- Joined
- Jan 29, 2014
- Messages
- 21,923
- Reaction score
- 9,308
- Location
- Montgomery, NY, USA
- VCDS Serial number
- C?ID=57337
Yup ...its called PRINT to PDF........many programs out there.
what does 97 + 2 mm stand for?
Dimension - a - = 87 plusminus 2 mm
Dimension - b - = 73 plusminus 2 mm
The image you linked is too small to be legible.
THANKS that explains everything! Thanks sorry about the picture I'm so sorry about that.Looking at the photo, while squinting and using diet root beer goggles, this is what you are looking at:
- Audi
- A8/A8L
- 2004-2008
- Suspension, Wheels, Steering
- 40 - Removal and Installation
- Upper Control Arms
Pictures "A40-0477" and "A40-0478".
To that end, I show the following:
87mm, give or take 2mm, thus 85mm to 89mm is acceptable.
73mm, give or take 2mm, thus 71mm to 75mm is acceptable.
So when installing the upper control arm links, when you put a straight edge across the top of the strut, there be between (X) to (Y) mm distance between the straight edge and the end of the upper control arm.
Wednesday,16,December,2015,11:19:33:14758
VCDS Version: 15.7.0.1 (x64)
Data version: 20150729
VIN: WAUML44E74N017518 License Plate:
Mileage: 88300km-54867mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 25 28 34 36 37 38 42
46 47 4F 52 53 56 61 62 72 76
VIN: WAUML44E74N017518 Mileage: 88300km-54867miles
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0070
Revision: 00000000 Serial number: AUX3Z0CD531019
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 1F4DDD45CE847AC64F-804A
Readiness: 0010 1101
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0110
Revision: 00000001 Serial number: 0027237
VCID: 2447D2A9E7E2591E12-8070
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H46 0510
Coding: 0007597
Shop #: WSC 23435 000 00000
VCID: 224BD4B1FDF6572E60-8076
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 A
Component: FBS AUDID3 H03 0140
Revision: 01403903 Serial number: AUX3Z0CD531019
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: 58BFB659EB2ACDFE4E-800C
Component: ELV XXXX
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 S HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 346IP047514325
Coding: 0000103
VCID: 326B24F1AD16C7AE90-8066
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000097794
Subsystem 3 - Serial number: 0113.11.130000000100010015ÿ
Subsystem 4 - Serial number: 010015ÿ
Part No SW: 4E0 910 043 HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 016 0240
Revision: 00000022 Serial number: 00000000033347
Coding: 1151313
VCID: 5ABBAC519526DFEE78-800E
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO15122003065A000000000168ÿ†89
Subsystem 5 - Serial number: 000168ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO18122003065A00000000
Subsystem 7 - Serial number: 65A000000000072ÿ
00066 - Rear Right Footwell Heater (Z43)
Reset counter: 174
Mileage: 88308 km
Date: 2015.12.15
Time: 18:23:09
Voltage: 13.30 V
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0111113
VCID: 2A5B3C9185C68F6E28-807E
Subsystem 1 - Part No: 4E1 910 113
Component: Wischer WWS D3 H30 0320
Coding: 00000030
Shop #: WSC 02313
Part No SW: 4E0 910 111 F HW: 4E0 035 111
Component: CD-Changer H43 0470
Serial number: AUZ5ZBC1016260
VCID: 1C37EA49DF9261DEAA-8048
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 D HW: 4E0 035 593
Component: SDAR SIRIUS H04 0670
Revision: 00000000 Serial number: AUZ4Z7E2009013
