-10881mi   Repair Order:
    Chassis Type: AU (5Q0)
    Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZFP617747   Mileage: 17512km-10881miles
    Address 01: Engine (2D2D2-CXXB)       Labels: 04L-907-309-V1.clb
       Part No SW: 04L 906 056     HW: 04L 907 445 B
       Component: R4 1.6l TDI   H06 8983
       Revision: 22004001
       Coding: 01114032434405092000
       Shop #: WSC 00028 028 00074
       ASAM Dataset: EV_ECM16TDI03004L906056 002009
       ROD: EV_ECM16TDI03004L906056_VW37.rod
       VCID: EA9888CC0D370E6E63-80BE
    Readiness: N/A
       Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
       Component: ESC           H42 0610
       Revision: 00000000    Serial number: 60845000004741
       Coding: 04FA62A124210973077E060441CA2520462490E06082A4F31440F078C009
       Shop #: WSC 00028 028 00066
       VCID: C8DC124473FB1C7E55-809C
       Part No SW: 5G0 907 044 BC    HW: 5G0 907 044 BC
       Revision: 00001K08
       Coding: 02020104202100011005000000101000
       ROD: EV_ACClimaBHBVW37X_SK37.rod
       VCID: E99AF7C0083105766A-80BC
    Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
       Part No SW: 5Q0 937 086 AC    HW: 5Q0 937 086 AC
       Component: BCM PQ37BOSCH 028 0145
       Revision: --------    Serial number: 86581103151512
       Coding: 00000862C24102FB4FE44000000407281000000000000000000000000000
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: FBB6BD8872AD87E688-80AE
       Slave 1:
       Component: WWS    150309  043 0551
       Serial number:         150316142457
       Slave 2:
       Component: RLHS  037 0059
       Serial number: S4Y14M12D23H10M10S49
       Coding: 96A8DD
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
       Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0048
       Revision: --------    Serial number: 39391506504945
       Coding: 0071051001
       ROD: EV_EPHVA18AU3700000_SK48.rod
       VCID: BD3273902C3949D6F6-80E8
    Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-567.clb
       Part No SW: 5Q0 907 567 E    HW: 5Q0 907 567 E
       Component: ACC3          H06 0381
       Serial number: 03021276110039
       Coding: 00000300FE0309
       ASAM Dataset: EV_ACCBoschMQB 001019
       ROD: EV_ACCBoschMQB_VW37.rod
       Component: AirbagVW20    014 0385
       Serial number: 003F6R0H92F8
       Shop #: WSC 00028 028 00061
       VCID: C1CA0F6050C12D3692-8094
       Subsystem 1 - Part No SW: -----------    HW: 480 002 003 15
       Serial number: 35767000000F5224931Q
       Subsystem 2 - Part No SW: -----------    HW: 480 002 303 15
       Serial number: 358670000005C68C831+
       Subsystem 3 - Part No SW: -----------    HW: 480 402 003 15
       Serial number: 3516502991A14CA1939E
       Subsystem 4 - Part No SW: -----------    HW: 480 402 003 15
       Serial number: 3526502B919DB893011D
       Subsystem 5 - Part No SW: -----------    HW: 480 402 003 15
       Serial number: 3556502BD19EFD24A0C1
       Part No SW: 5Q0 953 521 K    HW: 5Q0 953 569 A
       Revision: FF032032    Serial number: 20150325500260
       Coding: 0400
       ROD: EV_SMLSVALEOMQB.rod
       VCID: BA38788C3D177EEED3-80EE
       Part No SW: 5G1 920 741     HW: 5G1 920 741
       Component: KOMBI         204 4270
       Coding: 07A512002780000800883A001400000000000000
       VCID: E484E6F4EF13581E59-80B0
       Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
       Component: GW MQB High   131 1204
       Revision: --------    Serial number: 0003733880
       Coding: 030100040F087300FF000258080F00010001050000000000000000000000
