This is related to my output test discovery work here: http://forums.ross-tech.com/showthread.php?3927-No-selective-output-tests-for-B8-S5-module-46
I figured this was generic enough to warrant it's own thread though. I wasn't able to find much in my Google searches.
When I run some of the tests, the module accepts them but then hangs. If I manually stop the test, VCDS comes back with a red "Refused by control module. Status 03" error.
Does anyone have a definition of what this means? My guess is that it's a valid test for that module's hardware, but the option you're trying to test isn't installed and/or coded. Like doing rear door lock tests on an A5 coupe, or testing a power sunshade that doesn't exist.
Some of my searches showed that the raw CANbus code might be 7F 22 22. Which is a negative response to mode $22, with the reason code being "conditions not correct or sequence error". I couldn't find anything saying this was the same as a Status 03 however.
Any light that can be shed on this would be greatly appreciated.
