Touareg 7P instrument cluster, supposed to have a green light while Autoholding?
yuyueyuyue
C?ID=231285
My car is NA spec. I've seen Touareg's in Asian markets with factory autohold show a green parking light on the instrument cluster while autohold is working. See picture below.
http://www.clubtouareg.com/forums/f43/autohold-retrofit-179466-5.html#post1194114
I've swapped and coded an autohold button to work with my NA spec car. But my instrument cluster is not showing anything while the autohold is working.
Just wondering if this light is controlled by the instrument channel or the ABS channel?
thanks
Mrclopec
Nipomo, CA, USA
C?ID=149231
You should be able to go into 17-instruments and under output tests get every light to turn on as a diagnostic. It will let you know if your instrument cluster has it or not.
yuyueyuyue
C?ID=231285
Thanks for the help. I just ran out and did a output test. It looks like the instrument cluster is capable of displaying a green light. See "PARK"
http://www.clubtouareg.com/forums/f43/autohold-retrofit-179466-8.html#post1366826
Here's my auto scan. More help is appreciated!
Saturday,22,November,2014,17:04:48:47293
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: WVGEF9BP8ED0xxxxx   License Plate:
Mileage:    Repair Order:
Chassis Type: BP (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
          69 6C 6D 72
VIN: WVGEF9BP8ED0xxxxx   Mileage:
Address 01: Engine (J623-CGRA)       Labels: None
   Part No SW: 03H 906 023 CD    HW: 03H 907 309 E
   Component: 3.6 FSI ULEV  H16 7534
   Revision: M7H16---
   Coding: 002A0012433600000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM36FSI01103H906023CD 001005
   ROD: EV_ECM36FSI01103H906023CD.rod
   VCID: 66C39B0099DF7011F57-8033
14784 - Oxygen (Lambda) Sensor B2 S2
          P013D 00 [096] - Response too Slow Lean to Rich
Address 02: Auto Trans (J217)       Labels: 0C8-927-750.clb
   Part No SW: 0C8 927 750 CG    HW: 0C8 927 750 CG
   Component: AL1000 AISIN  002 2665
   Coding: 001368
   Shop #: WSC 55410 001 1048576
   ASAM Dataset: EV_TCMAL991031 002115
   ROD: EV_TCMAL991031_VW52.rod
   VCID: 73E5F254DA0D95B9629-8026
Address 03: ABS Brakes (J104)       Labels: 7P0-907-379.clb
   Part No SW: 7P0 907 379 P    HW: 7P0 907 379 A
   Component: MK25A         H36 0446
   Revision: --------    Serial number: 405940010EC818
   Coding: 5B7613C349252556DAF7C89592D3A4407300
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 4A9B4FB0ED07B471F1F-801F
   Part No SW: 4H0 907 064 EK    HW: 4H0 907 064 EK
   Component: BCM2 2.0      H36 0521
   Coding: 0D860016000000000000
   VCID: 76E3CB40C17F8091457-8023
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
Address 08: Auto HVAC (J255)       Labels: 7P6-907-040.clb
   Part No SW: 7P6 907 040 BR    HW: 7P6 907 040 BR
   Component: Klima 2 Zonen H21 1306
   Coding: 4606200A80
   VCID: 0501BC8C84999B095CD-8050
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063.clb
   Part No SW: 4H0 907 063 CD    HW: 4H0 907 063 D
   Revision: 15012002    Serial number: 00000001541350
   Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
   VCID: 6CD7E9288F334A41A33-8039
   Component: WWS    140423  033 0021
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Coding: 025223
   Component: E1 - LDS  H04 0031
   Component: USHL4.2  H30 0030
   Part No SW: 7P0 959 655 D    HW: 7P0 959 655 D
   Component: VW10Airbag071 H06 0026
   Revision: --------    Serial number: 003L5005D9KX
   Coding: 000000000000000000000000000000003731
   ROD: EV_AirbaVW10BPAVW526.rod
   VCID: 428B6790D5376C3139F-8017
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R142280JD0V
   Serial number: 3575LRB401E50OF49A3$
   Serial number: 3585LRB401E50OF4C1H5
   Serial number: 3515RRB401G52JCMAPM2
   Serial number: 3525RRB401G52JCMNHF1
   Serial number: 3555NRB400252JCEGA5$
   Serial number: 3565NRB400252JCEJPLV
   Part No SW: 4H0 953 568 F    HW: 7P6 953 507 L
   Revision: --------    Serial number: 01335NE8000M2
   Coding: 000015
   VCID: 36630B4081FFC091857-8063
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H05 0028
Address 17: Instruments (J285)       Labels: 7P6-920-xxx-17.clb
   Part No SW: 7P6 920 982 K    HW: 7P6 920 982 K
   Component: Kombi         H13 0419
   Revision: 13240270    Serial number: 658090514592018
   Coding: 8B7732022B00CF05020004
   ASAM Dataset: EV_KombiUDSRBVW526 001020
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 46837B80F91F5011157-8013
   Part No SW: 7P6 907 530 J    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H13 6032
