Results 1 to 10 of 20
Thread: A3 8V High Beam Assist Retrofit
    Jun 2015
    Hi all,
    I have a 2015 A3 with LED headlights, and am trying to activate high beam assist. It has factory activated Dynamic Light Assist. I have the advanced technology package (which includes lane assist, so I have the forward facing camera.) I've found these threads:
    http://forums.ross-tech.com/showthre...r-non-erasable
    http://www.briskoda.net/forums/topic...h-beam-assist/
    http://www.audi-sport.net/xf/threads...-style.255917/
    http://www.audi-sport.net/xf/threads...ssible.236851/
    Based on these, I believe the changes that need to be made are as listed below. Since I have lane assist, I do not have module 20.
    • Module 09 - Adaptations - “Assistant light functions - Menuesteurung Fernlichtassistent" changed to 'PRESENT'
    • Module A5 - Long Coding, change byte 2, use drop down menu to select correct coding - "02 Light/High Beam Assist Mode 2 - High Beam Assist (FLA) / Dynamic Light Assist (DLA)"
    • Module 09 - Long coding - Byte 2, Bits 0-2 - select the correct combo of lighting (see below)
    There is no long coding helper for my 09 module, but based on the threads above I *believe* I need to change Byte 2 from 1C to 1D. (Specifically, in the other Ross-Tech thread the user had full LED headlights on an S3 and this was the coding difference, and same thing in the audi-sport.net thread.)
    After making these changes, selecting high beam assist in the MMI, and pushing the signal stalk to activate high beam assist, I get an error on the dash display: "High Beam Assist: System Fault". I've posted a scan below with the above changes made and error present. I've tried all combinations of bits 0-2 on byte 2 on module 9 with no success...and I've also tried changing the value in A5 to 01 - High Beam Assist (FLA), with no success there either. I'm noticing that 5F is throwing an error in the scan below, so wondering if there is coding that needs to happen in that module as well - but again, there is no map for my module.
    Any ideas?
    Thanks in advance!
    Friday,06,November,2015,19:50:39:40635
    VCDS Version: 15.7.1.0 (x64)
    Data version: 20150904
    VIN: WAUKFGFF0F113XXXX   License Plate:
    Mileage: 3243km-2015mi   Repair Order:
    Chassis Type: FF (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 3C 42 44 52 55 5F
              6C A5
    VIN: WAUKFGFF0F113XXXX   Mileage: 3243km-2015miles
    Address 01: Engine (J623-CNTC)       Labels: 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0006
       Revision: --H13---
       Coding: 0A1D00324466000F3000
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM20TFS0205G0906259A 001008
       ROD: EV_ECM20TFS0205G0906259A_AU37.rod
       VCID: 2C57BA6647958C5ED1-8078
       Part No SW: 0D9 300 012 K    HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H53 4515
       Revision: 05853104    Serial number: TFK01504051057
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021_AU37.rod
       VCID: 1E3360AE01296ECE4F-804A
       Part No SW: 3Q0 907 379 R    HW: 3Q0 907 379 G
       Component: ESC           H42 0711
       Revision: 00000000    Serial number: 60805000003091
       Coding: 13FF6A9234230A740178030381C629C8562C5080C08194B4184150588208
       ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
       VCID: 4999E3F2E827B976CA-801C
       Revision: 00021000    Serial number: 0365010490
       Coding: 030C0C
       ROD: EV_KessyHellaMQBAB_AU37.rod
       VCID: 3A7B8C3EBDC122EE53-806E
    Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
       Component: AC Automat    H13 0060
       Revision: 20027000    Serial number: 00000000620697
       Coding: 03000014010000000000000000001400
       VCID: 3365A11A9AABD3A690-8066
       Part No SW: 5Q0 937 085 AB    HW: 5Q0 937 085 AB
       Component: BCM MQBAB MNA H18 0137
       Serial number: 01011510000879
       Coding: 04151D46C04106FD41C04004511007A00800000000000000000000000000
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: 79F95332F847E9F61A-802C
       Slave 1:
       Component: WWS371 150413  042 0585
       Serial number:         150416172542
       Coding: 0A47F7
       Slave 2:
       Serial number: 23884850
       Coding: 07006C
       Slave 3:
       Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
       Serial number: 04 02 2015  00000303
       Serial number: 00000000000032249687
       Component: J245 PS73.404  H03 0004
       Serial number: 0000FST0008NYWP00000
       Coding: 101F00
    534549 - Databus
                        Reset counter: 10
                        Mileage: 3243 km
                        Date: 2015.11.06
                        Time: 15:45:54
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
       Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0051
       Revision: --------    Serial number: 39391509700601
       Coding: 0070151011
       ROD: EV_EPHVA18AU3700000_AU37.rod
       VCID: 428BF4DED5116A2E0B-8016
    Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
       Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
       Component: ACC Bosch MQB H05 0304
       Serial number: 23021503273588
       Coding: 01241701FE0339
       ROD: EV_ACCMRRBoschVW372_AU37.rod
       VCID: 387F963683CD30FEA5-806C
       Serial number: 003GCR01TSYL
       Coding: 9DCCFCC0000000005000001AC24800000065
       VCID: 479DE5CAFE334F06DC-8012
       Seat belt tensioner; left:
       Component: BeltPretRevFL  H36 0350
       Serial number: 34178311B16041571539
       Coding: 333135
       Seat belt tensioner; right:
       Component: BeltPretRevFR  H36 0350
       Serial number: 34178312B17041540136
       Coding: 333135
       Seat occupant detection; front passenger side:
       Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
       Serial number: 6940000Y150001AYK803
       Coding: 303230
       Subsystem 4 - Part No SW: -----------    HW: 480 001 304 15
       Serial number: 3570000000022D901414
       Subsystem 5 - Part No SW: -----------    HW: 480 001 304 15
       Serial number: 35800000000A34A01416
       Subsystem 6 - Part No SW: -----------    HW: 480 400 904 15
       Serial number: 3510002A51A87862A2E8
       Subsystem 7 - Part No SW: -----------    HW: 480 400 904 15
       Serial number: 3520002B31A87861C12$
       Subsystem 8 - Part No SW: -----------    HW: 480 402 502 15
       Serial number: 3550002AF1993FB293AQ
       Subsystem 9 - Part No SW: -----------    HW: 480 402 502 15
       Serial number: 3560002B11993FB363EG
       Part No SW: 8V0 953 521 ED    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 15041504220165
       Coding: E818
       ROD: EV_SMLSKLOMQB_AU37.rod
       VCID: 000F3ED69B9DB83E5D-8054
       Part No SW: 8V0 920 971 G    HW: 8V0 920 971 G
       Component: KOMBI         H02 4292
       Coding: 0BC518196F88D7050280E8001800000000000000
       VCID: 4189FBD2D017713612-8014
       Revision: --------    Serial number: 16041510800439
       Coding: 0101000830085A005B00021C180B00000001010000000000000000000000
       ROD: EV_GatewConti.rod
       VCID: 72EB641EA5319AAE5B-8026
       Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
       Serial number: 27 03 2015  C0094125
    Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
       Serial number: HA1-00017.03.15
       Coding: 0001
       ROD: EV_AllWheelContrHA1VW37X_AU21.rod
       VCID: 4683E8CEF939560E27-8012
       Revision: 00000000    Serial number: 15000092647005
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB_AU37.rod
       VCID: 3467A2069FA5D49E89-8060
    Address 3C: Lane Change (J769)       Labels: 5Q0-907-566.clb
       Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
       Component: SWA Master    H05 0071
       Serial number: 0363707495
       Coding: 030211
       ROD: EV_LaneChangAssis_AU37.rod
       Lane Change Assistant 2:
       Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
       Serial number: 230315BCL20716
       Coding: 005D1F205C00048000000003
       ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
       Component: EPS_MQB_ZFLS  126 1061
       Coding: 9102
       ROD: EV_SteerAssisMQB.rod
       VCID: 4385F1DACA0B632600-8016
       Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
       Serial number: 310315BCU1225A
       Coding: 005D17205E00048000000003
       ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
       Component: AFS-ECU       H01 0091
       Coding: 012A000123200400
       ROD: EV_HeadlRegulAFSMQBMLB_AU37.rod
       VCID: 3F8DFD2AA6E307C664-806A
       Coding: E00100
       Coding: E00100
       Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M
       Component: LeiMo links  H01 7050
       Coding: E00100
       Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M
       Component: LeiMo rechts  H01 7050
       Coding: E00100
       Part No SW: 8V0 035 038 B    HW: 8V0 035 038 B
       Component: MU-H-LNS-US   H43 0394
       Serial number: A302D0FB012316
       Coding: 017301020000000021220002041A00102F000125010001047E
       ROD: EV_MUHig6C3HBAS_AU37.rod
       Engine Control Module 2:
       Subsystem 1 - Part No SW: V03 959 800 ST    HW: -----------
       Component: NAR 2015/2016  --- 0044
       Seat Adjustment Driver Side:
       Component: DU High  H49 0014
       Serial number: AUZ8Z9FY202Y9Z
       Sound System:
       Subsystem 3 - Part No SW: 8V0 919 614 L    HW: 8V0 919 614 L
       Component: ControlUnit_H  H81 0816
       Serial number: C1000027021500030513
       Door Electronics Rear Left:
       Component: Gracenote  --- 3006
    6697 - Databus
                        Reset counter: 50
                        Mileage: 716 km
                        Date: 2015.07.16
                        Time: 13:17:22
    6667 - Optical Data Bus for Information Electronics 1
              U10CA 00 [008] - Intermittent Disruption
                        Fault Frequency: 16
                        Reset counter: 50
                        Mileage: 660 km
                        Date: 2015.07.11
                        Time: 12:34:42
    6937 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 50
                        Mileage: 2237 km
                        Date: 2015.09.21
                        Time: 11:46:11
    Address 6C: Back-up Cam. (J772)       Labels: 5Q0-907-441.clb
       Part No SW: 5Q0 907 441 A    HW: 5Q0 907 441 A
       Component: MQB RVC Mid   H07 0140
       Coding: 027300010201000300
       ASAM Dataset: EV_2CamSysRearPASE 006016
       ROD: EV_CamSysRearPANAAU914.rod
       VCID: 306FAE166BBDE8BEED-8064
    Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
       Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
       Component: MQB_MFK       H06 0052
       Serial number: 10000330712
       Coding: 0100020000010303000500010100000100
       ROD: EV_MFKBoschAU370_AU37.rod
       VCID: 3B75893AB2FB1BE648-806E
    2359296 - Databus
                        Reset counter: 10
                        Mileage: 3243 km
                        Date: 2015.11.06
                        Time: 15:43:16
    End-------------------------(Elapsed Time: 04:47)--------------------------
  2. Likes Uwe liked this post
  3. #2
    Jun 2015
    Disregard....I undid everything and did it all again (as suggested to an earlier poster who had a similar problem over on Briskoda), and it worked, no more errors!
  4. Likes Uwe, Dana liked this post
  5. #3
    Verified VCDS User cilitkas's Avatar
    May 2016
    LT
    hi, could you post a channel map of your 09 bcm module?
    doing full led conversion on mine and its only info im missing.
    thanks.
  6. #4
    Verified VCDS User lala30's Avatar
    Mar 2015
    Croatia
    for LED light
    ECU 9 Byte 02, bit 0 selected, bit 1 unselected, bit 02 selected,
    see first post with high beam Octavia RS 2014
    second post
    my car Audi A3 2014 adapted log :
    full led with HIGH beam asist with rear dynamic light from FL ....
    Mar 2015
    Croatia
    octavia RS with HIGH beam
    SW:5Q0-937-084-AJ   HW:5Q0-937-084-AJ ---  Cent. Elect.
    	Component:BCM MQBAB H   H18 0137, Coding:0C000A46C24722FB47E04000001807280000000000000000000000000000
    	EV_BCMCONTI,013000,EV_BCMBOSCH_013_SK37.rod
    	Saturday,01,October,2016,12:30:00:14216
    	VCDS Version: Release 16.8.2 (x64)  Data version: 20160926 DS261.0
    	VCID: 000F5E809B348B42B4-8054
    IDE00001-ENG99061-Production mode-Access control,not active
    IDE00001-ENG115730-Production mode-Aussenbeleuchtung,not active
    IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active
    IDE00001-ENG112304-Production mode-Heckwischer,not active
    IDE00001-ENG98647-Production mode-Interior lighting,not active
    IDE00001-ENG115729-Production mode-Scheinwerferreinigung,not active
    IDE00001-ENG115731-Production mode-Virtuel_pedal,not active
    IDE00002-Transport mode,active
    IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,not active
    IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10
    IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active
    IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active
    IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active
    IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active
    IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating
    IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active
    IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,2000 ms
    IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,1100 ms
    IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms
    IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms
    IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,600 ms
    IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active
    IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active
    IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,active
    IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,0
    IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active
    IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,active
    IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active
    IDE01550-Service position,166.51 °
    IDE02152-Characteristics in production mode,2000 ms
    IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate
    IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,not active
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,kurz
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,not active
    IDE02332-Deactivate production mode,0
    IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active
    IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active
    IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken,not active
    IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,not active
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,not active
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active
    IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,20 %
    IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,40 %
    IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,40 %
    IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled
    IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed
    IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.25 °
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.00 %/s
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,double sided
    IDE03638-ENG116675-static AFS light-Lower speed threshold,0.00 km/h
    IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.00 °C
    IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.00 °C
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,90 °
    IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.00 °C
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,30 °
    IDE03638-ENG116676-static AFS light-Upper speed threshold,40.00 km/h
    IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119
    IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte
    IDE04923-ENG115774-Turn signal control-Komfortblinken,active
    IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,3
    IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,SMLS
    IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled
    IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active
    IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active
    IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.10
    IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,20.00 %
    IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,50 km/h
    IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,50 km/h
    IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung
    IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active
    IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig
    IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren
    IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h
    IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided
    IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active
    IDE04924-ENG126816-Driving light and parking light-Standlicht aus,active
    IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active
    IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active
    IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen
    IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min
    IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam
    IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic
    IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door
    IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,46400 lx
    IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx
    IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled
    IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 s
    IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,10 s
    IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active
    IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active
    IDE04927-IDE01446-Window heater-Running time of heated front window,600 s
    IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C
    IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C
    IDE04927-ENG126845-Window heater-FSH Automatik,active
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,not active
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,not active
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active
    IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active
    IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme
    IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung
    IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active
    IDE05142-ENG116621-Access control-automatisches Entriegeln,active
    IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active
    IDE05142-ENG116706-Access control-Autounlock NAR,not active
    IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active
    IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,active
    IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active
    IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active
    IDE05142-ENG115722-Access control-Elektrische Laderaumabdeckung,not active
    IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active
    IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active
    IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active
    IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active
    IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active
    IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active
    IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active
    IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active
    IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable
    IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active
    IDE05142-ENG115755-Access control-Notschließfunktion,active
    IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,active
    IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active
    IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,Always
    IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden,Always
    IDE05142-ENG115758-Access control-Valet Parking,not active
    IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe,not active
    IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active
    IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active
    IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active
    IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active
    IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Globale Entriegelung
    IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active
    IDE05144-Read parameter address,00 00 00
    IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34
    IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E
    IDE05145-ENG116063-Light configuration-BAP Bitposition 10,37
    IDE05145-ENG116082-Light configuration-BAP Bitposition 11,41
    IDE05145-ENG116101-Light configuration-BAP Bitposition 12,38
    IDE05145-ENG116120-Light configuration-BAP Bitposition 13,42
    IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00
    IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00
    IDE05145-ENG116177-Light configuration-BAP Bitposition 16,35
    IDE05145-ENG116196-Light configuration-BAP Bitposition 17,3F
    IDE05145-ENG116215-Light configuration-BAP Bitposition 18,08
    IDE05145-ENG116234-Light configuration-BAP Bitposition 19,18
    IDE05145-ENG115911-Light configuration-BAP Bitposition 2,48
    IDE05145-ENG116253-Light configuration-BAP Bitposition 20,09
    IDE05145-ENG116272-Light configuration-BAP Bitposition 21,19
    IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29
    IDE05145-ENG116310-Light configuration-BAP Bitposition 23,0A
    IDE05145-ENG116329-Light configuration-BAP Bitposition 24,1A
    IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28
    IDE05145-ENG116367-Light configuration-BAP Bitposition 26,0C
    IDE05145-ENG116386-Light configuration-BAP Bitposition 27,1C
    IDE05145-ENG116405-Light configuration-BAP Bitposition 28,0B
    IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B
    IDE05145-ENG115930-Light configuration-BAP Bitposition 3,4C
    IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00
    IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00
    IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00
    IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00
    IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00
    IDE05145-ENG115949-Light configuration-BAP Bitposition 4,3A
    IDE05145-ENG115968-Light configuration-BAP Bitposition 5,44
    IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36
    IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40
    IDE05145-ENG116025-Light configuration-BAP Bitposition 8,38
    IDE05145-ENG116044-Light configuration-BAP Bitposition 9,42
    IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize
    IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize
    IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize
    IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize
    IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize
    IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize
    IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize
    IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize
    IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize
    IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize
    IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize
    IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize
    IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,maximize
    IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize
    IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize
    IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize
    IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize
    IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize
    IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize
    IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize
    IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize
    IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize
    IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize
    IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,maximize
    IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize
    IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize
    IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize
    IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize
    IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize
    IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,maximize
    IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,maximize
    IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize
    IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize
    IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize
    IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize
    IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize
    IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize
    IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize
    IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize
    IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize
    IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize
    IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize
    IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize
    IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize
    IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize
    IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize
    IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize
    IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize
    IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize
    IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize
    IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize
    IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize
    IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,maximize
    IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize
    IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize
    IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize
    IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize
    IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize
    IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize
    IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize
    IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize
    IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize
    IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize
    IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize
    IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize
    IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize
    IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize
    IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize
    IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize
    IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize
    IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize
    IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize
    IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize
    IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize
    IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize
    IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize
    IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize
    IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize
    IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize
    IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize
    IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize
    IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize
    IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,maximize
    IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize
    IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize
    IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize
    IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize
    IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize
    IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize
    IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize
    IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize
    IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize
    IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize
    IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,maximize
    IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize
    IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize
    IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize
    IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize
    IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize
    IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize
    IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize
    IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize
    IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize
    IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize
    IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize
    IDE05145-ENG115878-Light configuration-Dimmwert AB 0,100
    IDE05145-ENG115897-Light configuration-Dimmwert AB 1,100
    IDE05145-ENG116067-Light configuration-Dimmwert AB 10,127
    IDE05145-ENG116086-Light configuration-Dimmwert AB 11,127
    IDE05145-ENG116105-Light configuration-Dimmwert AB 12,100
    IDE05145-ENG116124-Light configuration-Dimmwert AB 13,100
    IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0
    IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0
    IDE05145-ENG116181-Light configuration-Dimmwert AB 16,100
    IDE05145-ENG116200-Light configuration-Dimmwert AB 17,100
    IDE05145-ENG116219-Light configuration-Dimmwert AB 18,100
    IDE05145-ENG116238-Light configuration-Dimmwert AB 19,100
    IDE05145-ENG115915-Light configuration-Dimmwert AB 2,35
    IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100
    IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100
    IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100
    IDE05145-ENG116314-Light configuration-Dimmwert AB 23,100
    IDE05145-ENG116333-Light configuration-Dimmwert AB 24,100
    IDE05145-ENG116352-Light configuration-Dimmwert AB 25,100
    IDE05145-ENG116371-Light configuration-Dimmwert AB 26,100
    IDE05145-ENG116390-Light configuration-Dimmwert AB 27,0
    IDE05145-ENG116409-Light configuration-Dimmwert AB 28,100
    IDE05145-ENG116428-Light configuration-Dimmwert AB 29,100
    IDE05145-ENG115934-Light configuration-Dimmwert AB 3,35
    IDE05145-ENG116447-Light configuration-Dimmwert AB 30,0
    IDE05145-ENG116466-Light configuration-Dimmwert AB 31,100
    IDE05145-ENG116485-Light configuration-Dimmwert AB 32,100
    IDE05145-ENG116504-Light configuration-Dimmwert AB 33,100
    IDE05145-ENG116523-Light configuration-Dimmwert AB 34,100
    IDE05145-ENG115953-Light configuration-Dimmwert AB 4,127
    IDE05145-ENG115972-Light configuration-Dimmwert AB 5,127
    IDE05145-ENG115991-Light configuration-Dimmwert AB 6,127
    IDE05145-ENG116010-Light configuration-Dimmwert AB 7,127
    IDE05145-ENG116029-Light configuration-Dimmwert AB 8,100
    IDE05145-ENG116048-Light configuration-Dimmwert AB 9,100
    IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0
    IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0
    IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0
    IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0
    IDE05145-ENG116109-Light configuration-Dimmwert CD 12,0
    IDE05145-ENG116128-Light configuration-Dimmwert CD 13,0
    IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0
    IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0
    IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0
    IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0
    IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0
    IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0
    IDE05145-ENG115919-Light configuration-Dimmwert CD 2,35
    IDE05145-ENG116261-Light configuration-Dimmwert CD 20,0
    IDE05145-ENG116280-Light configuration-Dimmwert CD 21,0
    IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0
    IDE05145-ENG116318-Light configuration-Dimmwert CD 23,100
    IDE05145-ENG116337-Light configuration-Dimmwert CD 24,100
    IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0
    IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0
    IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0
    IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0
    IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0
    IDE05145-ENG115938-Light configuration-Dimmwert CD 3,35
    IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0
    IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0
    IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0
    IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0
    IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0
    IDE05145-ENG115957-Light configuration-Dimmwert CD 4,127
    IDE05145-ENG115976-Light configuration-Dimmwert CD 5,127
    IDE05145-ENG115995-Light configuration-Dimmwert CD 6,127
    IDE05145-ENG116014-Light configuration-Dimmwert CD 7,127
    IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0
    IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0
    IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0
    IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0
    IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0
    IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0
    IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0
    IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0
    IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0
    IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0
    IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0
    IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0
    IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0
    IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0
    IDE05145-ENG115923-Light configuration-Dimmwert EF 2,100
    IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0
    IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0
    IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0
    IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0
    IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0
    IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0
    IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0
    IDE05145-ENG116398-Light configuration-Dimmwert EF 27,0
    IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0
    IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0
    IDE05145-ENG115942-Light configuration-Dimmwert EF 3,100
    IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0
    IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0
    IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0
    IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0
    IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0
    IDE05145-ENG115961-Light configuration-Dimmwert EF 4,127
    IDE05145-ENG115980-Light configuration-Dimmwert EF 5,127
    IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0
    IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0
    IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0
    IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0
    IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0
    IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0
    IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0
    IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0
    IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0
    IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0
    IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0
    IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0
    IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0
    IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0
    IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0
    IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0
    IDE05145-ENG115927-Light configuration-Dimmwert GH 2,0
    IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0
    IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0
    IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0
    IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0
    IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0
    IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0
    IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0
    IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0
    IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0
    IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0
    IDE05145-ENG115946-Light configuration-Dimmwert GH 3,0
    IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0
    IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0
    IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0
    IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0
    IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0
    IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0
    IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0
    IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0
    IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0
    IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0
    IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0
    IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14
    IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15
    IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,1E
    IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,1F
    IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,22
    IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,23
    IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00
    IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00
    IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,17
    IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,19
    IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,16
    IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,18
    IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,4A
    IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,2B
    IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,2D
    IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C
    IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,29
    IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,2A
    IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30
    IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,2E
    IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,2F
    IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,31
    IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32
    IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,4C
    IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,00
    IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,03
    IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,04
    IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,05
    IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,06
    IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,49
    IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,4B
    IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A
    IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B
    IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,24
    IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,25
    IDE05145-ENG115873-Light configuration-Lasttyp 0,12 - Blinkleuchten
    IDE05145-ENG115892-Light configuration-Lasttyp 1,12 - Blinkleuchten
    IDE05145-ENG116062-Light configuration-Lasttyp 10,2 - Shutter: Diagnosesensierung für 'LED low'
    IDE05145-ENG116081-Light configuration-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low'
    IDE05145-ENG116100-Light configuration-Lasttyp 12,10 - allgemeine Scheinwerfer
    IDE05145-ENG116119-Light configuration-Lasttyp 13,10 - allgemeine Scheinwerfer
    IDE05145-ENG116138-Light configuration-Lasttyp 14,not active
    IDE05145-ENG116157-Light configuration-Lasttyp 15,not active
    IDE05145-ENG116176-Light configuration-Lasttyp 16,8 - allgemeine Glühlampe 12W
    IDE05145-ENG116195-Light configuration-Lasttyp 17,8 - allgemeine Glühlampe 12W
    IDE05145-ENG116214-Light configuration-Lasttyp 18,12 - Blinkleuchten
    IDE05145-ENG116233-Light configuration-Lasttyp 19,12 - Blinkleuchten
    IDE05145-ENG115910-Light configuration-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal
    IDE05145-ENG116252-Light configuration-Lasttyp 20,34 - LED Bremsleuchten
    IDE05145-ENG116271-Light configuration-Lasttyp 21,34 - LED Bremsleuchten
    IDE05145-ENG116290-Light configuration-Lasttyp 22,34 - LED Bremsleuchten
    IDE05145-ENG116309-Light configuration-Lasttyp 23,32 - allgemeine LED bis 12W
    IDE05145-ENG116328-Light configuration-Lasttyp 24,32 - allgemeine LED bis 12W
    IDE05145-ENG116347-Light configuration-Lasttyp 25,18 - 2* 5W
    IDE05145-ENG116366-Light configuration-Lasttyp 26,9 - allgemeine Glühlampe 27W: auch H15
    IDE05145-ENG116385-Light configuration-Lasttyp 27,9 - allgemeine Glühlampe 27W: auch H15
    IDE05145-ENG116404-Light configuration-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15
    IDE05145-ENG116423-Light configuration-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15
    IDE05145-ENG115929-Light configuration-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal
    IDE05145-ENG116442-Light configuration-Lasttyp 30,not active
    IDE05145-ENG116461-Light configuration-Lasttyp 31,not active
    IDE05145-ENG116480-Light configuration-Lasttyp 32,not active
    IDE05145-ENG116499-Light configuration-Lasttyp 33,not active
    IDE05145-ENG116518-Light configuration-Lasttyp 34,not active
    IDE05145-ENG115948-Light configuration-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung
    IDE05145-ENG115967-Light configuration-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung
    IDE05145-ENG115986-Light configuration-Lasttyp 6,3 - Xenon Abblendlicht
    IDE05145-ENG116005-Light configuration-Lasttyp 7,3 - Xenon Abblendlicht
    IDE05145-ENG116024-Light configuration-Lasttyp 8,10 - allgemeine Scheinwerfer
    IDE05145-ENG116043-Light configuration-Lasttyp 9,10 - allgemeine Scheinwerfer
    IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always
    IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always
    IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always
    IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always
    IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always
    IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always
    IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always
    IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always
    IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,Always
    IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,Always
    IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always
    IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always
    IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always
    IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always
    IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always
    IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always
    IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always
    IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always
    IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always
    IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,Always
    IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,Always
    IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,Always
    IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,Always
    IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always
    IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always
    IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always
    IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always
    IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always
    IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always
    IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always
    IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always
    IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always
    IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always
    IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always
    IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always
    IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17,10
    IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13,0
    IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2
    IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4
    IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,13
    IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,14
    IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,18
    IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,19
    IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0
    IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0
    IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,8
    IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,8
    IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2
    IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4
    IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,8
    IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,24
    IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,24
    IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24
    IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,8
    IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,8
    IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8
    IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,26
    IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,0
    IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,25
    IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25
    IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,8
    IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,0
    IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,45
    IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,46
    IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,47
    IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,48
    IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,8
    IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,8
    IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11
    IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12
    IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,18
    IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,19
    IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0
    IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0
    IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,15
    IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,15
    IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,0
    IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,0
    IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0
    IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0
    IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,9
    IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0
    IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0
    IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,9
    IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0
    IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0
    IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0
    IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,9
    IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,10
    IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,30
    IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0
    IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0
    IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0
    IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0
    IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,10
    IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0
    IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0
    IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0
    IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0
    IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0
    IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,9
    IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,10
    IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,15
    IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,15
    IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,0
    IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,0
    IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,0
    IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,0
    IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0
    IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0
    IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,0
    IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0
    IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0
    IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,0
    IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,0
    IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,0
    IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,0
    IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,30
    IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,0
    IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,0
    IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0
    IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,30
    IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,30
    IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0
    IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0
    IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0
    IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,0
    IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0
    IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,30
    IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0
    IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0
    IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0
    IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0
    IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0
    IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,30
    IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,30
    IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,30
    IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,30
    IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0
    IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0
    IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0
    IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0
    IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0
    IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0
    IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0
    IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0
    IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0
    IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0
    IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0
    IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0
    IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0
    IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0
    IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0
    IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,0
    IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,0
    IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0
    IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,0
    IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,0
    IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0
    IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0
    IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0
    IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0
    IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0
    IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0
    IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0
    IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0
    IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0
    IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0
    IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0
    IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,0
    IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,0
    IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0
    IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0
    IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0
    IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0
    IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0
    IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0
    IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0
    IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0
    IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0
    IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0
    IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0
    IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0
    IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0
    IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0
    IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0
    IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0
    IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,20
    IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,30
    IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,30
    IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0
    IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,0
    IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,0
    IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0
    IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0
    IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,0
    IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0
    IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0
    IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,20
    IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0
    IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0
    IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0
    IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0
    IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0
    IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,20
    IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,20
    IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0
    IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0
    IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0
    IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0
    IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0
    IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0
    IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0
    IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0
    IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0
    IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0
    IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0
    IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0
    IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0
    IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0
    IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0
    IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0
    IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,0
    IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0
    IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0
    IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0
    IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0
    IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0
    IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0
    IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0
    IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0
    IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0
    IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0
    IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0
    IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0
    IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0
    IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0
    IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0
    IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,0
    IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0
    IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0
    IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0
    IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0
    IDE05145-ENG115941-Light configuration-Lichtfunktion F3,0
    IDE05145-ENG115979-Light configuration-Lichtfunktion F5,0
    IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0
    IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0
    IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0
    IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0
    IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0
    IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0
    IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0
    IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0
    IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0
    IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0
    IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0
    IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0
    IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,0
    IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0
    IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0
    IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0
    IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0
    IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0
    IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0
    IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0
    IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0
    IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0
    IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0
    IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,0
    IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0
    IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0
    IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0
    IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0
    IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0
    IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0
    IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0
    IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0
    IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0
    IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0
    IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0
    IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0
    IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0
    IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0
    IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0
    IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0
    IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0
    IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0
    IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0
    IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0
    IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0
    IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0
    IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0
    IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0
    IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0
    IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0
    IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0
    IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0
    IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0
    IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0
    IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0
    IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0
    IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0
    IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0
    IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0
    IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0
    IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0
    IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0
    IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0
    IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0
    IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0
    IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0
    IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0
    IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0
    IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0
    IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,30 s
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,1.10 °C
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,33.00 °C
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,32.00 °C
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,33.00 °C
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,32.00 °C
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,37.50 °C
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,36.50 °C
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,37.50 °C
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,36.50 °C
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,41.00 °C
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,40.00 °C
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,41.00 °C
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,40.00 °C
    IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active
    IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active
    IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,active
    IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active
    IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active
    IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,60 %
    IDE06425-Roller test bench mode: functional,not active
    IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights
    IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active
    IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active
    IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active
    IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active
    IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active
    IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active
    IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active
    IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active
    IDE07356-Position during interval mode,25.51 °
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min
    IDE08542-IDE02021-Access control 2-Comfort closing,active
    IDE08542-IDE02022-Access control 2-Comfort opening,active
    IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active
    IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active
    IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s
    IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active
    IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active
    IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active
    IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active
    IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,active
    IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key
    IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,not active
    IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,active
    IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,not active
    IDE08542-ENG115670-Access control 2-Komfortbedienung global,active
    IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active
    IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active
    IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable
    IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active
    IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,active
    IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,active
    IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active
    IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,not active
    IDE08542-ENG125656-Access control 2-Regenschliessen_art,once
    IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,not active
    IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,not active
    IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active
    IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active
    IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,not active
    IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting
    IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,active
    IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active
    IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,active
    IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,active
    IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,active
    IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active
    IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active
    IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,2000 ms
    IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active
    IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach,not active
    IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis
    IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,active
    IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms
    IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active
    IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present
    IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,Not Present
    IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active
    IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,not active
    IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active
    IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active
    IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active
    IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active
    IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active
    IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active
    IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active
    IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active
    IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken,not active
    IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active
    IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active
    IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active
    IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active
    IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active
    IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active
    IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active
    IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active
    IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active
    IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active
    IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active
    IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active
    IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active
    IDE09595-ENG115658-Characteristic curve-x0,0 lx
    IDE09595-ENG101574-Characteristic curve-X1,2000 lx
    IDE09595-ENG99557-Characteristic curve-X2,4000 lx
    IDE09595-ENG102140-Characteristic curve-X3,6000 lx
    IDE09595-ENG102936-Characteristic curve-X4,8000 lx
    IDE09595-ENG103548-Characteristic curve-X5,10200 lx
    IDE09595-ENG17883-Characteristic curve-y1_0,0
    IDE09595-ENG17884-Characteristic curve-y1_1,40
    IDE09595-ENG17885-Characteristic curve-y1_2,90
    IDE09595-ENG17886-Characteristic curve-y1_3,140
    IDE09595-ENG17887-Characteristic curve-y1_4,190
    IDE09595-ENG17888-Characteristic curve-y1_5,245
    IDE09595-ENG17889-Characteristic curve-y2_0,0
    IDE09595-ENG17890-Characteristic curve-y2_1,60
    IDE09595-ENG17891-Characteristic curve-y2_2,110
    IDE09595-ENG17892-Characteristic curve-y2_3,160
    IDE09595-ENG17893-Characteristic curve-y2_4,210
    IDE09595-ENG17894-Characteristic curve-y2_5,255
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.25 s
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1
    IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1,225
    IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2,225
    IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3,225
    IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active
    IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %
    IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active
    IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active
    IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active
    IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active
    IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active
    IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1,225
    IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2,225
    IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3,225
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active
    IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active
    IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active
    IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active
    IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active
    IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active
    IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active
    IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active
    IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1,225
    IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2,225
    IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3,225
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed
    IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed
    IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed
    IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed
    IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,not installed
    IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active
    IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed
    IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed
    IDE09733-ENG16335-LED bar setting values-Filterzeit Anpassung,3000 ms
    IDE09733-ENG16334-LED bar setting values-Filterzeit Umgebungshelligkeit,1000 ms
    IDE09733-ENG17895-LED bar setting values-Maximale Dauer fuer konstante Anzeige,0 s
    IDE09733-ENG17896-LED bar setting values-Maximale Helligkeitsdifferenz,25
    IDE09733-ENG17899-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor,0
    IDE09733-ENG17897-LED bar setting values-Schwellwert Plausibilisierung RLS,393210 lx
    IDE09733-ENG17898-LED bar setting values-Schwellwert Plausibilisierung SLS,393210 lx
    IDE09733-ENG16333-LED bar setting values-Sperrzeit,0 s
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %
    IDE10298-Alternating park position 1,8.51 °
    IDE10299-Alternating park position 2,22.51 °
    MAS05055-lower turn position,25.51 °
    MAS05056-upper turn position,166.51 °
    MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active
    MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active
    MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active
    MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active
    MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active
    MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active
    MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active
    MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active
    MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active
    MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active
    MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active
    MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active
    MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active
    MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active
    MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,not active
    ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00
    ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00
    ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00
    ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00
    ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00
    ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00
    ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00
    ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00
    ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00
    ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00
    ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00
    ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00
    ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00
    ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00
    ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00
    ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door
    ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door
    ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door
    ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door
    ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door
    ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door
    ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door
    ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door
    ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door
    ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door
    ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door
    ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door
    ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door
    ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door
    ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door
    ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1,not installed
    ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10,not installed
    ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11,not installed
    ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12,not installed
    ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13,not installed
    ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14,not installed
    ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15,not installed
    ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed
    ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3,not installed
    ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4,not installed
    ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5,not installed
    ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6,not installed
    ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7,not installed
    ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8,not installed
    ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9,not installed
    ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12,0
    ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0
    ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10,0
    ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11,0
    ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13,0
    ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14,0
    ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15,0
    ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16,0
    ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17,0
    ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18,0
    ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19,0
    ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0
    ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20,0
    ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0
    ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0
    ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5,0
    ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6,0
    ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7,0
    ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8,0
    ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9,0
    ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,0
    ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10,0
    ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11,0
    ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12,0
    ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13,0
    ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14,0
    ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15,0
    ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16,0
    ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17,0
    ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18,0
    ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19,0
    ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0
    ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20,0
    ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0
    ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0
    ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5,0
    ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6,0
    ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7,0
    ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9,0
    ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8,0
    ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed
    ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10,not installed
    ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11,not installed
    ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12,not installed
    ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13,not installed
    ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14,not installed
    ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15,not installed
    ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16,not installed
    ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17,not installed
    ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18,not installed
    ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19,not installed
    ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed
    ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20,not installed
    ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed
    ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed
    ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5,not installed
    ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6,not installed
    ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7,not installed
    ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9,not installed
    ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8,not installed
    ENG126647-ENG98399-debug_light_function-Activation,0
    ENG126647-ENG101417-debug_light_function-Adresse,0
    ENG126647-ENG126820-debug_light_function-Bitmask,0
    ENG126647-ENG126821-debug_light_function-Divisor,0
    ENG126647-ENG98827-debug_light_function-Offset,0
    ENG126647-ENG126822-debug_light_function-Polaritaet,0
    ENG126647-ENG126823-debug_light_function-WBT-Ausgabe,0
    ENG99457-ENG117394-Head area heater-blower_speed,1
    ENG99457-ENG98971-Head area heater-Temperature,-2
    ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms
    ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms
    ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms
    ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms
    ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms
    ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms
    ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms
    ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms
    ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms
    ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms
    ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms
    ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.00 %
    ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,100.00 %
    ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.00 %
    ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,95.00 %
    ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,80.00 %
    ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,40.00 %
    ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,20.00 %
    ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,10.00 %
    ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,5.00 %
    ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,3.00 %
    ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,1.00 %
    ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0
    ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50
    ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0
    ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100
    ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200
    ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253
    ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0
    ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0
    ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0
    ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0
    ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0
    ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx
    ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx
    ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx
    ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx
    ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200
    ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500
    ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0
    ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx
    ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx
    ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx
    ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx
    ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms
    ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms
    ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms
    ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms
    ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms
    ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms
    ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms
    ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms
    ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms
    ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms
    ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms
    ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.00 %
    ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.00 %
    ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.00 %
    ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.00 %
    ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.00 %
    ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.00 %
    ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.00 %
    ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.00 %
    ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.00 %
    ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.00 %
    ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.00 %
    ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %
    ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %
    ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %
    ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %
    ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %
    ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %
    ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10
    ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10
    ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100
    ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150
    ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220
    ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253
    ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx
    ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx
    ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx
    ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx
    ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx
    ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.00
    ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.00
    ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.00
    ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.00
    ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.00
    ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx
    ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx
    ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx
    ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx
    ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx
    ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.00
    ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.00
    ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.00
    ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.00
    ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.00
    ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0
    ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10
    ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50
    ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100
    ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220
    ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253
    ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,2.00 %
    ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,2.00 %
    ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,6.00 %
    ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,10.00 %
    ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,80.00 %
    ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %
    ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx
    ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx
    ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx
    ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx
    ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.00
    ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.00
    ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.00
    ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.00
    ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx
    ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx
    ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx
    ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,510 lx
    ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.00
    ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.00
    ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.00
    ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.00
    ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.00 %
    ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.00 %
    ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.00 %
    ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.00 %
    ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %
    ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %
    ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx
    ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx
    ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx
    ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx
    ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.00
    ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.00
    ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.00
    ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.00
    ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx
    ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx
    ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx
    ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx
    ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.00
    ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.00
    ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.00
    ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.00
    ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.00 %
    ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.00 %
    ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.00 %
    ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.00 %
    ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %
    ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %
    ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms
    ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,2000 ms
    ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,3000 ms
    ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,4000 ms
    ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,5100 ms
    ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %
    ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00
    ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00
    ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,40.00
    ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00
    ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0,maximize
    ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0,maximize
    ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0,maximize
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100
    ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0,0
    ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0,0
    ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0,0
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten
    ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0,Always
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase
    ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0,not active
    ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,not active
    ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0,not active
    ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0,not active
    ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0,not active
    ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0,not active
    ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0,not active
    ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10,maximize
    ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10,maximize
    ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10,maximize
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,127
    ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10,0
    ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10,0
    ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10,0
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,1E
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,37
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,2 - Shutter: Diagnosesensierung für 'LED low'
    ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10,Always
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,Left high beam
    ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10,Lichthupe generell
    ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10,not active
    ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10,not active
    ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10,not active
    ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10,not active
    ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10,not active
    ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10,not active
    ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11,maximize
    ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11,maximize
    ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11,maximize
    ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11,127
    ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11,0
    ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11,0
    ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11,0
    ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,1F
    ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,41
    ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low'
    ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11,Always
    ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11,Right high beam
    ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11,Lichthupe generell
    ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11,not active
    ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11,not active
    ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11,not active
    ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11,not active
    ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11,not active
    ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11,not active
    ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12,maximize
    ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12,maximize
    ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12,maximize
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100
    ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12,0
    ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12,0
    ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12,0
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer
    ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12,Always
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active
    ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12,not active
    ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12,not active
    ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12,not active
    ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12,not active
    ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12,not active
    ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12,not active
    ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13,maximize
    ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13,maximize
    ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13,maximize
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100
    ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13,0
    ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13,0
    ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13,0
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer
    ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13,Always
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active
    ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13,not active
    ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13,not active
    ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13,not active
    ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13,not active
    ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13,not active
    ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13,not active
    ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize
    ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize
    ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize
    ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0
    ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0
    ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0
    ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0
    ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00
    ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00
    ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active
    ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always
    ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active
    ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active
    ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active
    ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active
    ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active
    ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active
    ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active
    ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active
    ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16,maximize
    ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16,maximize
    ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16,maximize
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,100
    ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16,0
    ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16,0
    ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16,0
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,17
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,35
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,8 - allgemeine Glühlampe 12W
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Parklicht links (beidseitiges Parklicht aktiviert li & re)
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active
    ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16,not active
    ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16,not active
    ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16,not active
    ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16,not active
    ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16,not active
    ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17,maximize
    ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17,maximize
    ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17,maximize
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,100
    ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17,0
    ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17,0
    ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17,0
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,19
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,3F
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,8 - allgemeine Glühlampe 12W
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Parking light right
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active
    ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17,not active
    ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17,not active
    ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17,not active
    ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17,not active
    ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17,not active
    ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18,maximize
    ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18,maximize
    ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18,maximize
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100
    ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18,0
    ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18,0
    ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18,0
    ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,16
    ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,08
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,12 - Blinkleuchten
    ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18,Always
    ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,Blinken links Hellphase
    ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18,not active
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active
    ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18,not active
    ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18,not active
    ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18,not active
    ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18,not active
    ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18,not active
    ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19,maximize
    ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19,maximize
    ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19,maximize
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100
    ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19,0
    ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19,0
    ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19,0
    ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,18
    ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,18
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,12 - Blinkleuchten
    ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19,Always
    ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,Blinken rechts Hellphase
    ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19,not active
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active
    ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19,not active
    ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19,not active
    ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19,not active
    ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19,not active
    ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19,not active
    ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1,maximize
    ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1,maximize
    ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1,maximize
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100
    ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1,0
    ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1,0
    ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1,0
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten
    ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1,Always
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase
    ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1,not active
    ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,not active
    ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1,not active
    ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1,not active
    ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1,not active
    ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1,not active
    ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1,not active
    ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20,maximize
    ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20,maximize
    ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20,maximize
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100
    ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,0
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0
    ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20,0
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,2B
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,09
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten
    ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20,Always
    ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake light
    ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,not active
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active
    ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,not active
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,Coming Home oder Leaving Home aktiv
    ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20,not active
    ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20,not active
    ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20,not active
    ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21,maximize
    ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21,maximize
    ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21,maximize
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100
    ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,0
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0
    ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21,0
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,2D
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,19
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten
    ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21,Always
    ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake light
    ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,not active
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active
    ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,not active
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Coming Home oder Leaving Home aktiv
    ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21,not active
    ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21,not active
    ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21,not active
    ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22,maximize
    ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22,maximize
    ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22,maximize
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100
    ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22,0
    ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22,0
    ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22,0
    ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22,2C
    ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22,29
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,34 - LED Bremsleuchten
    ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22,Always
    ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22,Brake light
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active
    ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22,not active
    ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22,not active
    ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22,not active
    ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22,not active
    ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22,not active
    ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22,not active
    ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23,maximize
    ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23,maximize
    ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23,maximize
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,100
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,100
    ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23,0
    ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23,0
    ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,29
    ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23,0A
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,32 - allgemeine LED bis 12W
    ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,Always
    ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re)
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Coming Home oder Leaving Home aktiv
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active
    ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,not active
    ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23,not active
    ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23,not active
    ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23,not active
    ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24,maximize
    ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24,maximize
    ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24,maximize
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,100
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,100
    ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24,0
    ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24,0
    ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,2A
    ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24,1A
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,32 - allgemeine LED bis 12W
    ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,Always
    ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Coming Home oder Leaving Home aktiv
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active
    ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24,not active
    ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24,not active
    ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24,not active
    ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24,not active
    ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25,maximize
    ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25,maximize
    ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25,maximize
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,100
    ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25,0
    ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25,0
    ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25,0
    ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25,30
    ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25,28
    ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25,18 - 2* 5W
    ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25,Always
    ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,Coming Home oder Leaving Home aktiv
    ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25,not active
    ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25,not active
    ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25,not active
    ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25,not active
    ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25,not active
    ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25,not active
    ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26,maximize
    ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26,maximize
    ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26,maximize
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100
    ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26,0
    ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26,0
    ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26,0
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2E
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0C
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,9 - allgemeine Glühlampe 27W: auch H15
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt
    ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26,not active
    ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26,not active
    ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26,not active
    ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26,not active
    ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26,not active
    ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26,not active
    ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26,not active
    ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,maximize
    ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27,maximize
    ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27,maximize
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0
    ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27,0
    ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27,0
    ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27,0
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,2F
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1C
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,9 - allgemeine Glühlampe 27W: auch H15
    ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,Always
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active
    ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27,not active
    ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,not active
    ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27,not active
    ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,not active
    ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27,not active
    ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27,not active
    ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27,not active
    ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28,maximize
    ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28,maximize
    ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28,maximize
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100
    ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28,0
    ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28,0
    ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28,0
    ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28,31
    ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28,0B
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always
    ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28,Rueckfahrlicht
    ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28,not active
    ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28,not active
    ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28,not active
    ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28,not active
    ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28,not active
    ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28,not active
    ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28,not active
    ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29,maximize
    ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29,maximize
    ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29,maximize
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,100
    ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29,0
    ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29,0
    ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29,0
    ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29,32
    ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29,1B
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always
    ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29,Rueckfahrlicht
    ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29,not active
    ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29,not active
    ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29,not active
    ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29,not active
    ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29,not active
    ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29,not active
    ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29,not active
    ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2,maximize
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize
    ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,maximize
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,35
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,35
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,100
    ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2,0
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal
    ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2,Always
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,Parklicht links (beidseitiges Parklicht aktiviert li & re)
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Coming Home oder Leaving Home aktiv
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Daytime running lights
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active
    ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,not active
    ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2,not active
    ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30,maximize
    ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30,maximize
    ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30,maximize
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,0
    ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30,0
    ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30,0
    ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30,0
    ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00
    ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30,00
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,not active
    ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30,Always
    ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,not active
    ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30,not active
    ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30,not active
    ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30,not active
    ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30,not active
    ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30,not active
    ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30,not active
    ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30,not active
    ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31,maximize
    ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31,maximize
    ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31,maximize
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,100
    ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31,0
    ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31,0
    ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31,0
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,03
    ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31,00
    ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31,not active
    ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31,Always
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,Ambientelicht 1
    ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31,not active
    ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31,not active
    ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31,not active
    ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31,not active
    ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31,not active
    ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31,not active
    ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31,not active
    ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32,maximize
    ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32,maximize
    ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32,maximize
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,100
    ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32,0
    ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32,0
    ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32,0
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,04
    ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32,00
    ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32,not active
    ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32,Always
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,Ambientelicht 2
    ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32,not active
    ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32,not active
    ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32,not active
    ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32,not active
    ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32,not active
    ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32,not active
    ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32,not active
    ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33,maximize
    ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33,maximize
    ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33,maximize
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,100
    ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33,0
    ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33,0
    ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33,0
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,05
    ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33,00
    ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33,not active
    ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33,Always
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,Ambientelicht 3
    ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33,not active
    ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33,not active
    ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33,not active
    ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33,not active
    ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33,not active
    ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33,not active
    ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33,not active
    ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34,maximize
    ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34,maximize
    ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34,maximize
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,100
    ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34,0
    ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34,0
    ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34,0
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,06
    ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34,00
    ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34,not active
    ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34,Always
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,Ambientelicht 4
    ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34,not active
    ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34,not active
    ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34,not active
    ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34,not active
    ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34,not active
    ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34,not active
    ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34,not active
    ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3,maximize
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize
    ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,maximize
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,35
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,35
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,100
    ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3,0
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal
    ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3,Always
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,Parking light right
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Coming Home oder Leaving Home aktiv
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Daytime running lights
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active
    ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3,not active
    ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3,not active
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize
    ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4,maximize
    ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4,maximize
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127
    ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,127
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,127
    ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4,0
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung
    ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4,Always
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4,Parklicht links (beidseitiges Parklicht aktiviert li & re)
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Coming Home oder Leaving Home aktiv
    ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4,not active
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Daytime running lights
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,not active
    ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4,not active
    ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4,not active
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize
    ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5,maximize
    ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5,maximize
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127
    ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,127
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,127
    ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5,0
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung
    ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5,Always
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
    ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5,Parking light right
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Coming Home oder Leaving Home aktiv
    ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5,not active
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Daytime running lights
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,not active
    ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5,not active
    ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5,not active
    ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6,maximize
    ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6,maximize
    ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6,maximize
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,127
    ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6,0
    ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6,0
    ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,1A
    ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6,36
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,3 - Xenon Abblendlicht
    ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6,Always
    ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6,Abblendlicht links
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,Coming Home oder Leaving Home aktiv
    ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6,not active
    ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6,not active
    ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6,not active
    ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6,not active
    ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6,not active
    ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7,maximize
    ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7,maximize
    ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7,maximize
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,127
    ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7,0
    ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7,0
    ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,1B
    ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7,40
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,3 - Xenon Abblendlicht
    ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7,Always
    ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7,Abblendlicht rechts
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,Coming Home oder Leaving Home aktiv
    ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7,not active
    ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7,not active
    ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7,not active
    ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7,not active
    ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7,not active
    ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8,maximize
    ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8,maximize
    ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8,maximize
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,100
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0
    ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8,0
    ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8,0
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,24
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,38
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,10 - allgemeine Scheinwerfer
    ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8,Always
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Nebellicht links
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,not active
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active
    ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8,not active
    ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8,not active
    ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8,not active
    ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8,not active
    ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9,maximize
    ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9,maximize
    ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9,maximize
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,100
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0
    ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9,0
    ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9,0
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,25
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,42
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,10 - allgemeine Scheinwerfer
    ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9,Always
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Nebellicht rechts
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,not active
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active
    ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9,not active
    ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9,not active
    ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9,not active
    ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9,not active
    ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize
    ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize
    ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize
    ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0
    ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0
    ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0
    ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0
    ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00
    ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00
    ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active
    ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always
    ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active
    ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active
    ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active
    ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active
    ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active
    ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active
    ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active
    ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active
    ENG126648-ENG17940-LIN-Mirrormode-Bitmaske,63
    ENG126648-ENG17792-LIN-Mirrormode-Stage,0
    ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.00 %
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.00 %
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.00 %
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.00 %
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.00
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.50
    ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.00 %
    ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.00 %
    ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.00 %
    ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.00 %
    ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.00 %
    ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.00 %
    ENG98831-ENG126849-Personalisierung-Aktivierungsoption_im_HMI-Menue_sichtbar,not active
    ENG98831-ENG126850-Personalisierung-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,not active
    ENG98831-ENG126848-Personalisierung-Personalisierung_aktiv,not active
    ENG98831-ENG126851-Personalisierung-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,not active
    ENG122976-ENG17819-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts,1
    ENG122976-ENG17804-Remote_Start_Adaption-RemoteStart Betrieb Dauer,1 min
    Elapsed Time: 01:59
  8. Likes Uwe liked this post
  9. #6
    Verified VCDS User lala30's Avatar
    Mar 2015
    Croatia
    Audi A3 8V 2014 full led ....