VCID: 285FC6999BCABD7E3E-807C
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Coding: 0012241
VCID: 65C18FADAC586016C5-8030
Component: Lenkradmodul H04 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 B
Component: KOMBIINSTR. VDO H44 0090
Revision: D15 Serial number: AUDID3CD006664
Coding: 0000232
Shop #: WSC 65537 000 00032
VCID: 5CB7AA499F1221DE6A-8008
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0030
Revision: 07 Serial number: 0200503C0111AE
Coding: FCFE5FCC1B2904
Shop #: WSC 07228 444 53694
VCID: 2643C8A191DEAB0E0C-8072
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 A
Component: KLIMA-STG. FOND 015 0210
Revision: 00000014 Serial number: 00000000013996
Coding: 0000000
VCID: 61C99BBDB8700C3639-8034
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
Shop #: WSC 22145 444 54027
VCID: 2541CFADECD8A01605-8070
VCID: 55A1BF6DBC38F09655-FFFE
No Faults Found
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H42 1100
Revision: 00000000 Serial number: 355LL037514310
VCID: 387F16D94B6A2DFEAE-806C
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H01 0090
Serial number: 00000332500063
Coding: 0004021
VCID: 1D31E74DC48868D65D-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM005 0110
Coding: 0042525
VCID: 5EB3A041890E33CE04-800A
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040312110112
Coding: 0065150
VCID: 275DC5A596D4B20637-8072
Component: Heckdeckel H06 0060
Component: Neigungssensor H02 0020
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 175
Mileage: 193858 km
Date: 2011.08.15
Time: 01:50:33
Address 47: Sound System Labels: None
Part No SW: 4E0 910 224 C HW: 4E0 035 223 B
Component: DSP-High D3/AUX H13 0470
Revision: Dev_D01 Serial number: 00000000655399
Coding: 0000000
VCID: 1E33E041C98E73CE44-804A
Reset counter: 173
02084 - Component Protection
Fault Status: 01100101
Reset counter: 173
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H08 0020
Revision: Serial number: 00000000030051
Coding: 0010111
Subsystem 1 - Serial number: VK4978T078WE
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM005 0110
Coding: 0042525
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000532
Shop #: WSC 23435 444 58960
Part No SW: 4E0 910 541 T HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial number: 304CE047583230
Shop #: WSC 06802 176 59446
VCID: 31692BFDA810FCB6E9-8064
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 A HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0230
Revision: 00000000 Serial number: 00000004980755
Shop #: WSC 07212 444 82777
Subsystem 1 - Part No: 000 915 105 DL
Component: von VA0 310314E04K
Coding: 303030393135313035444C5641303331303331344530344B
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0000013
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM005 0110
Coding: 0000013
VCID: 5DB1A74D840828D61D-8008
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H11 0010
Revision: --.--.-- Serial number: 00000335600021
Coding: 0001208
VCID: 2149DBBDF8F04C3679-8074
End-------------------------(Elapsed Time: 03:31)--------------------------
So if I'm correct I'm gonna put just 16 on the workshop code 16 on the importer number and 16 on equipment number and when you say non-zero value I assume you mean just put the number 16 with no zeros correct ???thanks for all your helpLooks like your Audi Amp has lost its mind. Try a coding it to 0000016 with non-zero values for WSC, Importer, and Equipment Number.
