- Mar 2, 2014
- 109
- 72
- S.E.Kent UK
- C?ID=49193
Monday,30,November,2015,11:55:18:22041VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 15.7.1.0
Data version: 20150904
VIN: TMBBJ9NP9G7029*** License Plate: **65***
Mileage: 4 Repair Order: On Delivery
Chassis Type: NP (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 36 3C 42 44 52 55
5F 6C 6D A5
VIN: TMBBJ9NP9G7029918
Address 01: Engine (J623-DFCA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 026 FN HW: 04L 907 309 M
Component: R4 2,0L EDC H23 1195
Revision: B4H23---
Coding: 011D0032036501083000
Shop #: WSC 33361 790 00063
ASAM Dataset: EV_ECM20TDI01104L906026FN 002001
ROD: EV_ECM20TDI01104L906026FN_SK48.rod
VCID: 7BFE421BF2B379E608-802E
Part No SW: 0D9 300 041 B HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4803
Revision: 06253104 Serial number: TFK01509242689
ROD: EV_TCMDQ250021_AU37.rod
VCID: 17367EABEEDBBD868C-8042
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 62725000002243
Coding: 1D07929C34220B750780060141CB49B8492CD0E0608292F53861F0F8C2A9
ROD: EV_Brake1UDSContiMK100IPB_SK37.rod
VCID: 7AF0471FFD8940EE13-802E
Part No SW: 3Q0 959 435 C HW: 3Q0 959 435 C
Component: VWKESSYMQB 036 0710
Revision: 00036000 Serial number: 0382855505
Coding: 030C0C0703
ROD: EV_KessyHellaMQBAB_SK48.rod
VCID: 3A70871FBD0980EE53-806E
Subsystem 2 - Part No SW: 3AA 962 243 E HW: 3AA 962 243 E
Component: GEB.F.Heckoef H16 0813
Serial number: 65032489
1077250 - ROD - Unknown Error Code
- 00 [008]
Fault Frequency: 13
Reset counter: 40
Mileage: 3 km
Date: 2011.10.22
Time: 12:21:09
Address 08: Auto HVAC (E87) Labels: None
Part No SW: 3V0 907 044 AN HW: 3V0 907 044 AN
Component: AC Automat H32 3601
Revision: 20K04000 Serial number: 00000B00027973
Coding: 11110104000400011005100100101102
ASAM Dataset: EV_ACClimaPrehVW37X 002009
ROD: EV_ACClimaPrehVW37X_SK48.rod
VCID: 000435F79B551A3E5D-8054
Slave 1:
0515 - Transport Mode Active
U1105 00 [008] - -
Fault Frequency: 17
Reset counter: 40
Mileage: 3 km
Date: 2011.10.22
Time: 12:21:09
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061528007986
Coding: 0F019E66C2C72AFB17844086B118172C0800000000000000000000000000
ROD: EV_BCMBOSCH_SK48.rod
VCID: 091228D3A86F5B760A-805C
Slave 1:
Subsystem 1 - Part No SW: 3V2 955 119 HW: 3V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: 48x RL 150225 032 0121
Serial number: 00000001502210602013
Coding: 165DDD
Slave 2:
Component: RLHS 037 0059
Serial number: S4Y15M10D19H01M57S19
Coding: 0088DF
Serial number: 000000000ZY1523614FM
Serial number: 00000000000033597986
Subsystem 5 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Component: SysNameFanLin 014 0101
Serial number: ESE0048458
Subsystem 6 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0105694
Subsystem 7 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0102725
Subsystem 8 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0105695
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5QA 919 298 HW: 5Q0 919 298 C
Component: PLA 3.0 12KH08 0161
Serial number: 000305183615269
Coding: 0371167851
ASAM Dataset: EV_EPHVA2CAU3700000 009017
ROD: EV_EPHVA2CAU3700000_SK48.rod
VCID: 0D1A1CC3DC07475626-8058
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0192
Coding: 320067C355FFC428949C804D
ASAM Dataset: EV_ACCBOSCHVW48X 001008
ROD: EV_ACCBOSCHVW48X.rod
VCID: 346CA9279F6D769E89-8060
0110 - Transport Mode Active
U1105 00 [008] - -
Reset counter: 40
Mileage: 3 km
Date: 2011.10.22
Time: 12:21:09
Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0120
Serial number: 16101541350715
ROD: EV_DRCONTITEMIC.rod
VCID: 37769E2B8E1B9D86AC-8062
Part No SW: 5Q0 959 655 AE HW: 5Q0 959 655 AE
Component: AirbagVW21 005 0130
Serial number: 003NSR15TKCJ
Coding: 98FCC0C0000000005C5400CF00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
ROD: EV_AirbaVW20SMEVW37X_SK48.rod
VCID: 030E3AFB8A43012640-8056
Seat belt tensioner; left:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1032
Serial number: 3V0857701C0285P00576
Coding: 80000D
Seat belt tensioner; right:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1032
Serial number: 3V0857702C0283P01085
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 000 110 15
Serial number: 35700000000309FCB61T
Subsystem 4 - Part No SW: ----------- HW: 480 000 110 15
Serial number: 35800000000026290710
Subsystem 5 - Part No SW: ----------- HW: 480 400 510 15
Serial number: 3510002A11CF2D70D289
Subsystem 6 - Part No SW: ----------- HW: 480 400 510 15
