Results 1 to 6 of 6
Thread: Got a few question here..
    Oct 2015
    London
    Help guys I need some help to do repairs on my 07 plate A6.
    Brake pad warning sensor.
    I see it is very common issue but I cannot find any solutions yet.
    I changed the front pads and the discs and there were no warning for three days. Than the warning light with a silly noise come up. I used genuine parts I clean the connectors with WD40 I checked the wires, Everything fine but the warning still on.
    What else should I do? I do not really want to bypass the connectors with two wires.
    Rear set belt tensioner.
    Rear seat belt needs to replace or fix, but I am stocked at the beginning.
    I would appreciate a guide how to remove it?
    It not work from the boot. It seems the only option to remove a plastic cover somehow, but I du not want to damage it at all. I would really need to know where to start.
    Component protection active
    Everything working so it not really bothers me, but I tried to retrofit AMI and for some reason it won't work on my car. I bought a factory software update for Basic/Basic plus Low and my cd drive does not recognise the update cd.
    Is it possible because of component protection activated? Audi charge 180+VAT to remove it, but If I cannot fit AMI there is no point to du it.
    02115- Locking Unit for Central Locking
    When I test it with VCDS it works well for few hours, but after that the n/s door stays locked. I do a test again ad it works for a few time than the issue comes back.
    Do I really need to replace the module or it can be solved with some coding?
    Magdeburg, Germany
    Start by posting a complete Auto-Scan please. The "07 plate" (registration) stuff is something only you blokes in UK got, it says little to nothing about the actual build date of the car essentially making specific answers nearly impossible in some cases. You can find the actual model/chassis type in digit 7 & 8 of the VIN, the model year is in digit 10 of the VIN.
  3. Likes Uwe liked this post
    Oct 2015
    London
    Sure, got it I hope I do it right.
     Chassis Type: 4F (4F0)
    Scan: 01 03 05 07 08 09 0E 15 16 17 19 1E 37 42 46 47 4F 52 53 56
              61 62 72
    VIN: WAUZZZ4F37N135533   Mileage: 134170km-83369miles
    Address 01: Engine        Labels: 03G-906-016-BLB.clb
       Part No SW: 03G 906 016 HS    HW: 03G 906 016 HS
       Component: R4 2,0L EDC G000SG  9673
       Revision: --H05---    Serial number:
       Coding: 0000072
       Shop #: WSC 02324 785 00200
       VCID: 7BF5A99A3AF411E608-802E
       Part No SW: 4F0 910 517 AC    HW: 4F0 614 517 T
       Component: ESP8 front      H01 0070
       Coding: 0020855
       Shop #: WSC 02325 785 00200
       VCID: 65C1EFE2AC70B716CE-8030
    Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
       Component: FBSAUDIC6 ELV   H31 0220
       Revision: 31050601    Serial number: 10601100695356
       Coding: 0000017
       Shop #: WSC 02323 785 00200
       VCID: 63C5F1FAA244C92620-8036
       Subsystem 1 - Part No: 4F0 910 131 D
       Component: FBSAUDIC6 IDG   H01 0040
    Address 07: Control Head        Labels: Redir Fail!
       Part No SW: 4F0 910 769 H    HW: 4F0 035 769 B
       Component: MMI Cockpit     H55 0410
       Revision: C61030BE    Serial number: AUZ6Z3G2UB55K3
       Coding: 0140002
       Shop #: WSC 02335 785 00200
       VCID: 326B44BEAD3E10AE9B-8066
       Subsystem 2 - Serial number: 00000000673714
       Subsystem 3 - Serial number: 0116.02.070000000100010596ˇ
       Subsystem 4 - Serial number: 010596ˇ
                000 -  -  - Intermittent
                        Mileage: 129075 km
                        Date: 2015.09.01
                        Time: 17:33:21
    Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
       Part No SW: 4F0 910 043 A    HW: 4F2 820 043 P
       Component: KLIMABETAETIGUNGH30 0020
       Revision: 00000052    Serial number: 00000000365641
       Coding: 0001044
       VCID: 1C378A06DFBAB6DEA1-8048
       Part No SW: 4F0 910 279 L    HW: 4F0 907 279 B
       Coding: 0000101
       Subsystem 1 - Part No: 4F2 910 113 B  Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H04 0190
       Coding: 00064784
       Shop #: WSC 02335
       Coding: 00146221
       Shop #: WSC 02335
                        Fault Status: 00111011
                        Fault Frequency: 115
                        Reset counter: 201
                        Mileage: 122876 km
                        Date: 2015.07.25
                        Time: 02:24:00
                        Fault Status: 00100111
                        Fault Frequency: 61
                        Reset counter: 199
                        Mileage: 122712 km
                        Date: 2015.07.21
                        Time: 04:09:00
                        Fault Status: 00101011
                        Fault Frequency: 119
                        Reset counter: 201
                        Mileage: 123616 km
                        Date: 2015.08.09
                        Time: 05:37:00
                        Fault Frequency: 61
                        Reset counter: 192
                        Mileage: 123020 km
                        Date: 2015.07.29
                        Time: 02:46:00
    Address 0E: Media Player 1        Labels: Redir Fail!