    SW:5Q0-937-084-AJ   HW:5Q0-937-084-AJ ---  Cent. Elect.
    	Component:BCM MQBAB H   H18 0134, Coding:04040D46C2410AFD43C06014B11807E80000000000000000000000000000
    	EV_BCMCONTI,013000,EV_BCMBOSCH_VW37.rod
    	Thursday,30,June,2016,11:10:14:14216
    	VCDS Version: Beta 16.6.0 (x64)  Data version: 20160602 DS251
    	VCID: 000F5E809B348B43D9-8054
    (5)-Production mode-Aussenbeleuchtung,not active
    (2)-Production mode-Frontwischer deaktivieren,not active
    (3)-Production mode-Heckwischer,not active
    (4)-Production mode-Innenbeleuchtung,not active
    (1)-Production mode-Scheinwerferreinigung,not active
    (7)-Production mode-Virtuel_pedal,not active
    (6)-Production mode-Zugangskontrolle,not active
    Transport mode,active
    (19)-Windshield wiper-Adaptives Nachwischen bei SRA,active
    (1)-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,8
    (14)-Windshield wiper-Frontwischer Notlaufprogramm,active
    (8)-Windshield wiper-Frontwischer Referenzlauf,not active
    (22)-Windshield wiper-Frontwischer_Abtauposition,not active
    (16)-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active
    (13)-Windshield wiper-Menuesteuerung Frontwischer,active
    (12)-Windshield wiper-Regensensor aktivieren,Deactivating
    (7)-Windshield wiper-SRA bei Waschwassermangel,active
    (4)-Windshield wiper-SRA Einweichpausenzeit,1000 ms
    (5)-Windshield wiper-SRA Nachwaschzeit,1000 ms
    (6)-Windshield wiper-SRA Pausenzeit,1000 ms
    (2)-Windshield wiper-SRA Verzoegerungszeit,1000 ms
    (3)-Windshield wiper-SRA Waschzeit,1000 ms
    (21)-Windshield wiper-Tippendes_Frontwaschen,not active
    (15)-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active
    (17)-Windshield wiper-Traenenwischen Front Status,active
    (9)-Windshield wiper-Variable Regensensoraktivierung,not active
    (18)-Windshield wiper-Washer_Tipwiping_Variant,0
    (11)-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active
    (10)-Windshield wiper-Wischer stop bei KL15 aus,not active
    (20)-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,active
    Service position,133.30 °
    Characteristics in production mode,2000 ms
    (4)-Acknowledgement signals-Optical feedback during locking,Decelerate
    (1)-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active
    (8)-Acknowledgement signals-Akustische Rueckmeldung global,not active
    (9)-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active
    (2)-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active
    (3)-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal
    (7)-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active
    (6)-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active
    (5)-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,not active
    (10)-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl,not active
    (11)-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,not active
    Deactivate production mode,0
    DWA Interior monitoring,100 %
    (3)-Rear Window Wiper-Automatisches Heckwischen,not active
    (13)-Rear Window Wiper-Einzelansteuerung Heckintervallwischen,not active
    (11)-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,0 s
    (12)-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,0.0 s
    (5)-Rear Window Wiper-Heckwischer Weiterlauf,not active
    (6)-Rear Window Wiper-Kein automatisches Abparken,not active
    (1)-Rear Window Wiper-Komfortwischen Heck,active
    (9)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,3 s
    (10)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,1 s
    (8)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,5 s
    (7)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,5 s
    (2)-Rear Window Wiper-Menuesteuerung Komfortwischen HW,not active
    (4)-Rear Window Wiper-Traenenwischen Heck,not active
    (1)-Ambient lighting-Defaultwert Ambienteprofil Fussraum,50 %
    (2)-Ambient lighting-Defaultwert Ambienteprofil Tuer,50 %
    (3)-Ambient lighting-Defaultwert Ambienteprofil Vorn,50 %
    (6)-Ambient lighting-Innenlichtinszenierung,not enabled
    (5)-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed
    (4)-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed
    (5)-static AFS light-Steering wheel angle	 offset,-0.25 °
    (8)-static AFS light-Abdimmgeschwindigkeit,50.00 %/s
    (1)-static AFS light-bei Rueckwaertsfahrt,OFF
    (9)-static AFS light-Maximaltemperatur,100.00 °C
    (4)-static AFS light-Obere Geschwindigkeitsschwelle,32.00 km/h
    (10)-static AFS light-obere Grenztemperatur,95.00 °C
    (7)-static AFS light-Oberer Lenkradwinkel,90 °
    (3)-static AFS light-Untere Geschwindigkeitsschwelle,0.00 km/h
    (11)-static AFS light-untere Grenztemperatur,80.00 °C
    (6)-static AFS light-Unterer Lenkradwinkel,30 °
    (2)-static AFS light-Vorschrift,OFF
    (10)-Turn signal control-Abbruch Komfortblinken,not active
    (5)-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte
    (7)-Turn signal control-Komfortblinken,active
    (2)-Turn signal control-Komfortblinken Blinkzyklen,3
    (4)-Turn signal control-Signalprioritaet fuer Blinker,SMLS
    (3)-Turn signal control-Sonderfunktionen,not enabled
    (1)-Turn signal control-Warnblinken bei Verdeckentriegelung,not active
    (6)-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active
    (9)-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.25
    (8)-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,1.00 %
    (13)-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h
    (12)-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h
    (1)-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,separate
    (9)-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active
    (10)-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig
    (11)-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung aktivieren
    (14)-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,60 km/h
    (4)-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided
    (2)-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active
    (3)-Driving light and parking light-Standlicht aus,active
    (5)-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active
    (7)-Driving light and parking light-Warnung Fahrt mit Standlicht,active
    (6)-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen
    (8)-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min
    (4)-Comfort illumination-Coming Home Leuchten,Low beam
    (1)-Comfort illumination-Coming Home Verbaustatus,automatic
    (5)-Comfort illumination-Coming-home Einschaltereignis,Driver door
    (10)-Comfort illumination-Helligkeitsschwelle Forward-Messung,6400 lx
    (6)-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx
    (7)-Comfort illumination-Leaving-Home Verbausstatus,Enabled
    (3)-Comfort illumination-Menueeinstellung Cominghome,20 s
    (9)-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,60 s
    (2)-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active
    (8)-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active
    (5)-Window heater-Running time of heated front window,600 s
    (7)-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C
    (6)-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C
    (3)-Window heater-FSH Automatik,not active
    (4)-Window heater-Heckscheibenheizung Zeitwert,600 s
    (2)-Window heater-Temperaturabhaengige Einschaltzeit FSH,not active
    (1)-Window heater-Temperaturabhaengige Einschaltzeit HSH,active
    (7)-Anti-theft device-Akustischer Alarm Signalhorn,not active
    (1)-Anti-theft device-Alarmsignal,frequency modulated
    (3)-Anti-theft device-DWA Alarmverzoegerung,driver door contact thatcham
    (4)-Anti-theft device-DWA Camper Modus,not active
    (6)-Anti-theft device-Sirenen Alarmzahl,1 Alarm
    (5)-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active
    (2)-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung
    (15)-Access control-Autolock Autounlock wirkt auf Heck,active
    (4)-Access control-automatisches Entriegeln,active
    (3)-Access control-automatisches Verriegeln bei Geschwindigkeit,active
    (25)-Access control-Autounlock NAR,not active
    (19)-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active
    (7)-Access control-CAN Wecken bei Softtouchbetaetigung,active
    (33)-Access control-Deaktivierung_Laderaumschliessung_extern,not active
    (29)-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active
    (12)-Access control-Direkter Auswurf des Heckdeckels,active
    (22)-Access control-Elektrische Laderaumabdeckung,not active
    (30)-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active
    (21)-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active
    (26)-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active
    (1)-Access control-Funk bei Klemme 15 ein,not active
    (5)-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active
    (10)-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active
    (32)-Access control-Heckfreigabe_Ohne_Verzoegerung,not active
    (34)-Access control-LS_Taster_Togglefunktion,not active
    (23)-Access control-Menuesteuerung Tuerentriegelung,active
    (24)-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable
    (37)-Access control-Mindestbetaetigung_HDF_Innentaster,0.00 s
    (14)-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,active
    (2)-Access control-Notschließfunktion,not active
    (35)-Access control-Nutzfahrzeug_Schliessung,not active
    (9)-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active
    (18)-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active
    (28)-Access control-Servoheck Schlossansteuerung,Immer
    (27)-Access control-Softtouch-Betaetigung senden,Immer
    (11)-Access control-Valet Parking,not active
    (31)-Access control-Vorrastenhaenger_Freigabe,not active
    (17)-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active
    (8)-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active
    (36)-Access control-Wiederverriegelung_Laderaum,Freigabe_Softtouch
    (13)-Access control-ZV entriegelt auch Heckdeckel,active
    (16)-Access control-ZV Heck nur direkt auswerfen,not active
    (6)-Access control-ZV Tuerentriegelung,Globale Entriegelung
    (20)-Access control-ZV-Entriegelung nach Seitencrash,active
    Read parameter address,00 00 00
    (2)-Light configuration-BAP Bitposition 0,34
    (21)-Light configuration-BAP Bitposition 1,3E
    (192)-Light configuration-BAP Bitposition 10,00
    (211)-Light configuration-BAP Bitposition 11,00
    (230)-Light configuration-BAP Bitposition 12,00
    (249)-Light configuration-BAP Bitposition 13,00
    (268)-Light configuration-BAP Bitposition 14,00
    (287)-Light configuration-BAP Bitposition 15,00
    (306)-Light configuration-BAP Bitposition 16,00
    (325)-Light configuration-BAP Bitposition 17,00
    (344)-Light configuration-BAP Bitposition 18,01
    (363)-Light configuration-BAP Bitposition 19,00
    (40)-Light configuration-BAP Bitposition 2,48
    (382)-Light configuration-BAP Bitposition 20,00
    (401)-Light configuration-BAP Bitposition 21,00
    (420)-Light configuration-BAP Bitposition 22,00
    (439)-Light configuration-BAP Bitposition 23,00
    (458)-Light configuration-BAP Bitposition 24,00
    (477)-Light configuration-BAP Bitposition 25,00
    (496)-Light configuration-BAP Bitposition 26,00
    (515)-Light configuration-BAP Bitposition 27,00
    (534)-Light configuration-BAP Bitposition 28,FF
    (553)-Light configuration-BAP Bitposition 29,FA
    (59)-Light configuration-BAP Bitposition 3,4C
    (572)-Light configuration-BAP Bitposition 30,00
    (591)-Light configuration-BAP Bitposition 31,00
    (610)-Light configuration-BAP Bitposition 32,00
    (629)-Light configuration-BAP Bitposition 33,00
    (648)-Light configuration-BAP Bitposition 34,FF
    (78)-Light configuration-BAP Bitposition 4,48
    (97)-Light configuration-BAP Bitposition 5,4C
    (116)-Light configuration-BAP Bitposition 6,36
    (135)-Light configuration-BAP Bitposition 7,40
    (154)-Light configuration-BAP Bitposition 8,21
    (173)-Light configuration-BAP Bitposition 9,33
    (11)-Light configuration-Dimming Direction CD 0,maximize
    (30)-Light configuration-Dimming Direction CD 1,maximize
    (201)-Light configuration-Dimming Direction CD 10,maximize
    (220)-Light configuration-Dimming Direction CD 11,maximize
    (239)-Light configuration-Dimming Direction CD 12,maximize
    (258)-Light configuration-Dimming Direction CD 13,maximize
    (277)-Light configuration-Dimming Direction CD 14,maximize
    (296)-Light configuration-Dimming Direction CD 15,maximize
    (315)-Light configuration-Dimming Direction CD 16,maximize
    (334)-Light configuration-Dimming Direction CD 17,maximize
    (353)-Light configuration-Dimming Direction CD 18,maximize
    (372)-Light configuration-Dimming Direction CD 19,maximize
    (49)-Light configuration-Dimming Direction CD 2,maximize
    (391)-Light configuration-Dimming Direction CD 20,maximize
    (410)-Light configuration-Dimming Direction CD 21,maximize
    (429)-Light configuration-Dimming Direction CD 22,maximize
    (448)-Light configuration-Dimming Direction CD 23,maximize
    (467)-Light configuration-Dimming Direction CD 24,maximize
    (486)-Light configuration-Dimming Direction CD 25,maximize
    (505)-Light configuration-Dimming Direction CD 26,maximize
    (524)-Light configuration-Dimming Direction CD 27,maximize
    (543)-Light configuration-Dimming Direction CD 28,maximize
    (562)-Light configuration-Dimming Direction CD 29,maximize
    (68)-Light configuration-Dimming Direction CD 3,maximize
    (581)-Light configuration-Dimming Direction CD 30,maximize
    (600)-Light configuration-Dimming Direction CD 31,maximize
    (619)-Light configuration-Dimming Direction CD 32,maximize
    (638)-Light configuration-Dimming Direction CD 33,maximize
    (657)-Light configuration-Dimming Direction CD 34,maximize
    (87)-Light configuration-Dimming Direction CD 4,maximize
    (106)-Light configuration-Dimming Direction CD 5,maximize
    (125)-Light configuration-Dimming Direction CD 6,maximize
    (144)-Light configuration-Dimming Direction CD 7,maximize
    (163)-Light configuration-Dimming Direction CD 8,maximize
    (182)-Light configuration-Dimming Direction CD 9,maximize
    (15)-Light configuration-Dimming Direction EF 0,maximize
    (34)-Light configuration-Dimming Direction EF 1,maximize
    (205)-Light configuration-Dimming Direction EF 10,maximize
    (224)-Light configuration-Dimming Direction EF 11,maximize
    (243)-Light configuration-Dimming Direction EF 12,maximize
    (262)-Light configuration-Dimming Direction EF 13,maximize
    (281)-Light configuration-Dimming Direction EF 14,maximize
    (300)-Light configuration-Dimming Direction EF 15,maximize
    (319)-Light configuration-Dimming Direction EF 16,maximize
    (338)-Light configuration-Dimming Direction EF 17,maximize
    (357)-Light configuration-Dimming Direction EF 18,maximize
    (376)-Light configuration-Dimming Direction EF 19,minimize
    (53)-Light configuration-Dimming Direction EF 2,maximize
    (395)-Light configuration-Dimming Direction EF 20,maximize
    (414)-Light configuration-Dimming Direction EF 21,maximize
    (433)-Light configuration-Dimming Direction EF 22,maximize
    (452)-Light configuration-Dimming Direction EF 23,minimize
    (471)-Light configuration-Dimming Direction EF 24,minimize
    (490)-Light configuration-Dimming Direction EF 25,maximize
    (509)-Light configuration-Dimming Direction EF 26,minimize
    (528)-Light configuration-Dimming Direction EF 27,maximize
    (547)-Light configuration-Dimming Direction EF 28,minimize
    (566)-Light configuration-Dimming Direction EF 29,maximize
    (72)-Light configuration-Dimming Direction EF 3,maximize
    (585)-Light configuration-Dimming Direction EF 30,maximize
    (604)-Light configuration-Dimming Direction EF 31,minimize
    (623)-Light configuration-Dimming Direction EF 32,maximize
    (642)-Light configuration-Dimming Direction EF 33,maximize
    (661)-Light configuration-Dimming Direction EF 34,minimize
    (91)-Light configuration-Dimming Direction EF 4,maximize
    (110)-Light configuration-Dimming Direction EF 5,maximize
    (129)-Light configuration-Dimming Direction EF 6,maximize
    (148)-Light configuration-Dimming Direction EF 7,maximize
    (167)-Light configuration-Dimming Direction EF 8,maximize
    (186)-Light configuration-Dimming Direction EF 9,maximize
    (19)-Light configuration-Dimming Direction GH 0,maximize
    (38)-Light configuration-Dimming Direction GH 1,maximize
    (209)-Light configuration-Dimming Direction GH 10,maximize
    (228)-Light configuration-Dimming Direction GH 11,maximize
    (247)-Light configuration-Dimming Direction GH 12,maximize
    (266)-Light configuration-Dimming Direction GH 13,maximize
    (285)-Light configuration-Dimming Direction GH 14,maximize
    (304)-Light configuration-Dimming Direction GH 15,maximize
    (323)-Light configuration-Dimming Direction GH 16,maximize
    (342)-Light configuration-Dimming Direction GH 17,maximize
    (361)-Light configuration-Dimming Direction GH 18,maximize
    (380)-Light configuration-Dimming Direction GH 19,maximize
    (57)-Light configuration-Dimming Direction GH 2,minimize
    (399)-Light configuration-Dimming Direction GH 20,maximize
    (418)-Light configuration-Dimming Direction GH 21,maximize
    (437)-Light configuration-Dimming Direction GH 22,maximize
    (456)-Light configuration-Dimming Direction GH 23,maximize
    (475)-Light configuration-Dimming Direction GH 24,maximize
    (494)-Light configuration-Dimming Direction GH 25,maximize
    (513)-Light configuration-Dimming Direction GH 26,maximize
    (532)-Light configuration-Dimming Direction GH 27,minimize
    (551)-Light configuration-Dimming Direction GH 28,maximize
    (570)-Light configuration-Dimming Direction GH 29,maximize
    (76)-Light configuration-Dimming Direction GH 3,minimize
    (589)-Light configuration-Dimming Direction GH 30,maximize
    (608)-Light configuration-Dimming Direction GH 31,maximize
    (627)-Light configuration-Dimming Direction GH 32,maximize
    (646)-Light configuration-Dimming Direction GH 33,maximize
    (665)-Light configuration-Dimming Direction GH 34,maximize
    (95)-Light configuration-Dimming Direction GH 4,maximize
    (114)-Light configuration-Dimming Direction GH 5,maximize
    (133)-Light configuration-Dimming Direction GH 6,maximize
    (152)-Light configuration-Dimming Direction GH 7,maximize
    (171)-Light configuration-Dimming Direction GH 8,minimize
    (190)-Light configuration-Dimming Direction GH 9,maximize
    (6)-Light configuration-Dimmwert AB 0,127
    (25)-Light configuration-Dimmwert AB 1,127
    (196)-Light configuration-Dimmwert AB 10,0
    (215)-Light configuration-Dimmwert AB 11,57
    (234)-Light configuration-Dimmwert AB 12,0
    (253)-Light configuration-Dimmwert AB 13,108
    (272)-Light configuration-Dimmwert AB 14,0
    (291)-Light configuration-Dimmwert AB 15,31
    (310)-Light configuration-Dimmwert AB 16,0
    (329)-Light configuration-Dimmwert AB 17,80
    (348)-Light configuration-Dimmwert AB 18,13
    (367)-Light configuration-Dimmwert AB 19,117
    (44)-Light configuration-Dimmwert AB 2,30
    (386)-Light configuration-Dimmwert AB 20,56
    (405)-Light configuration-Dimmwert AB 21,0
    (424)-Light configuration-Dimmwert AB 22,32
    (443)-Light configuration-Dimmwert AB 23,32
    (462)-Light configuration-Dimmwert AB 24,2
    (481)-Light configuration-Dimmwert AB 25,40
    (500)-Light configuration-Dimmwert AB 26,69
    (519)-Light configuration-Dimmwert AB 27,1
    (538)-Light configuration-Dimmwert AB 28,34