       Shop #: WSC 50352 001 104857
       ASAM Dataset: EV_GatewLear 011020
       ROD: EV_GatewLear.rod
       VCID: F2A890AC25E7C6AEDB-80A6
       Subsystem 2 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K
       Component: E221__MFL-DC1  H16 0040
       Serial number: 29150001000670125201
       Coding: 2C0000
       Serial number: 6051995803
       Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593 A
       Component: TSG FS        H12 0006
       Serial number: 18101200010718
       Coding: 003B0320D000040000001000
       ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
       VCID: BFCE099826355BC6E4-80EA
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
       Serial number: 00000000000008397834
       Coding: 110000
       Component: EPS_MQB_ZFLS  126 1061
       Coding: 8102
       Shop #: WSC 39823 001 1048576
       ROD: EV_SteerAssisMQB.rod
       VCID: C3C605684ADD3F2680-8096
       Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
       Component: TSG BFS       009 0014
       Serial number: 0000112431293
       Coding: 003B0120DE00040000801000
       ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
       Serial number: 00000000000008328184
       Coding: 090000
       Part No SW: 5G0 035 819 A    HW: 5G0 035 819 A
       Component: MU-S--ER      041 0421
       Serial number: V1C02603153215
       Coding: 02730200FF00000011110001000800001F0100840100010001
       ROD: EV_MUStd4CPASE_SK37.rod
       VCID: A71EB1F8DEA5F306BC-80F2
       Media Player Position 1:
       Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
       Component: ABT_Std_Radio  H60 0030
       Serial number: VWZ8Z9RS2081L4
    End-------------------------(Elapsed Time: 01:51)--------------------------
  10. #7
    Verified VCDS User Gizmo's Avatar
    Mar 2014
    S.E.Kent UK
    Quote Originally Posted by andreag0 View Post
    Thank you.
    I am getting exactly the same issues as above apart from I am using HEX-NET on an iPad
    #hndoc:?docid=000013DB&xt=hnh:E74F21D4D694445A389C922AA5306652400C4BDAA76F46B5B8D2C07CE7BEDE64VCDS Mobile 0.4231.0.4
    VIN: TMBBJ9NP9G7029918
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 36 3C 42 44 52 55
         5F 6C 6D A5
    Address 01: Engine  (DFCA2 J623)    Labels: 04-01.lbl
        Part No SW: 04L 906 026 FN    HW: 04L 907 309 M
        Component: R4 2,0L EDC   H23 1195
        Revision: B4H23---
        Coding: 011D0032036501083000
        Shop #: WSC 33361 790 00063
        ASAM Dataset: EV_ECM20TDI01104L906026FN 002001
        ROD: N/A
        VCID: 7BB964EF62E4E8BFF6C1CB-802E
        No ASAM data for: "EV_ECM20TDI01104L906026FN"
    No fault codes found.
    Address 02: Auto Trans  (J743)    Labels: 0D-02.lbl
        Part No SW: 0D9 300 041 B    HW: 02E 927 770 AQ
        Component: DQ250-6F MQB  H53 4803
        Revision: 06253104
        ROD: N/A
        VCID: 1771585F7E8C2CDF72F987-8042
        No ASAM data for: "EV_TCMDQ250021"
    Address 03: ABS Brakes  (J104)    Labels: None
        Revision: 00000000
        Coding: 1D07929C34220B750780060141CB49B8492CD0E0608292F53861F0F8C2A90000000000000000000000000000000000000000000000000000000000000000000000
        ROD: N/A
        VCID: 7AB761EB6DDED1B7EDD7C6-802F
        No ASAM data for: "EV_Brake1UDSContiMK100IPB"
    Address 05: Acc/Start Auth.  (J518)    Labels: None
        Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
        Component: VWKESSYMQB    036 0710
        Revision: 00036000
        Coding: 030C0C0703
        ASAM Dataset: EV_KessyHellaMQBAB 004032
        ROD: N/A
