Audi A3 89 rear passenger door only opens from inside
mob
Ireland
C?ID=178070
This error only seems to have started now I actually need to get stuff in and out of the passenger rear door. It won't open/unlock using the key fob, internal central unlocking button or manually using the external handle. It will open if you use the internal door handle
Summary
When I scanned it using VCDS 15.7.1 I get the following errors related to the door Address 42,62
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0050
Coding: 0000688
Shop #: WSC 06314 000 00000
VCID: 43ABAD510208612600-8016
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000144
Shop #: WSC 06314 000 1012544
VCID: 41A7A7591814733612-8014
The other error codes are a glow plug, radio speaker which I've had for a while and a rear fog light which is new but is it related
Any ideas what the problem might be with the rear door before I get someone to look into it?
Please post a complete auto-scan....... not what you think is relevant.
Fix the obvious mechanical problem with the lock unit, or outer handle.
Get a repair manual at Erwin.
mob
Ireland
C?ID=178070
whats the obvious mechanical problem and solution?
Here is the full scan without the vin number but its an 80 sportsback
Saturday,21,November,2015,12:24:22:40377
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN:    License Plate:
Mileage: 238360km-148110mi   Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
VIN:    Mileage: 238360km-148110miles
Address 01: Engine        Labels: 03G-906-021-BLS.clb
   Part No SW: 03G 906 021 RG    HW: 03G 906 021 AB
   Component: R4 1,9L EDC  000SG  1957
   Revision: --H07---    Serial number: AUX7Z0H1FN50NE
   Coding: 0000071
   Shop #: WSC 00385 210 91297
   VCID: 75CF03891C5C8F967E-8020
005659 - Glowplug for Cylinder 2 (Q11)
               P161B - 000 - Open Circuit
                    Mileage: 221006 km
                    Date: 2015.06.02
                    Time: 07:57:49
                    RPM: 882 /min
                    Voltage: 13.91 V
                    Bin. Bits: 00000100
                    Temperature: 9.9°C
                    Bin. Bits: 10110000
   Revision: 00H11001
   Coding: 0021121
   VCID: 73CB3D91122891A650-8026
   Part No: 8P0 820 047
   Component: J255  Klima Man H07 0030
   VCID: 6DFF2BE9740C475686-8038
Address 09: Cent. Elect.        Labels: 8P0-907-279-30-B.lbl
   Part No SW: 8P0 907 279 J    HW: 8P0 907 279 J
   Component: Bordnetz-SG     H54 2501
   Revision: 00H54000    Serial number: 00000008037223
   Coding: 00880F01B01410004F1600001600000000085A175C010000000000000000
   Shop #: WSC 06314 000 08192
   VCID: 44A9AE4D0706661E39-8010
   Subsystem 1 - Part No: 8P2 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H01 0130
   Coding: 00062736
   Shop #: WSC 06314
01502 - Bulb for Rear Fog; Left (L46)
                    Fault Frequency: 21
                    Reset counter: 120
                    Mileage: 221658 km
                    Date: 2015.06.09
                    Time: 07:58:00
                    Voltage: 12.90 V
Address 15: Airbags        Labels: 8P0-959-655-94.lbl
   Part No SW: 8P0 959 655 L    HW: 8P0 959 655 L
   Component:    Airbag 9.41  H01 4220
   Revision: 91H01422    Serial number: 003CP002PSAJ
   Coding: 0071612
   VCID: 4BBB85712A58A966F8-801E
   Subsystem 1 - Serial number: 6332DRB40E69872A$
   Subsystem 2 - Serial number: 6342DRB406AC9231R
   Subsystem 3 - Serial number: 63528RB40385DBF0Z
   Subsystem 4 - Serial number: 63628RB403843960E
   Subsystem 5 - Serial number: 63747RB40369EEE22
   Subsystem 6 - Serial number: 63847RB40369ED9E9
   Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
   Component: J0527           036 0070
   VCID: 78D10ABD0B4EF2FE65-802C
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
   Part No SW: 8P0 920 981 K    HW: 8P0 920 981 K
   Component: KOMBIINSTR. VDO H22 0660
   Revision: D0H22003    Serial number: 2241H003108478
   Coding: 0006423
   Shop #: WSC 80093 222 69422
   VCID: 40A1A25D131E7A3E1D-8014
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 P    HW: 1K0 907 951
   Component: J533__Gateway   H16 0192
   Revision:   H16       Serial number: 2500K0820401C4
   Coding: E9807F061002022103
   VCID: 3449FE8D57A6D69E89-8060
   Revision: D0H22003    Serial number: AUX7Z0H1FN50NE
   Coding: 0000688
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.078 H08 1901
   VCID: 364DC48541DAC48EB7-8062
   Part No: 8P0 959 433 J
   Component:    KSG          H11 0080
   Coding: 1980202002186D0985054C9FC637
   Component: Neigungssensor  005 0003
   Part No SW: 8P4 035 382 D    HW: 8P4 035 382 D
   Component: AB2 SUBWOOFERBOXH06 0180
   Revision: 00005       Serial number: 30674752816328
   VCID: 354FC3895CDCCF96BE-8060
00421 - Rear Left DSP Midrange Speaker (R105)
                    Fault Status: 00101011
                    Reset counter: 139
                    Mileage: 237227 km
                    Date: 2015.11.10
                    Time: 17:26:02
                    Temperature: 13.0°C
   Part No SW: 8P0 959 802 K    HW: 8P0 959 802 K
   Coding: 0000688
   Part No SW: 8P0 035 186 P    HW: 8P0 035 186 P
   Component: R Concert2+     H02 0270
   Revision: 00H02000    Serial number: AUZ1Z3H8880884
   Coding: 0110211
   VCID: 3FA3A1A16EE005C664-806A
   Coding: 0000144
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 E    HW: 8P4 959 802 E
   Coding: 0000144
   VCID: 42A5A8551D12682E0B-8016
End-------------------------(Elapsed Time: 01:13)--------------------------
Really? I wasn't aware Audi made an A3 model in 1980, and if they did, it certainly wouldn't have been diagnostic capable.
Also the thread title states it's an 89. Also not plausible. Except if maybe if you're talking about "registration plates" which are irrelevant, because they don't correlate to model year very well at all, and it's utterly meaningless to anyone who lives on anything resembling a continent rather than an island.
So please post at least the first 10 digits of your VIN. ;)
Ahhhhhh you describe it..........
The point is that this is a mechanical issue being general repair.
You must take the door apart and inspect it via the repair manual, or take both rear doors apart and compare function and fitment operation.
If doing so......... take pictures as you go.
Remember...... VCDS is a tool, not an elixir ...........nor a substitute for the repair manual, or common sense.