Serial number: 3520002B91CF2DA3335D
Subsystem 7 - Part No SW: ----------- HW: 480 403 009 15
Serial number: 3550002C91CF2D75534H
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 3Q0 953 521 BA HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20151007400651
Coding: 6010
ROD: EV_SMLSVALEOMQB.rod
VCID: 70E46537ABF50ABEAD-8024
Address 17: Instruments (J285) Labels: None
Part No SW: 3V0 920 911 HW: 3V0 920 911
Component: KOMBI 305 6422
Coding: 27A5011A7F80A600018B6A0B5001000000000000
Shop #: WSC 73430 031 00063
ROD: EV_DashBoardVDDMQBAB_SK25.rod
VCID: 6FE6664BB6CB1546B4-803A
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M
Component: GW MQB High 212 2227
Revision: -------- Serial number: 13101510802143
Coding: 030100044F087300EB00025E9C0F00010001070000000000000000000000
Shop #: WSC 73430 790 00063
ROD: EV_GatewConti.rod
VCID: 75EA5423D4972F967E-8020
Subsystem 2 - Part No SW: 3V0 919 719 B HW: 3V0 919 719 B
Component: E221__MFL-PR6 H02 0150
Serial number: 000000000A2937081015
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 0876128103
Component: ELV-MQBB H05 0031
Serial number: 15000073687004
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71E26033A0FF03B6A2-8024
Address 36: Seat Mem. Drvr (J810) Labels: None
Part No SW: 5Q0 959 760 A HW: 5Q0 959 760 A
Component: Sitzmemory H06 0009
Serial number: Y0006OIG13839
Coding: 001400000000010001A080808080000000008181000000D4
ASAM Dataset: EV_SeatMemorDriveSide 001015
ROD: EV_SeatMemorDriveSide_SK37.rod
VCID: 3B7E821BB233B9E648-806E
Address 3C: Lane Change (J1086) Labels: None
Component: HRE_Master H11 0071
Serial number: 0381848004
Coding: 02011203
ROD: EV_HREntryHella_SK37.rod
VCID: 3C7C8107B73DBEDE41-8068
Component: TSG FS 020 0041
Serial number: 150915BIF02812
Coding: 001D0820DE01048000001100
ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
VCID: 438EFAFBCAC3C12600-8016
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1063
Coding: 9303
ROD: EV_SteerAssisMQB.rod
VCID: 448CF9E7CFCDC61E39-8010
Component: TSG BFS 020 0041
Serial number: 250915BIO15667
Coding: 001D0220DE01048000001100
ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
VCID: 4280FFFFD5D9C82E0B-8016
Component: AFS-ECU H07 0090
Coding: 06D602007F010000
ROD: EV_HeadlRegulVWAFS_SE26.rod
VCID: 4084F5F7DBD5DA3E1D-8014
Subsystem 1 - Part No SW: 4H0 941 329 HW: 4H0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H02 0013
Coding: B30000
Subsystem 2 - Part No SW: 4H0 941 329 HW: 4H0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 0013
Coding: B30000
Part No SW: 3V0 035 020 A HW: 3V0 035 020
Component: MU-H-ND-EU H42 0318
Serial number: A435J0F7522308
Coding: 038401010000000011111202008808002F0003E601200100DE
ROD: EV_MUHig4CGen2HBAS_SK37.rod
VCID: 244C59672F8DE61E19-8070
Media Player Position 1:
Radio Tuner - Digital:
Subsystem 2 - Part No SW: 3V0 919 606 HW: 3V0 919 606
Component: ABT_High-2 H44 1028
Serial number: SKZ8Z9RAM00BJX
Engine Control Module 2:
Subsystem 3 - Part No SW: ----------- HW: -----------
Component: ------------- --- ----
Seat Adjustment Driver Side:
Subsystem 4 - Part No SW: V03 959 801 JJ HW: -----------
Component: ECE 2015/2016 --- 0122
Air Conditioning Compressor:
Diesel Pump Control Unit:
Door Electronics Driver Side:
Subsystem 7 - Part No SW: ----------- HW: -----------
Brake Assistance:
Subsystem 8 - Part No SW: ----------- HW: -----------
Interior Monitoring:
Subsystem 9 - Part No SW: ----------- HW: -----------
Sound System:
Door Electronics Rear Left:
Subsystem 12 - Part No SW: ----------- HW: -----------
Subsystem 13 - Part No SW: ----------- HW: -----------
Subsystem 14 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1011
Address 6C: Back-up Cam. (J772) Labels: None
Part No SW: 5Q0 980 556 HW: 5Q0 980 556
Component: RVC Compact H07 0100
Coding: 04840101A600201F000040
ROD: EV_CamSysRVRVCPANAMQBAB.rod
VCID: 77F65E2BCE9B5D866C-8022
Address 6D: Trunk Elect. (J605) Labels: None
Part No SW: 5Q0 959 107 G HW: 5Q0 959 107 G
Component: HDSG-Modul H12 0250
Revision: -------- Serial number: 30282636500000
Coding: 1008
ASAM Dataset: EV_DeckLidCONTIAU736 001011
ROD: EV_DeckLidCONTIAU736_SK48.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels: None
Part No SW: 3Q0 980 654 D HW: 3Q0 980 654
Component: MQB_B_MFK H04 0024
Serial number: 05101511K11646
Coding: 020408010000040100062346C040A00088000E100040
ROD: EV_MFKBoschMQBB_SK48.rod
VCID: 38749D17830592FEA5-806C
End-------------------------(Elapsed Time: 07:22)--------------------------