    (557)-Light configuration-Dimmwert AB 29,80
    (63)-Light configuration-Dimmwert AB 3,30
    (576)-Light configuration-Dimmwert AB 30,123
    (595)-Light configuration-Dimmwert AB 31,40
    (614)-Light configuration-Dimmwert AB 32,16
    (633)-Light configuration-Dimmwert AB 33,62
    (652)-Light configuration-Dimmwert AB 34,0
    (82)-Light configuration-Dimmwert AB 4,100
    (101)-Light configuration-Dimmwert AB 5,100
    (120)-Light configuration-Dimmwert AB 6,127
    (139)-Light configuration-Dimmwert AB 7,127
    (158)-Light configuration-Dimmwert AB 8,99
    (177)-Light configuration-Dimmwert AB 9,49
    (10)-Light configuration-Dimmwert CD 0,0
    (29)-Light configuration-Dimmwert CD 1,0
    (200)-Light configuration-Dimmwert CD 10,0
    (219)-Light configuration-Dimmwert CD 11,0
    (238)-Light configuration-Dimmwert CD 12,1
    (257)-Light configuration-Dimmwert CD 13,0
    (276)-Light configuration-Dimmwert CD 14,0
    (295)-Light configuration-Dimmwert CD 15,0
    (314)-Light configuration-Dimmwert CD 16,1
    (333)-Light configuration-Dimmwert CD 17,1
    (352)-Light configuration-Dimmwert CD 18,0
    (371)-Light configuration-Dimmwert CD 19,1
    (48)-Light configuration-Dimmwert CD 2,30
    (390)-Light configuration-Dimmwert CD 20,0
    (409)-Light configuration-Dimmwert CD 21,0
    (428)-Light configuration-Dimmwert CD 22,0
    (447)-Light configuration-Dimmwert CD 23,0
    (466)-Light configuration-Dimmwert CD 24,0
    (485)-Light configuration-Dimmwert CD 25,0
    (504)-Light configuration-Dimmwert CD 26,0
    (523)-Light configuration-Dimmwert CD 27,0
    (542)-Light configuration-Dimmwert CD 28,0
    (561)-Light configuration-Dimmwert CD 29,0
    (67)-Light configuration-Dimmwert CD 3,30
    (580)-Light configuration-Dimmwert CD 30,0
    (599)-Light configuration-Dimmwert CD 31,0
    (618)-Light configuration-Dimmwert CD 32,0
    (637)-Light configuration-Dimmwert CD 33,0
    (656)-Light configuration-Dimmwert CD 34,0
    (86)-Light configuration-Dimmwert CD 4,100
    (105)-Light configuration-Dimmwert CD 5,100
    (124)-Light configuration-Dimmwert CD 6,127
    (143)-Light configuration-Dimmwert CD 7,127
    (162)-Light configuration-Dimmwert CD 8,0
    (181)-Light configuration-Dimmwert CD 9,51
    (14)-Light configuration-Dimmwert EF 0,0
    (33)-Light configuration-Dimmwert EF 1,0
    (204)-Light configuration-Dimmwert EF 10,0
    (223)-Light configuration-Dimmwert EF 11,112
    (242)-Light configuration-Dimmwert EF 12,1
    (261)-Light configuration-Dimmwert EF 13,112
    (280)-Light configuration-Dimmwert EF 14,0
    (299)-Light configuration-Dimmwert EF 15,1
    (318)-Light configuration-Dimmwert EF 16,0
    (337)-Light configuration-Dimmwert EF 17,105
    (356)-Light configuration-Dimmwert EF 18,80
    (375)-Light configuration-Dimmwert EF 19,40
    (52)-Light configuration-Dimmwert EF 2,100
    (394)-Light configuration-Dimmwert EF 20,1
    (413)-Light configuration-Dimmwert EF 21,0
    (432)-Light configuration-Dimmwert EF 22,16
    (451)-Light configuration-Dimmwert EF 23,40
    (470)-Light configuration-Dimmwert EF 24,65
    (489)-Light configuration-Dimmwert EF 25,1
    (508)-Light configuration-Dimmwert EF 26,126
    (527)-Light configuration-Dimmwert EF 27,112
    (546)-Light configuration-Dimmwert EF 28,112
    (565)-Light configuration-Dimmwert EF 29,14
    (71)-Light configuration-Dimmwert EF 3,100
    (584)-Light configuration-Dimmwert EF 30,16
    (603)-Light configuration-Dimmwert EF 31,88
    (622)-Light configuration-Dimmwert EF 32,18
    (641)-Light configuration-Dimmwert EF 33,19
    (660)-Light configuration-Dimmwert EF 34,32
    (90)-Light configuration-Dimmwert EF 4,0
    (109)-Light configuration-Dimmwert EF 5,0
    (128)-Light configuration-Dimmwert EF 6,0
    (147)-Light configuration-Dimmwert EF 7,0
    (166)-Light configuration-Dimmwert EF 8,1
    (185)-Light configuration-Dimmwert EF 9,96
    (18)-Light configuration-Dimmwert GH 0,0
    (37)-Light configuration-Dimmwert GH 1,0
    (208)-Light configuration-Dimmwert GH 10,1
    (227)-Light configuration-Dimmwert GH 11,0
    (246)-Light configuration-Dimmwert GH 12,1
    (265)-Light configuration-Dimmwert GH 13,0
    (284)-Light configuration-Dimmwert GH 14,1
    (303)-Light configuration-Dimmwert GH 15,0
    (322)-Light configuration-Dimmwert GH 16,1
    (341)-Light configuration-Dimmwert GH 17,1
    (360)-Light configuration-Dimmwert GH 18,1
    (379)-Light configuration-Dimmwert GH 19,0
    (56)-Light configuration-Dimmwert GH 2,10
    (398)-Light configuration-Dimmwert GH 20,0
    (417)-Light configuration-Dimmwert GH 21,0
    (436)-Light configuration-Dimmwert GH 22,1
    (455)-Light configuration-Dimmwert GH 23,0
    (474)-Light configuration-Dimmwert GH 24,0
    (493)-Light configuration-Dimmwert GH 25,0
    (512)-Light configuration-Dimmwert GH 26,0
    (531)-Light configuration-Dimmwert GH 27,127
    (550)-Light configuration-Dimmwert GH 28,0
    (569)-Light configuration-Dimmwert GH 29,0
    (75)-Light configuration-Dimmwert GH 3,10
    (588)-Light configuration-Dimmwert GH 30,0
    (607)-Light configuration-Dimmwert GH 31,1
    (626)-Light configuration-Dimmwert GH 32,0
    (645)-Light configuration-Dimmwert GH 33,0
    (664)-Light configuration-Dimmwert GH 34,0
    (94)-Light configuration-Dimmwert GH 4,100
    (113)-Light configuration-Dimmwert GH 5,100
    (132)-Light configuration-Dimmwert GH 6,0
    (151)-Light configuration-Dimmwert GH 7,0
    (170)-Light configuration-Dimmwert GH 8,127
    (189)-Light configuration-Dimmwert GH 9,0
    (3)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14
    (22)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15
    (193)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,01
    (212)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,39
    (231)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,8B
    (250)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,01
    (269)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,01
    (288)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,01
    (307)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,00
    (326)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,00
    (345)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,01
    (364)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,00
    (41)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,4A
    (383)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,00
    (402)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,00
    (421)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,00
    (440)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,00
    (459)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,00
    (478)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,01
    (497)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,00
    (516)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,00
    (535)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,FA
    (554)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,FA
    (60)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,4C
    (573)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,00
    (592)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,FA
    (611)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,00
    (630)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,00
    (649)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,00
    (79)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,49
    (98)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,4B
    (117)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A
    (136)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B
    (155)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,00
    (174)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,2C
    (1)-Light configuration-Lasttyp 0,33 - LED-Modul Blinkleuchten
    (20)-Light configuration-Lasttyp 1,33 - LED-Modul Blinkleuchten
    (191)-Light configuration-Lasttyp 10,not active
    (210)-Light configuration-Lasttyp 11,3 - Xenon Abblendlicht
    (229)-Light configuration-Lasttyp 12,not active
    (248)-Light configuration-Lasttyp 13,not active
    (267)-Light configuration-Lasttyp 14,not active
    (305)-Light configuration-Lasttyp 16,1 - LED Tagfahrlichtmodul Versorgung
    (362)-Light configuration-Lasttyp 19,not active
    (39)-Light configuration-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal
    (381)-Light configuration-Lasttyp 20,not active
    (400)-Light configuration-Lasttyp 21,5 - LED Abblendlicht
    (419)-Light configuration-Lasttyp 22,not active
    (457)-Light configuration-Lasttyp 24,not active
    (476)-Light configuration-Lasttyp 25,not active
    (514)-Light configuration-Lasttyp 27,not active
    (58)-Light configuration-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal
    (571)-Light configuration-Lasttyp 30,not active
    (590)-Light configuration-Lasttyp 31,not active
    (609)-Light configuration-Lasttyp 32,not active
    (647)-Light configuration-Lasttyp 34,not active
    (77)-Light configuration-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung
    (96)-Light configuration-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung
    (115)-Light configuration-Lasttyp 6,5 - LED Abblendlicht
    (134)-Light configuration-Lasttyp 7,5 - LED Abblendlicht
    (7)-Light configuration-Lichtansteuerung HD AB 0,Always
    (26)-Light configuration-Lichtansteuerung HD AB 1,Always
    (197)-Light configuration-Lichtansteuerung HD AB 10,Always
    (216)-Light configuration-Lichtansteuerung HD AB 11,Always
    (235)-Light configuration-Lichtansteuerung HD AB 12,Always
    (254)-Light configuration-Lichtansteuerung HD AB 13,only_if_closed
    (273)-Light configuration-Lichtansteuerung HD AB 14,Always
    (292)-Light configuration-Lichtansteuerung HD AB 15,Always
    (311)-Light configuration-Lichtansteuerung HD AB 16,Always
    (330)-Light configuration-Lichtansteuerung HD AB 17,Always
    (349)-Light configuration-Lichtansteuerung HD AB 18,Always
    (368)-Light configuration-Lichtansteuerung HD AB 19,only_if_closed
    (45)-Light configuration-Lichtansteuerung HD AB 2,Always
    (387)-Light configuration-Lichtansteuerung HD AB 20,Always
    (406)-Light configuration-Lichtansteuerung HD AB 21,Always
    (425)-Light configuration-Lichtansteuerung HD AB 22,Always
    (444)-Light configuration-Lichtansteuerung HD AB 23,Always
    (463)-Light configuration-Lichtansteuerung HD AB 24,Always
    (482)-Light configuration-Lichtansteuerung HD AB 25,Always
    (501)-Light configuration-Lichtansteuerung HD AB 26,Always
    (520)-Light configuration-Lichtansteuerung HD AB 27,Always
    (539)-Light configuration-Lichtansteuerung HD AB 28,Always
    (558)-Light configuration-Lichtansteuerung HD AB 29,Always
    (64)-Light configuration-Lichtansteuerung HD AB 3,Always
    (577)-Light configuration-Lichtansteuerung HD AB 30,Always
    (596)-Light configuration-Lichtansteuerung HD AB 31,only_if_closed
    (615)-Light configuration-Lichtansteuerung HD AB 32,Always
    (634)-Light configuration-Lichtansteuerung HD AB 33,only_if_closed
    (653)-Light configuration-Lichtansteuerung HD AB 34,Always
    (83)-Light configuration-Lichtansteuerung HD AB 4,Always
    (102)-Light configuration-Lichtansteuerung HD AB 5,Always
    (121)-Light configuration-Lichtansteuerung HD AB 6,Always
    (140)-Light configuration-Lichtansteuerung HD AB 7,Always
    (159)-Light configuration-Lichtansteuerung HD AB 8,only_if_closed
    (178)-Light configuration-Lichtansteuerung HD AB 9,Always
    (328)-Light configuration-Lichtfunktion  B 17,0
    (255)-Light configuration-Lichtfunktion  C 13,1
    (4)-Light configuration-Lichtfunktion A 0,2
    (23)-Light configuration-Lichtfunktion A 1,4
    (194)-Light configuration-Lichtfunktion A 10,0
    (213)-Light configuration-Lichtfunktion A 11,0
    (232)-Light configuration-Lichtfunktion A 12,0
    (251)-Light configuration-Lichtfunktion A 13,2
    (270)-Light configuration-Lichtfunktion A 14,1
    (289)-Light configuration-Lichtfunktion A 15,58
    (308)-Light configuration-Lichtfunktion A 16,176
    (327)-Light configuration-Lichtfunktion A 17,1
    (346)-Light configuration-Lichtfunktion A 18,14
    (365)-Light configuration-Lichtfunktion A 19,80
    (42)-Light configuration-Lichtfunktion A 2,8
    (384)-Light configuration-Lichtfunktion A 20,62
    (403)-Light configuration-Lichtfunktion A 21,241
    (422)-Light configuration-Lichtfunktion A 22,1
    (441)-Light configuration-Lichtfunktion A 23,88
    (460)-Light configuration-Lichtfunktion A 24,1
    (479)-Light configuration-Lichtfunktion A 25,59
    (498)-Light configuration-Lichtfunktion A 26,0
    (517)-Light configuration-Lichtfunktion A 27,72
    (536)-Light configuration-Lichtfunktion A 28,60
    (555)-Light configuration-Lichtfunktion A 29,0
    (61)-Light configuration-Lichtfunktion A 3,8
    (574)-Light configuration-Lichtfunktion A 30,16
    (593)-Light configuration-Lichtfunktion A 31,29
    (612)-Light configuration-Lichtfunktion A 32,0
    (631)-Light configuration-Lichtfunktion A 33,0
    (650)-Light configuration-Lichtfunktion A 34,254
    (80)-Light configuration-Lichtfunktion A 4,20
    (99)-Light configuration-Lichtfunktion A 5,20
    (118)-Light configuration-Lichtfunktion A 6,11
    (137)-Light configuration-Lichtfunktion A 7,12
    (156)-Light configuration-Lichtfunktion A 8,77
    (175)-Light configuration-Lichtfunktion A 9,49
    (5)-Light configuration-Lichtfunktion B 0,0
    (24)-Light configuration-Lichtfunktion B 1,0
    (195)-Light configuration-Lichtfunktion B 10,0
    (214)-Light configuration-Lichtfunktion B 11,0
    (233)-Light configuration-Lichtfunktion B 12,0
    (252)-Light configuration-Lichtfunktion B 13,1
    (271)-Light configuration-Lichtfunktion B 14,0
    (290)-Light configuration-Lichtfunktion B 15,0
    (309)-Light configuration-Lichtfunktion B 16,0
    (347)-Light configuration-Lichtfunktion B 18,0
    (366)-Light configuration-Lichtfunktion B 19,250
    (43)-Light configuration-Lichtfunktion B 2,9
    (385)-Light configuration-Lichtfunktion B 20,0
    (404)-Light configuration-Lichtfunktion B 21,0
    (423)-Light configuration-Lichtfunktion B 22,0
    (442)-Light configuration-Lichtfunktion B 23,0
    (461)-Light configuration-Lichtfunktion B 24,0
    (480)-Light configuration-Lichtfunktion B 25,0
    (499)-Light configuration-Lichtfunktion B 26,1
    (518)-Light configuration-Lichtfunktion B 27,0
    (537)-Light configuration-Lichtfunktion B 28,250
    (556)-Light configuration-Lichtfunktion B 29,250
    (62)-Light configuration-Lichtfunktion B 3,10
    (575)-Light configuration-Lichtfunktion B 30,0
    (594)-Light configuration-Lichtfunktion B 31,0
    (613)-Light configuration-Lichtfunktion B 32,0
    (632)-Light configuration-Lichtfunktion B 33,0
    (651)-Light configuration-Lichtfunktion B 34,255
    (81)-Light configuration-Lichtfunktion B 4,8
    (100)-Light configuration-Lichtfunktion B 5,8
    (119)-Light configuration-Lichtfunktion B 6,0
    (138)-Light configuration-Lichtfunktion B 7,0
    (157)-Light configuration-Lichtfunktion B 8,34
    (176)-Light configuration-Lichtfunktion B 9,48
    (8)-Light configuration-Lichtfunktion C 0,3
    (27)-Light configuration-Lichtfunktion C 1,5
    (198)-Light configuration-Lichtfunktion C 10,0
    (217)-Light configuration-Lichtfunktion C 11,139
    (236)-Light configuration-Lichtfunktion C 12,0
    (274)-Light configuration-Lichtfunktion C 14,0
    (293)-Light configuration-Lichtfunktion C 15,202
    (312)-Light configuration-Lichtfunktion C 16,0
    (331)-Light configuration-Lichtfunktion C 17,1
    (350)-Light configuration-Lichtfunktion C 18,85
    (369)-Light configuration-Lichtfunktion C 19,250
    (46)-Light configuration-Lichtfunktion C 2,30
    (388)-Light configuration-Lichtfunktion C 20,1
    (407)-Light configuration-Lichtfunktion C 21,0
    (426)-Light configuration-Lichtfunktion C 22,0
    (445)-Light configuration-Lichtfunktion C 23,0
    (464)-Light configuration-Lichtfunktion C 24,0
    (483)-Light configuration-Lichtfunktion C 25,0
    (502)-Light configuration-Lichtfunktion C 26,0
    (521)-Light configuration-Lichtfunktion C 27,1
    (540)-Light configuration-Lichtfunktion C 28,0
    (559)-Light configuration-Lichtfunktion C 29,250
    (65)-Light configuration-Lichtfunktion C 3,30
    (578)-Light configuration-Lichtfunktion C 30,250
    (597)-Light configuration-Lichtfunktion C 31,1
    (616)-Light configuration-Lichtfunktion C 32,1
    (635)-Light configuration-Lichtfunktion C 33,1
    (654)-Light configuration-Lichtfunktion C 34,1
    (84)-Light configuration-Lichtfunktion C 4,30
    (103)-Light configuration-Lichtfunktion C 5,30
    (122)-Light configuration-Lichtfunktion C 6,30
    (141)-Light configuration-Lichtfunktion C 7,30
    (160)-Light configuration-Lichtfunktion C 8,162
    (179)-Light configuration-Lichtfunktion C 9,53
    (9)-Light configuration-Lichtfunktion D 0,0
    (28)-Light configuration-Lichtfunktion D 1,0
    (199)-Light configuration-Lichtfunktion D 10,1
    (218)-Light configuration-Lichtfunktion D 11,0
    (237)-Light configuration-Lichtfunktion D 12,112
    (256)-Light configuration-Lichtfunktion D 13,0
    (275)-Light configuration-Lichtfunktion D 14,1
    (294)-Light configuration-Lichtfunktion D 15,0
    (313)-Light configuration-Lichtfunktion D 16,0
    (332)-Light configuration-Lichtfunktion D 17,80
    (351)-Light configuration-Lichtfunktion D 18,0
    (370)-Light configuration-Lichtfunktion D 19,64
    (47)-Light configuration-Lichtfunktion D 2,0
    (389)-Light configuration-Lichtfunktion D 20,0
    (408)-Light configuration-Lichtfunktion D 21,0
    (427)-Light configuration-Lichtfunktion D 22,32
    (446)-Light configuration-Lichtfunktion D 23,0
    (465)-Light configuration-Lichtfunktion D 24,211
    (484)-Light configuration-Lichtfunktion D 25,1
    (503)-Light configuration-Lichtfunktion D 26,0
    (522)-Light configuration-Lichtfunktion D 27,0
    (541)-Light configuration-Lichtfunktion D 28,165
    (560)-Light configuration-Lichtfunktion D 29,176
    (66)-Light configuration-Lichtfunktion D 3,0
    (579)-Light configuration-Lichtfunktion D 30,240
    (598)-Light configuration-Lichtfunktion D 31,0
    (617)-Light configuration-Lichtfunktion D 32,240
    (636)-Light configuration-Lichtfunktion D 33,0
    (655)-Light configuration-Lichtfunktion D 34,176
    (85)-Light configuration-Lichtfunktion D 4,9
    (104)-Light configuration-Lichtfunktion D 5,10
    (123)-Light configuration-Lichtfunktion D 6,0
    (142)-Light configuration-Lichtfunktion D 7,0
    (161)-Light configuration-Lichtfunktion D 8,35
    (180)-Light configuration-Lichtfunktion D 9,52
    (12)-Light configuration-Lichtfunktion E 0,0
    (31)-Light configuration-Lichtfunktion E 1,0
    (202)-Light configuration-Lichtfunktion E 10,0
    (221)-Light configuration-Lichtfunktion E 11,0
    (240)-Light configuration-Lichtfunktion E 12,0
    (259)-Light configuration-Lichtfunktion E 13,0
    (278)-Light configuration-Lichtfunktion E 14,205
    (297)-Light configuration-Lichtfunktion E 15,0
    (316)-Light configuration-Lichtfunktion E 16,0
    (335)-Light configuration-Lichtfunktion E 17,58
    (354)-Light configuration-Lichtfunktion E 18,0
    (373)-Light configuration-Lichtfunktion E 19,63
    (50)-Light configuration-Lichtfunktion E 2,20
    (392)-Light configuration-Lichtfunktion E 20,253
    (411)-Light configuration-Lichtfunktion E 21,15
    (430)-Light configuration-Lichtfunktion E 22,1
    (449)-Light configuration-Lichtfunktion E 23,94
    (468)-Light configuration-Lichtfunktion E 24,0
    (487)-Light configuration-Lichtfunktion E 25,0
    (506)-Light configuration-Lichtfunktion E 26,0
