hi everyone, i need help with my A4 b8 ABS fault codes.
here is few scans. very first, second and latest one.
intro: car is equipped with auto hold function. A button near handbrake. always driving with it on. at the time all flashed i was turning around in the middle of the road very quickly shifting R-D-R-D and i could hear as car was trying to turn on auto stop but had no chance. hence this is not first time shifting gears quick due to my driving stile.
by looking at it from time stamp its closer to problem in broken link in abs module as per this link: https://www.drive2.ru/l/112785
as he had same problems and replacing sensor didn`t help.
here is time frame of faults so it would be easier for you to look at it:
first
08:46:00 Cent. Elect.- ABS Control Module
08:46:34 ABS- Wheel Speed Sensor; Front Left (G47)
08:46:35 ABS- Control Module for Elect. Park/Hand Brake
08:46:35 Steering wheel- ABS Control Module
08:46:35 Parking Brake- ABS Control Module
14:33:04 Engine- Function Restriction due to Faults in Other Modules
second
17:18:00 Cent. Elect.- ABS Control Module
17:18:47 ABS- ABS Wheel Speed Sensor; Front Left (G47)
17:18:47 Steering wheel- ABS Control Module
17:18:48 ABS- Control Module for Elect. Park/Hand Brake (J540)
17:18:48 Parking Brake- ABS Control Module
17:32:59 ABS- TPMS Functionality in ESP
new
16:33:00 Cent. Elect.- ABS Control Module
16:33:25 ABS-ABS Wheel Speed Sensor; Front Left (G47)
16:48:38 Engine- Function Restriction due to Faults in Other Modules
16:48:38 ABS- Control Module for Elect. Park/Hand Brake (J540)
16:48:38 Steering wheel- ABS Control Module
16:48:38 Parking Brake- ABS Control Module
FIRST SCAN
SECOND : /////////////////////////////////////////////////////////////////////////////////////////////////
LATEST : //////////////////////////////////////////////////////////////////////////////////////
thanks.
first
second
new
FIRST SCAN
Friday,20,November,2015,14:39:57:31877
VCDS Version: 15.7.1.0 (x64)
Data version: 20*****4
VIN: WAUZZZ8K********21 License Plate: BADDD
Mileage: 154200km-95815mi Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 02 03 05 07 08 09 0E 10 15 16 17 19 1E 37 42 46 47 52 53
55 56 62 72 77
VIN: WAUZZZ8K*******1 Mileage: 154200km-95815miles
Address 01: Engine (J623-CCWA) Labels: 059-907-401-V1.clb
Part No SW: 8K2 907 401 HW: 8K1 907 401 A
Component: 3.0TDI EDC17 H01 0006
Revision: 15H01---
Coding: 0104002C190F0120
Shop #: WSC 06325 123 12345
ASAM Dataset: EV_ECM30TDI0118K2907401 001006
ROD: EV_ECM30TDI0118K2907401.rod
VCID: 6ADBEEC38D036C6EE3-803E
U1113 00 [039] - -
Mileage: 154201 km
Date: 2015.11.20
Time: 14:33:04
U1113 00 [039] - -
Mileage: 154201 km
Date: 2015.11.20
Time: 14:33:04
Address 02: Auto Trans (J217) Labels: 0B6-927-156.clb
Part No SW: 8K0 927 158 A HW: 0B6 927 156
Component: 0B6 30 TDIRdW H04 0030
Revision: --H04---
Coding: 001001
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMAL651 A01004
ROD: EV_TCMAL651.rod
VCID: 346730BB9F47EA9E89-8060
4765 - Functionality limited due to Engine Control Module
P1719 00 [032] - -
Mileage: 153451 km
Date: 2015.11.11
Time: 21:08:23
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AD HW: 8K0 907 379 AD
Component: ESP8 quattro H04 0060
Coding: 144D00
VCID: 7BF5DB87FA99E5E608-802E
00283 - ABS Wheel Speed Sensor; Front Left (G47)
003 - Mechanical Failure - MIL ON
Fault Status: 11100011
Reset counter: 170
Mileage: 154177 km
Date: 2015.11.20
Time: 08:46:34
Hex Value: 0x5C00
Hex Value: 0x4016
Hex Value: 0x123E
Hex Value: 0xA8B5
Hex Value: 0x00FF
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 170
Mileage: 154177 km
Date: 2015.11.20
Time: 08:46:35
Hex Value: 0x6400
Hex Value: 0x4316
Hex Value: 0x1216
Hex Value: 0x02B5
Hex Value: 0x00FF
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000063509
Coding: 2600D0914134AF211601000300001D0D4F9D420800010141000000
VCID: 306F3CAB635FD6BEED-8064
Subsystem 1 - Part No SW: 8K2 955 119 HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 180608 H05 0060
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 C HW: 8K0 955 559 C Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 000A5A
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Reset counter: 170
Mileage: 154177 km
Date: 2015.11.20