        VCID: 3A37A1EB2D5E11B7AD5706-806F
        No ASAM data for: "EV_KessyHellaMQBAB"
        Subsystem 1 -
    1077250 - ROD - Unknown faultcode
    Address 08: Auto HVAC  (E87)    Labels: None
        Part No SW: 3V0 907 044 AN    HW: 3V0 907 044 AN
        Component: AC Automat    H32 3601
        Revision: 20K04000
        Coding: 11110104000400011005100100101102
        ASAM Dataset: EV_ACClimaPrehVW37X 002009
        ROD: N/A
        VCID: 804393038B020B67231304-80D5
        No ASAM data for: "EV_ACClimaPrehVW37X"
    000515 - ROD - Unknown faultcode
    Address 09: Cent. Elect.  (J519)    Labels: 5Q-09.lbl
        Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
        Coding: 0F019E66C2C72AFB17844086B118172C0800000000000000000000000000
        ROD: N/A
        VCID: 89558E27B8384A2F744D61-80DC
        No ASAM data for: "EV_BCMMQB"
        Subsystem 1 -     Part No SW: 3V2-955-119
        Component: ]Ý
        Subsystem 2 -
        Subsystem 3 -
        Subsystem 4 -
        Subsystem 5 -     Component: ]Ý
        Subsystem 6 -
        Subsystem 7 -
    Address 10: Park/Steer Assist  (J791)    Labels: None
        Part No SW: 5QA 919 298    HW: 5Q0 919 298 C
        Component: PLA 3.0 12K
        Coding: 0371167851
        ASAM Dataset: EV_EPHVA2CAU3700000 009017
        ROD: N/A
        VCID: 0D5D3A374C50D60FD89515-8058
        No ASAM data for: "EV_EPHVA2CAU3700000"
    Address 13: Auto Dist. Reg  (J428)    Labels: None
        Component: ACC BOSCH MQB H04 0192
        Coding: 320067C355FFC428949C804D
        ASAM Dataset: EV_ACCBOSCHVW48X 001008
        ROD: N/A
        VCID: 342B8FD30F3AE7C7771BB8-8061
        No ASAM data for: "EV_ACCBOSCHVW48X"
    000110 - ROD - Unknown faultcode
    Address 14: Susp. Elect.  (J250)    Labels: 5Q0-907-376.clb
        Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
        Component: DAEMPFUNGS-SG H17 0120
        Shop #: WSC 00000 000
        ROD: N/A
        VCID: 3731B8DF1E4C0CDF5239E7-8062
        No ASAM data for: "EV_DRCONTITEMIC"
        Part No SW: 5Q0 959 655 AE    HW: 5Q0 959 655 AE
        Component: AirbagVW21    005 0130
        Coding: 98FCC0C0000000005C5400CF00C800000065
        ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
        ROD: N/A
        VCID: 83499C0F9A14107F3E3123-80D6
        No ASAM data for: "EV_AirbaVW20SMEVW37X"
        Subsystem 1 -     Part No SW: 4M0-980-945-A
        Component: €
        Subsystem 2 -     Component: €
        Subsystem 3 -     Component: ---
        Subsystem 4 -     Component: ---
        Subsystem 5 -     Component: ---
        Subsystem 6 -     Component: ---
    Address 16: Steering wheel  (J524)    Labels: None
        Part No SW: 3Q0 953 521 BA    HW: 5Q0 953 569 A
        Revision: FF033033
        Coding: 6010
        ROD: N/A
        VCID: 70A343C33BA29BE7537354-8025
        No ASAM data for: "EV_SMLSVALEOMQB"
    Address 17: Instruments  (J285)    Labels: None
        Part No SW: 3V0 920 911    HW: 3V0 920 911
        Component: KOMBI         305 6422
        Coding: 27A5011A7F80A600018B6A0B5001000000000000
        Shop #: WSC 73430 031 00063
        ROD: N/A
        VCID: EFA1C0BFA69C041FCA49CF-80BA
        No ASAM data for: "EV_DashBoardVDDMQBAB"
    Address 19: CAN Gateway  (J533)    Labels: None
        Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
        Component: GW MQB High   212 2227
        Revision: --------
        Coding: 030100044F087300EB00025E9C0F00010001070000000000000000000000
        Shop #: WSC 73430 790 00063
        ROD: N/A
        VCID: 75AD72D744C0BECF80858D-8020
