Results 1 to 3 of 3
Thread: Error 01176 (Mk.4 Golf)
    Verified VCDS-Lite User
    Jun 2015
    UK, Crawley
    Hi i did a autoscan on my car today and this is what i got
    Monday, 23 November 2015, 13:50:04:29282
    Chassis Type: 01 - My Golf
    Scan: 01,03,08,15,17,19,46,56
    Address 01: Engine       Labels: 06A-906-032-AJQ.LBL
       Controller: 06A 906 032 MJ
       Component: 1.8L R4/5VT         0003
       Coding: 11510
       Shop #: WSC 01266
       VCID: 72972BA92DB7
       WVWZZZ1JZ4W112895     VWZ6Z0C0133447
    Address 03: ABS Brakes       Labels: None
       Controller: 1C0 907 379 M
       Coding: 0019970
       Shop #: WSC 01266
       VCID: 341BEDB11723
    Address 08: Auto HVAC       Labels: 3Bx-907-044.LBL
       Controller: 3B1 907 044 C
       Component: CLIMATRONIC     C 2.0.0
       Coding: 11000
       Shop #: WSC 01266
       VCID: 213514E5B8D1
    Address 15: Airbags       Labels: 6Q0-909-605-VW5.LBL
       Controller: 1C0 909 605 A
       Component: 27 AIRBAG VW51 01   0008
       Coding: 12855
       Shop #: WSC 01266
       VCID: 22371BE9BDD7
    Address 17: Instruments       Labels: 1J0-920-xx5-17.LBL
       Controller: 1J0 920 926 A
       Component: KOMBI+WEGFAHRS. RB8 V29
       Coding: 05414
       VCID: 282309C1DBEB
    01176 -  Key
                07-10 -  Signal too Low - Intermittent
    Address 19: CAN Gateway       Labels: 6N0-909-901-19.LBL
       Controller: 6N0 909 901
       Coding: 00006
       Shop #: WSC 01266
       VCID: F093A1A1A3BB
    Address 46: Central Conv.       Labels: 1C0-959-799.LBL
       Controller: 1C0 959 799 B
       Component: 1X KomfortgerŠt HLO 0003
       Coding: 00259
       Shop #: WSC 54146
       VCID: 361FD7B9015F
    Address 56: Radio       Labels: 1J0-035-18x-56.LBL
       Controller: 1J0 035 186 D
       Component:  RADIO SON         0004
       Coding: 01403
       Shop #: WSC 01266
       VCID: 263F07F9D1FF
    End   --------------------------------------------------------------------------------------------------
    I see it could be my key, I did change the key batt about a month ago. The reason I did the scan was this morning I got STOP Check coolant service manual. yet had coolant at the correct level and only had waterpump changed 4 months ago with timing belt. yet no error code for that.
    How can I test this error more as hate to think its the Immobilizer.
    My girlfriend said when she use the car about amonth ago after changing the key bat. she got in the car and it went all blank as she went to start. she had to lock the car and open again and all was fine after she said.
    The battery in your key has nothing to do with that fault code. The immobilizer transponder is a separate (passive) device from the remote transmitter in your key.
    A transponder issue will not cause the rest of the electrics in the car to blank out either.
    Check, clean, condition connections between immo pickup coil at ignition switch and instrument cluster.
    Check connections at Central Convenience Module as well.
    Jun 2015
    UK, Crawley
    Thanks for the reply
    As it has only happen once, I think it will be easier to just reset and see if the code comes back in the future. if so then will check all the wiring with a meter at the ignition.
    Were would I look for the Central Convenience Module.