Time: 08:46:00
03207 - Charisma Switch Module
Reset counter: 146
Mileage: 153177 km
Date: 2015.11.09
Time: 16:33:00
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Component: Lenks.Modul H12 0013
Revision: -------- Serial number: 90315HFP000AR
Coding: 000036
VCID: 3D71159FA40D2BD676-8068
Component: E221 - MFL H02 0003
Reset counter: 170
Mileage: 154177 km
Date: 2015.11.20
Time: 08:46:35
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Part No SW: 8K0 907 064 C HW: 8K0 907 064 C
Component: BCM2 1.1 H70 0134
Revision: 00002001 Serial number: 0112435924
Coding: 011F062200390400032001
Component: LIN BACKUP HO H03 1301
02616 - Fuel Tank Cap; Unlock
Fault Status: 00101001
Reset counter: 208
Mileage: 153686 km
Date: 2015.11.14
Time: 16:55:55
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 00000000158718
VCID: 316939AF6855DFB6E2-8064
Fault Status: 11101101
Reset counter: 170
Mileage: 154177 km
Date: 2015.11.20
Time: 08:46:35
Voltage: 14.50 V
Count: 62
Speed: 98.0 km/h
Hex Value: 0x0260
Hex Value: 0x0004
Hex Value: 0x0101
Tuesday,24,November,2015,15:34:30:31877
Data version: 20***04
VIN: WAUZZZ8K******1 License Plate: AGAIN
Mileage: 154490km-95995mi Repair Order:
55 56 62 72 77
VIN: WAUZZZ8K*******1 Mileage: 154490km-95995miles
Revision: 15H01---
U1113 00 [032] - -
Mileage: 154493 km
Date: 2015.11.24
Time: 15:09:16
U1113 00 [032] - -
Mileage: 154493 km
Date: 2015.11.24
Time: 15:09:16
Revision: --H04---
Coding: 001001
P1719 00 [032] - -
Mileage: 154210 km
Date: 2015.11.20
Time: 16:53:56
Coding: 144D00
003 - Mechanical Failure - Intermittent - MIL ON
Fault Status: 10100011
Reset counter: 215
Mileage: 154228 km
Date: 2015.11.20
Time: 17:18:47
Hex Value: 0x1F00
Hex Value: 0x4006
Hex Value: 0x123E
Hex Value: 0xA8B6
Hex Value: 0x00FF
Fault Status: 00101101
Reset counter: 215
Mileage: 154228 km
Date: 2015.11.20
Time: 17:18:48
Hex Value: 0x2000
Hex Value: 0x4306
Hex Value: 0x1216
Hex Value: 0x02B5
Hex Value: 0x00FF
03159 - TPMS Functionality in ESP
Reset counter: 211
Mileage: 154241 km
Date: 2015.11.20
Time: 17:32:59
Hex Value: 0x4F00
Hex Value: 0x4306
Hex Value: 0x1F1A
Hex Value: 0x0DB5
Hex Value: 0x00FF
Coding: 00FD11
Coding: 000A5A
Reset counter: 215
Mileage: 154228 km
Date: 2015.11.20
Time: 17:18:00
Reset counter: 170
Mileage: 154205 km
Date: 2015.11.20
Time: 16:31:00
Coding: 000036
Reset counter: 215
Mileage: 154228 km
Date: 2015.11.20
Time: 17:18:47
Reset counter: 213
Mileage: 154379 km
Date: 2015.11.23
Time: 13:01:35
02615 - Fuel Tank Cap; Lock
Reset counter: 215
Mileage: 154480 km
Date: 2015.11.24
Time: 11:58:10
Reset counter: 215
Mileage: 154228 km
Date: 2015.11.20
Time: 17:18:48
Voltage: 14.50 V
Count: 62
Speed: 32.0 km/h
Hex Value: 0x0260
Hex Value: 0x0004
Hex Value: 0x0101
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Part No SW: 8K0 959 794 HW: 8K0 959 795
Component: TSG HR H06 0170
Revision: Serial number: 0000007354265
Coding: 010C02204001210001
VCID: 7EF3D293E98BF0CE2F-802A
Reset counter: 171
Mileage: 154205 km
Date: 2015.11.20
Time: 16:36:44
Tuesday,24,November,2015,17:41:29:31877
Data version: 2*****04
VIN: WAUZZZ8K********1 License Plate: NEW
Mileage: 154500km-96001mi Repair Order:
55 56 62 72 77
VIN: WAUZZZ8K*******1 Mileage: 154500km-96001miles
Revision: 15H01---
U1113 00 [032] - -
Mileage: 154503 km
Date: 2015.11.24
Time: 16:48:38
U1113 00 [032] - -
Mileage: 154503 km
Date: 2015.11.24
Time: 16:48:38
Coding: 144D00
Reset counter: 215
Mileage: 154503 km
Date: 2015.11.24
Time: 16:33:25
Hex Value: 0x0000
Hex Value: 0x02A0
Hex Value: 0x003E
Hex Value: 0xA89B
Hex Value: 0x00FF
Reset counter: 215
Mileage: 154503 km
Date: 2015.11.24
Time: 16:48:38
Hex Value: 0x0D00
Hex Value: 0x4302
Hex Value: 0x0216
Hex Value: 0x02AB
Hex Value: 0x00FF
Coding: 00FD11
Coding: 000A5A
Reset counter: 175
Mileage: 154503 km
Date: 2015.11.24
Time: 16:33:00
Reset counter: 175
Mileage: 154497 km
Date: 2015.11.24
Time: 15:34:00
Coding: 000036
Reset counter: 175
Mileage: 154503 km
Date: 2015.11.24
Time: 16:48:38
Reset counter: 175
Mileage: 154503 km
Date: 2015.11.24
Time: 16:48:38
Voltage: 13.70 V
Count: 62
Speed: 12.0 km/h
Hex Value: 0x0260
Hex Value: 0x0004
Hex Value: 0x0101
Reset counter: 175
Mileage: 154497 km
Date: 2015.11.24
Time: 15:36:41
thanks.