Coding: 0000000
Coding: 0000016
Shop #: WSC 54321 444 12345
Friday,18,December,2015,08:16:37:14758
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
Mileage: 88440km-54954mi Repair Order:
VIN: WAUML44E74N017518 Mileage: 88440km-54954miles
Coding: 0007773
VCID: 1F4DDD45CE847AC668-804A
Readiness: 0010 1001
VCID: 2447D2A9E7E2591E35-8070
Coding: 0263168
VCID: 58BFB659EB2ACDFE69-800C
Component: ELV XXXX
Coding: 0000103
VCID: 326B24F1AD16C7AEB7-8066
Coding: 1151313
VCID: 5ABBAC519526DFEE5F-800E
Reset counter: 178
Mileage: 88445 km
Date: 2015.12.17
Time: 21:28:15
Voltage: 13.10 V
Coding: 0111113
VCID: 2A5B3C9185C68F6E0F-807E
Coding: 00000030
Shop #: WSC 02313
VCID: 1C37EA49DF9261DE8D-8048
VCID: 285FC6999BCABD7E19-807C
Coding: 0530707
Coding: 0012241
VCID: 65C18FADAC586016E2-8030
Coding: 0000232
VCID: 5CB7AA499F1221DE4D-8008
VCID: 2643C8A191DEAB0E2B-8072
Coding: 0263168
Component: ELV XXXX
Coding: 0000000
VCID: 61C99BBDB8700C361E-8034
Coding: 0015510
VCID: 2541CFADECD8A01622-8070
VCID: 55A1BF6DBC38F09672-FFFE
No Faults Found
Part No SW: 4E0 910 887 K HW: 4E0 919 887 C
Component: MNS US H42 0570
Revision: 00000000 Serial number: 355LS037511437
VCID: 35611FED5C78D09692-8060
VCID: 1D31E74DC48868D67A-8048
No Faults Found
Coding: 0042525
VCID: 5EB3A041890E33CE23-800A
Coding: 0065150
VCID: 275DC5A596D4B20610-8072
Reset counter: 178
Mileage: 193858 km
Date: 2011.08.15
Time: 01:50:33
Coding: 0000016
VCID: 1E33E041C98E73CE63-804A
Reset counter: 173
Coding: 0010111
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Subsystem 2 - Serial number: VK4978T078WE
Coding: 0042525
VCID: 31692BFDA810FCB6CE-8064
Coding: 0000013
Coding: 0000013
VCID: 5DB1A74D840828D63A-8008
Coding: 0001208
VCID: 2149DBBDF8F04C365E-8074
End-------------------------(Elapsed Time: 03:25)--------------------------
From this:
To this:
Note that the actual numbers listed in the WSC really don't effect the operation of a control module. Control modules want to know what dealer is doing the coding. New car dealers have a Work Shop Code, a 5 digit value and that info is stored in the scan tools back in the service department. In the US of Freedom A market, the Importer is 444. And shops can have several scan tools, thus different Equipment numbers.
I'm sorry should have known lolPlease post a current scan from VCDS.
Monday,25,January,2016,09:26:44:14758
Mileage: 90460km-56209mi Repair Order:
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 25 28 34 36 37 38 42 46
VIN: WAUML44E74N017518 Mileage: 90460km-56209miles
Coding: 0007773
Coding: 0007597
VCID: 224BD4B1FDF6572E47-8076
Coding: 0263168
Component: ELV XXXX
Coding: 0000103
Coding: 1151313
Reset counter: 240
Mileage: 90426 km
Date: 2016.01.24
Time: 23:55:25
Voltage: 13.40 V
Coding: 0111113
Coding: 00000030
Shop #: WSC 02313
Coding: 0530707
Coding: 0012241
Coding: 0000202
Coding: 7CFE5FCC1B2104
Coding: 0263168
Component: ELV XXXX
Coding: 0000000
Coding: 0015510
No Faults Found
Coding: 0004021
02138 - Control Circuit for Front Right Interior Lights
Reset counter: 240
Mileage: 90424 km
Date: 2016.01.25
Time: 00:01:00
00211 - Control Circuit for Rear Illumination Lights
Reset counter: 240
Mileage: 90424 km
Date: 2016.01.25
Time: 00:05:00
Coding: 0000540
Coding: 0065278
Reset counter: 240
Mileage: 193858 km
Date: 2011.08.15
Time: 01:50:33
Coding: 0000016
Reset counter: 240
Mileage: 90426 km
Date: 2016.01.24
Time: 22:33:15
Coding: 0010111
Coding: 0000540
Component: von VA0 310314E03L
Coding: 303030393135313035444C5641303331303331344530334C
Coding: 0004108
Coding: 0000012
End-------------------------(Elapsed Time: 03:13)--------------------------
Code:Address 36: Seat Mem. Drvr Labels: None VCID: 55A1BF6DBC38F09672-FFFE No Faults Found or DTCs not supported by controller or a communication error occurred [...] Address 53: Parking Brake Cannot be reached