    (525)-Light configuration-Lichtfunktion E 27,0
    (544)-Light configuration-Lichtfunktion E 28,200
    (563)-Light configuration-Lichtfunktion E 29,78
    (69)-Light configuration-Lichtfunktion E 3,20
    (582)-Light configuration-Lichtfunktion E 30,78
    (601)-Light configuration-Lichtfunktion E 31,176
    (620)-Light configuration-Lichtfunktion E 32,87
    (639)-Light configuration-Lichtfunktion E 33,0
    (658)-Light configuration-Lichtfunktion E 34,123
    (88)-Light configuration-Lichtfunktion E 4,0
    (107)-Light configuration-Lichtfunktion E 5,0
    (126)-Light configuration-Lichtfunktion E 6,0
    (145)-Light configuration-Lichtfunktion E 7,0
    (164)-Light configuration-Lichtfunktion E 8,1
    (183)-Light configuration-Lichtfunktion E 9,49
    (13)-Light configuration-Lichtfunktion F 0,0
    (32)-Light configuration-Lichtfunktion F 1,0
    (203)-Light configuration-Lichtfunktion F 10,0
    (222)-Light configuration-Lichtfunktion F 11,0
    (241)-Light configuration-Lichtfunktion F 12,0
    (260)-Light configuration-Lichtfunktion F 13,0
    (279)-Light configuration-Lichtfunktion F 14,0
    (298)-Light configuration-Lichtfunktion F 15,0
    (317)-Light configuration-Lichtfunktion F 16,0
    (336)-Light configuration-Lichtfunktion F 17,1
    (355)-Light configuration-Lichtfunktion F 18,0
    (374)-Light configuration-Lichtfunktion F 19,1
    (51)-Light configuration-Lichtfunktion F 2,0
    (393)-Light configuration-Lichtfunktion F 20,33
    (412)-Light configuration-Lichtfunktion F 21,250
    (431)-Light configuration-Lichtfunktion F 22,0
    (450)-Light configuration-Lichtfunktion F 23,1
    (469)-Light configuration-Lichtfunktion F 24,0
    (488)-Light configuration-Lichtfunktion F 25,0
    (507)-Light configuration-Lichtfunktion F 26,0
    (526)-Light configuration-Lichtfunktion F 27,0
    (545)-Light configuration-Lichtfunktion F 28,0
    (564)-Light configuration-Lichtfunktion F 29,0
    (583)-Light configuration-Lichtfunktion F 30,0
    (602)-Light configuration-Lichtfunktion F 31,1
    (621)-Light configuration-Lichtfunktion F 32,250
    (640)-Light configuration-Lichtfunktion F 33,0
    (659)-Light configuration-Lichtfunktion F 34,0
    (89)-Light configuration-Lichtfunktion F 4,0
    (127)-Light configuration-Lichtfunktion F 6,0
    (146)-Light configuration-Lichtfunktion F 7,0
    (165)-Light configuration-Lichtfunktion F 8,0
    (184)-Light configuration-Lichtfunktion F 9,0
    (70)-Light configuration-Lichtfunktion F3,0
    (108)-Light configuration-Lichtfunktion F5,0
    (16)-Light configuration-Lichtfunktion G 0,0
    (35)-Light configuration-Lichtfunktion G 1,0
    (206)-Light configuration-Lichtfunktion G 10,0
    (225)-Light configuration-Lichtfunktion G 11,1
    (244)-Light configuration-Lichtfunktion G 12,0
    (263)-Light configuration-Lichtfunktion G 13,1
    (282)-Light configuration-Lichtfunktion G 14,0
    (301)-Light configuration-Lichtfunktion G 15,0
    (320)-Light configuration-Lichtfunktion G 16,0
    (339)-Light configuration-Lichtfunktion G 17,33
    (358)-Light configuration-Lichtfunktion G 18,1
    (377)-Light configuration-Lichtfunktion G 19,0
    (54)-Light configuration-Lichtfunktion G 2,6
    (396)-Light configuration-Lichtfunktion G 20,0
    (415)-Light configuration-Lichtfunktion G 21,0
    (434)-Light configuration-Lichtfunktion G 22,0
    (453)-Light configuration-Lichtfunktion G 23,0
    (472)-Light configuration-Lichtfunktion G 24,0
    (491)-Light configuration-Lichtfunktion G 25,0
    (510)-Light configuration-Lichtfunktion G 26,255
    (529)-Light configuration-Lichtfunktion G 27,0
    (548)-Light configuration-Lichtfunktion G 28,0
    (567)-Light configuration-Lichtfunktion G 29,0
    (73)-Light configuration-Lichtfunktion G 3,7
    (586)-Light configuration-Lichtfunktion G 30,0
    (605)-Light configuration-Lichtfunktion G 31,1
    (624)-Light configuration-Lichtfunktion G 32,0
    (643)-Light configuration-Lichtfunktion G 33,0
    (662)-Light configuration-Lichtfunktion G 34,0
    (92)-Light configuration-Lichtfunktion G 4,6
    (111)-Light configuration-Lichtfunktion G 5,7
    (130)-Light configuration-Lichtfunktion G 6,0
    (149)-Light configuration-Lichtfunktion G 7,0
    (168)-Light configuration-Lichtfunktion G 8,0
    (187)-Light configuration-Lichtfunktion G 9,250
    (17)-Light configuration-Lichtfunktion H 0,0
    (36)-Light configuration-Lichtfunktion H 1,0
    (207)-Light configuration-Lichtfunktion H 10,5
    (226)-Light configuration-Lichtfunktion H 11,0
    (245)-Light configuration-Lichtfunktion H 12,213
    (264)-Light configuration-Lichtfunktion H 13,0
    (283)-Light configuration-Lichtfunktion H 14,212
    (302)-Light configuration-Lichtfunktion H 15,36
    (321)-Light configuration-Lichtfunktion H 16,215
    (340)-Light configuration-Lichtfunktion H 17,80
    (359)-Light configuration-Lichtfunktion H 18,76
    (378)-Light configuration-Lichtfunktion H 19,241
    (55)-Light configuration-Lichtfunktion H 2,0
    (397)-Light configuration-Lichtfunktion H 20,16
    (416)-Light configuration-Lichtfunktion H 21,0
    (435)-Light configuration-Lichtfunktion H 22,225
    (454)-Light configuration-Lichtfunktion H 23,0
    (473)-Light configuration-Lichtfunktion H 24,210
    (492)-Light configuration-Lichtfunktion H 25,255
    (511)-Light configuration-Lichtfunktion H 26,0
    (530)-Light configuration-Lichtfunktion H 27,255
    (549)-Light configuration-Lichtfunktion H 28,78
    (568)-Light configuration-Lichtfunktion H 29,0
    (74)-Light configuration-Lichtfunktion H 3,0
    (587)-Light configuration-Lichtfunktion H 30,0
    (606)-Light configuration-Lichtfunktion H 31,176
    (625)-Light configuration-Lichtfunktion H 32,0
    (644)-Light configuration-Lichtfunktion H 33,0
    (663)-Light configuration-Lichtfunktion H 34,19
    (93)-Light configuration-Lichtfunktion H 4,0
    (112)-Light configuration-Lichtfunktion H 5,0
    (131)-Light configuration-Lichtfunktion H 6,0
    (150)-Light configuration-Lichtfunktion H 7,0
    (169)-Light configuration-Lichtfunktion H 8,255
    (188)-Light configuration-Lichtfunktion H 9,0
    DWA Vehicle inclination sensor,100 %
    DWA Interior monitoring parameter set,01 0A 08 00 43 63 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD 46 26 00 0F 1D 00 85 0F 39 F7 24 19 45 31 57 9B 25 44 3F 3A 69 35 95 18 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 29 0F E3 31 87 9B 05 34 3F 3A 69 58 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 29 19 45 31 77 9B 05 24 3F 3A 69 47 03 08 09 A3 04 23 15 4A 16 0A 16 1F 88 0B 28 51 32 0C 61 31 5A 94 05 24 8F FD 57 45 02 00 2C4C323 22 00 00 B7FE044D 639A5A30 2609606B E9A1A1E8 E758CEE9 00 01 00 01 00 FFFFFFFF FFFFFFFF 3533332C 372C2C36 2C2C2C2C 302C302C 3733312C 302C2C36 342C3078 45333430 30302C34 4330 00 00 627AD960 7FFA 00 00 00 00 403DFD70 01 144000 00 00 00 01 00 300 00
    (13)-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s
    (14)-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C
    (2)-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,20.00 °C
    (1)-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,19.00 °C
    (4)-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,28.00 °C
    (3)-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,27.50 °C
    (6)-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C
    (5)-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.00 °C
    (8)-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,41.00 °C
    (7)-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,40.50 °C
    (10)-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,50.00 °C
    (9)-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,49.00 °C
    (12)-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,63.00 °C
    (11)-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,62.50 °C
    (1)-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,not active
    (2)-Interior lighting-KL30G ohne PWM,active
    (3)-Interior lighting-KL58 Einschalten mit Rampe,not active
    (4)-Interior lighting-KL58 Verriegelungsausschalten,active
    (5)-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active
    (6)-Interior lighting-Suchbeleuchtung Festwert,50 %
    Roller test bench mode	 functional,not active
    (8)-Daytime running lights-Fahrlicht bei Tag,Daytime running lights
    (1)-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,active
    (4)-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active
    (2)-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active
    (5)-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active
    (9)-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active
    (6)-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,active
    (7)-Daytime running lights-Tagfahrlichtkontrollleuchte,not active
    (3)-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active
    Position during interval mode,21.69 °
    (1)-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit
    (3)-After-run for park light-Bedingungen zur Parklichtbegrenzung,not active
    (2)-After-run for park light-Bedingungen zur Standlichtbegrenzung,not active
    (4)-After-run for park light-Faktor fuer Verfügbarkeitstimer,Faktor fuer x1 Stunden
    (5)-After-run for park light-Standlicht-Nachlaufzeit,30 min
    (6)-After-run for park light-Standlicht-Verfügbarkeit,0 s
    (3)-Access control 2-Comfort closing,active
    (2)-Access control 2-Comfort opening,not active
    (38)-Access control 2-easycloselight_aktiv,not active
    (31)-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,not active
    (32)-Access control 2-Fahrertuerbedienung Fensterheber schliessen,not active
    (30)-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s
    (13)-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active
    (14)-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active
    (7)-Access control 2-Funk Komfort oeffnen,active
    (6)-Access control 2-Funk Komfort schliessen,active
    (23)-Access control 2-Funk Spiegelanklappen,active
    (24)-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key
    (19)-Access control 2-Kessy Komfort oeffnen,active
    (20)-Access control 2-Kessy Komfort schliessen,active
    (21)-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,active
    (1)-Access control 2-Komfortbedienung global,active
    (4)-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active
    (26)-Access control 2-Menuesteuerung Funk Spiegel anklappen,active
    (27)-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable
    (28)-Access control 2-Menuesteuerung Regenschliessen,not active
    (22)-Access control 2-Menuesteuerung Spiegelabsenkung,active
    (25)-Access control 2-Menuesteuerung synchrone Spiegelverstellung,active
    (5)-Access control 2-Nachsaven_nach_Verdecklauf,not active
    (34)-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,not active
    (16)-Access control 2-Regenschliessen_art,once
    (15)-Access control 2-Regenschliessen_ein_aus,not active
    (33)-Access control 2-Remote_Unlock_Lock,not_active
    (12)-Access control 2-SAD Komfort oeffnen,active
    (11)-Access control 2-SAD Komfort schliessen,active
    (29)-Access control 2-SAD PreCrash Konturschliessen,active
    (10)-Access control 2-SAD Richtung Komfortoeffnen,tilting
    (8)-Access control 2-Schliesszylinder Komfort oeffnen,active
    (9)-Access control 2-Schliesszylinder Komfort schliessen,active
    (35)-Access control 2-Signalisierung_Spiegelanklappung,active
    (17)-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,active
    (39)-Access control 2-Spiegelanklappen_bei_Wiederverriegelung,not active
    (18)-Access control 2-Spiegelverstellung Synchron,not active
    (36)-Access control 2-Virtuelles_Pedal,not active
    (37)-Access control 2-virtuelles_pedal_HMI_einstellbar,not active
    (11)-Assistance light functions-AFL Zeitverzoegerung,500 ms
    (7)-Assistance light functions-Assistenzfahrlicht bei Regen,active
    (10)-Assistance light functions-Fahrlicht_Hinweis_mehrfach,not active
    (8)-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL
    (5)-Assistance light functions-Fernlichtassistent Reset,active
    (3)-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,800 ms
    (12)-Assistance light functions-Lichtsensorempfindlichkeit,normal
    (9)-Assistance light functions-LS_Error_Ausgabe,active
    (2)-Assistance light functions-Menuesteuerung Fernlichtassistent,present
    (6)-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present
    (1)-Assistance light functions-Notbremsanzeige NBA,active
    (4)-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,not active
    (4)-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active
    (3)-Auxiliary functions-Signalhorn ohne KL15,not active
    (2)-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active
    (1)-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active
    (14)-Dyn. turn signal modes-ABBA_Blinken,active
    (15)-Dyn. turn signal modes-Crashblinken,not active
    (7)-Dyn. turn signal modes-DWA_Alarm_Blinken,active
    (6)-Dyn. turn signal modes-DWA_Schaerfungsquittung,active
    (18)-Dyn. turn signal modes-Emergency_alert_blinken,active
    (10)-Dyn. turn signal modes-Multi_kollisions_Blinken,not active
    (11)-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active
    (9)-Dyn. turn signal modes-Panikblinken,active
    (13)-Dyn. turn signal modes-Richtungs_blinken_links,active
    (12)-Dyn. turn signal modes-Richtungs_blinken_rechts,active
    (1)-Dyn. turn signal modes-Schluessel_Anlern_Blinken,active
    (8)-Dyn. turn signal modes-Taxialarmblinken,active
    (5)-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,active
    (2)-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active
    (17)-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,active
    (16)-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,active
    (4)-Dyn. turn signal modes-ZV_Blinken_auf,active
    (3)-Dyn. turn signal modes-ZV_Blinken_zu,active
    (1)-Int. light	 2nd generation-Aufloesung Dimmzeit,0.10 s
    (11)-Int. light	 2nd generation-BAP Farbwert Farbe 1,2
    (12)-Int. light	 2nd generation-BAP Farbwert Farbe 2,3
    (13)-Int. light	 2nd generation-BAP Farbwert Farbe 3,1
    (33)-Int. light	 2nd generation-Blauwert Farbe 1,225
    (36)-Int. light	 2nd generation-Blauwert Farbe 2,225
    (39)-Int. light	 2nd generation-Blauwert Farbe 3,225
    (5)-Int. light	 2nd generation-Cockpitbeleuchtung mehrfarbig,active
    (8)-Int. light	 2nd generation-Dachbeleuchtung mehrfarbig,not active
    (15)-Int. light	 2nd generation-Defaultwert Ambienteprofil Dach,80 %
    (16)-Int. light	 2nd generation-Defaultwert Ambienteprofil Farbe,2
    (14)-Int. light	 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %
    (26)-Int. light	 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active
    (29)-Int. light	 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active
    (25)-Int. light	 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active
    (27)-Int. light	 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active
    (28)-Int. light	 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active
    (30)-Int. light	 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active
    (24)-Int. light	 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active
    (32)-Int. light	 2nd generation-Gruenwert Farbe 1,225
    (35)-Int. light	 2nd generation-Gruenwert Farbe 2,225
    (38)-Int. light	 2nd generation-Gruenwert Farbe 3,225
    (19)-Int. light	 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active
    (22)-Int. light	 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active
    (18)-Int. light	 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active
    (20)-Int. light	 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active
    (21)-Int. light	 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active
    (23)-Int. light	 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active
    (17)-Int. light	 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,active
    (4)-Int. light	 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active
    (6)-Int. light	 2nd generation-Lautsprecherbeleuchtung mehrfarbig,active
    (7)-Int. light	 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active
    (10)-Int. light	 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active
    (9)-Int. light	 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active
    (31)-Int. light	 2nd generation-Rotwert Farbe 1,225
    (34)-Int. light	 2nd generation-Rotwert Farbe 2,225
    (37)-Int. light	 2nd generation-Rotwert Farbe 3,225
    (3)-Int. light	 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active
    (2)-Int. light	 2nd generation-weicher Farbwechsel,not active
    (14)-Interior light	 light configuration-Ambient_Farbliste_HMI,not active
    (3)-Interior light	 light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed
    (1)-Interior light	 light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed
    (2)-Interior light	 light configuration-Ambiente_Lautsprecher,installed
    (13)-Interior light	 light configuration-Ambientemenue mit alle Zonen,active
    (12)-Interior light	 light configuration-Ambientemenue mit globalem aus,not active
    (4)-Interior light	 light configuration-Cockpitbeleuchtung,installed
    (6)-Interior light	 light configuration-Dachbeleuchtung,not installed
    (10)-Interior light	 light configuration-Farbwahl ueber Fahrprofil,not installed
    (9)-Interior light	 light configuration-Farbwahl ueber HMI,not installed
    (15)-Interior light	 light configuration-Frei_Farbwahl_ueber_HMI,not active
    (8)-Interior light	 light configuration-Fussraumbeleuchtung,installed
    (11)-Interior light	 light configuration-LIN-Dachkonsole lokal aktivierbar,not active
    (5)-Interior light	 light configuration-Mittelkonsolenbeleuchtung,not installed
    (7)-Interior light	 light configuration-Panoramaschiebedachbeleuchtung,not installed
    (2)-Seat fan charac. curve-Level_1_Lehne,30 %
    (1)-Seat fan charac. curve-Level_1_Sitz,25 %
    (4)-Seat fan charac. curve-Level_2_Lehne,30 %
    (3)-Seat fan charac. curve-Level_2_Sitz,25 %
    (6)-Seat fan charac. curve-Level_3_Lehne,58 %
    (5)-Seat fan charac. curve-Level_3_Sitz,53 %
    (8)-Seat fan charac. curve-Level_4_Lehne,58 %
    (7)-Seat fan charac. curve-Level_4_Sitz,53 %
    (10)-Seat fan charac. curve-Level_5_Lehne,85 %
    (9)-Seat fan charac. curve-Level_5_Sitz,80 %
    (12)-Seat fan charac. curve-Level_6_Lehne,85 %
    (11)-Seat fan charac. curve-Level_6_Sitz,80 %
    Alternating park position 1,18.69 °
    Alternating park position 2,21.69 °
    lower turn position,27.69 °
    upper turn position,166.30 °
    (10)-Convert. top oper.-Doppelpuls nur Verdeck,active
    (12)-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active
    (13)-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active
    (1)-Convert. top oper.-Komfortbedienung Verdeck global,active
    (2)-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active
    (3)-Convert. top oper.-Komfortbedienung Verdeck schließen,active
    (14)-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active
    (16)-Convert. top oper.-Remote Lock Unlock Timer s1,0 s
    (17)-Convert. top oper.-Remote Lock Unlock Timer s3,0.000 ms
    (11)-Convert. top oper.-Verdeck mit Schiebedach,not active
    (6)-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active
    (8)-Convert. top oper.-Verdeck oeffnen via Kessy,active
    (4)-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active
    (7)-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active
    (9)-Convert. top oper.-Verdeck schließen via Kessy,active