       Coding: 0140002
    Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
       Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
       Component: 4E AIRBAG AUDI8RH30 0280
       Revision: 09H30000    Serial number: 0037LD0P98VV
       Coding: 0013381
       VCID: 2959A3D280E853762A-807C
       Subsystem 1 - Serial number: 6332CSME17634933/
       Subsystem 2 - Serial number: 6342CSME17646705+
       Subsystem 3 - Serial number: 6352QSME2236310B5
       Subsystem 4 - Serial number: 6362QSME23330B1DE
       Subsystem 5 - Serial number: 63734SME214F3921
       Subsystem 6 - Serial number: 63834SME220D314F%
       Component: Lenks‰ulenmodul H08 0230
       Revision: 00H08000    Serial number: 90026070550659
       Coding: 0102041
       VCID: 66C3E8EE5176BC0EC7-8032
       Part No SW: 4F0 910 900 C    HW: 4F0 920 950 R
       Component: KOMBIINSTR. M73 H13 0170
       Revision: 00000000    Serial number: 58W72XR27
       Coding: 2308448
       Shop #: WSC 59286 001 1048576
       VCID: 204FBEF6F3D2923E7D-8074
    Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
       Component: Gateway         H11 0070
       Revision: 11          Serial number: 130080722184A0
       Coding: 6CEE53C43B2104
       VCID: 275DA5EA96FC65063C-8072
    Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
       Part No SW: 4E0 910 110 C    HW: 4E0 035 110 A
       Component: MP3-Changer     H44 0350
       Revision: 00044000    Serial number: AUZ5ZBG3172571
       VCID: 183F96162B82DAFE85-804C
    Address 37: Navigation        Labels: Redir Fail!
       Coding: 0140002
       Component: TSG FA          H12 0120
       Revision: 00000000    Serial number: Q
       Coding: 0002586
       Shop #: WSC 02327 785 00200
       VCID: 2C575AC68F1A465ED1-8078
                        Fault Frequency: 85
                        Reset counter: 164
                        Mileage: 132125 km
                        Date: 2015.09.28
                        Time: 07:56:08
    Address 46: Central Conv.        Labels: 4F0-910-289.lbl
       Component: Komfortgeraet   H22 0170
       Revision: 01700022    Serial number: 01035468870000
       Coding: 0000251
       VCID: 2E5350CEB906344EFF-807A
    Address 47: Sound System (J525)       Labels: Redir Fail!
       Part No SW: 4F0 910 223 H    HW: 4F0 035 223 K
       Component: Amp.-ASK-RD   H07 0130
       Revision: 08S00000
       Shop #: WSC 02399 823 56573
       VCID: 2345B1FA22C4892660-8076
                        Reset counter: 143
                        Mileage: 122428 km
                        Date: 2015.07.15
                        Time: 09:52:02
                        Voltage: 12.20 V
                        Temperature: 22.0∞C
                        Bin. Bits: 00000011
       Revision:             Serial number: 00000000401839
       Coding: 0001104
       VCID: 5EB3C00E8926E4CE0F-800A
       Component: TSG BF          H12 0120
       Revision: 00-00000
       Coding: 0002586
                        Fault Frequency: 92
                        Reset counter: 133
                        Mileage: 122380 km
                        Date: 2015.07.14
                        Time: 12:54:13
       Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
       Component: EPB  CDEC0080   H04 0080
       Revision: --H04---
       Coding: 0000111
    Address 56: Radio        Labels: Redir Fail!
       Coding: 0140002
       Revision: 00000000    Serial number: 00000000031818
       Shop #: WSC 00000 384 00290
       VCID: 2345B1FAE2C4892660-8076
       Subsystem 1 - Part No: 4F0 915 105 C
       Component: von VA0  2702170389
       Coding: 344630393135313035432056413032373032313730333839
    02272 - Quiescent Current Stage 1
                        Mileage: 125222 km
                        Date: 2015.08.12
                        Time: 17:28:32
                        Date: 2015.08.12
                        Time: 17:32:09
       Coding: 0002050
       Part No SW: 4F0 910 795 F    HW: 4F0 959 794 F
       VCID: 2F6D4DCABE0C3D46F4-807A
    End-------------------------(Elapsed Time: 02:10)--------------------------
  5. Likes Uwe liked this post
  6. #4
    Magdeburg, Germany
    What part number has the cd/set you bought for the MMI-Low?
    Oct 2015
    London
    cd- 4L0 998 961 A
    AMi unit- 4E0 035 785F
    Oct 2015
    London
    That is cool....