        No ASAM data for: "EV_GatewConti"
        Subsystem 1 -
        Subsystem 2 -
        Subsystem 3 -
    Address 2B: Steer. Col. Lock  (J764)    Labels: None
        Part No SW: 3Q0 905 861    HW: 3Q0 905 861
        Coding: 0800000000000000
        ROD: N/A
        VCID: F1A5C6C7B0A812EFDC7DD9-80A4
        No ASAM data for: "EV_ELVMarquMQBB"
    Address 36: Seat Mem. Drvr  (J810)    Labels: None
        Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
        Component: Sitzmemory    H06 0009
        Coding: 001400000000010001A080808080000000008181000000D4
        ASAM Dataset: EV_SeatMemorDriveSide 001015
        ROD: N/A
        VCID: 3B39A4EF226428BFB6410B-806E
        No ASAM data for: "EV_SeatMemorDriveSide"
    Address 3C: Lane Change  (J1086)    Labels: None
        Component: HRE_Master    H11 0071
        Coding: 02011203
        ROD: N/A
        VCID: 3C3BA7F3276A2F87BF4B10-8069
        No ASAM data for: "EV_HREntryHella"
    Address 42: Door Elect, Driver  (J386)    Labels: 5Q-42.lbl
        Coding: 001D0820DE01048000001100
        ROD: N/A
        VCID: 43C9DC0F5A94507FFEB163-8016
        No ASAM data for: "EV_DCUDriveSideEWMAXKLO"
        Component: EPS_MQB_ZFLS  125 1063
        Coding: 9303
        VCID: 44CBDF135F9A5747C7BB68-8011
    Address 52: Door Elect, Pass.  (J387)    Labels: 5Q-52.lbl
        Coding: 001D0220DE01048000001100
        ROD: N/A
        VCID: 42C7D90B458E5977F5875E-8017
        No ASAM data for: "EV_DCUPasseSideEWMAXKLO"
    Address 55: Xenon Range  (J745)    Labels: 7P6-907-357.clb
        Revision: --------
        Coding: 06D602007F010000
        ROD: N/A
        VCID: 40C3D3034B824B67E39344-8015
        No ASAM data for: "EV_HeadlRegulVWAFSMQB"
        Subsystem 1 -     Part No SW: 4H0-941-329
        Component: ³
        Part No SW: 3V0 035 020 A    HW: 3V0 035 020
        Component: MU-H-ND-EU    H42 0318
        Coding: 038401010000000011111202008808002F0003E601200100DE
        ROD: N/A
        VCID: 240B7F93BFDA7747E77B08-8071
        No ASAM data for: "EV_MUHig4CGen2HBAS"
        Subsystem 1 -
        Subsystem 2 -
        Subsystem 3 -
        Subsystem 4 -
        Subsystem 5 -
        Subsystem 6 -
        Subsystem 7 -
        Subsystem 8 -
        Subsystem 9 -
        Subsystem 10 -
        Subsystem 11 -
        Subsystem 12 -
        Subsystem 13 -
        Subsystem 14 -
    Address 6C: Back-up Cam.  (J772)    Labels: None
        Part No SW: 5Q0 980 556    HW: 5Q0 980 556
        Component: RVC Compact   H07 0100
        Coding: 04840101A600201F000040
        ROD: N/A
        VCID: F7B1F8DFDECC4CDF12B927-80A2
        No ASAM data for: "EV_CamSysRVRVCPANAMQBAB"
    Address 6D: Trunk Elect.  (J605)    Labels: None
        Part No SW: 5Q0 959 107 G    HW: 5Q0 959 107 G
        Component: HDSG-Modul    H12 0250
        Revision: --------
        Coding: 1008
        ASAM Dataset: EV_DeckLidCONTIAU736 001011
        ROD: N/A
        No ASAM data for: "EV_DeckLidCONTIAU736"
    Address A5: Frt Sens. Drv. Assist  (R242)    Labels: None
        Part No SW: 3Q0 980 654 D    HW: 3Q0 980 654
        Component: MQB_B_MFK     H04 0024
        Coding: 020408010000040100062346C040A00088000E100040
        ROD: N/A
        VCID: 3833BBE3135203A75B23EC-806D
        No ASAM data for: "EV_MFKBoschMQBB"
    Java 8 Update 66
    OS X El Capitan (version 10.11.1)
    Also on Wndows 7 (same Java 8 Update 66)
    This is on a brand new (4 miles) UK Škoda Superb L&K
    HEX-NET
    2016 Škoda Superb L&K (190CR)
    Pre-booked a VW ID.3 1st Edition
  11. Likes Uwe liked this post