    (5)-Convert. top oper.-Verdeck schließen via Schließzylinder,active
    (15)-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,active
    (3)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00
    (30)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00
    (33)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00
    (36)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00
    (39)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00
    (42)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00
    (45)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00
    (6)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00
    (9)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00
    (12)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00
    (15)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00
    (18)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00
    (21)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00
    (24)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00
    (27)-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00
    (2)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door
    (29)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door
    (32)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door
    (35)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door
    (38)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door
    (41)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door
    (44)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door
    (5)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door
    (8)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door
    (11)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door
    (14)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door
    (17)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door
    (20)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door
    (23)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door
    (26)-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door
    (1)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1,not installed
    (28)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10,not installed
    (31)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11,not installed
    (34)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12,not installed
    (37)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13,not installed
    (40)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14,not installed
    (43)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15,not installed
    (4)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed
    (7)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3,not installed
    (10)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4,not installed
    (13)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5,not installed
    (16)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6,not installed
    (19)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7,not installed
    (22)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8,not installed
    (25)-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9,not installed
    (34)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12,0
    (1)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0
    (28)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10,0
    (31)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11,0
    (37)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13,0
    (40)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14,0
    (43)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15,0
    (46)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16,0
    (49)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17,0
    (52)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18,0
    (55)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19,0
    (4)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0
    (58)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20,0
    (7)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0
    (10)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0
    (13)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5,0
    (16)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6,0
    (19)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7,0
    (22)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8,0
    (25)-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9,0
    (3)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00
    (30)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10,0
    (33)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11,0
    (36)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12,0
    (39)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13,0
    (42)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14,0
    (45)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15,0
    (48)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16,0
    (51)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17,0
    (54)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18,0
    (57)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19,0
    (6)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0
    (60)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20,0
    (9)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0
    (12)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0
    (15)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5,0
    (18)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6,0
    (21)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7,0
    (27)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9,0
    (24)-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8,0
    (2)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed
    (29)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10,not installed
    (32)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11,not installed
    (35)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12,not installed
    (38)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13,not installed
    (41)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14,not installed
    (44)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15,not installed
    (47)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16,not installed
    (50)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17,not installed
    (53)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18,not installed
    (56)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19,not installed
    (5)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed
    (59)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20,not installed
    (8)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed
    (11)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed
    (14)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5,not installed
    (17)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6,not installed
    (20)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7,not installed
    (26)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9,not installed
    (23)-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8,not installed
    (1)-debug_light_function-Adresse,0
    (6)-debug_light_function-Aktivierung,0
    (2)-debug_light_function-Bitmask,0
    (4)-debug_light_function-Divisor,0
    (3)-debug_light_function-Offset,0
    (5)-debug_light_function-Polaritaet,0
    (7)-debug_light_function-WBT-Ausgabe,0
    (1)-Innenbeleuchtung Abdimmen-x0,0 ms
    (2)-Innenbeleuchtung Abdimmen-X1,200 ms
    (11)-Innenbeleuchtung Abdimmen-x10,2000 ms
    (3)-Innenbeleuchtung Abdimmen-X2,400 ms
    (4)-Innenbeleuchtung Abdimmen-X3,600 ms
    (5)-Innenbeleuchtung Abdimmen-X4,800 ms
    (6)-Innenbeleuchtung Abdimmen-X5,1000 ms
    (7)-Innenbeleuchtung Abdimmen-X6,1200 ms
    (8)-Innenbeleuchtung Abdimmen-x7,1400 ms
    (9)-Innenbeleuchtung Abdimmen-x8,1600 ms
    (10)-Innenbeleuchtung Abdimmen-x9,1800 ms
    (12)-Innenbeleuchtung Abdimmen-y0,100.00 %
    (13)-Innenbeleuchtung Abdimmen-Y1,100.00 %
    (22)-Innenbeleuchtung Abdimmen-y10,0.00 %
    (14)-Innenbeleuchtung Abdimmen-Y2,95.00 %
    (15)-Innenbeleuchtung Abdimmen-Y3,80.00 %
    (16)-Innenbeleuchtung Abdimmen-Y4,40.00 %
    (17)-Innenbeleuchtung Abdimmen-Y5,20.00 %
    (18)-Innenbeleuchtung Abdimmen-Y6,10.00 %
    (19)-Innenbeleuchtung Abdimmen-y7,5.00 %
    (20)-Innenbeleuchtung Abdimmen-y8,3.00 %
    (21)-Innenbeleuchtung Abdimmen-y9,1.00 %
    (1)-Innenbeleuchtung Fotosensor-x0,0
    (2)-Innenbeleuchtung Fotosensor-X1,50
    (11)-Innenbeleuchtung Fotosensor-x10,0
    (3)-Innenbeleuchtung Fotosensor-X2,100
    (4)-Innenbeleuchtung Fotosensor-X3,200
    (5)-Innenbeleuchtung Fotosensor-X4,253
    (6)-Innenbeleuchtung Fotosensor-X5,0
    (7)-Innenbeleuchtung Fotosensor-X6,0
    (8)-Innenbeleuchtung Fotosensor-x7,0
    (9)-Innenbeleuchtung Fotosensor-x8,0
    (10)-Innenbeleuchtung Fotosensor-x9,0
    (12)-Innenbeleuchtung Fotosensor-y0,0 lx
    (13)-Innenbeleuchtung Fotosensor-Y1,50 lx
    (22)-Innenbeleuchtung Fotosensor-y10,0 lx
    (14)-Innenbeleuchtung Fotosensor-Y2,100 lx
    (15)-Innenbeleuchtung Fotosensor-Y3,200
    (16)-Innenbeleuchtung Fotosensor-Y4,500
    (17)-Innenbeleuchtung Fotosensor-Y5,0
    (18)-Innenbeleuchtung Fotosensor-Y6,0 lx
    (19)-Innenbeleuchtung Fotosensor-y7,0 lx
    (20)-Innenbeleuchtung Fotosensor-y8,0 lx
    (21)-Innenbeleuchtung Fotosensor-y9,0 lx
    (1)-Innenbeleuchtung Hochdimmen-x0,0 ms
    (2)-Innenbeleuchtung Hochdimmen-X1,200 ms
    (11)-Innenbeleuchtung Hochdimmen-x10,2000 ms
    (3)-Innenbeleuchtung Hochdimmen-X2,400 ms
    (4)-Innenbeleuchtung Hochdimmen-X3,600 ms
    (5)-Innenbeleuchtung Hochdimmen-X4,800 ms
    (6)-Innenbeleuchtung Hochdimmen-X5,1000 ms
    (7)-Innenbeleuchtung Hochdimmen-X6,1200 ms
    (8)-Innenbeleuchtung Hochdimmen-x7,1400 ms
    (9)-Innenbeleuchtung Hochdimmen-x8,1600 ms
    (10)-Innenbeleuchtung Hochdimmen-x9,1800 ms
    (12)-Innenbeleuchtung Hochdimmen-y0,0.00 %
    (13)-Innenbeleuchtung Hochdimmen-Y1,1.00 %
    (22)-Innenbeleuchtung Hochdimmen-y10,100.00 %
    (14)-Innenbeleuchtung Hochdimmen-Y2,3.00 %
    (15)-Innenbeleuchtung Hochdimmen-Y3,5.00 %
    (16)-Innenbeleuchtung Hochdimmen-Y4,11.00 %
    (17)-Innenbeleuchtung Hochdimmen-Y5,22.00 %
    (18)-Innenbeleuchtung Hochdimmen-Y6,40.00 %
    (19)-Innenbeleuchtung Hochdimmen-y7,80.00 %
    (20)-Innenbeleuchtung Hochdimmen-y8,95.00 %
    (21)-Innenbeleuchtung Hochdimmen-y9,100.00 %
    (1)-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %
    (2)-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %
    (3)-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %
    (4)-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %
    (5)-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %
    (6)-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %
    (7)-Innenbeleuchtung KL 58xd log Bus-y0,10
    (8)-Innenbeleuchtung KL 58xd log Bus-Y1,10
    (9)-Innenbeleuchtung KL 58xd log Bus-Y2,100
    (10)-Innenbeleuchtung KL 58xd log Bus-Y3,150
    (11)-Innenbeleuchtung KL 58xd log Bus-Y4,220
    (12)-Innenbeleuchtung KL 58xd log Bus-Y5,253
    (1)-Innenbeleuchtung KL 58xd max-x0,0 lx
    (2)-Innenbeleuchtung KL 58xd max-X1,8 lx
    (3)-Innenbeleuchtung KL 58xd max-X2,200 lx
    (4)-Innenbeleuchtung KL 58xd max-X3,300 lx
    (5)-Innenbeleuchtung KL 58xd max-X4,500 lx
    (6)-Innenbeleuchtung KL 58xd max-y0,16.00
    (7)-Innenbeleuchtung KL 58xd max-Y1,16.00
    (8)-Innenbeleuchtung KL 58xd max-Y2,100.00
    (9)-Innenbeleuchtung KL 58xd max-Y3,100.00
    (10)-Innenbeleuchtung KL 58xd max-Y4,100.00
    (1)-Innenbeleuchtung KL 58xd min-x0,0 lx
    (2)-Innenbeleuchtung KL 58xd min-X1,8 lx
    (3)-Innenbeleuchtung KL 58xd min-X2,220 lx
    (4)-Innenbeleuchtung KL 58xd min-X3,300 lx
    (5)-Innenbeleuchtung KL 58xd min-X4,500 lx
    (6)-Innenbeleuchtung KL 58xd min-y0,6.00
    (7)-Innenbeleuchtung KL 58xd min-Y1,6.00
    (8)-Innenbeleuchtung KL 58xd min-Y2,100.00
    (9)-Innenbeleuchtung KL 58xd min-Y3,100.00
    (10)-Innenbeleuchtung KL 58xd min-Y4,100.00
    (1)-Innenbeleuchtung KL 58xd PWM-x0,0
    (2)-Innenbeleuchtung KL 58xd PWM-X1,10
    (3)-Innenbeleuchtung KL 58xd PWM-X2,100
    (4)-Innenbeleuchtung KL 58xd PWM-X3,150
    (5)-Innenbeleuchtung KL 58xd PWM-X4,220
    (6)-Innenbeleuchtung KL 58xd PWM-X5,253
    (7)-Innenbeleuchtung KL 58xd PWM-y0,6.00 %
    (8)-Innenbeleuchtung KL 58xd PWM-Y1,6.00 %
    (9)-Innenbeleuchtung KL 58xd PWM-Y2,16.00 %
    (10)-Innenbeleuchtung KL 58xd PWM-Y3,30.00 %
    (11)-Innenbeleuchtung KL 58xd PWM-Y4,60.00 %
    (12)-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %
    (1)-Innenbeleuchtung KL 58xs max-x0,0 lx
    (2)-Innenbeleuchtung KL 58xs max-X1,8 lx
    (3)-Innenbeleuchtung KL 58xs max-X2,50 lx
    (4)-Innenbeleuchtung KL 58xs max-X3,500 lx
    (5)-Innenbeleuchtung KL 58xs max-y0,100.00
    (6)-Innenbeleuchtung KL 58xs max-Y1,100.00
    (7)-Innenbeleuchtung KL 58xs max-Y2,100.00
    (8)-Innenbeleuchtung KL 58xs max-Y3,100.00
    (1)-Innenbeleuchtung KL 58xs min-x0,0 lx
    (2)-Innenbeleuchtung KL 58xs min-X1,8 lx
    (3)-Innenbeleuchtung KL 58xs min-X2,50 lx
    (4)-Innenbeleuchtung KL 58xs min-X3,500 lx
    (5)-Innenbeleuchtung KL 58xs min-y0,6.00
    (6)-Innenbeleuchtung KL 58xs min-Y1,6.00
    (7)-Innenbeleuchtung KL 58xs min-Y2,100.00
    (8)-Innenbeleuchtung KL 58xs min-Y3,100.00
    (1)-Innenbeleuchtung KL 58xs PWM-x0,0.00 %
    (2)-Innenbeleuchtung KL 58xs PWM-X1,50.00 %
    (3)-Innenbeleuchtung KL 58xs PWM-X2,100.00 %
    (4)-Innenbeleuchtung KL 58xs PWM-y0,0.00 %
    (5)-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %
    (6)-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %
    (1)-Innenbeleuchtung KL 58xt max-x0,0 lx
    (2)-Innenbeleuchtung KL 58xt max-X1,8 lx
    (3)-Innenbeleuchtung KL 58xt max-X2,50 lx
    (4)-Innenbeleuchtung KL 58xt max-X3,500 lx
    (5)-Innenbeleuchtung KL 58xt max-y0,100.00
    (6)-Innenbeleuchtung KL 58xt max-Y1,100.00
    (7)-Innenbeleuchtung KL 58xt max-Y2,100.00
    (8)-Innenbeleuchtung KL 58xt max-Y3,100.00
    (1)-Innenbeleuchtung KL 58xt min-x0,0 lx
    (2)-Innenbeleuchtung KL 58xt min-X1,8 lx
    (3)-Innenbeleuchtung KL 58xt min-X2,50 lx
    (4)-Innenbeleuchtung KL 58xt min-X3,500 lx
    (5)-Innenbeleuchtung KL 58xt min-y0,6.00
    (6)-Innenbeleuchtung KL 58xt min-Y1,6.00
    (7)-Innenbeleuchtung KL 58xt min-Y2,100.00
    (8)-Innenbeleuchtung KL 58xt min-Y3,100.00
    (1)-Innenbeleuchtung KL 58xt PWM-x0,0.00 %
    (2)-Innenbeleuchtung KL 58xt PWM-X1,50.00 %
    (3)-Innenbeleuchtung KL 58xt PWM-X2,100.00 %
    (4)-Innenbeleuchtung KL 58xt PWM-y0,0.00 %
    (5)-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %
    (6)-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %
    (1)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms
    (2)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,2000 ms
    (3)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,3000 ms
    (4)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,4000 ms
    (5)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,5100 ms
    (6)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %
    (7)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00
    (8)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00
    (9)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,40.00
    (10)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00
    (1)-Kopfraumheizung-blower_speed,1
    (2)-Kopfraumheizung-Temperature,-2
    (11)-Leuchte 0 BLK VL B36-Dimming Direction CD 0,maximize
    (15)-Leuchte 0 BLK VL B36-Dimming Direction EF 0,maximize
    (19)-Leuchte 0 BLK VL B36-Dimming Direction GH 0,maximize
    (6)-Leuchte 0 BLK VL B36-Dimmwert AB 0,127
    (10)-Leuchte 0 BLK VL B36-Dimmwert CD 0,0
    (14)-Leuchte 0 BLK VL B36-Dimmwert EF 0,0
    (18)-Leuchte 0 BLK VL B36-Dimmwert GH 0,0
    (3)-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14
    (2)-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34
    (1)-Leuchte 0 BLK VL B36-Lasttyp 0,33 - LED-Modul Blinkleuchten
    (7)-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0,Always
    (4)-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase
    (5)-Leuchte 0 BLK VL B36-Lichtfunktion B 0,nicht aktiv
    (8)-Leuchte 0 BLK VL B36-Lichtfunktion C 0,Blinken links Dunkelphase
    (9)-Leuchte 0 BLK VL B36-Lichtfunktion D 0,nicht aktiv
    (12)-Leuchte 0 BLK VL B36-Lichtfunktion E 0,nicht aktiv
    (13)-Leuchte 0 BLK VL B36-Lichtfunktion F 0,nicht aktiv
    (16)-Leuchte 0 BLK VL B36-Lichtfunktion G 0,nicht aktiv
    (17)-Leuchte 0 BLK VL B36-Lichtfunktion H 0,nicht aktiv
    (11)-Leuchte10SHUTTER LB23-Dimming Direction CD 10,maximize
    (15)-Leuchte10SHUTTER LB23-Dimming Direction EF 10,maximize
    (19)-Leuchte10SHUTTER LB23-Dimming Direction GH 10,maximize
    (6)-Leuchte10SHUTTER LB23-Dimmwert AB 10,127
    (10)-Leuchte10SHUTTER LB23-Dimmwert CD 10,0
    (14)-Leuchte10SHUTTER LB23-Dimmwert EF 10,0
    (18)-Leuchte10SHUTTER LB23-Dimmwert GH 10,0
    (3)-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,62
    (2)-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00
    (1)-Leuchte10SHUTTER LB23-Lasttyp 10,4 - LED Tagfahrlichtmodul Signal
    (7)-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10,Always
    (4)-Leuchte10SHUTTER LB23-Lichtfunktion A 10,Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken
    (5)-Leuchte10SHUTTER LB23-Lichtfunktion B 10,nicht aktiv
    (8)-Leuchte10SHUTTER LB23-Lichtfunktion C 10,nicht aktiv
    (9)-Leuchte10SHUTTER LB23-Lichtfunktion D 10,nicht aktiv
    (12)-Leuchte10SHUTTER LB23-Lichtfunktion E 10,nicht aktiv
    (13)-Leuchte10SHUTTER LB23-Lichtfunktion F 10,nicht aktiv
    (16)-Leuchte10SHUTTER LB23-Lichtfunktion G 10,nicht aktiv
    (17)-Leuchte10SHUTTER LB23-Lichtfunktion H 10,nicht aktiv
    (11)-Leuchte11SHUTTER RB22-Dimming Direction CD 11,maximize
    (15)-Leuchte11SHUTTER RB22-Dimming Direction EF 11,maximize
    (19)-Leuchte11SHUTTER RB22-Dimming Direction GH 11,maximize
    (6)-Leuchte11SHUTTER RB22-Dimmwert AB 11,127
    (10)-Leuchte11SHUTTER RB22-Dimmwert CD 11,0
    (14)-Leuchte11SHUTTER RB22-Dimmwert EF 11,0
    (18)-Leuchte11SHUTTER RB22-Dimmwert GH 11,0
    (3)-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,62
    (2)-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,00
    (1)-Leuchte11SHUTTER RB22-Lasttyp 11,4 - LED Tagfahrlichtmodul Signal
    (7)-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11,Always
    (4)-Leuchte11SHUTTER RB22-Lichtfunktion A 11,Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken
    (5)-Leuchte11SHUTTER RB22-Lichtfunktion B 11,nicht aktiv
    (8)-Leuchte11SHUTTER RB22-Lichtfunktion C 11,nicht aktiv
    (9)-Leuchte11SHUTTER RB22-Lichtfunktion D 11,nicht aktiv
    (12)-Leuchte11SHUTTER RB22-Lichtfunktion E 11,nicht aktiv
    (13)-Leuchte11SHUTTER RB22-Lichtfunktion F 11,nicht aktiv
    (16)-Leuchte11SHUTTER RB22-Lichtfunktion G 11,nicht aktiv
    (17)-Leuchte11SHUTTER RB22-Lichtfunktion H 11,nicht aktiv
    (11)-Leuchte12NL LB45-Dimming Direction CD 12,maximize
    (15)-Leuchte12NL LB45-Dimming Direction EF 12,maximize
    (19)-Leuchte12NL LB45-Dimming Direction GH 12,maximize
    (6)-Leuchte12NL LB45-Dimmwert AB 12,0
    (10)-Leuchte12NL LB45-Dimmwert CD 12,0
    (14)-Leuchte12NL LB45-Dimmwert EF 12,0
    (18)-Leuchte12NL LB45-Dimmwert GH 12,0
    (3)-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,00
    (2)-Leuchte12NL LB45-Lampendefektbitposition 12,00
    (1)-Leuchte12NL LB45-Lasttyp 12,not active
    (7)-Leuchte12NL LB45-Lichtansteuerung HD AB 12,Always
    (4)-Leuchte12NL LB45-Lichtfunktion A 12,nicht aktiv
    (5)-Leuchte12NL LB45-Lichtfunktion B 12,nicht aktiv