   Revision: --------    Serial number: 00000001380848
   Coding: 0021035600
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3F8D6E64A6C501D9561-806A
   Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0190
   Serial number: 31114G58455701131711
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000098913258
   Coding: 00581B0000004001000001010101202020202121202020
   VCID: 346731489783D281BB3-8061
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H02 0306
   Revision: --------    Serial number: 0000102151385
   Coding: 011D17205E00453005080000
   VCID: 7AFBDF70F567E4F121F-802F
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0333864729
   Coding: 0186123A68B9509580B00620210A08000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
   Component: GTO BT  H19 0059
   Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
   Component: J245 PS30.055  H01 0008
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
   Component: J394 PS30.055  H01 0008
   Coding: 191100
   Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H02 0306
   Revision: --------    Serial number: 0000102031441
   VCID: 489F75B8FB0B4661E7B-801D
Address 53: Parking Brake (J540-)       Labels: 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1450200926
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   VCID: 36630B4089FFC091857-8063
   Slave 3:
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Coding: 010A00010F000400
   VCID: 7CF7D968F753DAC1333-8029
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329
   Component: LeiMo links  H01 0003
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329
   Component: LeiMo rechts  H01 0003
   Coding: 130000
   Component: Radio U SIRIU H60 0133
   Revision: AB001007    Serial number: 156EV0E8006424
   Coding: 020007020100000001
   VCID: 2447C108276342012B3-8071
   Part No SW: 7P6 035 664 E    HW: 7P6 035 664 A
   Component: H-BN-NA       H40 0783
   Revision: --------    Serial number: 273ET0E7515004
   Coding: 010200050040E1EE41022B0C00000003F00001030000000000
   VCID: 3A7B1F70B5E724F161F-806F
   Subsystem 1 - Part No: 8R0 060 884 BL
   Component: NAR 2014  0902
   Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: DU8 SV Touch  H26 0045
   Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: CD-Database  5571
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H03 0306
   Revision: --------    Serial number: 0000102048796
   Coding: 011817200000253005080000
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 10000000135156
   ROD: EV_RDKBERU25_VW52.rod
8392961 - TPMS Transceiver in Front Left Wheel Well
          C104C 01 [008] - Electrical Failure
                    Reset counter: 36
                    Mileage: 4399 km
                    Date: 2014.11.07
                    Time: 12:28:04
Address 69: Trailer (J345)       Labels: None
   Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
   Component: Anhaenger     H11 0110
   Revision: 5A001001    Serial number: 00008200335309
   Coding: 020D000000000000
   VCID: 3B751A74BADD1DF97A9-806E
   Part No SW: 7P6 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0020
   Revision: 00H08000    Serial number: 525 PA8J442593
   Coding: 0110001
   VCID: 377D064446F539999E1-8062
Address 6D: Trunk Elect. (----)       Labels: 7N0-959-107.clb
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 115400349
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H03 0306
   Revision: --------    Serial number: 0000102681264
End-------------------------(Elapsed Time: 05:11)--------------------------
MK7.5
C?ID=402753
          69 6C 6D 72
   Revision: M7H16---
   Coding: 001368
   Coding: 4606200A80
   Coding: 004DBD
   Coding: 025223
   Coding: 000015
   Coding: 0021035600
   Coding: 191100
   Coding: 191100
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   Slave 3:
   Coding: 130000
   Coding: 130000
                    Reset counter: 36
                    Mileage: 4399 km
                    Date: 2014.11.07
                    Time: 12:28:04
   Coding: 0110001
   Coding: 0533314003
did anyone ever figure this out?
yuyueyuyue
C?ID=231285
Did that work for you on the Touareg? I have a 2019 Golf R and cannot access module 53
Ok, probably completely different ecus between MLB and MQB
An MQB-chassis Golf is not like a Touareg at all; it's a totally different animal.
Your Golf doesn't have a separate EPB control module at address 53. All EPB functionality is integrated in your ABS module at address 03.