    (8)-Leuchte12NL LB45-Lichtfunktion C 12,nicht aktiv
    (9)-Leuchte12NL LB45-Lichtfunktion D 12,nicht aktiv
    (12)-Leuchte12NL LB45-Lichtfunktion E 12,nicht aktiv
    (13)-Leuchte12NL LB45-Lichtfunktion F 12,nicht aktiv
    (16)-Leuchte12NL LB45-Lichtfunktion G 12,nicht aktiv
    (17)-Leuchte12NL LB45-Lichtfunktion H 12,nicht aktiv
    (11)-Leuchte13NL RB5-Dimming Direction CD 13,maximize
    (15)-Leuchte13NL RB5-Dimming Direction EF 13,maximize
    (19)-Leuchte13NL RB5-Dimming Direction GH 13,maximize
    (6)-Leuchte13NL RB5-Dimmwert AB 13,100
    (10)-Leuchte13NL RB5-Dimmwert CD 13,0
    (14)-Leuchte13NL RB5-Dimmwert EF 13,0
    (18)-Leuchte13NL RB5-Dimmwert GH 13,0
    (3)-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,00
    (2)-Leuchte13NL RB5-Lampendefektbitposition 13,00
    (1)-Leuchte13NL RB5-Lasttyp 13,not active
    (7)-Leuchte13NL RB5-Lichtansteuerung HD AB 13,Always
    (4)-Leuchte13NL RB5-Lichtfunktion A 13,nicht aktiv
    (5)-Leuchte13NL RB5-Lichtfunktion B 13,nicht aktiv
    (8)-Leuchte13NL RB5-Lichtfunktion C 13,nicht aktiv
    (9)-Leuchte13NL RB5-Lichtfunktion D 13,nicht aktiv
    (12)-Leuchte13NL RB5-Lichtfunktion E 13,nicht aktiv
    (13)-Leuchte13NL RB5-Lichtfunktion F 13,nicht aktiv
    (16)-Leuchte13NL RB5-Lichtfunktion G 13,nicht aktiv
    (17)-Leuchte13NL RB5-Lichtfunktion H 13,nicht aktiv
    (11)-Leuchte15AL RB44-Dimming Direction CD 15,maximize
    (15)-Leuchte15AL RB44-Dimming Direction EF 15,maximize
    (19)-Leuchte15AL RB44-Dimming Direction GH 15,maximize
    (6)-Leuchte15AL RB44-Dimmwert AB 15,0
    (10)-Leuchte15AL RB44-Dimmwert CD 15,0
    (14)-Leuchte15AL RB44-Dimmwert EF 15,0
    (18)-Leuchte15AL RB44-Dimmwert GH 15,0
    (3)-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00
    (2)-Leuchte15AL RB44-Lampendefektbitposition 15,00
    (1)-Leuchte15AL RB44-Lasttyp 15,not active
    (7)-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always
    (4)-Leuchte15AL RB44-Lichtfunktion A 15,nicht aktiv
    (5)-Leuchte15AL RB44-Lichtfunktion B 15,nicht aktiv
    (8)-Leuchte15AL RB44-Lichtfunktion C 15,nicht aktiv
    (9)-Leuchte15AL RB44-Lichtfunktion D 15,nicht aktiv
    (12)-Leuchte15AL RB44-Lichtfunktion E 15,nicht aktiv
    (13)-Leuchte15AL RB44-Lichtfunktion F 15,nicht aktiv
    (16)-Leuchte15AL RB44-Lichtfunktion G 15,nicht aktiv
    (17)-Leuchte15AL RB44-Lichtfunktion H 15,nicht aktiv
    (11)-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16,maximize
    (15)-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16,maximize
    (19)-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16,maximize
    (6)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,127
    (10)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16,0
    (14)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16,0
    (18)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16,0
    (3)-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,41
    (2)-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,08
    (1)-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,38 - LED Blinkleuchten
    (7)-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always
    (4)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Blinken links Hellphase
    (5)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,nicht aktiv
    (8)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,Blinken links Dunkelphase
    (9)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16,nicht aktiv
    (12)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16,nicht aktiv
    (13)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16,nicht aktiv
    (16)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16,nicht aktiv
    (17)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16,nicht aktiv
    (11)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17,maximize
    (15)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17,maximize
    (19)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17,maximize
    (6)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,127
    (10)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17,0
    (14)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17,0
    (18)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17,0
    (3)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,42
    (2)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,18
    (1)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,38 - LED Blinkleuchten
    (7)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always
    (4)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Blinken rechts Hellphase
    (5)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,nicht aktiv
    (8)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,Blinken rechts Dunkelphase
    (9)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17,nicht aktiv
    (12)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17,nicht aktiv
    (13)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17,nicht aktiv
    (16)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17,nicht aktiv
    (17)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17,nicht aktiv
    (11)-Leuchte18BLK HLA60-Dimming Direction CD 18,maximize
    (15)-Leuchte18BLK HLA60-Dimming Direction EF 18,maximize
    (19)-Leuchte18BLK HLA60-Dimming Direction GH 18,maximize
    (6)-Leuchte18BLK HLA60-Dimmwert AB 18,127
    (10)-Leuchte18BLK HLA60-Dimmwert CD 18,0
    (14)-Leuchte18BLK HLA60-Dimmwert EF 18,0
    (18)-Leuchte18BLK HLA60-Dimmwert GH 18,0
    (3)-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,16
    (2)-Leuchte18BLK HLA60-Lampendefektbitposition 18,08
    (1)-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten
    (7)-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18,Always
    (4)-Leuchte18BLK HLA60-Lichtfunktion A 18,Blinken links Hellphase
    (5)-Leuchte18BLK HLA60-Lichtfunktion B 18,nicht aktiv
    (8)-Leuchte18BLK HLA60-Lichtfunktion C 18,Blinken links Dunkelphase
    (9)-Leuchte18BLK HLA60-Lichtfunktion D 18,nicht aktiv
    (12)-Leuchte18BLK HLA60-Lichtfunktion E 18,nicht aktiv
    (13)-Leuchte18BLK HLA60-Lichtfunktion F 18,nicht aktiv
    (16)-Leuchte18BLK HLA60-Lichtfunktion G 18,nicht aktiv
    (17)-Leuchte18BLK HLA60-Lichtfunktion H 18,nicht aktiv
    (11)-Leuchte19BLK HRC31-Dimming Direction CD 19,maximize
    (15)-Leuchte19BLK HRC31-Dimming Direction EF 19,maximize
    (19)-Leuchte19BLK HRC31-Dimming Direction GH 19,maximize
    (6)-Leuchte19BLK HRC31-Dimmwert AB 19,127
    (10)-Leuchte19BLK HRC31-Dimmwert CD 19,0
    (14)-Leuchte19BLK HRC31-Dimmwert EF 19,0
    (18)-Leuchte19BLK HRC31-Dimmwert GH 19,0
    (3)-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,18
    (2)-Leuchte19BLK HRC31-Lampendefektbitposition 19,18
    (1)-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten
    (7)-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19,Always
    (4)-Leuchte19BLK HRC31-Lichtfunktion A 19,Blinken rechts Hellphase
    (5)-Leuchte19BLK HRC31-Lichtfunktion B 19,nicht aktiv
    (8)-Leuchte19BLK HRC31-Lichtfunktion C 19,Blinken rechts Dunkelphase
    (9)-Leuchte19BLK HRC31-Lichtfunktion D 19,nicht aktiv
    (12)-Leuchte19BLK HRC31-Lichtfunktion E 19,nicht aktiv
    (13)-Leuchte19BLK HRC31-Lichtfunktion F 19,nicht aktiv
    (16)-Leuchte19BLK HRC31-Lichtfunktion G 19,nicht aktiv
    (17)-Leuchte19BLK HRC31-Lichtfunktion H 19,nicht aktiv
    (11)-Leuchte1BLK VRB20-Dimming Direction CD 1,maximize
    (15)-Leuchte1BLK VRB20-Dimming Direction EF 1,maximize
    (19)-Leuchte1BLK VRB20-Dimming Direction GH 1,maximize
    (6)-Leuchte1BLK VRB20-Dimmwert AB 1,127
    (10)-Leuchte1BLK VRB20-Dimmwert CD 1,0
    (14)-Leuchte1BLK VRB20-Dimmwert EF 1,0
    (18)-Leuchte1BLK VRB20-Dimmwert GH 1,0
    (3)-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15
    (2)-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E
    (1)-Leuchte1BLK VRB20-Lasttyp 1,33 - LED-Modul Blinkleuchten
    (7)-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1,Always
    (4)-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase
    (5)-Leuchte1BLK VRB20-Lichtfunktion B 1,nicht aktiv
    (8)-Leuchte1BLK VRB20-Lichtfunktion C 1,Blinken rechts Dunkelphase
    (9)-Leuchte1BLK VRB20-Lichtfunktion D 1,nicht aktiv
    (12)-Leuchte1BLK VRB20-Lichtfunktion E 1,nicht aktiv
    (13)-Leuchte1BLK VRB20-Lichtfunktion F 1,nicht aktiv
    (16)-Leuchte1BLK VRB20-Lichtfunktion G 1,nicht aktiv
    (17)-Leuchte1BLK VRB20-Lichtfunktion H 1,nicht aktiv
    (11)-Leuchte20BR LA71-Dimming Direction CD 20,maximize
    (15)-Leuchte20BR LA71-Dimming Direction EF 20,maximize
    (19)-Leuchte20BR LA71-Dimming Direction GH 20,maximize
    (6)-Leuchte20BR LA71-Dimmwert AB 20,100
    (10)-Leuchte20BR LA71-Dimmwert CD 20,0
    (14)-Leuchte20BR LA71-Dimmwert EF 20,0
    (18)-Leuchte20BR LA71-Dimmwert GH 20,0
    (3)-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,2B
    (2)-Leuchte20BR LA71-Lampendefektbitposition 20,09
    (1)-Leuchte20BR LA71-Lasttyp 20,39 - LED Bremsleuchten
    (7)-Leuchte20BR LA71-Lichtansteuerung HD AB 20,Always
    (4)-Leuchte20BR LA71-Lichtfunktion A 20,Bremslicht
    (5)-Leuchte20BR LA71-Lichtfunktion B 20,nicht aktiv
    (8)-Leuchte20BR LA71-Lichtfunktion C 20,nicht aktiv
    (9)-Leuchte20BR LA71-Lichtfunktion D 20,nicht aktiv
    (12)-Leuchte20BR LA71-Lichtfunktion E 20,nicht aktiv
    (13)-Leuchte20BR LA71-Lichtfunktion F 20,nicht aktiv
    (16)-Leuchte20BR LA71-Lichtfunktion G 20,nicht aktiv
    (17)-Leuchte20BR LA71-Lichtfunktion H 20,nicht aktiv
    (11)-Leuchte21BR RC8-Dimming Direction CD 21,maximize
    (15)-Leuchte21BR RC8-Dimming Direction EF 21,maximize
    (19)-Leuchte21BR RC8-Dimming Direction GH 21,maximize
    (6)-Leuchte21BR RC8-Dimmwert AB 21,100
    (10)-Leuchte21BR RC8-Dimmwert CD 21,0
    (14)-Leuchte21BR RC8-Dimmwert EF 21,0
    (18)-Leuchte21BR RC8-Dimmwert GH 21,0
    (3)-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,2D
    (2)-Leuchte21BR RC8-Lampendefektbitposition 21,19
    (1)-Leuchte21BR RC8-Lasttyp 21,39 - LED Bremsleuchten
    (7)-Leuchte21BR RC8-Lichtansteuerung HD AB 21,Always
    (4)-Leuchte21BR RC8-Lichtfunktion A 21,Bremslicht
    (5)-Leuchte21BR RC8-Lichtfunktion B 21,nicht aktiv
    (8)-Leuchte21BR RC8-Lichtfunktion C 21,nicht aktiv
    (9)-Leuchte21BR RC8-Lichtfunktion D 21,nicht aktiv
    (12)-Leuchte21BR RC8-Lichtfunktion E 21,nicht aktiv
    (13)-Leuchte21BR RC8-Lichtfunktion F 21,nicht aktiv
    (16)-Leuchte21BR RC8-Lichtfunktion G 21,nicht aktiv
    (17)-Leuchte21BR RC8-Lichtfunktion H 21,nicht aktiv
    (11)-Leuchte22BR MA57-Dimming Direction CD 22,maximize
    (15)-Leuchte22BR MA57-Dimming Direction EF 22,maximize
    (19)-Leuchte22BR MA57-Dimming Direction GH 22,maximize
    (6)-Leuchte22BR MA57-Dimmwert AB 22,100
    (10)-Leuchte22BR MA57-Dimmwert CD 22,0
    (14)-Leuchte22BR MA57-Dimmwert EF 22,0
    (18)-Leuchte22BR MA57-Dimmwert GH 22,0
    (3)-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22,2C
    (2)-Leuchte22BR MA57-Lampendefektbitposition 22,29
    (1)-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte
    (7)-Leuchte22BR MA57-Lichtansteuerung HD AB 22,Always
    (4)-Leuchte22BR MA57-Lichtfunktion A 22,Bremslicht
    (5)-Leuchte22BR MA57-Lichtfunktion B 22,nicht aktiv
    (8)-Leuchte22BR MA57-Lichtfunktion C 22,nicht aktiv
    (9)-Leuchte22BR MA57-Lichtfunktion D 22,nicht aktiv
    (12)-Leuchte22BR MA57-Lichtfunktion E 22,nicht aktiv
    (13)-Leuchte22BR MA57-Lichtfunktion F 22,nicht aktiv
    (16)-Leuchte22BR MA57-Lichtfunktion G 22,nicht aktiv
    (17)-Leuchte22BR MA57-Lichtfunktion H 22,nicht aktiv
    (11)-Leuchte23SL HLC10-Dimming Direction CD 23,maximize
    (15)-Leuchte23SL HLC10-Dimming Direction EF 23,maximize
    (19)-Leuchte23SL HLC10-Dimming Direction GH 23,maximize
    (6)-Leuchte23SL HLC10-Dimmwert AB 23,80
    (10)-Leuchte23SL HLC10-Dimmwert CD 23,80
    (14)-Leuchte23SL HLC10-Dimmwert EF 23,80
    (18)-Leuchte23SL HLC10-Dimmwert GH 23,0
    (3)-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,29
    (2)-Leuchte23SL HLC10-Lampendefektbitposition 23,0A
    (1)-Leuchte23SL HLC10-Lasttyp 23,37 - allgemeine LED bis 12W
    (7)-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,Always
    (4)-Leuchte23SL HLC10-Lichtfunktion A 23,Standlicht allgemein (Schlusslicht	 Positionslicht	 Begrenzungslicht)
    (5)-Leuchte23SL HLC10-Lichtfunktion B 23,Coming Home oder Leaving Home aktiv
    (8)-Leuchte23SL HLC10-Lichtfunktion C 23,Parklicht links (beidseitiges Parklicht aktiviert li & re)
    (9)-Leuchte23SL HLC10-Lichtfunktion D 23,nicht aktiv
    (12)-Leuchte23SL HLC10-Lichtfunktion E 23,Tagfahrlicht
    (13)-Leuchte23SL HLC10-Lichtfunktion F 23,nicht aktiv
    (16)-Leuchte23SL HLC10-Lichtfunktion G 23,nicht aktiv
    (17)-Leuchte23SL HLC10-Lichtfunktion H 23,nicht aktiv
    (11)-Leuchte24SL HRA65-Dimming Direction CD 24,maximize
    (15)-Leuchte24SL HRA65-Dimming Direction EF 24,maximize
    (19)-Leuchte24SL HRA65-Dimming Direction GH 24,maximize
    (6)-Leuchte24SL HRA65-Dimmwert AB 24,80
    (10)-Leuchte24SL HRA65-Dimmwert CD 24,80
    (14)-Leuchte24SL HRA65-Dimmwert EF 24,80
    (18)-Leuchte24SL HRA65-Dimmwert GH 24,0
    (3)-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,2A
    (2)-Leuchte24SL HRA65-Lampendefektbitposition 24,1A
    (1)-Leuchte24SL HRA65-Lasttyp 24,37 - allgemeine LED bis 12W
    (7)-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,Always
    (4)-Leuchte24SL HRA65-Lichtfunktion A 24,Standlicht allgemein (Schlusslicht	 Positionslicht	 Begrenzungslicht)
    (5)-Leuchte24SL HRA65-Lichtfunktion B 24,Coming Home oder Leaving Home aktiv
    (8)-Leuchte24SL HRA65-Lichtfunktion C 24,Parklicht rechts
    (9)-Leuchte24SL HRA65-Lichtfunktion D 24,nicht aktiv
    (12)-Leuchte24SL HRA65-Lichtfunktion E 24,Tagfahrlicht
    (13)-Leuchte24SL HRA65-Lichtfunktion F 24,nicht aktiv
    (16)-Leuchte24SL HRA65-Lichtfunktion G 24,nicht aktiv
    (17)-Leuchte24SL HRA65-Lichtfunktion H 24,nicht aktiv
    (11)-Leuchte25KZL HA59-Dimming Direction CD 25,maximize
    (15)-Leuchte25KZL HA59-Dimming Direction EF 25,maximize
    (19)-Leuchte25KZL HA59-Dimming Direction GH 25,maximize
    (6)-Leuchte25KZL HA59-Dimmwert AB 25,100
    (10)-Leuchte25KZL HA59-Dimmwert CD 25,100
    (14)-Leuchte25KZL HA59-Dimmwert EF 25,0
    (18)-Leuchte25KZL HA59-Dimmwert GH 25,0
    (3)-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25,30
    (2)-Leuchte25KZL HA59-Lampendefektbitposition 25,28
    (1)-Leuchte25KZL HA59-Lasttyp 25,43 - allgemeine LED
    (7)-Leuchte25KZL HA59-Lichtansteuerung HD AB 25,Always
    (4)-Leuchte25KZL HA59-Lichtfunktion A 25,Standlicht allgemein (Schlusslicht	 Positionslicht	 Begrenzungslicht)
    (5)-Leuchte25KZL HA59-Lichtfunktion B 25,Coming Home oder Leaving Home aktiv
    (8)-Leuchte25KZL HA59-Lichtfunktion C 25,Tagfahrlicht
    (9)-Leuchte25KZL HA59-Lichtfunktion D 25,nicht aktiv
    (12)-Leuchte25KZL HA59-Lichtfunktion E 25,nicht aktiv
    (13)-Leuchte25KZL HA59-Lichtfunktion F 25,nicht aktiv
    (16)-Leuchte25KZL HA59-Lichtfunktion G 25,nicht aktiv
    (17)-Leuchte25KZL HA59-Lichtfunktion H 25,nicht aktiv
    (11)-Leuchte26NSL LA72-Dimming Direction CD 26,maximize
    (15)-Leuchte26NSL LA72-Dimming Direction EF 26,maximize
    (19)-Leuchte26NSL LA72-Dimming Direction GH 26,maximize
    (6)-Leuchte26NSL LA72-Dimmwert AB 26,127
    (10)-Leuchte26NSL LA72-Dimmwert CD 26,0
    (14)-Leuchte26NSL LA72-Dimmwert EF 26,0
    (18)-Leuchte26NSL LA72-Dimmwert GH 26,0
    (3)-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2E
    (2)-Leuchte26NSL LA72-Lampendefektbitposition 26,0C
    (1)-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED
    (7)-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed
    (4)-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt
    (5)-Leuchte26NSL LA72-Lichtfunktion B 26,nicht aktiv
    (8)-Leuchte26NSL LA72-Lichtfunktion C 26,nicht aktiv
    (9)-Leuchte26NSL LA72-Lichtfunktion D 26,nicht aktiv
    (12)-Leuchte26NSL LA72-Lichtfunktion E 26,nicht aktiv
    (13)-Leuchte26NSL LA72-Lichtfunktion F 26,nicht aktiv
    (16)-Leuchte26NSL LA72-Lichtfunktion G 26,nicht aktiv
    (17)-Leuchte26NSL LA72-Lichtfunktion H 26,nicht aktiv
    (11)-Leuchte27NSL RC6-Dimming Direction CD 27,maximize
    (15)-Leuchte27NSL RC6-Dimming Direction EF 27,maximize
    (19)-Leuchte27NSL RC6-Dimming Direction GH 27,maximize
    (6)-Leuchte27NSL RC6-Dimmwert AB 27,127
    (10)-Leuchte27NSL RC6-Dimmwert CD 27,0
    (14)-Leuchte27NSL RC6-Dimmwert EF 27,0
    (18)-Leuchte27NSL RC6-Dimmwert GH 27,0
    (3)-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,2F
    (2)-Leuchte27NSL RC6-Lampendefektbitposition 27,1C
    (1)-Leuchte27NSL RC6-Lasttyp 27,43 - allgemeine LED
    (7)-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,only_if_closed
    (4)-Leuchte27NSL RC6-Lichtfunktion A 27,Nebelschlusslicht wenn kein Anhaenger gesteckt
    (5)-Leuchte27NSL RC6-Lichtfunktion B 27,nicht aktiv
    (8)-Leuchte27NSL RC6-Lichtfunktion C 27,nicht aktiv
    (9)-Leuchte27NSL RC6-Lichtfunktion D 27,nicht aktiv
    (12)-Leuchte27NSL RC6-Lichtfunktion E 27,nicht aktiv
    (13)-Leuchte27NSL RC6-Lichtfunktion F 27,nicht aktiv
    (16)-Leuchte27NSL RC6-Lichtfunktion G 27,nicht aktiv
    (17)-Leuchte27NSL RC6-Lichtfunktion H 27,nicht aktiv
    (11)-Leuchte28RFL LC11-Dimming Direction CD 28,maximize
    (15)-Leuchte28RFL LC11-Dimming Direction EF 28,maximize
    (19)-Leuchte28RFL LC11-Dimming Direction GH 28,maximize
    (6)-Leuchte28RFL LC11-Dimmwert AB 28,100
    (10)-Leuchte28RFL LC11-Dimmwert CD 28,0
    (14)-Leuchte28RFL LC11-Dimmwert EF 28,0
    (18)-Leuchte28RFL LC11-Dimmwert GH 28,0
    (3)-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28,31
    (2)-Leuchte28RFL LC11-Lampendefektbitposition 28,0B
    (1)-Leuchte28RFL LC11-Lasttyp 28,37 - allgemeine LED bis 12W
    (7)-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always
    (4)-Leuchte28RFL LC11-Lichtfunktion A 28,Rueckfahrlicht
    (5)-Leuchte28RFL LC11-Lichtfunktion B 28,nicht aktiv
    (8)-Leuchte28RFL LC11-Lichtfunktion C 28,nicht aktiv
    (9)-Leuchte28RFL LC11-Lichtfunktion D 28,nicht aktiv
    (12)-Leuchte28RFL LC11-Lichtfunktion E 28,nicht aktiv
    (13)-Leuchte28RFL LC11-Lichtfunktion F 28,nicht aktiv
    (16)-Leuchte28RFL LC11-Lichtfunktion G 28,nicht aktiv
    (17)-Leuchte28RFL LC11-Lichtfunktion H 28,nicht aktiv
    (11)-Leuchte29RFL RA64-Dimming Direction CD 29,maximize
    (15)-Leuchte29RFL RA64-Dimming Direction EF 29,maximize
    (19)-Leuchte29RFL RA64-Dimming Direction GH 29,maximize
    (6)-Leuchte29RFL RA64-Dimmwert AB 29,100
    (10)-Leuchte29RFL RA64-Dimmwert CD 29,0
    (14)-Leuchte29RFL RA64-Dimmwert EF 29,0
    (18)-Leuchte29RFL RA64-Dimmwert GH 29,0
    (3)-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29,32
    (2)-Leuchte29RFL RA64-Lampendefektbitposition 29,1B
    (1)-Leuchte29RFL RA64-Lasttyp 29,37 - allgemeine LED bis 12W
    (7)-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always
    (4)-Leuchte29RFL RA64-Lichtfunktion A 29,Rueckfahrlicht
    (5)-Leuchte29RFL RA64-Lichtfunktion B 29,nicht aktiv
    (8)-Leuchte29RFL RA64-Lichtfunktion C 29,nicht aktiv
    (9)-Leuchte29RFL RA64-Lichtfunktion D 29,nicht aktiv
    (12)-Leuchte29RFL RA64-Lichtfunktion E 29,nicht aktiv
    (13)-Leuchte29RFL RA64-Lichtfunktion F 29,nicht aktiv
    (16)-Leuchte29RFL RA64-Lichtfunktion G 29,nicht aktiv
    (17)-Leuchte29RFL RA64-Lichtfunktion H 29,nicht aktiv
    (11)-Leuchte2SL VLB10-Dimming Direction CD 2,maximize
    (15)-Leuchte2SL VLB10-Dimming Direction EF 2,maximize
    (19)-Leuchte2SL VLB10-Dimming Direction GH 2,minimize
    (6)-Leuchte2SL VLB10-Dimmwert AB 2,30
    (10)-Leuchte2SL VLB10-Dimmwert CD 2,30
    (14)-Leuchte2SL VLB10-Dimmwert EF 2,100
    (18)-Leuchte2SL VLB10-Dimmwert GH 2,10
    (3)-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A
    (2)-Leuchte2SL VLB10-Lampendefektbitposition 2,48
    (1)-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal
    (7)-Leuchte2SL VLB10-Lichtansteuerung HD AB 2,Always
    (4)-Leuchte2SL VLB10-Lichtfunktion A 2,Standlicht allgemein (Schlusslicht	 Positionslicht	 Begrenzungslicht)
    (5)-Leuchte2SL VLB10-Lichtfunktion B 2,Parklicht links (beidseitiges Parklicht aktiviert li & re)
    (8)-Leuchte2SL VLB10-Lichtfunktion C 2,Coming Home oder Leaving Home aktiv
    (9)-Leuchte2SL VLB10-Lichtfunktion D 2,nicht aktiv
    (12)-Leuchte2SL VLB10-Lichtfunktion E 2,Tagfahrlicht
    (13)-Leuchte2SL VLB10-Lichtfunktion F 2,nicht aktiv
    (16)-Leuchte2SL VLB10-Lichtfunktion G 2,Blinken links aktiv (beide Phasen)
    (17)-Leuchte2SL VLB10-Lichtfunktion H 2,nicht aktiv
    (11)-Leuchte30FR LC72-Dimming Direction CD 30,maximize
    (15)-Leuchte30FR LC72-Dimming Direction EF 30,maximize
    (19)-Leuchte30FR LC72-Dimming Direction GH 30,maximize
    (6)-Leuchte30FR LC72-Dimmwert AB 30,100
    (10)-Leuchte30FR LC72-Dimmwert CD 30,0
    (14)-Leuchte30FR LC72-Dimmwert EF 30,0
    (18)-Leuchte30FR LC72-Dimmwert GH 30,0
    (3)-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,02
    (2)-Leuchte30FR LC72-Lampendefektbitposition 30,00
    (1)-Leuchte30FR LC72-Lasttyp 30,46 - LED Kleinleistung
    (7)-Leuchte30FR LC72-Lichtansteuerung HD AB 30,Always
    (4)-Leuchte30FR LC72-Lichtfunktion A 30,Fussraumlicht
    (5)-Leuchte30FR LC72-Lichtfunktion B 30,nicht aktiv
    (8)-Leuchte30FR LC72-Lichtfunktion C 30,nicht aktiv
    (9)-Leuchte30FR LC72-Lichtfunktion D 30,nicht aktiv
    (12)-Leuchte30FR LC72-Lichtfunktion E 30,nicht aktiv
    (13)-Leuchte30FR LC72-Lichtfunktion F 30,nicht aktiv
    (16)-Leuchte30FR LC72-Lichtfunktion G 30,nicht aktiv
    (17)-Leuchte30FR LC72-Lichtfunktion H 30,nicht aktiv
    (11)-Leuchte31AMBL 1C61-Dimming Direction CD 31,maximize
    (15)-Leuchte31AMBL 1C61-Dimming Direction EF 31,maximize
    (19)-Leuchte31AMBL 1C61-Dimming Direction GH 31,maximize
    (6)-Leuchte31AMBL 1C61-Dimmwert AB 31,100
    (10)-Leuchte31AMBL 1C61-Dimmwert CD 31,0
    (14)-Leuchte31AMBL 1C61-Dimmwert EF 31,0
    (18)-Leuchte31AMBL 1C61-Dimmwert GH 31,0
    (3)-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,03
    (2)-Leuchte31AMBL 1C61-Lampendefektbitposition 31,00
    (1)-Leuchte31AMBL 1C61-Lasttyp 31,not active
    (7)-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31,Always
    (4)-Leuchte31AMBL 1C61-Lichtfunktion A 31,Ambientelicht 1
    (5)-Leuchte31AMBL 1C61-Lichtfunktion B 31,nicht aktiv
    (8)-Leuchte31AMBL 1C61-Lichtfunktion C 31,nicht aktiv
    (9)-Leuchte31AMBL 1C61-Lichtfunktion D 31,nicht aktiv
    (12)-Leuchte31AMBL 1C61-Lichtfunktion E 31,nicht aktiv
    (13)-Leuchte31AMBL 1C61-Lichtfunktion F 31,nicht aktiv
    (16)-Leuchte31AMBL 1C61-Lichtfunktion G 31,nicht aktiv
    (17)-Leuchte31AMBL 1C61-Lichtfunktion H 31,nicht aktiv
    (11)-Leuchte32AMBL 2C35-Dimming Direction CD 32,maximize
    (15)-Leuchte32AMBL 2C35-Dimming Direction EF 32,maximize
    (19)-Leuchte32AMBL 2C35-Dimming Direction GH 32,maximize
    (6)-Leuchte32AMBL 2C35-Dimmwert AB 32,100
    (10)-Leuchte32AMBL 2C35-Dimmwert CD 32,0
    (14)-Leuchte32AMBL 2C35-Dimmwert EF 32,0
    (18)-Leuchte32AMBL 2C35-Dimmwert GH 32,0
    (3)-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,04
    (2)-Leuchte32AMBL 2C35-Lampendefektbitposition 32,00
    (1)-Leuchte32AMBL 2C35-Lasttyp 32,not active
    (7)-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32,Always
    (4)-Leuchte32AMBL 2C35-Lichtfunktion A 32,Ambientelicht 1
    (5)-Leuchte32AMBL 2C35-Lichtfunktion B 32,nicht aktiv
    (8)-Leuchte32AMBL 2C35-Lichtfunktion C 32,nicht aktiv
    (9)-Leuchte32AMBL 2C35-Lichtfunktion D 32,nicht aktiv
    (12)-Leuchte32AMBL 2C35-Lichtfunktion E 32,nicht aktiv
    (13)-Leuchte32AMBL 2C35-Lichtfunktion F 32,nicht aktiv
    (16)-Leuchte32AMBL 2C35-Lichtfunktion G 32,nicht aktiv
    (17)-Leuchte32AMBL 2C35-Lichtfunktion H 32,nicht aktiv
    (11)-Leuchte33AMBL 3C36-Dimming Direction CD 33,maximize
    (15)-Leuchte33AMBL 3C36-Dimming Direction EF 33,maximize
    (19)-Leuchte33AMBL 3C36-Dimming Direction GH 33,maximize
    (6)-Leuchte33AMBL 3C36-Dimmwert AB 33,100
    (10)-Leuchte33AMBL 3C36-Dimmwert CD 33,0
    (14)-Leuchte33AMBL 3C36-Dimmwert EF 33,0
    (18)-Leuchte33AMBL 3C36-Dimmwert GH 33,0
    (3)-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,05
    (2)-Leuchte33AMBL 3C36-Lampendefektbitposition 33,00
    (1)-Leuchte33AMBL 3C36-Lasttyp 33,not active
    (7)-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33,Always
    (4)-Leuchte33AMBL 3C36-Lichtfunktion A 33,Ambientelicht 1
    (5)-Leuchte33AMBL 3C36-Lichtfunktion B 33,nicht aktiv
    (8)-Leuchte33AMBL 3C36-Lichtfunktion C 33,nicht aktiv
    (9)-Leuchte33AMBL 3C36-Lichtfunktion D 33,nicht aktiv
    (12)-Leuchte33AMBL 3C36-Lichtfunktion E 33,nicht aktiv
    (13)-Leuchte33AMBL 3C36-Lichtfunktion F 33,nicht aktiv
    (16)-Leuchte33AMBL 3C36-Lichtfunktion G 33,nicht aktiv
    (17)-Leuchte33AMBL 3C36-Lichtfunktion H 33,nicht aktiv
    (11)-Leuchte34AMBL 4C37-Dimming Direction CD 34,maximize
    (15)-Leuchte34AMBL 4C37-Dimming Direction EF 34,maximize
    (19)-Leuchte34AMBL 4C37-Dimming Direction GH 34,maximize
    (6)-Leuchte34AMBL 4C37-Dimmwert AB 34,100
    (10)-Leuchte34AMBL 4C37-Dimmwert CD 34,0
    (14)-Leuchte34AMBL 4C37-Dimmwert EF 34,0
    (18)-Leuchte34AMBL 4C37-Dimmwert GH 34,0
    (3)-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,06
    (2)-Leuchte34AMBL 4C37-Lampendefektbitposition 34,00
    (1)-Leuchte34AMBL 4C37-Lasttyp 34,not active
    (7)-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34,Always
    (4)-Leuchte34AMBL 4C37-Lichtfunktion A 34,Ambientelicht 1
    (5)-Leuchte34AMBL 4C37-Lichtfunktion B 34,nicht aktiv
    (8)-Leuchte34AMBL 4C37-Lichtfunktion C 34,nicht aktiv
    (9)-Leuchte34AMBL 4C37-Lichtfunktion D 34,nicht aktiv
    (12)-Leuchte34AMBL 4C37-Lichtfunktion E 34,nicht aktiv
    (13)-Leuchte34AMBL 4C37-Lichtfunktion F 34,nicht aktiv
    (16)-Leuchte34AMBL 4C37-Lichtfunktion G 34,nicht aktiv
    (17)-Leuchte34AMBL 4C37-Lichtfunktion H 34,nicht aktiv
    (11)-Leuchte3SL VRB21-Dimming Direction CD 3,maximize
    (15)-Leuchte3SL VRB21-Dimming Direction EF 3,maximize
    (19)-Leuchte3SL VRB21-Dimming Direction GH 3,minimize
    (6)-Leuchte3SL VRB21-Dimmwert AB 3,30
    (10)-Leuchte3SL VRB21-Dimmwert CD 3,30
    (14)-Leuchte3SL VRB21-Dimmwert EF 3,100
    (18)-Leuchte3SL VRB21-Dimmwert GH 3,10
    (3)-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C
    (2)-Leuchte3SL VRB21-Lampendefektbitposition 3,4C
    (1)-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal
    (7)-Leuchte3SL VRB21-Lichtansteuerung HD AB 3,Always
    (4)-Leuchte3SL VRB21-Lichtfunktion A 3,Standlicht allgemein (Schlusslicht	 Positionslicht	 Begrenzungslicht)
    (5)-Leuchte3SL VRB21-Lichtfunktion B 3,Parklicht rechts
    (8)-Leuchte3SL VRB21-Lichtfunktion C 3,Coming Home oder Leaving Home aktiv
    (9)-Leuchte3SL VRB21-Lichtfunktion D 3,nicht aktiv
    (12)-Leuchte3SL VRB21-Lichtfunktion E 3,Tagfahrlicht
    (13)-Leuchte3SL VRB21-Lichtfunktion F 3,nicht aktiv
    (16)-Leuchte3SL VRB21-Lichtfunktion G 3,Blinken rechts aktiv (beide Phasen)
    (17)-Leuchte3SL VRB21-Lichtfunktion H 3,nicht aktiv
    (11)-Leuchte4TFL LB4-Dimming Direction CD 4,maximize
    (15)-Leuchte4TFL LB4-Dimming Direction EF 4,maximize
    (19)-Leuchte4TFL LB4-Dimming Direction GH 4,maximize
    (6)-Leuchte4TFL LB4-Dimmwert AB 4,100
    (10)-Leuchte4TFL LB4-Dimmwert CD 4,100
    (14)-Leuchte4TFL LB4-Dimmwert EF 4,0
    (18)-Leuchte4TFL LB4-Dimmwert GH 4,100
    (3)-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49
    (2)-Leuchte4TFL LB4-Lampendefektbitposition 4,48
    (1)-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung
    (7)-Leuchte4TFL LB4-Lichtansteuerung HD AB 4,Always
    (4)-Leuchte4TFL LB4-Lichtfunktion A 4,Tagfahrlicht
    (5)-Leuchte4TFL LB4-Lichtfunktion B 4,Standlicht allgemein (Schlusslicht	 Positionslicht	 Begrenzungslicht)
    (8)-Leuchte4TFL LB4-Lichtfunktion C 4,Coming Home oder Leaving Home aktiv
    (9)-Leuchte4TFL LB4-Lichtfunktion D 4,Parklicht links (beidseitiges Parklicht aktiviert li & re)
    (12)-Leuchte4TFL LB4-Lichtfunktion E 4,nicht aktiv
    (13)-Leuchte4TFL LB4-Lichtfunktion F 4,nicht aktiv
    (16)-Leuchte4TFL LB4-Lichtfunktion G 4,Blinken links aktiv (beide Phasen)
    (17)-Leuchte4TFL LB4-Lichtfunktion H 4,nicht aktiv
    (11)-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize
    (15)-Leuchte5 TFL RB32-Dimming Direction EF 5,maximize
    (19)-Leuchte5 TFL RB32-Dimming Direction GH 5,maximize
    (6)-Leuchte5 TFL RB32-Dimmwert AB 5,100
    (10)-Leuchte5 TFL RB32-Dimmwert CD 5,100
    (14)-Leuchte5 TFL RB32-Dimmwert EF 5,0
    (18)-Leuchte5 TFL RB32-Dimmwert GH 5,100
    (3)-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B
    (2)-Leuchte5 TFL RB32-Lampendefektbitposition 5,4C
    (1)-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung
    (7)-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5,Always
    (4)-Leuchte5 TFL RB32-Lichtfunktion A 5,Tagfahrlicht
    (5)-Leuchte5 TFL RB32-Lichtfunktion B 5,Standlicht allgemein (Schlusslicht	 Positionslicht	 Begrenzungslicht)
    (8)-Leuchte5 TFL RB32-Lichtfunktion C 5,Coming Home oder Leaving Home aktiv
    (9)-Leuchte5 TFL RB32-Lichtfunktion D 5,Parklicht rechts
    (12)-Leuchte5 TFL RB32-Lichtfunktion E 5,nicht aktiv
    (13)-Leuchte5 TFL RB32-Lichtfunktion F 5,nicht aktiv
    (16)-Leuchte5 TFL RB32-Lichtfunktion G 5,Blinken rechts aktiv (beide Phasen)
    (17)-Leuchte5 TFL RB32-Lichtfunktion H 5,nicht aktiv
    (11)-Leuchte6ABL LC5-Dimming Direction CD 6,maximize
    (15)-Leuchte6ABL LC5-Dimming Direction EF 6,maximize
    (19)-Leuchte6ABL LC5-Dimming Direction GH 6,maximize
    (6)-Leuchte6ABL LC5-Dimmwert AB 6,127
    (10)-Leuchte6ABL LC5-Dimmwert CD 6,127
    (14)-Leuchte6ABL LC5-Dimmwert EF 6,0
    (18)-Leuchte6ABL LC5-Dimmwert GH 6,0
    (3)-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,1A
    (2)-Leuchte6ABL LC5-Lampendefektbitposition 6,36
    (1)-Leuchte6ABL LC5-Lasttyp 6,5 - LED Abblendlicht
    (7)-Leuchte6ABL LC5-Lichtansteuerung HD AB 6,Always
    (4)-Leuchte6ABL LC5-Lichtfunktion A 6,Abblendlicht links
    (5)-Leuchte6ABL LC5-Lichtfunktion B 6,nicht aktiv
    (8)-Leuchte6ABL LC5-Lichtfunktion C 6,Coming Home oder Leaving Home aktiv
    (9)-Leuchte6ABL LC5-Lichtfunktion D 6,nicht aktiv
    (12)-Leuchte6ABL LC5-Lichtfunktion E 6,nicht aktiv
    (13)-Leuchte6ABL LC5-Lichtfunktion F 6,nicht aktiv
    (16)-Leuchte6ABL LC5-Lichtfunktion G 6,nicht aktiv
    (17)-Leuchte6ABL LC5-Lichtfunktion H 6,nicht aktiv
    (11)-Leuchte7ABL RB1-Dimming Direction CD 7,maximize
    (15)-Leuchte7ABL RB1-Dimming Direction EF 7,maximize
    (19)-Leuchte7ABL RB1-Dimming Direction GH 7,maximize
    (6)-Leuchte7ABL RB1-Dimmwert AB 7,127
    (10)-Leuchte7ABL RB1-Dimmwert CD 7,127
    (14)-Leuchte7ABL RB1-Dimmwert EF 7,0
    (18)-Leuchte7ABL RB1-Dimmwert GH 7,0
    (3)-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,1B
    (2)-Leuchte7ABL RB1-Lampendefektbitposition 7,40
    (1)-Leuchte7ABL RB1-Lasttyp 7,5 - LED Abblendlicht
    (7)-Leuchte7ABL RB1-Lichtansteuerung HD AB 7,Always
    (4)-Leuchte7ABL RB1-Lichtfunktion A 7,Abblendlicht rechts
    (5)-Leuchte7ABL RB1-Lichtfunktion B 7,nicht aktiv
    (8)-Leuchte7ABL RB1-Lichtfunktion C 7,Coming Home oder Leaving Home aktiv
    (9)-Leuchte7ABL RB1-Lichtfunktion D 7,nicht aktiv
    (12)-Leuchte7ABL RB1-Lichtfunktion E 7,nicht aktiv
    (13)-Leuchte7ABL RB1-Lichtfunktion F 7,nicht aktiv
    (16)-Leuchte7ABL RB1-Lichtfunktion G 7,nicht aktiv
    (17)-Leuchte7ABL RB1-Lichtfunktion H 7,nicht aktiv
    (11)-Leuchte8FL LB39-Dimming Direction CD 8,maximize
    (15)-Leuchte8FL LB39-Dimming Direction EF 8,maximize
    (19)-Leuchte8FL LB39-Dimming Direction GH 8,maximize
    (6)-Leuchte8FL LB39-Dimmwert AB 8,100
    (10)-Leuchte8FL LB39-Dimmwert CD 8,0
    (14)-Leuchte8FL LB39-Dimmwert EF 8,0
    (18)-Leuchte8FL LB39-Dimmwert GH 8,0
    (3)-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,03
    (2)-Leuchte8FL LB39-Lampendefektbitposition 8,00
    (1)-Leuchte8FL LB39-Lasttyp 8,46 - LED Kleinleistung
    (7)-Leuchte8FL LB39-Lichtansteuerung HD AB 8,Always
    (4)-Leuchte8FL LB39-Lichtfunktion A 8,Ambientelicht 1
    (5)-Leuchte8FL LB39-Lichtfunktion B 8,nicht aktiv
    (8)-Leuchte8FL LB39-Lichtfunktion C 8,nicht aktiv
    (9)-Leuchte8FL LB39-Lichtfunktion D 8,nicht aktiv
    (12)-Leuchte8FL LB39-Lichtfunktion E 8,nicht aktiv
    (13)-Leuchte8FL LB39-Lichtfunktion F 8,nicht aktiv
    (16)-Leuchte8FL LB39-Lichtfunktion G 8,nicht aktiv
    (17)-Leuchte8FL LB39-Lichtfunktion H 8,nicht aktiv
    (11)-Leuchte9FL RB2-Dimming Direction CD 9,maximize
    (15)-Leuchte9FL RB2-Dimming Direction EF 9,maximize
    (19)-Leuchte9FL RB2-Dimming Direction GH 9,maximize
    (6)-Leuchte9FL RB2-Dimmwert AB 9,100
    (10)-Leuchte9FL RB2-Dimmwert CD 9,0
    (14)-Leuchte9FL RB2-Dimmwert EF 9,0
    (18)-Leuchte9FL RB2-Dimmwert GH 9,0
    (3)-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,04
    (2)-Leuchte9FL RB2-Lampendefektbitposition 9,00
    (1)-Leuchte9FL RB2-Lasttyp 9,46 - LED Kleinleistung
    (7)-Leuchte9FL RB2-Lichtansteuerung HD AB 9,Always
    (4)-Leuchte9FL RB2-Lichtfunktion A 9,Ambientelicht 2
    (5)-Leuchte9FL RB2-Lichtfunktion B 9,nicht aktiv
    (8)-Leuchte9FL RB2-Lichtfunktion C 9,nicht aktiv
    (9)-Leuchte9FL RB2-Lichtfunktion D 9,nicht aktiv
    (12)-Leuchte9FL RB2-Lichtfunktion E 9,nicht aktiv
    (13)-Leuchte9FL RB2-Lichtfunktion F 9,nicht aktiv
    (16)-Leuchte9FL RB2-Lichtfunktion G 9,nicht aktiv
    (17)-Leuchte9FL RB2-Lichtfunktion H 9,nicht aktiv
    (11)-Leuchten14AL LB6-Dimming Direction CD 14,maximize
    (15)-Leuchten14AL LB6-Dimming Direction EF 14,maximize
    (19)-Leuchten14AL LB6-Dimming Direction GH 14,maximize
    (6)-Leuchten14AL LB6-Dimmwert AB 14,0
    (10)-Leuchten14AL LB6-Dimmwert CD 14,0
    (14)-Leuchten14AL LB6-Dimmwert EF 14,0
    (18)-Leuchten14AL LB6-Dimmwert GH 14,0
    (3)-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00
    (2)-Leuchten14AL LB6-Lampendefektbitposition 14,00
    (1)-Leuchten14AL LB6-Lasttyp 14,not active
    (7)-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always
    (4)-Leuchten14AL LB6-Lichtfunktion A 14,nicht aktiv
    (5)-Leuchten14AL LB6-Lichtfunktion B 14,nicht aktiv
    (8)-Leuchten14AL LB6-Lichtfunktion C 14,nicht aktiv
    (9)-Leuchten14AL LB6-Lichtfunktion D 14,nicht aktiv
    (12)-Leuchten14AL LB6-Lichtfunktion E 14,nicht aktiv
    (13)-Leuchten14AL LB6-Lichtfunktion F 14,nicht aktiv
    (16)-Leuchten14AL LB6-Lichtfunktion G 14,nicht aktiv
    (17)-Leuchten14AL LB6-Lichtfunktion H 14,nicht aktiv
    (2)-LIN-Mirrormode-Data bus LIN 1,active
    (3)-LIN-Mirrormode-Data bus LIN 2,active
    (4)-LIN-Mirrormode-Data bus LIN 3,active
    (5)-LIN-Mirrormode-Data bus LIN 4,active
    (6)-LIN-Mirrormode-Data bus LIN 5,active
    (7)-LIN-Mirrormode-Data bus LIN 6,active
    (1)-LIN-Mirrormode-mirror_mode_typ,not active
    (1)-LuB Lichtrouter Kennlinie 1-x0,0.00 %
    (2)-LuB Lichtrouter Kennlinie 1-X1,5.00 %
    (3)-LuB Lichtrouter Kennlinie 1-X2,50.00 %
    (4)-LuB Lichtrouter Kennlinie 1-X3,75.00 %
    (5)-LuB Lichtrouter Kennlinie 1-X4,110.00
    (6)-LuB Lichtrouter Kennlinie 1-X5,126.50
    (7)-LuB Lichtrouter Kennlinie 1-y0,0.00 %
    (8)-LuB Lichtrouter Kennlinie 1-Y1,6.00 %
    (9)-LuB Lichtrouter Kennlinie 1-Y2,16.00 %
    (10)-LuB Lichtrouter Kennlinie 1-Y3,30.00 %
    (11)-LuB Lichtrouter Kennlinie 1-Y4,60.00 %
    (12)-LuB Lichtrouter Kennlinie 1-Y5,100.00 %
    (2)-Personalisierung-Aktivierungsoption_im_HMI-Menue_sichtbar,not active
    (5)-Personalisierung-Anzahl_Benutzerkonten,0
    (6)-Personalisierung-Automatische_ Schluesselzuordnung,not active
    (3)-Personalisierung-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,not active
    (1)-Personalisierung-Personalisierung_aktiv,not active
    (4)-Personalisierung-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,not active
    (7)-Personalisierung-PSO_FSG_Setup2_Bit_0,not active
    (8)-Personalisierung-PSO_FSG_Setup2_Bit_1,not active
    (9)-Personalisierung-PSO_FSG_Setup2_Bit_2,not active
    (10)-Personalisierung-PSO_FSG_Setup2_Bit_3,not active
    (11)-Personalisierung-PSO_FSG_Setup2_Bit_4,not active
    (12)-Personalisierung-PSO_FSG_Setup2_Bit_5,not active
    (13)-Personalisierung-PSO_FSG_Setup2_Bit_6,not active
    (14)-Personalisierung-PSO_FSG_Setup2_Bit_7,not active
    (2)-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active
    (1)-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung,not active
  10. Likes flooodi liked this post
  11. #7
    Verified VCDS User lala30's Avatar
    Mar 2015
    Croatia
    code A5
    ECU: 00A5 - Front Sensors Driver Assistance System
    *14.11.2016 15:00:26
    LL_FrontSensoDriveAssisSysteUDS (EV_MFKBoschAU370_001)
    Master - 001 Identification
    14.11.2016 15:00:26 Top^
    System description
    MQB_MFK
    SoftwareVersion
    0060
    HardwareVersion
    H06
    VW/Audi part number
    5Q0980653G
    Hardware part number
    5Q0980653
    Coding
    0101010001010308000500010100000100
    ASAM/ODX file identification
    EV_MFKBoschAU370
    ASAM/ODX file version
    001001
    Master - 006 Read code
    14.11.2016 15:00:29 Top^
    Byte00:
    0000 0001 ($01)
    Byte01:
    0000 0001 ($01)
    Byte02:
    0000 0001 ($01)
    Byte03:
    0000 0000 ($00)
    Byte04:
    0000 0001 ($01)
    Byte05:
    0000 0001 ($01)
    Byte06:
    0000 0011 ($03)
    Byte07:
    0000 1000 ($08)
    Byte08:
    0000 0000 ($00)
    Byte09:
    0000 0101 ($05)
    Byte10:
    0000 0000 ($00)
    Byte11:
    0000 0001 ($01)
    Byte12:
    0000 0001 ($01)
    Byte13:
    0000 0000 ($00)
    Byte14:
    0000 0000 ($00)
    Byte15:
    0000 0001 ($01)
    Byte16:
    0000 0000 ($00)
    [LO]_coding_HCA:
    [VN]_coded
    [LO]_coding_VZE:
    [VN]_coded
    [LO]_coding_Light_Assist:
    [VO]_High_Beam_Assist
    [LO]_FLA_Additional_High_Beam:
    [VN]_Not coded
    [LO]_VZE_RSR_region:
    [VO]_Westeurope
    [LO]_VZE_Brand:
    [VO]_Audi
    [LO]_VZE_Cam_type:
    [VO]_MQB_MFK
    [LO]_VZE_Navigationtype:
    [VO]_MIB2 High PSD 1.5
    [LO]_windshield kind (transmissions):
    [VO]_heat-insulating glass (green)
    [LO]_FLA_Headinglight_type:
    [VO]_LED
    [LO]_HCA_Mobilty_Char:
    [VO]_without
    [LO]_HCA_LaneChangeassist:
    [VO]_with
    [LO]_ACC_installed:
    [VO]_yes
    [LO]_HCA_country_coding:
    [VO]_RDW
    [LN]_Steering side of vehicle:
    [VN]_Left-hand drive vehicles
    [LO]_Windscreen_heater:
    [VN]_coded
    [LO]_trailer_control_module:
    [VN]_not installed
    Address A5: Frt Sens. Drv. Assist (R242) Labels: 5Q0-980-653.clb
    Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
    Component: MQB_MFK H06 0060
    Serial number: 10000137108
    Coding: 0101010001010308000500010100000100
    Shop #: WSC 06385 790 00016
    ROD: EV_MFKBoschAU370.rod
    VCID: 3C77EA70B75C2FA2B4-8068
  12. #8
    Verified VCDS User cilitkas's Avatar
    May 2016
    LT
    Thanks, any chance you got it in the same format as a skoda map, with IDE00001-ENG99061 at the beginning?
  13. #9
    Aug 2017
    Quote Originally Posted by skunkiechris View Post
    Disregard....I undid everything and did it all again (as suggested to an earlier poster who had a similar problem over on Briskoda), and it worked, no more errors!
    Hey! I'm trying the same thing with no luck. I've tried 3 times and each time I get the error. I've got a '16 S3 prestige. Any ideas that might help?
    Thanks!
  14. #10
    Jun 2017
    Auto-Scan please
    Depending on the camera, the coding can differ
  15. Likes Uwe liked this post
